Devices are not exported to Home Assistant as Matter
JorgeFrancisco
Today I will test the two dimmers that you adjusted.
qiusui
Re: Devices are not exported to Home Assistant as Matter
JorgeFrancisco 2025年 May 28日 20:58
I changed the hub and the sensors continued with the value of 20%, today they appeared with the value of 100%.
Allright, I will try to reduce the battery value by five times.
After receiving the message, please remove the device from the gateway and then configure the rear bridge to matter.
JorgeFrancisco
Hi! You don't need to change anything else, it is already displaying the correct value, which is 100%. You can leave it multiplying by 5.
qiusui
JorgeFrancisco 2025年 May 29日 16:57
I don't quite understand your meaning. When I replied last time, I had already completed the modification.
I suggest that you can retest it and then tell me the latest data situation so that I can make corresponding adjustments.
JorgeFrancisco
Unfortunately, the sensors continue to have the wrong value of 20%, and should have the value of 100%. Could you go back to the adjustment by multiplying the value by 5 again?
JorgeFrancisco
qiusui 2025年 May 29日 17:21
Could you check? Please. Return the change and multiply by 5?
qiusui
JorgeFrancisco 2025年 Jun 4日 08:12
Fine, I will return the change.
Yocee84
Please also check the zigbee fan coil thermostat below to make sure all its values are displayed properly under Home Assistant.
Thermostat (unsupported) (mpbki2zm)
by Tuya
https://vi.aliexpress.com/item/10050056 ... pt=glo2vnm
fangping.guo
I have updated the device files, please try updating the gateway version and test by unbinding the device and then rebinding it. Looking forward to your feedback.
Yocee84
Thank you!
Almost fine, but the fan speed is not selectable.
