matter 幻彩灯带自定义开发,局域网通过matter cluster控制的问题
tonish
CBU matter sdk3.8.4
1,局域网app 下发模式dp21,被sdk拦截转成matter cluster并报错,
Endpoint=1 Cluster=0x125D_FC01 Command=0x0000_0000 status 0xc3 (UNSUPPORTED_CLUSTER) (no additional context)
请教,cluster该如何设置
2,另外联网成功app操作,有 DP ID 21 Invalid
3,报[SessionManager.cpp:722] Data received on an unknown session (LSID=29997). Dropping it!
[01-01 08:00:07 TUYA E][SessionManager.cpp:722] Data received on an unknown session (LSID=29997). Dropping it!
log2.txt
(14.86 KiB) Downloaded 1378 times
log1.txt
(4.89 KiB) Downloaded 1281 times
谢君桀
Re: matter 幻彩灯带自定义开发,局域网通过matter cluster控制的问题
局域网下走的是matter通路,需要注册dp21对应的attribute_id = 21 到自定义cluster_id=0x125dfc01上面。就如同ON_OFF_ATTRIBUTE注册到ON_OFF_CLUSTER上一样。不知你这一步是否有设置
