T3_TUyaOS-3.8.30 编译demo不过
MaGong
xm@ubuntu:~/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS$ cd /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/
xm@ubuntu:~/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS$ export TUYA_IDE_PYTHON_ENV=/home/xm/.tuya/venv/bin/python
xm@ubuntu:~/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS$ ./build_app.sh apps/tuyaos_demo_quickstart tuyaos_demo_quickstart 1.9.2
APP_PATH=apps/tuyaos_demo_quickstart
APP_NAME=tuyaos_demo_quickstart
APP_VERSION=1.9.2
USER_CMD=
APP_VERSION= 1.9.2
TARGET_PLATFORM= T3
File "./scripts/set_app_config.py", line 15, in <module>
from ruamel import yaml # pip3 install ruamel.yaml
ModuleNotFoundError: No module named 'ruamel'
./scripts/prepare_param.sh: line 7: git: command not found
grep: make.yaml: No such file or directory
toolchain Name: T3
toolchain Repo: https://images.tuyacn.com/smart/embed/pruduct/T3_.zip
toolchain Version:
++++++++++++++++++++ CI package fullname ++++++++++++++++++++
++++++++++++++++++++ the SDK ID tuyaos_demo_quickstart_1.9.2_T3 ++++++++++++++++++++
generate build_param for [ tuyaos_demo_quickstart ] AT [ T3 ]
Project [ tuyaos_demo_quickstart ] Param:
BUILD_DATE=2025_01_14
BUILD_TIME=18_52_08
GIT_USER=
IOT_SDK_VER=1.9.2
IPC_SDK_VER=1.9.2
SDK_FULL_VER=1.9.2
SDK_BETA_VER=
IOT_SDK_VER_MAJOR=1
IOT_SDK_VER_MINOR=9
IOT_SDK_VER_PATCH=2
KERNEL_VERSION=
PROJECT_NAME=tuyaos_demo_quickstart
TARGET_PLATFORM=T3
TARGET_PLATFORM_REPO=https://images.tuyacn.com/smart/embed/pruduct/T3_.zip
TARGET_PLATFORM_VERSION=
BUILD_STATIC=1
BUILD_SHARED=
SDK_ID=tuyaos_demo_quickstart_1.9.2_T3
ROOT_DIR=/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS
OUTPUT_DIR=$(ROOT_DIR)/output/$(TARGET_PLATFORM)_$(PROJECT_NAME)
OUTPUT_DIR_INC=$(OUTPUT_DIR)/include
OUTPUT_DIR_STATIC_LIB=$(OUTPUT_DIR)/static/lib
OUTPUT_DIR_SHARED_LIB=$(OUTPUT_DIR)/shared/lib
OUTPUT_DIR_STATIC_OBJS=$(OUTPUT_DIR)/static/objs
OUTPUT_DIR_SHARED_OBJS=$(OUTPUT_DIR)/shared/objs
COMPILE_PREX = /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/tuyaos/../toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/arm-none-eabi-
TUYAOS_BUILD_PATH = /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/tuyaos
AR = $(COMPILE_PREX)ar
CC = $(COMPILE_PREX)gcc
NM = $(COMPILE_PREX)nm
CPP = $(COMPILE_PREX)g++
STRIP = $(COMPILE_PREX)strip
OBJCOPY = $(COMPILE_PREX)objcopy
OBJDUMP = $(COMPILE_PREX)objdump
RANLIB = $(COMPILE_PREX)ranlib
CXX = $(COMPILE_PREX)g++
CFLAGS =
CFLAGS += -pipe -D_REENTRANT -Wall -Wno-unused-result
ifeq ($(CONFIG_OPERATING_SYSTEM), 100)
CFLAGS += -fPIC
endif
ifeq ($(CONFIG_TUYA_IOT_DEBUG), 1)
CFLAGS += -g
endif
ifdef PRJ_DEFINES
CFLAGS += $(PRJ_DEFINES)
endif
ifdef COMPILE_INCLUDE
CFLAGS += -I $(COMPILE_INCLUDE)
endif
ifdef COMPILE_LIB
export LD_LIBRARY_PATH=$(COMPILE_LIB)
endif
LINKFLAGS =
LINKFLAGS += -lpthread -lm
endif
ifdef PRJ_LINKS
LINKFLAGS += $(PRJ_LINKS)
endif
------ use bk lwip ------
find: ‘apps/tuyaos_demo_quickstart/application_components’: No such file or directory
find: ‘apps/tuyaos_demo_quickstart/application_drivers’: No such file or directory
clean application static ...
