Trouble with Tuya API POST request returning code 1004 or sign invalid
mark_libres
I'm working on integrating the Tuya API into my Python application to control smart devices. I'm able to successfully make GET requests, but I'm encountering issues when trying to make POST requests.
Whenever I attempt to send a POST request to the Tuya API, I consistently receive either a code 1004 error or a "sign invalid" message. I've verified that my client ID and client secret are correct, and my GET requests are working fine.
here is my Request class file
import time
import hashlib
import hmac
import requests
import subprocess
class Request:
def __init__(self):
    self.ClientID = "**"
    self.ClientSecret = "**"
    self.BaseUrl = "https://openapi.tuyaus.com"
    self.EmptyBodyEncoded = "e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855"
def headers(self, sign):
    return {
        "sign_method": "HMAC-SHA256",
        "client_id": self.ClientID,
        "t": self.tuyatime(),
        "mode": "cors",
        "Content-Type": "application/json",
        "sign": sign
def tuyatime(self):
    return str(int(time.time() * 1000))
def access_token(self):
    URL = "/v1.0/token?grant_type=1"
    StringToSign = f"{self.ClientID}{self.tuyatime()}GET\n{self.EmptyBodyEncoded}\n\n{URL}"
    AccessTokenSign = hmac.new(self.ClientSecret.encode(), StringToSign.encode(), hashlib.sha256).hexdigest().upper()
    AccessTokenResponse = requests.get(f"{self.BaseUrl}{URL}", headers=self.headers(AccessTokenSign))
    return AccessTokenResponse.json()['result']["access_token"]
    pass
def sign(self, url, method):
    access_token = self.access_token()
    str_sign = f"{self.ClientID}{access_token}{self.tuyatime()}{method}\n{self.EmptyBodyEncoded}\n\n{url}"
    return [
        hmac.new(self.ClientSecret.encode(), str_sign.encode(), hashlib.sha256).hexdigest().upper(),
        access_token
def _sign(self, url, method, data):
    # Define the body
    print("data >> ", data)
    encoded_body = self.EmptyBodyEncoded
    if data != None:
        body_str = str(data).encode('utf-8')
        encoded_body = hashlib.sha256(body_str).hexdigest()
    print("encoded_body >> ", encoded_body)
    stringToSign = "\n".join([
        method, #HTTPMethod
        encoded_body, #Content-SHA256
        "", #Optional_Signature_key
        url #URL
    str_sign = f"{self.ClientID}{access_token}{self.tuyatime()}{stringToSign}"
    return [
        access_token
def request_extra_params(self, url, method, data):
    sign, access_token = self._sign(url, method, data)
    headers = self.headers(sign)
    headers["access_token"] = access_token
    return {
        "headers" : headers
    pass
def get(self, url, **kwargs):
    extra_params = self.request_extra_params(url, "GET", None)
    return requests.get(f"{self.BaseUrl}{url}", **extra_params, **kwargs)
def post(self, url, data, **kwargs):
    extra_params = self.request_extra_params(url, "POST", data)
    return requests.post(f"{self.BaseUrl}{url}", json=data, **extra_params, **kwargs)
here is the common file
from classes.Request import Request
import json
_request = Request()
DEVICES = {
    "mark_table" : "***"
def set_state_mark_table(value = True):
    URL = f"/v1.0/devices/{DEVICES['mark_table']}/commands"
    return _request.post(URL, data=json.dumps({
        "commands" : [{"code":"switch_1","value":value}]
her is the file to trigger the common file and Request class
import common
value = common.set_state_mark_table(False)
print(value.text)
JamesG
Re: Trouble with Tuya API POST request returning code 1004 or sign invalid
You can first take a look at this article: https://developer.tuya.com/en/docs/iot/ ... 0q34cs2e5g.
Check your program and if there are still issues, please provide feedback on the forum.
