Unexported switch via Matter
edlei@hotmail.com.br
Hello, I would like to inform you of an export problem via Matter of a zigbee switch, model 6 buttons.
After configuring it in the zigbee matter hub, it is not exported to Google Home or Alexa.
Could it be corrected?
fangping.guo
Re: Unexported switch via Matter
Hello, I have updated the configuration for your device.
Please try restarting the gateway or unbinding the device and trying again. I look forward to your feedback.
I have done this several times, but this 6 switch model is not being exported by Matter.
fangping.guo
I have updated the configuration file again. Please try unbinding the device and retry.
If the problem persists, please provide the gateway ID.
Now it has worked, it is exporting perfectly.
I also have a temperature device that is exporting via Matter but with the wrong temperature, it is fixed at 20⁰, does not change.
ID eb115bd39464352b29eoep
fangping.guo
Hello.
I have upgraded the temp sensor device configuration. Please rebind and test it.
Thank you.
It worked, thank you.
fangping.guo
:D
