[已解决]GR5515开发门锁配件,使用离线密码开锁时,遇到时间戳不对的问题.
zoule@venztech.com
刚开始认为是传入的timestamp 参数问题,后面打印 得到的 T2 和T3 都不正确,显示时间为
TUYA_APP: T2->[2033-05-13 23:xx:xx]
TUYA_APP: T3->[2034-06-11 16:xx:xx]
TUYA_APP: NOW->[2024-10-17 04:xx:xx]
想知道这是 怎么回事?已经如何调试,有没有指导文档。
下面贴出 细节代码:
case UART_SIMULATE_OFFLINE_PWD: {
uint8_t pwd[128] = {0};
        if(len == OFFLINE_PWD_LEN) {
            memcpy(pwd, data, OFFLINE_PWD_LEN);
        else if(len <= 27+1) { //8λʮ����ת��Ϊ���������27λ
            uint8_t notation = data[0];
            int object_array_len = source_to_object(notation, &data[1], len-1, 10, pwd);
            TUYA_APP_LOG_HEXDUMP_INFO("pwd", pwd, object_array_len);
        uint8_t plain_pwd[OFFLINE_PWD_LEN+6] = {0};
        uint8_t plain_pwd_len = 0;
        uint8_t key[16];
        memset(key, '0', sizeof(key));
        memcpy(&key[10], tuya_ble_current_para.sys_settings.login_key, LOGIN_KEY_LEN);
        uint32_t timestamp = app_port_get_timestamp();
        int32_t ret = lock_offline_pwd_verify(key, sizeof(key),
                                                &pwd[0], OFFLINE_PWD_LEN, timestamp,
                                                plain_pwd+6, &plain_pwd_len);
        for(uint32_t idx=0; idx<OFFLINE_PWD_LEN+6; idx++) {
            plain_pwd[idx] += 0x30;
        uint8_t encrypt_pwd[OFFLINE_PWD_LEN+6] = {0};
        uint8_t iv[16] = {0x00};
        app_port_aes128_cbc_encrypt(key, iv, plain_pwd, sizeof(plain_pwd), encrypt_pwd);
        if(ret == OFFLINE_PWD_VERIFY_SUCCESS) {
            lock_open_record_report_offline_pwd(OR_LOG_OFFLINE_PW_OPEN_WITH, encrypt_pwd);
            TUYA_APP_LOG_INFO("lock_open_with_offline_pwd_success");
        else if(ret == OFFLINE_PWD_CLEAR_SINGLE_SUCCESS) {
            lock_open_record_report_offline_pwd(OR_LOG_OFFLINE_PW_CLEAR_SINGLE_ALARM, encrypt_pwd);
            TUYA_APP_LOG_INFO("clear_single_with_offline_pwd_success");
        else if(ret == OFFLINE_PWD_CLEAR_ALL_SUCCESS) {
            lock_open_record_report_offline_pwd(OR_LOG_OFFLINE_PW_CLEAR_ALL_ALARM, encrypt_pwd);
            TUYA_APP_LOG_INFO("clear_all_with_offline_pwd_success");
        else {
            TUYA_APP_LOG_INFO("lock_open_with_offline_pwd_fail");
    } break;
it_xh
Re: GR5515开发门锁配件,使用离线密码开锁时,遇到时间戳不对的问题.
您好 请提供下以下信息,以便进一步分析问题所在
  1. lock_offline_pwd_verify 这个api接口调用时,请打印所有入参信息,包括时间戳、输入的密码与长度、以及key。
  2. 增加打印出T0时间戳
  3. 提供生成离线密码的截图
  4. 提供设备id
从问题描述看,T2 T3时间不对,一般是T0不对造成的
zoule@venztech.com
好的,问题已经找到了
