【问题汇总】TuyaOS-联网单品开发编译问题与解决方法汇总【欢迎跟帖】
chenyisong
常见问题1:
我的系统里面已经安装了python3.8/python2.7,但是还是提示python: not found
解决方法:
(1)windows系统下,环境变量设置有问题,在“系统属性”->“环境变量”->“系统环境变量”中设置
(2)Linux系统下,python软链接可能有问题
安装python3:
sudo apt-get install -y python3
获取当前python3路径:
which python3
创建软链接
sudo ln -s /usr/bin/python3 /usr/bin/python
常见问题2:
TuyaOS开发框架已经带了交叉编译器,但是还是提示toolchain/gcc-arm-none-eabi-4_9-2015q1/bin/arm-none-eabi-gcc: not found
解决方法:
当前安装的Linux系统是64bit,而arm-none-eabi-gcc是32bit的,linux系统下需要安装32位的库,通过以下命令解决:
sudo apt-get install -y libc6-i386
13393216460
Re: 【问题汇总】TuyaOS-联网单品开发编译问题与解决方法汇总【欢迎跟帖】
我使用的是 M1 系统,使用 pd 安装的 Ubuntu,在使用 TuyaOS-3.8.1 版本的时候 build apps/tuyaos_demo_quickstart 报错,
请问该怎么解决
clean application static ...
find: ‘apps/tuyaos_demo_quickstart/application_components’: No such file or directory
find: ‘apps/tuyaos_demo_quickstart/application_drivers’: No such file or directory
CC /home/parallels/Documents/tuya/Projects/BK7231N_TuyaOS-3.7.2/software/TuyaOS/vendor/bk7231n/tuyaos/tuyaos_adapter/include/init/src/tkl_init_common.c
/bin/sh: 1: /home/parallels/Documents/tuya/Projects/BK7231N_TuyaOS-3.7.2/software/TuyaOS/vendor/bk7231n/tuyaos/../toolchain/gcc-arm-none-eabi-4_9-2015q1/bin/arm-none-eabi-gcc: Exec format error
compile command: 这里省略
make: *** [scripts/mk/xmake.mk:220: /home/parallels/Documents/tuya/Projects/BK7231N_TuyaOS-3.7.2/software/TuyaOS/output/bk7231n_tuyaos_demo_quickstart/.objs/static/vendor/bk7231n/tuyaos/tuyaos_adapter/include/init/src/tkl_init_common.c.o] Error 1
chenyisong
需要确认一下M1下是否可以使用x64下的toolchain。
还有是否已经执行了 sudo apt-get install -y libc6-i386
18348313267
PS Microsoft.PowerShell.Core\FileSystem::\\192.168.56.101\share\T2_TuyaOS-3.3.4> cd '\\192.168.56.101\share\T2_TuyaOS-3.3.4\software\TuyaOS\'
PS Microsoft.PowerShell.Core\FileSystem::\\192.168.56.101\share\T2_TuyaOS-3.3.4\software\TuyaOS> & python.exe .\build_app.py apps\tuyaos_demo_quickstart tuyaos_demo_quickstart 1.0.0
C:\Development Tools\python-3.8.10\python.exe: can't open file '.\build_app.py': [Errno 2] No such file or directory
我在VSCode下编译,报的错不知道怎么解决
chenyisong
T2_TuyaOS-3.3.4 不要在Windows下编译,目前只支持linux,win下可以使用wsl来编译
Kristy21
看完上面的讨论,感觉环境配置这块还是挺折腾的(尤其是 32 位兼容和 M1 芯片)。有没有人试过把这套开发环境 Docker 化?如果有现成的容器,感觉能少走不少弯路。nulls brawl mods
