AR -rcs /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/lib/libtuyaos_adapter.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_wired/src/skeleton/tkl_wired.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/sensor/tkl_sensor.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/io/tkl_io.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/tar/tkl_tar.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/watchdog/tkl_watchdog_core.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/watchdog/tkl_watchdog_api.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/gpio/tkl_gpio_api.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/gpio/tkl_gpio_core.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/ir/tkl_ir_common.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/ir/tkl_ir.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/reboot/tkl_reboot.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/i2c/tkl_i2c_api.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/i2c/tkl_i2c_core.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/pwm/tkl_pwm_core.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/pwm/tkl_pwm_api.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/adc/tkl_adc_api.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/adc/tkl_adc_core.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/adc/tkl_adc_platform.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/rtc/tkl_rtc_core.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/rtc/tkl_rtc_api.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/imu/tkl_imu.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/passwd/tkl_passwd.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/utils/hal_file.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/utils/hal_log.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/input_event/tkl_input_event.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/input_event/tkl_input_event_common.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/tkl_dl/tkl_dl_ir.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/tkl_dl/tkl_dl_uart.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/tkl_dl/tkl_dl_input_event.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/tkl_dl/tkl_dl_gpio.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/tkl_dl/tkl_dl_pwm.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/tkl_dl/tkl_dl.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/tkl_dl/tkl_dl_adc.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/spi/tkl_spi_core.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/spi/tkl_spi_api.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/cmd/tkl_cmd.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/uart/tkl_uart_platform.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/uart/tkl_uart_core.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/uart/tkl_uart_api.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_base/src/motor/tkl_motor.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_system/src/tkl_queue.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_system/src/tkl_mutex.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_system/src/tkl_semaphore.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_system/src/tkl_fs.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_system/src/tkl_cmd.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_system/src/tkl_system.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_system/src/tkl_passwd.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_system/src/tkl_memory.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_system/src/tkl_output.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_system/src/tkl_reboot.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_system/src/tkl_thread.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_system/src/tkl_ota.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_system/src/tkl_tar.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_system/src/tkl_sleep.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_wifi/src/func/tkl_net.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_wifi/src/func/tkl_gen_net.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_wifi/src/func/tkl_wifi.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_wifi/src/func/tkl_wifi_hostap.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_wifi/src/func/wpa_s/wpa_command.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_wifi/src/func/wpa_s/wpa_cli_wrapper.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_wifi/src/utils/iwlib/iwlib.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_wifi/src/utils/wpa_cli/wpa_debug.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_wifi/src/utils/wpa_cli/eloop.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_wifi/src/utils/wpa_cli/os_unix.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_wifi/src/utils/wpa_cli/wpa_ctrl.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_wifi/src/utils/wpa_cli/edit_simple.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_wifi/src/utils/wpa_cli/wpa_cli.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/include/init/src/tkl_init.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/include/init/src/tkl_init_common.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/include/init/src/tkl_init_system.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/include/init/src/tkl_init_wifi.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/include/init/src/tkl_init_wired.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/include/utilities/src/tuya_ringbuf.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/include/utilities/src/tuya_smartpointer.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/include/utilities/src/tuya_list.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/include/utilities/src/tuya_mem_heap.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/include/utilities/src/tuya_tools.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/include/utilities/src/tuya_queue.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/include/utilities/src/tuya_hashmap.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/tkl_video_vi.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/autoscene/sensor/sc035gs.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/autoscene/sensor/sc3335.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/autoscene/sensor/sc500ai.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/autoscene/sensor/sc401ai.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/autoscene/sensor/sc223a.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/autoscene/sensor/imx307.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/autoscene/sensor/sc4336.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/autoscene/sensor/sc307e.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/autoscene/dnc.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/autoscene/autoscene.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/tkl_detect_db.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/tkl_video_osd.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/tkl_audio.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/tkl_isp.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/tkl_video_nna_detect.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/tkl_media_xm6xxv200/src/tkl_video_enc.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/nvram_kernel_driver/src/lib/nvram.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/bsp_verify/src/ecdsa.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/bsp_verify/src/sha256.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/bsp_verify/src/tuya_verify.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handler.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/notifier.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/property.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/swupgrade_async.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/swupgrade_network.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/swupgrade_progress.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/tuya_sha256.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/tuya_unpack.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/ipc/network_ipc.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/ipc/progress_ipc.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handlers/amlogic_nand_flash_handler.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handlers/dummy_handler.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handlers/nand_flash_handler.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handlers/nor_flash_handler.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handlers/rockchip_nand_flash_handler.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/3rdparty/mtd-utils/lib/libmtd.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handlers_wh/amlogic_nand_flash_handler_wh.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handlers_wh/dummy_handler_wh.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handlers_wh/nand_flash_handler_wh.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handlers_wh/nor_flash_handler_wh.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handlers_wh/rockchip_nand_flash_handler_wh.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handlers_bk/amlogic_nand_flash_handler_bk.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handlers_bk/dummy_handler_bk.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handlers_bk/nand_flash_handler_bk.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handlers_bk/nor_flash_handler_bk.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/handlers_bk/rockchip_nand_flash_handler_bk.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/vendor/xm6xxv200/tuyaos/tuyaos_adapter/src/swupgrade_unpack/src/3rdparty/mtd-utils/lib/libmtd_legacy.c.o
/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/lib/libtuyaos_adapter.a build done.
