Zigbee Locks via Matter in Home Assistant
fangping.guo
I've added your gateway device to a whitelist for upgrading to a new version. You can upgrade it and then verify the doorlock device bridging situation.
RebelMagpie
Re: Zigbee Locks via Matter in Home Assistant
Thank you! I have upgraded the hub device and rebooted. No change in behaviour of the locks. I can unlock them using Matter, but locking them times out after 30 seconds, as it did before.
Do I need to do anything at the lock?
fangping.guo
Could you please unbind and then re-bind the door lock for verification? After that, please send the new device ID and gateway ID. I hope to verify that it has obtained the correct conversion file.
RebelMagpie
Have removed and re-added. No change.
Lock Device ID bfe5eae7f1585756c8lxxg
Gateway ID bf8d9d92318c34b022d6qh
RebelMagpie
Also removed and re-added one of my other locks. Same result.
Device ID bf54c1fb3033c3a86bo843
faustino
RebelMagpie 2025年 Jan 20日 17:09
I have 4 Tuya zigbee locks
All connected to a Zemismart M1 Matter hub, ID: bf8d9d92318c34b022d6qh.
All 4 locks show up in Home Assistant via the Matter integration, and I can see the lock state correctly.
However, only the mortice lock allows me to control the lock from Home Assistant. I can unlock and lock the mortice lock directly from the Matter device entity in Home Assistant.
The 3 deadlocks show their status (locked/unlocked) in Home Assistant, but if I try to control them, they show "Unlocking" (or "Locking") for about a minute before reverting to the original state. Nothing happens at the lock
I would like to be able to control all the locks from within Home Assistant. Are you able to help?
Hi RebelMagpie, may I know if the matter hub has the data of which user unlocks the door? For example admin 1 unlocks the door via the fingerprint. Or user 2 unlocks the door via the fingerprint. This function is available in tuya app, but not sure if its available via matter hub currently
RebelMagpie
Yes, it does. The "Records" tab in the lock entity shows which fingerprint or passcode operated it.
faustino
Wow that's amazing. So basically with this matter hub, even if there is no internet, everything will still be working for 3 of your locks? I am putting an order now
RebelMagpie
Apologies, that's in the Tuya app, not Home Assistant
faustino
Oh, so there is no way for Home Assistant to know which user unlocks the door lock without internet at the moment?
