Tuya Matter - thermal sensor not exposed
wmbauer
Hi,
this thermal and humidity sensor works perfectly fine in Smart Home, but doesn't get exposed over matter:
bfb167e8fe5bdb7adfmbtn
Using Zemismart M1 bridge.
Is this the right place to ask for the sensor to be exposed? Can you enable this sensor?
huangxh
Re: Tuya Matter - thermal sensor not exposed
wmbauer 2024年 Jul 16日 03:54
Hi,
Hi, we have enable this sensor, first you delete it, then add it again.thanks.
wmbauer
Thank you very much for your very quick support!
Unfortunately the wrong numbers are being reported: temperature 2,91 degrees celsius, humidity 0,55%. Should be 29,1 degrees, 55%.
huangxh
wmbauer 2024年 Jul 16日 15:09
Sorry, could you please test it again? If the issue still exists, please tell me. Thank you.
wmbauer
Thank you. Temperature is fine now, humidity wrong by the factor of 10 (reads 5,2% instead of 52%).
huangxh
wmbauer 2024年 Jul 16日 21:35
it is all right now, you could test again. thanks.
wmbauer
Thank you very much, it's perfectly fine now!
wmbauer
Update:
Another thermal sensor which isn't being exposed at all:
bf62f9cc1ca02ec733caz6
Temperature, humidity, battery charge would be great if it would work over Matter!
huangxh
wmbauer 2024年 Aug 3日 01:46
Update:
you can add the device again, then test it.thanks.
wmbauer
Thank you. It appears now, but with wrong/strange values:
humidity: 40% (should be over 60)
temperature: 20°C (should be 24°C)
Tuya app shows correct values.
