【已解决】[IPC SDK]IPC_DEMO_5.x 视频流播放问题
Martin
您好!手机端的app没有拉到视频,可以帮看看有什么问题吗?
ipc_test_log.txt
(76.16 KiB) Downloaded 437 times
fallen-queen
Re: [IPC SDK]IPC_DEMO_5.x 视频流播放问题
请问APP上其他控制功能可以用吗,例如移动侦测开关?
Martin
图标是灰色的
fallen-queen
方便截个图吗
Martin
一直显示正在构建加密通道
Martin
请问可能是哪里的问题?
Martin
我重新配网后打印了一份log,可以帮我看看吗?
ipc_test_log_202303071738.txt
(146.65 KiB) Downloaded 410 times
Martin
[03-07 17:43:06 TUYA D][tuya_ring_buffer.c:343] ch0st0tr0 delay too much(seqNo:1656->1943)
[03-07 17:43:06 TUYA D][tuya_ring_buffer.c:348] ch0st0tr0 delay too much:0x7f908b2010 0x7f9098ecc4 0x7f90a92010 0x7f908dfb15 48000
[03-07 17:43:06 TUYA D][tuya_ring_buffer.c:1076] skip to next frame, type(1) node 181 seqNo 1681 ch0st0tr0
发现这个,请问是什么意思?
fallen-queen
看着像是网络不太好,可以尝试一下ping百度,看一下延迟。
另外,音频通道,似乎没有塞数据
Martin
ping baidu.com
PING baidu.com (110.242.68.66) 56(84) bytes of data.
64 bytes from 110.242.68.66 (110.242.68.66): icmp_seq=1 ttl=49 time=41.2 ms
64 bytes from 110.242.68.66 (110.242.68.66): icmp_seq=2 ttl=49 time=41.3 ms
64 bytes from 110.242.68.66 (110.242.68.66): icmp_seq=3 ttl=49 time=42.0 ms
64 bytes from 110.242.68.66 (110.242.68.66): icmp_seq=4 ttl=49 time=41.0 ms
64 bytes from 110.242.68.66 (110.242.68.66): icmp_seq=5 ttl=49 time=40.9 ms
64 bytes from 110.242.68.66 (110.242.68.66): icmp_seq=6 ttl=49 time=41.3 ms
64 bytes from 110.242.68.66 (110.242.68.66): icmp_seq=7 ttl=49 time=40.9 ms
64 bytes from 110.242.68.66 (110.242.68.66): icmp_seq=8 ttl=49 time=40.5 ms
64 bytes from 110.242.68.66 (110.242.68.66): icmp_seq=9 ttl=49 time=40.8 ms
64 bytes from 110.242.68.66 (110.242.68.66): icmp_seq=10 ttl=49 time=40.5 ms
64 bytes from 110.242.68.66 (110.242.68.66): icmp_seq=11 ttl=49 time=42.1 ms
64 bytes from 110.242.68.66 (110.242.68.66): icmp_seq=12 ttl=49 time=41.7 ms
64 bytes from 110.242.68.66 (110.242.68.66): icmp_seq=13 ttl=49 time=40.7 ms
64 bytes from 110.242.68.66 (110.242.68.66): icmp_seq=14 ttl=49 time=41.0 ms
C
--- baidu.com ping statistics ---
14 packets transmitted, 14 received, 0% packet loss, time 13021ms
rtt min/avg/max/mdev = 40.484/41.138/42.119/0.498 ms
ping百度结果这样可以吗
