The Presence Sensor states differ between SmartThings and the Moes Hub when connected via Matter.
fighting333
Hi~
I updated the Moes Hub to version 1.13.8, and it connected well to SmartThings via Matter. Thank you.
However, one issue has come up.
The Presence Sensor (24G) on the Moes Hub detects in three states: move, exist, and none, but it seems that only the exist state is transmitted to SmartThings via Matter.
So when the Moes Hub detects move, SmartThings cannot recognize it.
Is it possible to map the Occupancy Sensing Cluster states as (move or exist) -> occupied, and none -> unoccupied?
Or is there a way to receive both the move and exist states in SmartThings?
Moes Matter Hub
Virtual ID: ebd713b8505990be344h7g
High-precision breath sensor
Virtual ID: ebc48655327df11b4bdplu
fangping.guo
Re: The Presence Sensor states differ between SmartThings and the Moes Hub when connected via Matter.
Hello.
I have adjusted the device configuration file as (move or exist) -> occupied, and none -> unoccupied.
You can restart the gateway or unbind the device to test it. Thank you.
fighting333
I’ll apply it right away, thank you.
