Hello there,
I make a 4 relay ESP32 module with zerocode.espressif.com (put the json code below) two roller shutter matter device.
My problem is that in Tuya app i only see these:
If i add these device with google home , it generate two roller shutter device.
It also working in apple home:
Also talking about these with espressif devs, and he said that my code is OK, the problem propably on Tuya side:
https://github.com/espressif/esp-matter/issues/1469
Here the ID in tuya app that is generate: bfa5258l0lsnhzej
"config_version": 3,
"driver": [
"gpio_config": {
"active_level": 0,
"gpio_num": 14,
"long_press_time": 5
"id": 1000,
"name": "gpio",
"type": "ezc.driver.button"
"gpio_config": {
"active_level": 0,
"gpio_num": 13,
"id": 1001,
"name": "gpio",
"gpio_config": {
"active_level": 0,
"gpio_num": 18,
"id": 1002,
"name": "gpio",
"gpio_config": {
"active_level": 0,
"gpio_num": 17,
"id": 1003,
"name": "gpio",
"calibration_config": {
"calibration_type": 2
"gpio_config": {
"down_relay_gpio": 33,
"up_relay_gpio": 32
"id": 1004,
"name": "gpio",
"roller_blind_config": {
"allow_reverse_in_moving": false,
"default_max_move_time_ms": 10000,
"delay_time_between_moves_ms": 500,
"pause_between_moves": true,
"relay_control_delay_time_ms": 0
"type": "ezc.driver.roller_blind"
"gpio_config": {
"down_relay_gpio": 26,
"up_relay_gpio": 25
"id": 1005,
"name": "gpio",
"gamma_config": {
"curve_coe": 1,
"enable_gamma_adjust": true,
"gamma_blue": 100,
"gamma_cold": 100,
"gamma_green": 100,
"gamma_red": 100,
"gamma_warm": 100
"hardware_config": {
"rgb_max": 100,
"rgb_min": 10,
"rgb_power_max": 300,
"white_max": 100,
"white_min": 10,
"white_power_max": 100
"id": 1006,
"lighting_config": {
"beads_comb": 4,
"disable_auto_on": true,
"enable_gradient": true,
"enable_lowpower": false,
"enable_memory": false,
"fades_ms": 800,
"sync_change_brightness": true
"name": "ws2812",
"type": "ezc.driver.led",
"ws2812_config": {
"ctrl_io": 16,
"led_num": 1
"product": [
"data_model": {
"window_covering_type": 4
"driver": {
"input_down": 1001,
"input_up": 1000,
"output": 1004
"id": 1,
"subtype": 1,
"type": "ezc.product.window_covering"
"data_model": {
"driver": {
"input_down": 1002,
"input_up": 1003,
"output": 1005
"id": 2,
"subtype": 1,
"product_common": [
"driver": {
"output": 1006
"events": [
"b": 0,
"color_select": 1,
"g": 255,
"interrupt_forbidden": true,
"max_brightness": 100,
"min_brightness": 20,
"mode": "breathe",
"name": "setup_mode_start",
"r": 0,
"speed": 2000,
"total_ms": 0
"b": 0,
"color_select": 1,
"g": 255,
"mode": "breathe",
"name": "setup_started",
"r": 255,
"speed": 1000,
"total_ms": 0
"mode": "restore",
"name": "setup_successful"
"b": 0,
"color_select": 1,
"g": 0,
"mode": "solid",
"name": "setup_failed",
"r": 255
"b": 0,
"color_select": 1,
"g": 0,
"mode": "blink",
"name": "identification_start",
"r": 255,
"speed": 1000,
"total_ms": 0
"mode": "restore",
"name": "identification_stop"
"b": 255,
"color_select": 1,
"g": 255,
"mode": "blink",
"name": "identification_blink",
"r": 255,
"speed": 1000,
"total_ms": 1000
"b": 255,
"color_select": 1,
"g": 255,
"mode": "breathe",
"name": "identification_breathe",
"r": 255,
"speed": 1000,
"total_ms": 15000
"b": 0,
"color_select": 1,
"g": 255,
"mode": "blink",
"name": "identification_okay",
"r": 0,
"speed": 2000,
"total_ms": 1000
"b": 0,
"color_select": 1,
"g": 165,
"mode": "blink",
"name": "identification_channel_change",
"r": 255,
"speed": 16000,
"total_ms": 8000
"mode": "restore",
"name": "identification_finish_effect"
"mode": "restore",
"name": "identification_stop_effect"
"subtype": 0,
"type": "ezc.product_common.indicator"
"auto_trigger": true,
"driver": {
"input": 1000
"subtype": 2,
"type": "ezc.product_common.factory_reset"
"test_mode": [
"subtype": 1,
"type": "ezc.test_mode.common"
"subtype": 1,
"type": "ezc.test_mode.ble"
"subtype": 1,
"type": "ezc.test_mode.window_covering"
