【已解决】【TuyaOS SDK】在ubuntu环境下 调试IPC SDK demo报错/tmp/tuya.cfgs/tuya_sd_record_on_off: No such file or directory
liangcaimei
在ubuntu环境下 调试IPC SDK demo报错/tmp/tuya.cfgs/tuya_sd_record_on_off: No such file or directory,这是什么文件?
[03-15 11:54:01 TUYA D][iot_httpc.c:2411] dynamic cfg post data:{"ackList":[{"type":"timezone","ackId":"0-0"}],"t":1710474840}, ret:0.
ens33 no wireless extensions.
[03-15 11:54:01 TUYA D][simplekv.c:1211] read key:fjokmc_ver isFuzzy:0 skipCnt:0
[03-15 11:54:01 TUYA D][simplekv.c:1247] no key find
[03-15 11:54:01 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[03-15 11:54:01 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[03-15 11:54:01 TUYA D][tuya_svc_schema_upgrade.c:223] schema[fjokmc] not updated since activated
read int exc: cat /tmp/tuya.cfgs/tuya_sd_record_on_off
cat: /tmp/tuya.cfgs/tuya_sd_record_on_off: No such file or directory
readstr: andint:0
curr sd_record_on_off:0
ioctl error
readstr: andint:0
ioctl error
[03-15 11:54:03 TUYA D][tuya_ipc_p2p.c:3937] session[65537] audio Frame Send type[129] count[200]
readstr: andint:0
郭老庄
Re: 在ubuntu环境下 调试IPC SDK demo报错/tmp/tuya.cfgs/tuya_sd_record_on_off: No such file or directory
这是demo用来保存配置的文件,tuya_sd_record_on_off指sd卡录像是否开启的配置。配置如何保存你们可以自己做
