mmWave Sensors Not Exposed
iantrobinson
Hi. I have three different mmWave sensors added to my THP10-Z-X Smart Wired Gateway Pro and none of them are working properly over Matter.
Product Name: 电池款人体移动传感器 - Human presence sensor (kb5noeto)
Device ID: eb67a94941e0ec7ba7vxyf
Product Category: hps
This sensor is exposed over Matter but the output is reversed. When there is occupancy it says false. Where there is no occupancy it says true.
Product Name: ZigBee呼吸存在传感器 (ztc6ggyl)
Device IDs: eb4307d53b8d9cc7c80yzd, eb48b2bcd57ac50c7ak16c, eb49e75e43529509d6hsgp, eb4d49835b51cae51ecfpk, eba8d2160b3007fc1bpdl8
These 5 sensors are not exposed at all.
Product Name: 高精度呼吸感应器 - High-precision breath sensor (ijxvkhd0)
Device IDs: eb835899def4a5d734cahv, eb06d390c45855e7e9sdwv, eb59baef9272409172nocg, eba440ebb8a74101e7dcc8, ebaebbc5d956445f53xfu9
Product Category: kg
These 5 sensors are not exposed at all. These sensors are also coded to the wrong product category. They show up as kg but they are hps devices.
Is it possible to fix these devices so that they work properly over Matter?
Thanks!
qiusui
Re: mmWave Sensors Not Exposed
iantrobinson 2024年 Sep 11日 15:50
Thanks!
Hello, I will check these devices one by one according to your feedback, please wait patiently for my follow-up feedback.
qiusui
Hi,
I have updated the configuration of all your devices.
In addition, I would like to add the specific configuration of these devices, I think it will be helpful to you:
  1. Product Name: 电池款人体移动传感器 - Human presence sensor (kb5noeto)
    The presence, illumination, and battery power of this type of sensor have been supported.
  2. Product Name: ZigBee呼吸存在传感器 (ztc6ggyl)
    The presence and illumination of this type of sensor have been supported.
  3. Product Name: 高精度呼吸感应器 - High-precision breath sensor (ijxvkhd0)
    This product is special and belongs to the switch & sensor composite category, which is developed by tuya customers in a custom way based on MCU.
    I can't verify whether my configuration is accurate because I don't have access to samples to verify it. So it's important that you need to test it to sure if the current configuration meets your needs.
    I've also configured it as a sensor type, the presence and illumination have been supported.
You can try to re-configure them to the gateway and test whether they can be correctly exposed to Matter. Please let me know if there are other exceptions.
Kind Regards,
Qiusui
iantrobinson
Thank you very much for the quick reply. They are all working great now!
I have one other question. Is it possible to select which thread network the Smart Wired Gateway Pro joins? Right now it makes its own network but I would like to force it to join the one set up by my AppleTVs. I tried changing the channel to the same one as the AppleTV network but it didn't work.
Thanks.
huangxh
iantrobinson 2024年 Sep 14日 10:39
Thanks.
Sorry, not supported. thanks
