Hello there,
We use a Tuya Matter hub (THP10-Z-X)
Zigbee TRV - ID: bf9c8ee075e05afbf97sok
Avatto Thermostat - ID: bfe34764c897cc9b20hwod
Add Matter hub to Home Assistant but these two device are not showing.
It possible to fix it?
Thanks!!
Hello there,
Thanks!!
Vamp 2025年 Jan 9日 04:05Hello there,
Thanks!!
Hi,
We have received your feedback and are dealing with it. I will try my best to fix it. Please wait patiently for my next reply.
hello Vamp,
I have updated the corresponding configurations of your devices, please try to remove them and re-connect them to the gateway.
Maybe there will be other exceptions after the retry, you can let me know the result.
qiusui 2025年 Jan 9日 18:05hello Vamp,
Both Work well! (the TRV need a battery replace but after it perfect!)
Thanks a lot!
I also found a other device, that not see in HA. A 6 CH relay module. ID: bfbfe82ae37054db99sizr
I also want to ask, that if you fix these devices configuration, it work immediately , if other people are would like to use same devices?
Vamp 2025年 Jan 10日 03:14qiusui 2025年 Jan 9日 18:05hello Vamp,
Thanks a lot!I also found a other device, that not see in HA. A 6 CH relay module. ID: bfbfe82ae37054db99sizr
What a good news!
Also, I will add this device configuration later (ID: bfbfe82ae37054db99sizr), you can also try again to see if it is normal.
My configuration is valid for all devices with the same product id. Others can normally use the same device or device of the same pid.
Note: The configuration takes effect for the specified pid. A device of the same type may have multiple Pids. A pid that is not configured may have a similar exception.
@qiusui
The Relay board work well!!
But, the TRV that before add it (andf i said that it work after battery replace) it have some problem. It seems read the data , but we can not write (control it) Here the ID: bf9c8ee075e05afbf97sok
HA error:
@Vamp
First of all, I made some updates to your Zigbee TRV (old ID: bf9c8ee075e05afbf97sok) , which will require you to reconfigure it.
In addition, since it has been two days since your exception occurred, the data in the gateway has been overwritten, so please help us to do some operations:
(1) Restart the gateway.
(2) Reproducing abnormal issues;
(3) If the anomaly reappears, you will immediately reply me with the device id and abnormal time.
Thanks for your return and cooperation.
@qiusui
seems better now. I able to control the device via HA, but if i change something on Tuya app or Physically, it not show on HA interface.
ID are same
Vamp 2025年 Jan 13日 15:49@qiusui
ID are same
Can you describe this phenomenon in more detail?(For example, which specific data and feedback comparison between the two sides)
@qiusui
If I start the heating in HA, for example, it does it properly. But if I set it on the TRV or in the app, it doesn't go into the HA.
