Fetch with POST gives 'commands param is null'
Discussing technical aspects of Yun development products, including IoT Core and other cloud service APIs, data analysis products, etc.
Marty McFly
I think this might just be syntax related.
I have no problem getting a token and then getting a device response with any GET command.
I am trying a fetch with POST to send a command to a device and I am getting "commands param is null"
Hope this is something simple that someone may be able to help with?
var method2 = "POST";
var timestamp2 = Date.now().toString();
var signUrl2 = '/v1.0/devices/xxxxxxxxxxxxx/commands';
var contentHash2 = CryptoJS.SHA256(signStr2, secretKey);
var stringToSign2 = [method2, contentHash2, '', signUrl2].join('\n');
var signStr2 = ClientID + token + timestamp2 + stringToSign2;
fetch('https://openapi.tuyaus.com//v1.0/devices/xxxxxxxxxxxxx/commands', {
	method: 'POST',
	data: JSON.stringify({
	"commands": [
	"code": "switch_1",
	"value": true
	headers: {
		't': timestamp2,
		'sign_method': 'HMAC-SHA256',
		'Content-Type': 'application/json',
		'client_id': ClientID,
		'sign': await calcSign(signStr2, secretKey),
		'access_token': token
}).then(response => response.json())
	.then((data) => {console.log(data)});
async function calcSign(signStr2, secretKey){
  var hash2 = CryptoJS.HmacSHA256(signStr2, secretKey);
  var hashInBase642 = hash2.toString().toUpperCase();
  return hashInBase642;
Marty McFly
Re: Fetch with POST gives 'commands param is null'
I just tried it a different way and now I get 'sign invalid'
var signUrl2 = '/v1.0/devices/xxxxxxxxxx/commands';
var settings = {
  "url": "https://openapi.tuyaus.com//v1.0/devices/xxxxxxxxxx/commands",
  "method": "POST",
  "timeout": 0,
  "headers": {
    "client_id": ClientID,
    "access_token": token,
    "sign": await calcSign(signStr2, secretKey),
    "t": timestamp2,
    "sign_method": "HMAC-SHA256",
    "Content-Type": "application/json"
  "data": JSON.stringify({
    "commands": [
        "code": "switch_1",
        "value": true
$.ajax(settings).done(function (response) {
  console.log(response);
Marty McFly
I figured it out. A couple of things I was not doing...
The body....
  "commands": [
      "code": "switch_led",
      "value": true
needs to be converted to JSON....
{"commands":[{"code":"switch_led","value":true}]}
and then encrypted with SHA256.
JamesG
Are you able to operate normally now?
Marty McFly
JamesG 2023年 Dec 17日 20:10
Yes James. Thank you very much!
