Devices are not exported to Home Assistant as Matter
qiusui
Sure! I'll revise it right away.
qiusui
Re: Devices are not exported to Home Assistant as Matter
Have a try.
JorgeFrancisco
I removed and added it, now it shows the battery as zero:
eb4f2edcb011091501x2da
eb55f5d8671bd538024aqr
qiusui
I guess it's due to the power consumption data not being reported. You can trigger it actively or wait for a while to see. I will continue to follow up on your question tomorrow.
qiusui
I've noticed that all your devices are offline. Please keep them online to avoid missing the battery power reporting moment. This logic is determined by the device side. I'm the development engineer of the gateway and I'm not clear about the battery power reporting mechanism of the devices. We can only wait for now.
JorgeFrancisco
The sensors were in hibernation. I removed the batteries, now it shows 100% in API Explorer, but 20% when exported.
qiusui
JorgeFrancisco 2025年 May 27日 21:23
This is so strange. I updated based on the information you provided last time. How come the new data now doesn't match the expectations?
qiusui
Have you followed the previous operation to remove the device from the gateway, reconfigure and bridge it to ensure the configuration takes effect?
JorgeFrancisco
I changed the hub and the sensors continued with the value of 20%, today they appeared with the value of 100%.
JorgeFrancisco
