关于wifi成品局域网产测的问题
leslieli
OPERATE_RET __app_product_test_mf_cb(USHORT_T cmd, UCHAR_T *data, UINT_T len, OUT UCHAR_T **ret_data, OUT USHORT_T *ret_len)
    TAL_PR_ERR("__app_product_test_mf_cb ,cmd: %d,len=%d", cmd, len);
    TAL_PR_HEXDUMP_DEBUG("data:", data, len);
    UINT32_T time_start = 0, timer_end = 0;
    ty_cJSON *cmd_json = NULL;
    ty_cJSON *cmd_type = NULL;
    ty_cJSON *sensor_channel = NULL;
    char send_data[50] = {0};
    unsigned short length = 0;
    unsigned char flag;
    switch (cmd)
    case 0x01:
    switch (*data)
    case 0:
        tuya_hard_set_led(LED_ON_OFF, 0);
        break;
    case 1:
        tuya_hard_set_led(LED_ON_OFF, 1);
        break;
    case 2:
        tuya_hard_set_led(LED_FLASH, 500);
        break;
    *ret_len = strlen("{\"ret\":true}");
    strcpy(ret_data, "{\"ret\":true}");
    TAL_PR_ERR("ret_data=%s,ret_len=%d", ret_data, *ret_len);
    break;
case 0x03:
    time_start = tal_system_get_millisecond();
    user_state.KEY_MF_FLAG=true;
    *ret_len = strlen("{\"keyID\":0}");
    strcpy(ret_data, "{\"keyID\":0}");
    TAL_PR_DEBUG("ret_data=%s,ret_len=%d", ret_data, *ret_len);
    user_state.KEY_MF_FLAG = false;
    break;
case 0x35:
    cmd_json = ty_cJSON_Parse(data);
    if (NULL == cmd_json)
        ty_cJSON_Delete(cmd_json);
        return;
    cmd_type = ty_cJSON_GetObjectItem(cmd_json, "testItem");
    if (NULL == cmd_type)
        ty_cJSON_Delete(cmd_type);
        return;
    sensor_channel = ty_cJSON_GetObjectItem(cmd_json, "type");
    if (NULL == sensor_channel)
        ty_cJSON_Delete(sensor_channel);
        return;
    TAL_PR_ERR("type=%s,channel=%s", cmd_type->valuestring, sensor_channel->valuestring);
    if (strcmp(cmd_type->valuestring, "pid") == 0)
    sprintf(ret_data,"{\"ret\":true,\"testItem\":\"pid\", \"type\":\"string\", \"value\":\"%s\"}",PID);
    *ret_len=strlen(ret_data);
    TAL_PR_ERR("ret_data=%s,ret_len=%d", ret_data,*ret_len);
    break;
return OPRT_OK;
用成品产测的函数 做局域网产测 在进cmd回调侯 回复消息失败 我看了下产测那里的日志 是re_data没有成功上报上去 不知道是什么原因 用的是BK7231 3.9.0开成品产测的sdk 然后T3的这块成品局域网产测可以进 但是每次ret_data的时候会直接进user_hard_fault
卢台长
Re: 关于wifi成品局域网产测的问题
Hi,您好
进入user_hard_fault的原因是,错误的进行赋值了ret_data
  1. 当用户需要返回数据时,先进行Malloc申请,并将申请的内存指针赋值ret_data(由内部释放),长度赋值ret_len
  2. 错误则直接返回任何错误代码即可(除了OPRT_OK),内部会自动返回{\"ret\":false}
请参考如下代码进行回复
    // ---------------成功处理---------------------
    // 返回数据需要进行malloc
    UCHAR_T *data = Malloc(128);
    if (NULL == data) {
        return OPRT_MALLOC_FAILED;
    // 返回用户自定义数据
    sprintf((char *)send_data, "user data");
    *ret_data = send_data;
    *ret_len  = strlen(send_data);
    // ---------------失败处理--------------------------------
    // 直接返回错误代码即可,内部会自动返回{\"ret\":false}
    return OPRT_COM_ERROR
leslieli
卢台长 2024年 Nov 27日 14:43
Hi,您好
请参考如下代码进行回复
    // 返回数据需要进行malloc
    if (NULL == data) {
    // 返回用户自定义数据
这个可以 但是如何一次性回复2条
卢台长
leslieli 2024年 Nov 28日 15:52
Hi,您好
请参考如下代码进行回复
    // 返回数据需要进行malloc
    if (NULL == data) {
    // 返回用户自定义数据
这个可以 但是如何一次性回复2条
Hi,您好
您是什么场景,需要连续回复两条
leslieli
卢台长 2024年 Nov 29日 14:09
Hi,您好
请参考如下代码进行回复
    // 返回数据需要进行malloc
    if (NULL == data) {
    // 返回用户自定义数据
这个可以 但是如何一次性回复2条
Hi,您好
您是什么场景,需要连续回复两条
跟产测对接了 有一个开关量传感 需要上报2次状态 现在没法报 我现在用通用数据对接替代了
