Moes Matter Gateway and zigbee devices on Homekit
darkaeden
I am thinking to purchase a Moes Matter Gateway to replace my current Switchbot setup.
Before doing so i’d like to know if the following Zigbee devices will be properly exposed to Homekit:
1) Moes Tuya temperature/humidity sensor
2) Moes Tuya temperature/humidity/lux sensor
3) Moes Tuya soil meter
4) Moes Tuya Fingerbot
5) Moes Tuya Window Door contact sensor
6) Moes Tuya smart knob switch
7) Moes Tuya scene button switch
8) Moes Tuya smart IR remote control
Thanks!
qiusui
Re: Moes Matter Gateway and zigbee devices on Homekit
darkaeden 2025年 Feb 23日 11:15
Thanks!
Hi,
(1) Is the finger robot you are referring to Bluetooth protocol? If it is, we don't support it yet.
(2) For other categories, you also need to provide the pid or device id of the specific product, so that I can confirm whether it is supported.
darkaeden
Thanks for your reply.
1) Zigbee version. All above devices are zigbee.
2) As i don’t have them already purchased, is it enough to provide Aliexpress links?
Thanks
huangxh
darkaeden 2025年 Feb 24日 11:18
Thanks
Some categories are not yet supported in Matter, such as the fingerbot and soil meter, so these cannot be accurately mapped to HomeKit. Compatibility can only be achieved to some extent by mapping the fingerbot as a switch type and the soil meter as temperature and humidity, etc.
thanks
darkaeden
That is OK.
As long as fingerbot act as an on/off light/switch that is ok.
Also the soil meter as long as the sensor get exposed.
How about the other devices?
huangxh
darkaeden 2025年 Feb 24日 15:21
That is OK.
It looks like all devices are supported. However, as mentioned before, some devices must be configured with a different device type. This requires a specific configuration with the device PID.
thanks
darkaeden
Understood, thanks.
Just one last few question:
1) how about the smart knob button? It has one press, double press, long press and rotating knob (for light dimming).
Will it get exposed to Homekit? Also the rotation dimming function?
2) zigbee color bulb. Does it gets exposed to Homekit with dimming and color funcion, or just ON/OFF?
3) moes IR blaster. Does the learnt AC IR gets exposed to Homekit?
darkaeden
For information, the zigbee IR blaster is the following
https://a.aliexpress.com/_onFTUWE
Thanks for support.
darkaeden
Please, can you let me know for:
1) IR blaster learnt devices in Homekit (AC, TV etc)
2) Zigbee light color bulb. Does it get exposed on Homekit with dimming and color selection options? Or only dimming?
darkaeden
Can someone please let me know, expecially for the Zigbee IR blaster?
Thanks
