DEMO_PATH: apps/tuyaos_demo_beacon_remoter
DEMO_NAME: tuyaos_demo_beacon_remoter
DEMO_FIRMWARE_VERSION: 1.0.0
BOARD_NAME: phy6230_adv
SUPPORT_BOARDS: []
BUILD_COMMAND: build
build-pre...
windows
SYN app TEMPLATE------------------------
Compare Some Files With Template:
['.gitignore', 'build_app.py', 'build_app.sh', 'ci_autobuild.sh', 'ci_autopack.sh', 'gitx.sh', 'prepare.sh']
-> [Y] .gitignore is same
-> [Y] build_app.py is same
-> [Y] build_app.sh is same
-> [Y] ci_autobuild.sh is same
-> [Y] ci_autopack.sh is same
-> [Y] gitx.sh is same
-> [Y] prepare.sh is same
Change URL:------------------------
find macro define [Yes]: ['#define', 'ENABLE_WAKEUP', '1']
MY KCONFIG------------------------
INPUT:
project_path: ./
app_path: apps/tuyaos_demo_beacon_remoter
auto: 1
> Check ./apps/tuyaos_demo_beacon_remoter/tuya_iot.config exists
> Copy ./apps/tuyaos_demo_beacon_remoter/tuya_iot.config To ./build/tuya_iot.config
> Create HEAD_FILE = ./apps/tuyaos_demo_beacon_remoter/app_config.hINPUT:
project_path: C:/Users/Lingke/Documents/tuya/Projects/PHY6230_TuyaOS-3.9.5/software/TuyaOS
vendor_name: phy6230_adv
output_path: _output
firmware_name: tuyaos_demo_beacon_remoter
firmware_version: 1.0.0
CREATE:
-> apps/apps/tuyaos_demo_beacon_remoter
找不到文件 - "*.cpp"
-> components
-> tal_sdk_test
-> tal_xfifo
-> app libs
-> libs
-> include
-> adapter
-> vendor/phy6230_adv/tkl
-> drivers
-> system
-> utilities
-> bluetooth
-> zigbee
-> security
-> include
-> output
-> vendor/phy6230_adv/sdk
-> tool
WRITE TO FILE...
build...
windows
./project.json
MAKE
clean .log
copy json_file to .log
#1. fill the output dict
#2. fill the cmd dict
#3. fill flash cmd dict
#4. fill the src dict
#5. get var map
AFTER MAKE CALL VENDOR PYTHON SCRIPTS...
BUILD
[cmd]:cdk-make.exe --workspace="Demo.cdkws" --command="clean" --project="Demo" --config="BuildSet"
----------Cleaning project:[ Demo - BuildSet ]----------[cmd]:cdk-make.exe --workspace="Demo.cdkws" --command="build" --project="Demo" --config="BuildSet"
----------Building project:[ Demo - BuildSet ]----------
make[1]: Entering directory 'C:/Users/Lingke/Documents/tuya/Projects/PHY6230_TuyaOS-3.9.5/software/TuyaOS/.log'
csky-elfabiv2-gcc -mcpu=ck802 -D_PHY_DEBUG -DSERV_GGS=0 -DSERV_GATT_SERV=0 -DSERV_DEV_INFO=0 -DPHY_MCU_TYPE=MCU_BUMBEE_CK802 -DOSAL_CBTIMER_NUM_TASKS=1 -DHCI_TL_NONE=1 -DOSALMEM_METRICS=0 -D_DEF_DEBUG_INFO=0 -DCFG_WDT_ENABLE=1 -DCFG_SLEEP_MODE=PWR_MODE_SLEEP -DUSE_ROMSYM_ALIAS=1 -DHOST_CONFIG=4 -Os -g3 -Wall -ffunction-sections -Wno-unused-but-set-variable -Wno-unused-function -Wno-unused-variable -ffunction-sections -ffunction-sections -fdata-sections -DADV_NCONN_CFG=0x01 -DADV_CONN_CFG=0x02 -DSCAN_CFG=0x04 -DINIT_CFG=0x08 -DBROADCASTER_CFG=0x01 -DOBSERVER_CFG=0x02 -DPERIPHERAL_CFG=0x04 -DCENTRAL_CFG=0x08 -pipe -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dfl -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/host -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dwc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/controller -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/pwm_light -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/ctrap -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/secure -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver_rom/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/ck802 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/interface/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/crc16 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/misc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/hci -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/osal/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/register -I../vendor/phy6230_adv/tuyaos/include -I../vendor/phy6230_adv/tuyaos/bluetooth -I../include/vendor/adapter/system/include -I../include/components/tal_beacon_remoter2/include -I../include/vendor/adapter/spi/include -I../include/vendor/adapter/pwm/include -I../include/components/tal_xxtea/include -I../include/vendor/adapter/watchdog/include -I../include/vendor/adapter/utilities/include -I../include/base/include -I../include/vendor/adapter/uart/include -I../include/vendor/adapter/flash/include -I../include/vendor/adapter/rtc/include -I../include/vendor/adapter/i2c/include -I../include/vendor/adapter/security/include -I../include/vendor/adapter/bluetooth/include -I../include/vendor/adapter/timer/include -I../include/vendor/adapter/adc/include -I../include/vendor/adapter/gpio/include -I../include/vendor/adapter/wakeup/include -I../components/tal_xfifo/include -I../components/tal_sdk_test/include -I../apps/tuyaos_demo_beacon_remoter/include -E -o Lst/drivers_tkl_adc.i ../vendor/phy6230_adv/tuyaos/drivers/tkl_adc.c
csky-elfabiv2-gcc -mcpu=ck802 -D_PHY_DEBUG -DSERV_GGS=0 -DSERV_GATT_SERV=0 -DSERV_DEV_INFO=0 -DPHY_MCU_TYPE=MCU_BUMBEE_CK802 -DOSAL_CBTIMER_NUM_TASKS=1 -DHCI_TL_NONE=1 -DOSALMEM_METRICS=0 -D_DEF_DEBUG_INFO=0 -DCFG_WDT_ENABLE=1 -DCFG_SLEEP_MODE=PWR_MODE_SLEEP -DUSE_ROMSYM_ALIAS=1 -DHOST_CONFIG=4 -Os -g3 -Wall -ffunction-sections -Wno-unused-but-set-variable -Wno-unused-function -Wno-unused-variable -ffunction-sections -ffunction-sections -fdata-sections -DADV_NCONN_CFG=0x01 -DADV_CONN_CFG=0x02 -DSCAN_CFG=0x04 -DINIT_CFG=0x08 -DBROADCASTER_CFG=0x01 -DOBSERVER_CFG=0x02 -DPERIPHERAL_CFG=0x04 -DCENTRAL_CFG=0x08 -pipe -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dfl -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/host -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dwc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/controller -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/pwm_light -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/ctrap -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/secure -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver_rom/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/ck802 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/interface/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/crc16 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/misc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/hci -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/osal/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/register -I../vendor/phy6230_adv/tuyaos/include -I../vendor/phy6230_adv/tuyaos/bluetooth -I../include/vendor/adapter/system/include -I../include/components/tal_beacon_remoter2/include -I../include/vendor/adapter/spi/include -I../include/vendor/adapter/pwm/include -I../include/components/tal_xxtea/include -I../include/vendor/adapter/watchdog/include -I../include/vendor/adapter/utilities/include -I../include/base/include -I../include/vendor/adapter/uart/include -I../include/vendor/adapter/flash/include -I../include/vendor/adapter/rtc/include -I../include/vendor/adapter/i2c/include -I../include/vendor/adapter/security/include -I../include/vendor/adapter/bluetooth/include -I../include/vendor/adapter/timer/include -I../include/vendor/adapter/adc/include -I../include/vendor/adapter/gpio/include -I../include/vendor/adapter/wakeup/include -I../components/tal_xfifo/include -I../components/tal_sdk_test/include -I../apps/tuyaos_demo_beacon_remoter/include -E -o Lst/drivers_tkl_flash.i ../vendor/phy6230_adv/tuyaos/drivers/tkl_flash.c
csky-elfabiv2-gcc -mcpu=ck802 -D_PHY_DEBUG -DSERV_GGS=0 -DSERV_GATT_SERV=0 -DSERV_DEV_INFO=0 -DPHY_MCU_TYPE=MCU_BUMBEE_CK802 -DOSAL_CBTIMER_NUM_TASKS=1 -DHCI_TL_NONE=1 -DOSALMEM_METRICS=0 -D_DEF_DEBUG_INFO=0 -DCFG_WDT_ENABLE=1 -DCFG_SLEEP_MODE=PWR_MODE_SLEEP -DUSE_ROMSYM_ALIAS=1 -DHOST_CONFIG=4 -Os -g3 -Wall -ffunction-sections -Wno-unused-but-set-variable -Wno-unused-function -Wno-unused-variable -ffunction-sections -ffunction-sections -fdata-sections -DADV_NCONN_CFG=0x01 -DADV_CONN_CFG=0x02 -DSCAN_CFG=0x04 -DINIT_CFG=0x08 -DBROADCASTER_CFG=0x01 -DOBSERVER_CFG=0x02 -DPERIPHERAL_CFG=0x04 -DCENTRAL_CFG=0x08 -pipe -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dfl -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/host -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dwc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/controller -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/pwm_light -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/ctrap -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/secure -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver_rom/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/ck802 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/interface/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/crc16 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/misc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/hci -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/osal/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/register -I../vendor/phy6230_adv/tuyaos/include -I../vendor/phy6230_adv/tuyaos/bluetooth -I../include/vendor/adapter/system/include -I../include/components/tal_beacon_remoter2/include -I../include/vendor/adapter/spi/include -I../include/vendor/adapter/pwm/include -I../include/components/tal_xxtea/include -I../include/vendor/adapter/watchdog/include -I../include/vendor/adapter/utilities/include -I../include/base/include -I../include/vendor/adapter/uart/include -I../include/vendor/adapter/flash/include -I../include/vendor/adapter/rtc/include -I../include/vendor/adapter/i2c/include -I../include/vendor/adapter/security/include -I../include/vendor/adapter/bluetooth/include -I../include/vendor/adapter/timer/include -I../include/vendor/adapter/adc/include -I../include/vendor/adapter/gpio/include -I../include/vendor/adapter/wakeup/include -I../components/tal_xfifo/include -I../components/tal_sdk_test/include -I../apps/tuyaos_demo_beacon_remoter/include -E -o Lst/drivers_tkl_gpio.i ../vendor/phy6230_adv/tuyaos/drivers/tkl_gpio.c
csky-elfabiv2-gcc -mcpu=ck802 -D_PHY_DEBUG -DSERV_GGS=0 -DSERV_GATT_SERV=0 -DSERV_DEV_INFO=0 -DPHY_MCU_TYPE=MCU_BUMBEE_CK802 -DOSAL_CBTIMER_NUM_TASKS=1 -DHCI_TL_NONE=1 -DOSALMEM_METRICS=0 -D_DEF_DEBUG_INFO=0 -DCFG_WDT_ENABLE=1 -DCFG_SLEEP_MODE=PWR_MODE_SLEEP -DUSE_ROMSYM_ALIAS=1 -DHOST_CONFIG=4 -Os -g3 -Wall -ffunction-sections -Wno-unused-but-set-variable -Wno-unused-function -Wno-unused-variable -ffunction-sections -ffunction-sections -fdata-sections -DADV_NCONN_CFG=0x01 -DADV_CONN_CFG=0x02 -DSCAN_CFG=0x04 -DINIT_CFG=0x08 -DBROADCASTER_CFG=0x01 -DOBSERVER_CFG=0x02 -DPERIPHERAL_CFG=0x04 -DCENTRAL_CFG=0x08 -pipe -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dfl -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/host -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dwc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/controller -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/pwm_light -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/ctrap -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/secure -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver_rom/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/ck802 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/interface/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/crc16 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/misc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/hci -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/osal/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/register -I../vendor/phy6230_adv/tuyaos/include -I../vendor/phy6230_adv/tuyaos/bluetooth -I../include/vendor/adapter/system/include -I../include/components/tal_beacon_remoter2/include -I../include/vendor/adapter/spi/include -I../include/vendor/adapter/pwm/include -I../include/components/tal_xxtea/include -I../include/vendor/adapter/watchdog/include -I../include/vendor/adapter/utilities/include -I../include/base/include -I../include/vendor/adapter/uart/include -I../include/vendor/adapter/flash/include -I../include/vendor/adapter/rtc/include -I../include/vendor/adapter/i2c/include -I../include/vendor/adapter/security/include -I../include/vendor/adapter/bluetooth/include -I../include/vendor/adapter/timer/include -I../include/vendor/adapter/adc/include -I../include/vendor/adapter/gpio/include -I../include/vendor/adapter/wakeup/include -I../components/tal_xfifo/include -I../components/tal_sdk_test/include -I../apps/tuyaos_demo_beacon_remoter/include -E -o Lst/drivers_tkl_pwm.i ../vendor/phy6230_adv/tuyaos/drivers/tkl_pwm.c
