Vamp
Posts: 43 Joined: 2024年 Dec 16日 03:50
2025年 Apr 1日 01:00
Hello there,
I Install Tasmota a 4 relay board: https://lilygo.cc/products/t-relay?srsl ... Sjrk_g77zY
i set it up that it provide the relays with matter:
I able to add it to Tuya Matter Gateway (Moes) but not see anything. It only say taht not supported device. Here the Virtual device ID: bfb5a01u2decxzbw
qiusui
Posts: 150 Joined: 2023年 Dec 22日 14:07
2025年 Apr 1日 09:57
Hi Vamp,
I have received your feedback, but I can't solve your problem, I will ask other colleagues to deal with it, please wait patiently.
huangxh
Posts: 102 Joined: 2022年 Sep 16日 18:26
2025年 Apr 1日 14:09
Vamp 2025年 Apr 1日 01:00
Hello there,
Based on the current situation, we do not support this category of devices. Could you please let us know what type of device you have? thanks!
huangxh
2025年 May 8日 09:57
I advise you to update the Tuya app to version 6.5.0, then try it again.
thanks
Vamp
2025年 May 11日 17:28
huangxh 2025年 May 8日 09:57
thanks
Thanks a lot! It working like a charm! big step these the DiY and Tuya integration!
Vamp
2025年 May 11日 18:14
Further investigation:
The control are working but i can not able to make automation based these devices. The automation are not running.
The IDs:
W20-UBEA 3 bf1d431ff67c6d74a2cqth
W20-UBEA 2 bf3bef01e627f9caf5ib0v
W20-UBEA bf5d5a17f1378ad2d3w3j3
W20-UBEA 4 bf73bdd2461fc1efaapyzz
Matter网关兜底 bf87f9v7n3diubs4
Edit:
and only work if the app are same Wifi with the matter device.
huangxh
2025年 May 12日 10:05
Vamp 2025年 May 11日 18:14
The IDs:
Edit:
Thank you for your feedback. If you want to control these devices from an external network, you will need a Tuya gateway.
Yocee84
Posts: 6 Joined: 2025年 Jan 10日 16:01
2025年 May 12日 13:27
Please check this device too!
bf5510932bd20c41dbyimd
Athom Plug V3 Tasmota with matter.
huangxh
2025年 May 12日 17:02
Yocee84 2025年 May 12日 13:27
I have noticed that you can control the device with the on/off function, but the device does not report back. Do you have a gateway? You could add a gateway and then test it.
thanks
