[Bug Report] Dual-Channel Zigbee Drivers Not Controllable or Exposed via Tuya Matter Hub
qigong
Hello!
Around 14:50, only the addition of Google was seen, but no logs of Google controlling the device were observed.
There are a large number of devices in the gateway. To facilitate better troubleshooting, could we only add a few devices, say two?
When there are only a few devices left on the gateway,
  1. Can Google control them?
  2. When controlled by the Tuya APP, does the Google Home app have any response?
fangping.guo
Re: [Bug Report] Dual-Channel Zigbee Drivers Not Controllable or Exposed via Tuya Matter Hub
Got it. We're analyzing it now.
Joshuacjw
To answer to qigong,
  1. I cannot control any via google home if I direct connect to the matter hub, Only Tuya app is working. But connecting via Tuya account in Google home works.
  2. No, there is no response in Google home. It just shows offline. Be it I on/off via Tuya app.
Just to clarify:
  • My Google home has all the devices connected via Tuya cloud account. I am still able to control my devices in Google cloud.
But if I were to connect directly Google home <> matter hub itself all the devices shows offline
I upload some screenshots for more clarity
Update: I just tried with Home Assistant Green. It works fine. But I not sure why Google home shows offline
Google home connected to Tuya Account aka Tuya Cloud. Works
Google home - direct connect to Matter hub all offline
Tuya app - able to control
qigong
We are currently investigating this issue together with Google. If possible, you can use Apple's Matter device HomePod instead of the Google speaker for the test.
fangping.guo
You may now restart the gateway to disable debug logs. Thank you for your patience.
Joshuacjw
Okay! Thank you!
Joshuacjw
Hi fangping.guo,
i have additional devices that i would like to expose as matter:
a3aea7c6dab555ae76e3ik
a32606821a1cfaadc1jk3y
a30516ecb639016a90mpsg
a3c27e9c4df302eec9u7ud
a33cf49a667cdd36e0sucd
a3cbb43757a229f212q4e6
My matter hub id is: a33757912bf7088fc0s55k
Thank you!
fangping.guo
Hello, I have added the conversion files for the devices you listed, except for the vibration sensors (a32606821a1cfaadc1jk3y and a30516ecb639016a90mpsg).
Joshuacjw
Thank you!
Verified.