csky-elfabiv2-gcc -mcpu=ck802 -D_PHY_DEBUG -DSERV_GGS=0 -DSERV_GATT_SERV=0 -DSERV_DEV_INFO=0 -DPHY_MCU_TYPE=MCU_BUMBEE_CK802 -DOSAL_CBTIMER_NUM_TASKS=1 -DHCI_TL_NONE=1 -DOSALMEM_METRICS=0 -D_DEF_DEBUG_INFO=0 -DCFG_WDT_ENABLE=1 -DCFG_SLEEP_MODE=PWR_MODE_SLEEP -DUSE_ROMSYM_ALIAS=1 -DHOST_CONFIG=4 -Os -g3 -Wall -ffunction-sections -Wno-unused-but-set-variable -Wno-unused-function -Wno-unused-variable -ffunction-sections -ffunction-sections -fdata-sections -DADV_NCONN_CFG=0x01 -DADV_CONN_CFG=0x02 -DSCAN_CFG=0x04 -DINIT_CFG=0x08 -DBROADCASTER_CFG=0x01 -DOBSERVER_CFG=0x02 -DPERIPHERAL_CFG=0x04 -DCENTRAL_CFG=0x08 -pipe -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dfl -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/host -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dwc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/controller -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/pwm_light -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/ctrap -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/secure -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver_rom/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/ck802 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/interface/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/crc16 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/misc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/hci -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/osal/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/register -I../vendor/phy6230_adv/tuyaos/include -I../vendor/phy6230_adv/tuyaos/bluetooth -I../include/vendor/adapter/system/include -I../include/components/tal_beacon_remoter2/include -I../include/vendor/adapter/spi/include -I../include/vendor/adapter/pwm/include -I../include/components/tal_xxtea/include -I../include/vendor/adapter/watchdog/include -I../include/vendor/adapter/utilities/include -I../include/base/include -I../include/vendor/adapter/uart/include -I../include/vendor/adapter/flash/include -I../include/vendor/adapter/rtc/include -I../include/vendor/adapter/i2c/include -I../include/vendor/adapter/security/include -I../include/vendor/adapter/bluetooth/include -I../include/vendor/adapter/timer/include -I../include/vendor/adapter/adc/include -I../include/vendor/adapter/gpio/include -I../include/vendor/adapter/wakeup/include -I../components/tal_xfifo/include -I../components/tal_sdk_test/include -I../apps/tuyaos_demo_beacon_remoter/include -E -o Lst/drivers_tkl_spi.i ../vendor/phy6230_adv/tuyaos/drivers/tkl_spi.c
csky-elfabiv2-gcc -mcpu=ck802 -D_PHY_DEBUG -DSERV_GGS=0 -DSERV_GATT_SERV=0 -DSERV_DEV_INFO=0 -DPHY_MCU_TYPE=MCU_BUMBEE_CK802 -DOSAL_CBTIMER_NUM_TASKS=1 -DHCI_TL_NONE=1 -DOSALMEM_METRICS=0 -D_DEF_DEBUG_INFO=0 -DCFG_WDT_ENABLE=1 -DCFG_SLEEP_MODE=PWR_MODE_SLEEP -DUSE_ROMSYM_ALIAS=1 -DHOST_CONFIG=4 -Os -g3 -Wall -ffunction-sections -Wno-unused-but-set-variable -Wno-unused-function -Wno-unused-variable -ffunction-sections -ffunction-sections -fdata-sections -DADV_NCONN_CFG=0x01 -DADV_CONN_CFG=0x02 -DSCAN_CFG=0x04 -DINIT_CFG=0x08 -DBROADCASTER_CFG=0x01 -DOBSERVER_CFG=0x02 -DPERIPHERAL_CFG=0x04 -DCENTRAL_CFG=0x08 -pipe -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dfl -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/host -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dwc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/controller -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/pwm_light -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/ctrap -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/secure -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver_rom/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/ck802 