Tasmota - 4 relay board
Vamp
I try in internal network. it is a 4 channel relay board, integrated over Matter protocol.
ok now i try external network.
2025.05.27. 06:50 (UTC)
huangxh
Re: Tasmota - 4 relay board
Vamp 2025年 May 27日 14:48
OK, try the external network and send me the ID of the controlled device.thanks
Vamp
ok i do it:
2025.05.27.07:05 (UTC)
Matter bridge iD: bfc6311on1yieb1t
Device ID:bf7ef5a8b731e8f696ryft
In the log, i only see "on" command....
Seems it send the on command (the device recognise it nad turn on) but not report (or tuya not recognise) the on command.
huangxh
Vamp 2025年 May 27日 15:05
ok i do it:
I have observed the situation. At first glance, it seems that the control was successful, but the devicedid not report anything. Could you restart(power off then power on) the Tuya gateway and wait for 5 minutes? Then try to control it again in this way. thanks
Vamp
i restarted the gateway and the matter device also.
and tried it again at 2025.05.27 07:46 (UTC)
(i only able restart the gateway remotelly , i'm not at home right now)
huangxh
Vamp 2025年 May 27日 15:47
We have found the issue; we will fix it and notify you as soon as possible. Thank you for your help.
Vamp
Great thank you!!
huangxh
Pls update the gateway to version 1.13.6, then test it again;thank you.
Vamp
same problem. it not working the off command.
I try to re-add the devive, here the new IDs:
Matter网关兜底(bfa7edab3pq0pvek)
W20-UBEA 3(bf3645c4b0a7c434b7ss1n)
W20-UBEA(bf5eb031155acab38bmy8i)
W20-UBEA 2(bf8cf7c6a172e7b461ledd)
W20-UBEA 4(bfe69dd6a11eb56734mxph)
I try it about 2025.06.06 22:26 (UTC)
huangxh
Vamp 2025年 Jun 7日 06:31
Sorry, the useful log is covered, Could you restart(power off then power on) the Tuya gateway and wait for 5 minutes? Then try to control it again in this way. And tell me as soon as possible.thanks!
