This zigbee window motor actuator is not showing the open/close % value in home assistant or SmartThings shared via matter hub. Always 100% state.
MOES Tuya ZigBee-empujador de ventana corredera inteligente, abridor automático, aplicación de carga Solar, Control remoto, compatible con Alexa y Google Home
https://a.aliexpress.com/_EwWJGYm
Zibgee Window motor
Sergitovall
Zibgee Window motor
Re: Zibgee Window motor
Sergitovall 2025年 Jun 27日 13:42This zigbee window motor actuator is not showing the open/close % value in home assistant or SmartThings shared via matter hub. Always 100% state.
Please provide the device ID of the gateway. Thanks.
Sergitovall
Done! Thabks
Sergitovall
In goole home I can open and close (0% or 100%) but the % opening is not working properly either (or show the real actual openin % state)
Same in Smartthings
fangping.guo
Please provide the model number and software version of the gateway you are using, as well as the product model number of the curtains, so that we can check and analyze the problem.
Sergitovall
Hello.
Gateway
Moes Matter ZigBee Hub
Módulo principal: v1.12.6 Otro tipo: v3.7.2
Curtain motor
Moes Zigbee Window Pusher
Version: V1.0.13
Regards
fangping.guo
Copy that. We're analyzing it.
fangping.guo
Hi, we have updated the object model files for the device 【moes window pusher】.
Please unpair the devices and re-pair them to test, and we welcome your continued feedback.
Sergitovall
Thank you! I will update here the results
Sergitovall
Hello. Unpair. Paired again. No success, it is still not showing the actual % opened state (but it is possible select to a %, and it opens to the correct %)