Tran Manh Duy
I downloaded a Nodejs example code at:https://developer.tuya.com/en/docs/iot/ ... qza5d7iwkc
I successfully called GET method
But when I call POST method to send command control the device, it throws an error : Error: request api failed: sign invalid
This is source code:
import * as qs from 'qs';
import * as crypto from 'crypto';
import { default as axios } from 'axios';
let token = '';
const config = {
  /* openapi host */
  host: 'https://openapi.tuyaus.com',
  /* fetch from openapi platform */
  accessKey: '',
  secretKey: '',
  /* Interface example device_ID */
  deviceId: '',
const httpClient = axios.create({
  baseURL: config.host,
  timeout: 5 * 1e3,
async function main() {
  await getToken();
  const data = await sendCommandControlDevice(config.deviceId);
  console.log('fetch success: ', JSON.stringify(data));
 * fetch highway login token
async function getToken() {
  const method = 'GET';
  const timestamp = Date.now().toString();
  const signUrl = '/v1.0/token?grant_type=1';
  const contentHash = crypto.createHash('sha256').update('').digest('hex');
  const stringToSign = [method, contentHash, '', signUrl].join('\n');
  const signStr = config.accessKey + timestamp + stringToSign;
  const headers = {
    t: timestamp,
    sign_method: 'HMAC-SHA256',
    client_id: config.accessKey,
    sign: await encryptStr(signStr, config.secretKey),
  const { data: login } = await httpClient.get('/v1.0/token?grant_type=1', { headers });
  if (!login || !login.success) {
    throw Error(`fetch failed: ${login.msg}`);
  token = login.result.access_token;
 * GET method is success to fetch data
async function getDeviceInfo(deviceId: string) {
  const query = {};
  const url = `/v1.0/devices/${deviceId}`;
  const reqHeaders: { [k: string]: string } = await getRequestSign(url, method, {}, query);
  const { data } = await httpClient.request({
    method,
    data: {},
    params: {},
    headers: reqHeaders,
    url: reqHeaders.path,
  if (!data || !data.success) {
    throw Error(`request api failed: ${data.msg}`);
 * Fail when call POST method with Error: request api failed: sign invalid
async function sendCommandControlDevice(deviceId: string) {
  const query = {};
  const method = 'POST';
  const url = `/v1.0/iot-03/devices/${deviceId}/commands`;
    method,
    data:  {
      "commands":[{"code":"switch_1","value":true}]
    params: {},
 * HMAC-SHA256 crypto function
async function encryptStr(str: string, secret: string): Promise<string> {
  return crypto.createHmac('sha256', secret).update(str, 'utf8').digest('hex').toUpperCase();
 * request sign, save headers
 * @param path
 * @param method
 * @param headers
 * @param query
 * @param body
async function getRequestSign(
  path: string,
  method: string,
  headers: { [k: string]: string } = {},
  query: { [k: string]: any } = {},
  body: { [k: string]: any } = {},
  const t = Date.now().toString();
  const [uri, pathQuery] = path.split('?');
  const queryMerged = Object.assign(query, qs.parse(pathQuery));
  const sortedQuery: { [k: string]: string } = {};
  Object.keys(queryMerged)
    .sort()
    .forEach((i) => (sortedQuery[i] = query[i]));
  const querystring = decodeURIComponent(qs.stringify(sortedQuery));
  const url = querystring ? `${uri}?${querystring}` : uri;
  const contentHash = crypto.createHash('sha256').update(JSON.stringify(body)).digest('hex');
  const stringToSign = [method, contentHash, '', url].join('\n');
  const signStr = config.accessKey + token + t + stringToSign;
  return {
    t,
    path: url,
    access_token: token,
main().catch(err => {
  throw Error(`error: ${err}`);
Please give me a solution or workaround to fix this issue to call POST method
Thanks
panda-cat
To facilitate request analysis, please send the most recent abnormal request result including tid, thank you.
Tran Manh Duy
Here is console log. Pls refer to the attach file
PS C:\Users\Downloads\nodejs_demo.ts (origin111)\nodejs_demo> npm run test
highway@1.0.0 test
ts-node nodejs_demo.ts
Error: error: Error: request api failed: sign invalid
    at C:\Users\Downloads\nodejs_demo.ts (origin111)\nodejs_demo\nodejs_demo.ts:146:9
    at processTicksAndRejections (node:internal/process/task_queues:95:5)
panda-cat
Please refer to the modification of the arrow marked part:
const query = {};
--> const body = {"commands":[{"code":"switch_1","value":true}]};
const url = /v1.0/iot-03/devices/${deviceId}/commands;
--> const reqHeaders: { [k: string]: string } = await getRequestSign(url, method, {}, query,body);
method,
--> data: body,
params: {},
throw Error(request api failed: ${data.msg});
panda-cat
To ensure the security of your account data, please protect your personal account key information. Please delete sensitive information in the question code or delete the old project and rebuild it.
Tran Manh Duy
Thank you very much for supporting me. It worked. I can send the POST method success
And I deleted personal info in the above question
By the way, Could you give me the document or example to create GET, PUT, POST, and DELETE methods to call Tuya API?
panda-cat
This Service SDKs should have the information you need: https://developer.tuya.com/en/docs/iot/ ... 09frvx48db