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_main/src/main.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_main/src/ty_sys.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_main/src/ty_sdk_adapter.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_main/src/ty_sys_sub.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_av/src/ty_sys_sei.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_av/src/ty_dsp_adapter.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_av/src/ty_sys_av.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_av/src/ty_dsp_config.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_av/src/ty_dsp_adapter_wav.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_ircut/src/ty_sys_ircut.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_led/src/ty_sys_led.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_panel/src/ty_sys_panel.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_user_protocol/src/ty_user_cmd_dp_utils.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_user_protocol/src/ty_user_cmd_dp_handler.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_user_protocol/src/ty_user_cmd_api.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_user_ptz/src/app_user_ptz.c
CC /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_opensource_zbar/src/ty_opensource_zbar.c
AR -rcs /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/lib/libtuyaos-ipc-xm6xxv200-sc117wnz2.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_main/src/main.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_main/src/ty_sys.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_main/src/ty_sdk_adapter.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_main/src/ty_sys_sub.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_av/src/ty_sys_sei.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_av/src/ty_dsp_adapter.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_av/src/ty_sys_av.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_av/src/ty_dsp_config.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_av/src/ty_dsp_adapter_wav.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_ircut/src/ty_sys_ircut.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_led/src/ty_sys_led.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_sys_panel/src/ty_sys_panel.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_user_protocol/src/ty_user_cmd_dp_utils.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_user_protocol/src/ty_user_cmd_dp_handler.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_user_protocol/src/ty_user_cmd_api.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_user_ptz/src/app_user_ptz.c.o /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/.objs/static/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_opensource_zbar/src/ty_opensource_zbar.c.o
/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/lib/libtuyaos-ipc-xm6xxv200-sc117wnz2.a build done.
AR -rcs /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/lib/libtuyaapp_components.a
/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/lib/libtuyaapp_components.a build done.
AR -rcs /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/lib/libtuyaapp_drivers.a
/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/lib/libtuyaapp_drivers.a build done.
====== build app(tuyaos-ipc-xm6xxv200-sc117wnz2) begin =======
开始编译app
make[1]: Entering directory '/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2'
/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/vendor/xm6xxv200/tuyaos/../toolchain/opt/xm_toolchain/arm-xm-linux/usr/bin/arm-xm-linux-gcc -Os -fno-aggressive-loop-optimizations -Os -Wl,--gc-sections,--no-whole-archive,--no-export-dynamic -Xlinker "-(" /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/libs/libtuyaapp_components.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/libs/libzbar.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/libs/libiconv.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/libs/libtuyaos-ipc-xm6xxv200-sc117wnz2.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/libs/libtuyaos.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libmpi.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libvenc.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libvdec.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libh265e.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libh265d.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libx264.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libjpegenc.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libxmaudio3a.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libispapp.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libsns_XAx.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libphyvi.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libfvideo.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libisp.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libae.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libawb.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/librtc.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libive.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libxmia.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libxmia_td.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libfacnn.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libfdr.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libfpcnn.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libfr.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libxmia_dcv.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libxmia_fd_cnn.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libxmia_spc.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libnpu.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libdpu.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/bsp/bsp_sdk/media-sdk/libxmia_comm.a -mcpu=cortex-a9 -mfloat-abi=softfp -mfpu=neon -mno-unaligned-access -fno-aggressive-loop-optimizations -flax-vector-conversions -fsigned-char -fopenmp /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/libs/libtuyaos_adapter.a -lpthread -ldl -lm -lstdc++ -lrt -lcrypt /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/libs/libpcap.a /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/libs/libiw.a -Xlinker "-)" -o ./../../output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/firmware/tycam
/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/libs/libtuyaos.a(tal_network.c.o): In function tal_net_gethostbyname':iw_in_inet':
tal_network.c:(.text.tal_net_gethostbyname+0x48): warning: gethostbyname_r is obsolescent, use getnameinfo() instead.
