Incorrect readings from temperature and humidity sensor via Matter
qiusui
Zen2928 2024年 Dec 18日 06:09
The humidity in Google Home and HomeKit is now displayed correctly. It has the same value as in the Tuya app.
Thank you very much for your help.
You're welcome. Have a nice day!
iEnam
Re: Incorrect readings from temperature and humidity sensor via Matter
Great to see issue with the humidity being stuck at 40% is fixed.
Please update support for the device below as it is stuck at 40% humidity in both Home Assistant and Hubitat hubs:
Tuya Temperature and humidity Sensor (Virtual ID: bfb9aac686e0b93ac7rnby)
Thank you
qiusui
iEnam 2024年 Dec 22日 07:34
Thank you
Hi,
Although the exceptions you encountered are not exactly the same, I have updated your device configuration.
To try it out, remove the device and reconfigure it to see if the exception has been resolved.
Looking forward to your next pleasant reply, in the meantime, Merry Christmas Eve & Merry Christmas !
iEnam
@qiusui,
Thank you for your quick reply.
I have removed and re-added device.
See results below for my hubs:
Home Assistant - the humidity value is now correct but out by a factor of 10.
Hubitat - humidity value is still stuck at 40%
qiusui
iEnam 2024年 Dec 27日 09:49
@qiusui,
Hello iEnam,
(1) I can solve the decimal point problem in the Home Assistant right away, but you need to provide the latest device id. Next time I receive your reply, I will update the configuration in time.
(2) Hubitat - humidity value is still stuck at 40% : I think this may not be caused by our anomaly, maybe you can also contact the development engineer of this project.
Have a nice weekend!
iEnam
Great, thank you!
Please see new virtual id: bf60d7e7d062848065prkc
I will talk to the Hubitat dev.
Enjoy your weekend.
qiusui
iEnam 2024年 Dec 28日 07:40
Great, thank you!
Enjoy your weekend.
I've fixed the humidity decimal point problem. Let's try again!
iEnam
qiusui 2024年 Dec 30日 12:01
Great, thank you!
Enjoy your weekend.
I have re-paired the device in Smart Life app (without removing it, this keeps the current ID), and the decimal point problem is now fixed in Home Assistant.
I can also confirm that the correct humidity value is showing in Hubitat and not stuck at 40% anymore (not sure what happened previously) :D
Thank you again!
qiusui
That's really good news. Have fun using it!
And, Happy New Year!
mrtx8x
Hello!
I'm facing the same issue where I have 2 sensors reporting temperature correctly but only reporting 40% humidity in Home Assistant.
Virtual device IDs:
eb86125a927fb38cdbssae
eb9e8c33bf1454f88d5l5o
Hope you can help me fix this.
Best regards
