编译了libtuyaos.so后,编译app报错
zszn_ll
在build_app.sh中,在make app_by_name之前,先make os_shared,出现了以下错误:
/home/ll/Documents/tuya/Projects/Android-Arm-32-bit_TuyaOS-3.8.22-zszn/software/TuyaOS/libs/libtuyaos.so: error: undefined reference to 'tuya_iot_init_params'
/home/ll/Documents/tuya/Projects/Android-Arm-32-bit_TuyaOS-3.8.22-zszn/software/TuyaOS/libs/libtuyaos.so: error: undefined reference to 'pthread_cancel'
clang70: error: linker command failed with exit code 1 (use -v to see invocation)
make[1]: *** [Makefile:17:app_excute] 错误 1
make[1]: 离开目录“/home/ll/Documents/tuya/Projects/Android-Arm-32-bit_TuyaOS-3.8.22-zszn/software/TuyaOS/vendor/arm-linux-androideabi-49/tuyaos”
make: *** [/home/ll/Documents/tuya/Projects/Android-Arm-32-bit_TuyaOS-3.8.22-zszn/software/TuyaOS/scripts/mk/app.mk:195:app_by_name] 错误 2
build_log.txt
(16.43 KiB) Downloaded 220 times
Re: 编译了libtuyaos.so后,编译app报错
直接静态链接过去?动态库有一些符号可能不存在。