/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/libs/libtuyaos_adapter.a(iwlib.c.o): In function
iwlib.c:(.text.iw_in_inet+0x68): warning: gethostbyname is obsolescent, use getnameinfo() instead.
make[1]: Leaving directory '/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2'
pack img
/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/../..//apps/tuyaos-ipc-xm6xxv200-sc117wnz2/ty_pack.sh: line 25: /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/../..//scripts/param.env: No such file or directory
step 1 /home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/../..//vendor/xm6xxv200/toolchain/opt/xm_toolchain/arm-xm-linux/usr/bin/arm-xm-linux-
/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/firmware/out/target/tuya/xm6xxv200
cp: cannot stat '/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/../..//output/bsp//drv.squashfs.img': No such file or directory
step 2
“package_app start”
fatal: not a git repository (or any of the parent directories): .git
rm: cannot remove '/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/../..//output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/firmware/out/target/tuya/xm6xxv200/app/skyeye/bin/nvram': No such file or directory
Cannot stat source directory "/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/../..//output/xm6xxv200_tuyaos-ipc-xm6xxv200-sc117wnz2/firmware/out/target/tuya/xm6xxv200/fw/squashfs-root" because No such file or directory
cp: cannot stat '/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/../..//apps/tuyaos-ipc-xm6xxv200-sc117wnz2/script/startup.sh': No such file or directory
/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/../..//apps/tuyaos-ipc-xm6xxv200-sc117wnz2/ty_pack.sh: line 128: tree: command not found
Parallel mksquashfs: Using 1 processor
Creating 4.0 filesystem on user.squashfs.img, block size 131072.
[==================================================================================================================================-] 55/55 100%
Exportable Squashfs 4.0 filesystem, xz compressed, data block size 131072
compressed data, compressed metadata, compressed fragments,
compressed xattrs, compressed ids
duplicates are removed
Filesystem size 1950.50 Kbytes (1.90 Mbytes)
41.87% of uncompressed filesystem size (4658.19 Kbytes)
Inode table size 486 bytes (0.47 Kbytes)
37.21% of uncompressed inode table size (1306 bytes)
Directory table size 498 bytes (0.49 Kbytes)
62.72% of uncompressed directory table size (794 bytes)
Number of duplicate files found 0
Number of inodes 36
Number of files 21
Number of fragments 3
Number of symbolic links 3
Number of device nodes 0
Number of fifo nodes 0
Number of socket nodes 0
Number of directories 12
Number of ids (unique uids + gids) 1
Number of uids 1
wxj (1000)
Number of gids 1
wxj (1000)
step 3
package fac
cp: cannot stat '/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/../..//apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_user_fac/pack/script/': No such file or directory
cp: cannot stat '/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/../..//apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_user_fac/pack/cfg/': No such file or directory
cp: cannot stat '/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/../..//apps/tuyaos-ipc-xm6xxv200-sc117wnz2/xmake-build/out/tyfac': No such file or directory
/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/../..//vendor/xm6xxv200/toolchain/opt/xm_toolchain/arm-xm-linux/usr/bin/arm-xm-linux-strip: 'fac/bin/tyfac': No such file
cp: cannot stat '/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/../..//apps/tuyaos-ipc-xm6xxv200-sc117wnz2/application_components/app_user_fac/pack/tool/xm6xxv200/': No such file or directory
adding: tuya/fac/ (stored 0%)
adding: tuya/fac/bin/ (stored 0%)
adding: tuya/fac/script/ (stored 0%)
adding: tuya/fac/script/ty_wifi_link.sh (deflated 56%)
