Inquiry: Temperature decimals, reporting threshold and model names on Avatto Gateway
Zigbee device Development
Carvin
Hello,
I have recently started using an Avatto GW60T-Wired-S gateway and connected 3 Tuya Zigbee thermometers to it. I noticed a few minor issues regarding how the data is handled, and I would like to kindly ask if it is possible to look into the product profiles or DPID mapping for these devices.
Here are the details of what I observed:
Temperature decimals in UI: Currently, the Tuya/Smart Life app only displays whole Celsius numbers (e.g., 22°C instead of 22.4°C). Could you check if the decimal display can be enabled for these models?
Reporting threshold: The gateway currently registers a new temperature update only when it changes by a full 1°C. Since the hardware natively supports reporting at 0.2°C steps, is it possible to adjust the reporting threshold so the app receives updates more frequently? (Under Home Assistant with Zigbee2MQTT, it is clearly visible that the thermometers are capable of handling this and they report in 0.2°C increments.)
Model identification: I noticed that the app displays the wrong model names for some sensors. For example, my TH03 sensor is recognized and displayed as TH01. Could this product profile be updated to show the correct model?
I would highly appreciate it if you could check if these configurations can be adjusted on the cloud/gateway side. The devices are currently online, and here are their details:
Device 1 - TH03:
Tuya Device name my Tuya app: TH03
Tuya Device ID: bf1a360e41abb1fcc7bdym
The following data is from the Zigbee2MQTT system:
EndDevice
IEEE: 0xa4c138d4056f5cdb
Organizationally Unique Identifier
(IEEE Vendor Prefix)OUI: Telink Semiconductor (Taipei) Co. Ltd.
Hálózati cím
0xBECE
Hálózati cím (dec): 48846
Zigbee modell
TH01
Zbeacon
Def (Zigbee2MQTT)
TH01
Temperature and humidity sensor
Zbeacon
Firmware ID
0122052017
MQTT
zigbee2mqtt/0xa4c138d4056f5cdb
Device 2 - TH03Z (?):
Tuya Device name my Tuya app: TH03Z
Tuya Device ID: bfb0f32676f24f8ecb0vzk
EndDevice
IEEE: 0xa4c138c746e159b2
Zigbee modell
ZG-227Z
HOBEIAN
Def (Zigbee2MQTT)
ZG-227Z
Temperature & humidity sensor
HOBEIAN
Firmware ID
0131032026
31032026
MQTT
zigbee2mqtt/0xa4c138c746e159b2
Device 3 - TH01 (?):
Tuya Device name my Tuya app: TH01
Tuya Device ID: bf09420aa8337fa559q93f
EndDevice
IEEE: 0xa4c13894ac17a798
Zigbee modell
TH01
Zbeacon
Def (Zigbee2MQTT)
TH01
Zbeacon
Firmware ID
0122052017
MQTT
zigbee2mqtt/0xa4c13894ac17a798
Thank you very much for your time and help!
Carvin
Re: Inquiry: Temperature decimals, reporting threshold and model names on Avatto Gateway
I would like to ask if there is any chance for these thermometers to display decimal places, meaning is it possible for the developers to modify this?
Of course, I completely understand if it is not possible or if there is no time for this. I would just like to ask for a reply on whether it is worth waiting, or if I should go ahead and buy new devices and throw these roughly 8 thermometers away. I wanted to use them to control my air conditioners.
Thank you in advance for your reply!
Carvin
Unfortunately, it seems this won't be feasible. Could you please let me know if it is worth waiting for?
If possible, please just let me know whether my request can be resolved at some point or not.
If it cannot be resolved, I will disconnect the devices, as keeping them running like this unfortunately makes no sense.