CC /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/tuya_app_main.c
CC /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/dp_process.c
CC /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/tal_uart.c
CC /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/bitstream.c
CC /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/qrinput.c
CC /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/qrspec.c
CC /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/qrenc.c
/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/qrenc.c: In function 'writeANSI':
/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/qrenc.c:793:4: warning: 'strncat' specified bound 2 equals source length [-Wstringop-overflow=]
793 | strncat(buffer, " ", 2);
/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/qrenc.c:807:4: warning: 'strncat' specified bound 2 equals source length [-Wstringop-overflow=]
807 | strncat(buffer, " ", 2);
/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/qrenc.c:814:4: warning: 'strncat' specified bound 2 equals source length [-Wstringop-overflow=]
814 | strncat(buffer, " ", 2);
/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/qrenc.c:816:3: warning: 'strncat' specified bound 5 equals source length [-Wstringop-overflow=]
816 | strncat(buffer, "\033[0m\n", 5);
CC /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/mmask.c
CC /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/rsecc.c
CC /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/mqrspec.c
CC /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/mask.c
CC /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/qrencode.c
/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/qrencode.c: In function 'QRcode_APIVersionString':
/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/qrencode.c:905:1: warning: control reaches end of non-void function [-Wreturn-type]
905 | }
CC /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/split.c
/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/split.c:42: warning: "isdigit" redefined
42 | #define isdigit(c) ((unsigned char)((signed char)(c) - '0') < 10)
In file included from /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/lwip_intf_v2_1/lwip-2.1.2/src/include/lwip/arch.h:228,
from /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/lwip_intf_v2_1/lwip-2.1.2/src/include/lwip/debug.h:40,
from /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/lwip_intf_v2_1/lwip-2.1.2/src/include/lwip/opt.h:52,
from /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/lwip_intf_v2_1/lwip-2.1.2/src/include/lwip/errno.h:41,
from /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/split.c:35:
/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/arm-none-eabi/include/ctype.h:95: note: this is the location of the previous definition
95 | #define isdigit(c) (ctype_lookup(c)&N)
/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/split.c:43: warning: "isalnum" redefined
43 | #define isalnum(
c) (QRinput_lookAnTable(c) >= 0)
/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/arm-none-eabi/include/ctype.h:99: note: this is the location of the previous definition
99 | #define isalnum(
c) (ctype_lookup(c)&(
U|L|N))
CC /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/app_led.c
CC /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/apps/tuyaos_demo_quickstart/src/app_key.c
AR -rcs /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/lib/libtuyaos_demo_quickstart.a /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/tuya_app_main.c.o /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/dp_process.c.o /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/tal_uart.c.o /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/libqrencode/bitstream.c.o /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/libqrencode/qrinput.c.o /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/libqrencode/qrspec.c.o /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/libqrencode/qrenc.c.o /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/libqrencode/mmask.c.o /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/libqrencode/rsecc.c.o /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/libqrencode/mqrspec.c.o /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/libqrencode/mask.c.o /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/libqrencode/qrencode.c.o /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/libqrencode/split.c.o /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/app_led.c.o /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/app_key.c.o
/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/lib/libtuyaos_demo_quickstart.a build done.
AR -rcs /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/lib/libtuyaapp_components.a
/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/lib/libtuyaapp_components.a build done.
AR -rcs /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/lib/libtuyaapp_drivers.a
/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/lib/libtuyaapp_drivers.a build done.
AR -rcs /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/lib/libtuyaos_demo_quickstart.a /home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/output/T3_tuyaos_demo_quickstart/.objs/static/apps/tuyaos_demo_quickstart/src/app_led.c.o
====== build app(tuyaos_demo_quickstart) begin =======
开始编译app
APP_BIN_NAME=tuyaos_demo_quickstart
APP_VERSION=1.9.2
TARGET_PLATFORM=bk7236
CURR_TARGET_PLATFORM=T3
APP_PATH=../../../apps/tuyaos_demo_quickstart
USER_CMD=
Start Compile
not is ci build
CHECK COMPONENTS
H file has been generated as '/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/include/default_gpio_config.h'
APP_DIR:apps
make[1]: Entering directory '/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino'
Parsing CSV input to gen part table...
Remap part table, convert logic addr to phy addr...
Gen partition_bk7256_ota_a_new.json using remapped part table...
File "/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/tools/build_tools/armino", line 806, in <module>
main()
File "/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/tools/build_tools/armino", line 719, in main
checks_output = check_environment()
File "/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/tools/build_tools/armino", line 53, in check_environment
debug_print_armino_version()
File "/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/tools/build_tools/armino", line 115, in debug_print_armino_version
version = armino_version()
File "/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/tools/build_tools/armino_actions/tools.py", line 57, in armino_version
'--git-dir=%s' % os.path.join(os.environ['ARMINO_PATH'], '.git'),
File "/usr/lib/python3.8/os.py", line 675, in getitem
raise KeyError(key) from None
KeyError: 'ARMINO_PATH'
make[1]: *** [Makefile:132: bk7236] Error 1
make[1]: Leaving directory '/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino'
make failed
build.sh: 139: exit: Illegal number: -1
make: *** [/home/xm/Documents/tuya/Projects/T3_TuyaOS-3.8.30/software/TuyaOS/scripts/mk/app.mk:195: app_by_name] Error 2
chaser
Re: T3_TUyaOS-3.8.30 编译demo不过
https://docs.bekencorp.com/armino/bk723 ... index.html
参考这个工具链安装指导文档,安装 python3,CMake,Ninja 以及依赖库。
