物料广场的TyTabs选择器组件下载不了
silverlight
npm install @ray/components-ty-tabs报错如下。查询之后大概意思是该组件要求@ray-js/ray 的版本为 0.6.26
而使用yarn add @ray-js/components-ty-tabs,则直接报错没有@ray-js/components-ty-tabs
npm下载报错
npm ERR! code ERESOLVE
npm ERR! ERESOLVE unable to resolve dependency tree
npm ERR!
npm ERR! While resolving: public-sdm-template@1.0.1
npm ERR! Found: @ray-js/ray@1.5.17
npm ERR! node_modules/@ray-js/ray
npm ERR!   @ray-js/ray@"^1.4.45" from the root project
npm ERR!
npm ERR! Could not resolve dependency:
npm ERR! peer @ray-js/ray@"^0.6.26" from @ray-js/components-ty-actionsheet@0.0.26
npm ERR! node_modules/@ray-js/components-ty-actionsheet
npm ERR!   @ray-js/components-ty-actionsheet@"^0.0.26" from the root project
npm ERR!
npm ERR! Fix the upstream dependency conflict, or retry
npm ERR! this command with --force or --legacy-peer-deps
npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
npm ERR!
npm ERR!
npm ERR! For a full report see:
npm ERR! D:\nvm\nodejs\node_cache\_logs\2024-06-20T08_53_18_791Z-eresolve-report.txt
npm ERR! A complete log of this run can be found in: D:\nvm\nodejs\node_cache\_logs\2024-06-20T08_53_18_791Z-debug-0.log
yarn 下载报错
yarn add v1.22.22
warning package-lock.json found. Your project contains lock files generated by tools other than Yarn. It is advised not to mix package managers in order to avoid resolution inconsistencies caused by unsynchronized lock files. To clear this warning, remove package-lock.json.
[1/4] Resolving packages...
error Error: https://registry.npmjs.com/@ray%2fcomponents-ty-tabs: Not found
    at params.callback [as _callback] (D:\nvm\nodejs\node_global\node_modules\yarn\lib\cli.js:66680:18)
    at self.callback (D:\nvm\nodejs\node_global\node_modules\yarn\lib\cli.js:141410:22)
    at Request.emit (node:events:517:28)
    at Request.<anonymous> (D:\nvm\nodejs\node_global\node_modules\yarn\lib\cli.js:142382:10)
    at IncomingMessage.<anonymous> (D:\nvm\nodejs\node_global\node_modules\yarn\lib\cli.js:142304:12)
    at Object.onceWrapper (node:events:631:28)
    at IncomingMessage.emit (node:events:529:35)
    at endReadableNT (node:internal/streams/readable:1400:12)
    at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
info Visit https://yarnpkg.com/en/docs/cli/add for documentation about this command.
智能小程序开发者
Re: 物料广场的TyTabs选择器组件下载不了
你好,请将lock文件删除后重新安装
silverlight
智能小程序开发者 2024年 Jun 20日 17:09
你好,请将lock文件删除后重新安装
删除之后,我卸载重装了yarn ,还是无法安装。
yarn add @ray/components-ty-tabs
yarn add v1.22.22
智能小程序开发者
正确应该执行 yarn add @ray-js/components-ty-tabs 你这个命令行写错了。 怎么帖子内容里命令行写的对的,下面命令行输入的错的。
https://www.npmjs.com/package/@ray-js/c ... ts-ty-tabs
silverlight
智能小程序开发者 2024年 Jun 21日 09:50
我一开始是直接复制物料广场里面的命令行。发现安装不成功,所以去了npm查看代码。没注意到你们这两边文档的命令行居然不同
智能小程序开发者
感谢反馈,这里我们修改一下