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/interface/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/crc16 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/misc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/hci -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/osal/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/register -I../vendor/phy6230_adv/tuyaos/include -I../vendor/phy6230_adv/tuyaos/bluetooth -I../include/vendor/adapter/system/include -I../include/components/tal_beacon_remoter2/include -I../include/vendor/adapter/spi/include -I../include/vendor/adapter/pwm/include -I../include/components/tal_xxtea/include -I../include/vendor/adapter/watchdog/include -I../include/vendor/adapter/utilities/include -I../include/base/include -I../include/vendor/adapter/uart/include -I../include/vendor/adapter/flash/include -I../include/vendor/adapter/rtc/include -I../include/vendor/adapter/i2c/include -I../include/vendor/adapter/security/include -I../include/vendor/adapter/bluetooth/include -I../include/vendor/adapter/timer/include -I../include/vendor/adapter/adc/include -I../include/vendor/adapter/gpio/include -I../include/vendor/adapter/wakeup/include -I../components/tal_xfifo/include -I../components/tal_sdk_test/include -I../apps/tuyaos_demo_beacon_remoter/include -E -o Lst/drivers_tkl_uart.i ../vendor/phy6230_adv/tuyaos/drivers/tkl_uart.c
csky-elfabiv2-gcc -mcpu=ck802 -D_PHY_DEBUG -DSERV_GGS=0 -DSERV_GATT_SERV=0 -DSERV_DEV_INFO=0 -DPHY_MCU_TYPE=MCU_BUMBEE_CK802 -DOSAL_CBTIMER_NUM_TASKS=1 -DHCI_TL_NONE=1 -DOSALMEM_METRICS=0 -D_DEF_DEBUG_INFO=0 -DCFG_WDT_ENABLE=1 -DCFG_SLEEP_MODE=PWR_MODE_SLEEP -DUSE_ROMSYM_ALIAS=1 -DHOST_CONFIG=4 -Os -g3 -Wall -ffunction-sections -Wno-unused-but-set-variable -Wno-unused-function -Wno-unused-variable -ffunction-sections -ffunction-sections -fdata-sections -DADV_NCONN_CFG=0x01 -DADV_CONN_CFG=0x02 -DSCAN_CFG=0x04 -DINIT_CFG=0x08 -DBROADCASTER_CFG=0x01 -DOBSERVER_CFG=0x02 -DPERIPHERAL_CFG=0x04 -DCENTRAL_CFG=0x08 -pipe -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dfl -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/host -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dwc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/controller -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/pwm_light -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/ctrap -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/secure -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver_rom/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/ck802 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/interface/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/crc16 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/misc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/hci -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/osal/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/register -I../vendor/phy6230_adv/tuyaos/include -I../vendor/phy6230_adv/tuyaos/bluetooth -I../include/vendor/adapter/system/include -I../include/components/tal_beacon_remoter2/include -I../include/vendor/adapter/spi/include -I../include/vendor/adapter/pwm/include -I../include/components/tal_xxtea/include -I../include/vendor/adapter/watchdog/include -I../include/vendor/adapter/utilities/include -I../include/base/include -I../include/vendor/adapter/uart/include -I../include/vendor/adapter/flash/include -I../include/vendor/adapter/rtc/include -I../include/vendor/adapter/i2c/include -I../include/vendor/adapter/security/include -I../include/vendor/adapter/bluetooth/include -I../include/vendor/adapter/timer/include -I../include/vendor/adapter/adc/include -I../include/vendor/adapter/gpio/include -I../include/vendor/adapter/wakeup/include -I../components/tal_xfifo/include -I../components/tal_sdk_test/include -I../apps/tuyaos_demo_beacon_remoter/include -E -o Lst/drivers_tkl_watchdog.i ../vendor/phy6230_adv/tuyaos/drivers/tkl_watchdog.c