adding: tuya/fac/script/ty_passwd.sh (deflated 43%)
cp: cannot stat 'fac/cfg/config.ini': No such file or directory
step 4
cp: cannot create regular file '/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/../..//output/bsp/boot.bin': Permission denied
cp: cannot stat 'fw/drv.squashfs.img': No such file or directory
Parse config file
/home/wxj/Documents/tuya/Projects/tuyaos5/software/TuyaOS/apps/tuyaos-ipc-xm6xxv200-sc117wnz2/../..//apps/tuyaos-ipc-xm6xxv200-sc117wnz2/config/driver.config
Select needed kernel drivers
'drivers/ty_driver.ko' -> 'drv_tmp/ty_driver.ko'
'drivers/nvram_kernel_driver.ko' -> 'drv_tmp/nvram_kernel_driver.ko'
local signature
read EC key
writing EC key
./tuya_make_pubkey_bin.sh: 12: Bad substitution
rawstr1 is
./tuya_make_pubkey_bin.sh: 1: Bad substitution
rawstr2 is
rawstr3 is
rawstr4 is
rm raw tuya_verify_pubkey.bin
make ok
Update partitions.json
./build.sh: ./tools/flash_json_update.py: /usr/bin/python: bad interpreter: No such file or directory
Generate nvram image for cfg.bin
cfg: images/default.prop size: 0x10000
nvram_flash_read_zbuf: offs: 0x0, len: 65536
check_res 1
ASUS NVRAM, v0.08. Available space: 65536. Integrity: MTD is empty
encode failed
property_set("persist.ota.pubkey", "" failed
(Loading properties from images/default.prop)
nvram_flash_write_zbuf: offs: 0x10000, len: 65536, header->len 400
nvram_flash_write_zbuf: offs: 0x0, len: 65536, header->len 400
dump content:
[persist.cryptfs.enable]: [1]
[persist.cryptfs.key]: [dcc734ac6ed58f7bbdc8c9253922defc17aaeffb1ff39d7685d3debe166151d6]
[persist.kernel.version]: [0.0.1-beta.4]
[persist.rootfs.version]: [0.0.1-beta.5]
[persist.boot.version]: [0.0.1-beta.4]
[persist.xm6xxv200.version]: [0.0.7]
Generate rootfs and drv images
Parallel mksquashfs: Using 64 processors
Creating 4.0 filesystem on images/rootfs.squashfs.bin, block size 131072.
[==================================================================================================================================-] 71/71 100%
Filesystem size 932.50 Kbytes (0.91 Mbytes)
30.66% of uncompressed filesystem size (3041.31 Kbytes)
Inode table size 1512 bytes (1.48 Kbytes)
16.44% of uncompressed inode table size (9195 bytes)
Directory table size 2318 bytes (2.26 Kbytes)
52.98% of uncompressed directory table size (4375 bytes)
Number of inodes 259
Number of files 60
Number of fragments 13
Number of symbolic links 168
Number of directories 31
Number of uids 1
root (0)
Number of gids 1
root (0)
Creating 4.0 filesystem on images/drv.squashfs.bin, block size 131072.
[==================================================================================================================================|] 42/42 100%
Filesystem size 700.01 Kbytes (0.68 Mbytes)
38.59% of uncompressed filesystem size (1814.05 Kbytes)
Inode table size 434 bytes (0.42 Kbytes)
36.97% of uncompressed inode table size (1174 bytes)
Directory table size 438 bytes (0.43 Kbytes)
73.00% of uncompressed directory table size (600 bytes)
Number of inodes 35
Number of files 32
Number of fragments 4
Number of symbolic links 0
Number of uids 1
root (0)
Number of gids 1
root (0)
Generate rootfs cryptfs
Packing tuya firmware images
get_file_len: 1625048
df7a3fce9e5dbc10915ca4f1a9988cf4323a2db7ff0eaac293d72792cac32bed
get_file_len: 958464
691ef6098c68feda0fee2077c7168a78fb1b01676228b74f444f487fbc43be31
get_file_len: 720896
caabca0a31760c69f4c460e69982a9b4f0b5b5ac383f578a6aad1e5da3184be3
get_file_len: 1998848
76db706ef45b4340c22953ce29a05cae1864d79c39a9ace6af8fe4d7ffdb490b
8c89ca797a57871374cd9fd710f27534959c35594ea01b5f69e366f6dfb96161
tuya_sign_data_local: sum_str 8c89ca797a57871374cd9fd710f27534959c35594ea01b5f69e366f6dfb96161
tuya local sign
[OTA] firmware pack OK.
[get_file_size]: open file boot.bin failed.
fw_size(0) != flash_size(8388608)
pack ota firmware failed.
step 5
Don't pack ci
------ build app(tuyaos-ipc-xm6xxv200-sc117wnz2) end ---------
