【已解决】tuyaos_demo_matter_quickstart 编译出错
sky
tuyaos_demo_matter_quickstart 的 demo 没有作任何修改,
环境为 vMbox- Ubuntu 22.04.3 LTS;
编译得到的的log 如下
/home/sky/Documents/tuya/Projects/BK7231N_TuyaOS-3.7.6/software/TuyaOS/apps/tuyaos_demo_matter_quickstart/src/tuya_app_main.c:594:5: warning: implicit declaration of function ‘tkl_thread_create’; did you mean ‘tal_thread_delete’? [-Wimplicit-function-declaration]
  594 |     tkl_thread_create(&ty_chip_thread, "matter_task", 20*1024, 2, chip_thread, NULL);
      |     tal_thread_delete
/home/sky/Documents/tuya/Projects/BK7231N_TuyaOS-3.7.6/software/TuyaOS/apps/tuyaos_demo_matter_quickstart/src/tuya_app_main.c: Assembler messages:
/home/sky/Documents/tuya/Projects/BK7231N_TuyaOS-3.7.6/software/TuyaOS/apps/tuyaos_demo_matter_quickstart/src/tuya_app_main.c:485: Error: no such instruction: `bl __libc_init_array'
compile command:
gcc -pipe -D_REENTRANT -Wall -Wno-unused-result  -Iinclude -Iinclude/components -Iinclude/components/svc_devos -Iinclude/components/svc_devos/include -Iinclude/components/svc_matter_acl_intf -
SDK 信息如下
Type Dev Kit
Networked Product Development:Wifi-BLI-Matter Device Development Kit
Description
general development framework for matter on Wi-Fi&BLE platform, can be used for the development of all wifi&ble control equipment, including the development of electricians, lighting, door locks, and household appliances. While supporting standard matter protocol, it also supports Tuya cloud capability (using Tuya App or sharing to Tuya App).
TuyaOS Version
TuyaOS-3.7.6
Component Dev Kit(s)
tuyaos-iot_3.4.119_bk7231n_matter_1.2.6
请问怎么解决
haitun
Re: tuyaos_demo_matter_quickstart 编译出错
这个demo是在arm-linux上编译测试使用的,在gcc上没有测试验证过。
你用的是什么编译命令?用ide编译是没问题的?你用的是M1?
sky
我是用VirtualBox 虚拟机, 系统是 Ubuntu22 也是按照 doc 网页哪里操作,提示 tuya_app_main.c:485: Error: no such instruction: `bl __libc_init_array' 是不是有些库没装好
操作流程是没问题的,也比较奇怪哈,c库用的应该是原厂的,和系统里的没啥差别。你能把完整的编译过程的log,用文件的形式发过来看看吗?
sky
log 文件如下
tuya-error.log
(32.43 KiB) Downloaded 581 times
你能看看的vendor/bk7231n目录里有啥嘛?感觉是这个目录没有完整导致的。你可以删掉这个目录重新编译试试。
sky
:D 谢谢,我重新弄了个 ubuntu22.04的虚拟机可以了