csky-elfabiv2-gcc -mcpu=ck802 -D_PHY_DEBUG -DSERV_GGS=0 -DSERV_GATT_SERV=0 -DSERV_DEV_INFO=0 -DPHY_MCU_TYPE=MCU_BUMBEE_CK802 -DOSAL_CBTIMER_NUM_TASKS=1 -DHCI_TL_NONE=1 -DOSALMEM_METRICS=0 -D_DEF_DEBUG_INFO=0 -DCFG_WDT_ENABLE=1 -DCFG_SLEEP_MODE=PWR_MODE_SLEEP -DUSE_ROMSYM_ALIAS=1 -DHOST_CONFIG=4 -Os -g3 -Wall -ffunction-sections -Wno-unused-but-set-variable -Wno-unused-function -Wno-unused-variable -ffunction-sections -ffunction-sections -fdata-sections -DADV_NCONN_CFG=0x01 -DADV_CONN_CFG=0x02 -DSCAN_CFG=0x04 -DINIT_CFG=0x08 -DBROADCASTER_CFG=0x01 -DOBSERVER_CFG=0x02 -DPERIPHERAL_CFG=0x04 -DCENTRAL_CFG=0x08 -pipe -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dfl -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/host -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dwc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/controller -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/pwm_light -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/ctrap -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/secure -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver_rom/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/ck802 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/interface/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/crc16 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/misc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/hci -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/osal/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/register -I../vendor/phy6230_adv/tuyaos/include -I../vendor/phy6230_adv/tuyaos/bluetooth -I../include/vendor/adapter/system/include -I../include/components/tal_beacon_remoter2/include -I../include/vendor/adapter/spi/include -I../include/vendor/adapter/pwm/include -I../include/components/tal_xxtea/include -I../include/vendor/adapter/watchdog/include -I../include/vendor/adapter/utilities/include -I../include/base/include -I../include/vendor/adapter/uart/include -I../include/vendor/adapter/flash/include -I../include/vendor/adapter/rtc/include -I../include/vendor/adapter/i2c/include -I../include/vendor/adapter/security/include -I../include/vendor/adapter/bluetooth/include -I../include/vendor/adapter/timer/include -I../include/vendor/adapter/adc/include -I../include/vendor/adapter/gpio/include -I../include/vendor/adapter/wakeup/include -I../components/tal_xfifo/include -I../components/tal_sdk_test/include -I../apps/tuyaos_demo_beacon_remoter/include -E -o Lst/bluetooth_tkl_beacon.i ../vendor/phy6230_adv/tuyaos/bluetooth/tkl_beacon.c
csky-elfabiv2-gcc -mcpu=ck802 -D_PHY_DEBUG -DSERV_GGS=0 -DSERV_GATT_SERV=0 -DSERV_DEV_INFO=0 -DPHY_MCU_TYPE=MCU_BUMBEE_CK802 -DOSAL_CBTIMER_NUM_TASKS=1 -DHCI_TL_NONE=1 -DOSALMEM_METRICS=0 -D_DEF_DEBUG_INFO=0 -DCFG_WDT_ENABLE=1 -DCFG_SLEEP_MODE=PWR_MODE_SLEEP -DUSE_ROMSYM_ALIAS=1 -DHOST_CONFIG=4 -Os -g3 -Wall -ffunction-sections -Wno-unused-but-set-variable -Wno-unused-function -Wno-unused-variable -ffunction-sections -ffunction-sections -fdata-sections -DADV_NCONN_CFG=0x01 -DADV_CONN_CFG=0x02 -DSCAN_CFG=0x04 -DINIT_CFG=0x08 -DBROADCASTER_CFG=0x01 -DOBSERVER_CFG=0x02 -DPERIPHERAL_CFG=0x04 -DCENTRAL_CFG=0x08 -pipe -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dfl -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/host -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dwc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/controller -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/pwm_light -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/ctrap -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/secure -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver_rom/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/ck802 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/interface/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/crc16 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/misc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/hci -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/osal/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/register -I../vendor/phy6230_adv/tuyaos/include -I../vendor/phy6230_adv/tuyaos/bluetooth -I../include/vendor/adapter/system/include -I../include/components/tal_beacon_remoter2/include -I../include/vendor/adapter/spi/include -I../include/vendor/adapter/pwm/include -I../include/components/tal_xxtea/include -I../include/vendor/adapter/watchdog/include -I../include/vendor/adapter/utilities/include -I../include/base/include -I../include/vendor/adapter/uart/include -I../include/vendor/adapter/flash/include -I../include/vendor/adapter/rtc/include -I../include/vendor/adapter/i2c/include -I../include/vendor/adapter/security/include -I../include/vendor/adapter/bluetooth/include -I../include/vendor/adapter/timer/include -I../include/vendor/adapter/adc/include -I../include/vendor/adapter/gpio/include -I../include/vendor/adapter/wakeup/include -I../components/tal_xfifo/include -I../components/tal_sdk_test/include -I../apps/tuyaos_demo_beacon_remoter/include -E -o Lst/src_tal_beacon_sdk_test.i ../components/tal_sdk_test/src/tal_beacon_sdk_test.c
csky-elfabiv2-gcc -mcpu=ck802 -D_PHY_DEBUG -DSERV_GGS=0 -DSERV_GATT_SERV=0 -DSERV_DEV_INFO=0 -DPHY_MCU_TYPE=MCU_BUMBEE_CK802 -DOSAL_CBTIMER_NUM_TASKS=1 -DHCI_TL_NONE=1 -DOSALMEM_METRICS=0 -D_DEF_DEBUG_INFO=0 -DCFG_WDT_ENABLE=1 -DCFG_SLEEP_MODE=PWR_MODE_SLEEP -DUSE_ROMSYM_ALIAS=1 -DHOST_CONFIG=4 -Os -g3 -Wall -ffunction-sections -Wno-unused-but-set-variable -Wno-unused-function -Wno-unused-variable -ffunction-sections -ffunction-sections -fdata-sections -DADV_NCONN_CFG=0x01 -DADV_CONN_CFG=0x02 -DSCAN_CFG=0x04 -DINIT_CFG=0x08 -DBROADCASTER_CFG=0x01 -DOBSERVER_CFG=0x02 -DPERIPHERAL_CFG=0x04 -DCENTRAL_CFG=0x08 -pipe -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dfl -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/host -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dwc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/controller -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/pwm_light -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/ctrap -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/secure -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver_rom/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/ck802 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/interface/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/crc16 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/misc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/hci -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/osal/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/register -I../vendor/phy6230_adv/tuyaos/include -I../vendor/phy6230_adv/tuyaos/bluetooth -I../include/vendor/adapter/system/include -I../include/components/tal_beacon_remoter2/include -I../include/vendor/adapter/spi/include -I../include/vendor/adapter/pwm/include -I../include/components/tal_xxtea/include -I../include/vendor/adapter/watchdog/include -I../include/vendor/adapter/utilities/include -I../include/base/include -I../include/vendor/adapter/uart/include -I../include/vendor/adapter/flash/include -I../include/vendor/adapter/rtc/include -I../include/vendor/adapter/i2c/include -I../include/vendor/adapter/security/include -I../include/vendor/adapter/bluetooth/include -I../include/vendor/adapter/timer/include -I../include/vendor/adapter/adc/include -I../include/vendor/adapter/gpio/include -I../include/vendor/adapter/wakeup/include -I../components/tal_xfifo/include -I../components/tal_sdk_test/include -I../apps/tuyaos_demo_beacon_remoter/include -E -o Lst/src_tal_xfifo.i ../components/tal_xfifo/src/tal_xfifo.c
