Good morning. I have purchased several units of Smart Tag bluetooth. I have found a great limitation in Automations. it is not possible to create authorizations based on the detection status of the Smarta Tag (if it is nearby, if it has lost the connection...) . the leak of this options in automations makes them lose any value added to it for lntegrate into Tuya platform.
Bluetooth Smart Tag
Sergitovall
Sergitovall
Re: Bluetooth Smart Tag
The idea was use the Smart Tags for start the out of home automations... but I get a warning with the advice of it has lost the connection but I can not use it for anything
Please provide the device information of the smart tag. You can click on the upper right corner button, then click Device Information: you can view the device's ID, IP address, MAC address, time zone, and online status, etc.
https://support.tuya.com/en/help/_detail/K9d1qt73ht2rs
Sergitovall
Thnks for answering. The tag device information:
Virtual ID: bffeabzrldezxamr
Mac: DC:23:50:46:D5:E4
Time Zone: Europe/Madrid
Connected Throu.. : Gateway/Mobile Phon
DEvice Status: Local/Gateway Connection
Thank you for reaching out and sharing your feedback about the Bluetooth Smart Tag integration with Tuya's automation features. We appreciate your insights and understand the importance of having robust automation capabilities for a seamless smart home experience.Our automation rules do not currently support triggers based on the Bluetooth detection status of Smart Tags (e.g., "nearby," "lost connection," or "proximity"). Alternative Solutions,you can Leverage Tuya-compatible sensors (e.g., door/window sensors, motion detectors) for automation scenarios that require physical presence detection.
Sergitovall
Thank you again... the problem is the f##ed cat ![]()