csky-elfabiv2-gcc -mcpu=ck802 -D_PHY_DEBUG -DSERV_GGS=0 -DSERV_GATT_SERV=0 -DSERV_DEV_INFO=0 -DPHY_MCU_TYPE=MCU_BUMBEE_CK802 -DOSAL_CBTIMER_NUM_TASKS=1 -DHCI_TL_NONE=1 -DOSALMEM_METRICS=0 -D_DEF_DEBUG_INFO=0 -DCFG_WDT_ENABLE=1 -DCFG_SLEEP_MODE=PWR_MODE_SLEEP -DUSE_ROMSYM_ALIAS=1 -DHOST_CONFIG=4 -Os -g3 -Wall -ffunction-sections -Wno-unused-but-set-variable -Wno-unused-function -Wno-unused-variable -ffunction-sections -ffunction-sections -fdata-sections -DADV_NCONN_CFG=0x01 -DADV_CONN_CFG=0x02 -DSCAN_CFG=0x04 -DINIT_CFG=0x08 -DBROADCASTER_CFG=0x01 -DOBSERVER_CFG=0x02 -DPERIPHERAL_CFG=0x04 -DCENTRAL_CFG=0x08 -pipe -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dfl -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/host -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dwc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/controller -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/pwm_light -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/ctrap -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/secure -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver_rom/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/ck802 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/interface/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/crc16 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/misc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/hci -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/osal/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/register -I../vendor/phy6230_adv/tuyaos/include -I../vendor/phy6230_adv/tuyaos/bluetooth -I../include/vendor/adapter/system/include -I../include/components/tal_beacon_remoter2/include -I../include/vendor/adapter/spi/include -I../include/vendor/adapter/pwm/include -I../include/components/tal_xxtea/include -I../include/vendor/adapter/watchdog/include -I../include/vendor/adapter/utilities/include -I../include/base/include -I../include/vendor/adapter/uart/include -I../include/vendor/adapter/flash/include -I../include/vendor/adapter/rtc/include -I../include/vendor/adapter/i2c/include -I../include/vendor/adapter/security/include -I../include/vendor/adapter/bluetooth/include -I../include/vendor/adapter/timer/include -I../include/vendor/adapter/adc/include -I../include/vendor/adapter/gpio/include -I../include/vendor/adapter/wakeup/include -I../components/tal_xfifo/include -I../components/tal_sdk_test/include -I../apps/tuyaos_demo_beacon_remoter/include -E -o Lst/source_main.i ../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source/main.c
csky-elfabiv2-gcc -mcpu=ck802 -D_PHY_DEBUG -DSERV_GGS=0 -DSERV_GATT_SERV=0 -DSERV_DEV_INFO=0 -DPHY_MCU_TYPE=MCU_BUMBEE_CK802 -DOSAL_CBTIMER_NUM_TASKS=1 -DHCI_TL_NONE=1 -DOSALMEM_METRICS=0 -D_DEF_DEBUG_INFO=0 -DCFG_WDT_ENABLE=1 -DCFG_SLEEP_MODE=PWR_MODE_SLEEP -DUSE_ROMSYM_ALIAS=1 -DHOST_CONFIG=4 -Os -g3 -Wall -ffunction-sections -Wno-unused-but-set-variable -Wno-unused-function -Wno-unused-variable -ffunction-sections -ffunction-sections -fdata-sections -DADV_NCONN_CFG=0x01 -DADV_CONN_CFG=0x02 -DSCAN_CFG=0x04 -DINIT_CFG=0x08 -DBROADCASTER_CFG=0x01 -DOBSERVER_CFG=0x02 -DPERIPHERAL_CFG=0x04 -DCENTRAL_CFG=0x08 -pipe -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dfl -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/host -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dwc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/controller -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/pwm_light -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/ctrap -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/secure -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver_rom/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/ck802 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/interface/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/crc16 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/misc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/hci -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/osal/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/register -I../vendor/phy6230_adv/tuyaos/include -I../vendor/phy6230_adv/tuyaos/bluetooth -I../include/vendor/adapter/system/include -I../include/components/tal_beacon_remoter2/include -I../include/vendor/adapter/spi/include -I../include/vendor/adapter/pwm/include -I../include/components/tal_xxtea/include -I../include/vendor/adapter/watchdog/include -I../include/vendor/adapter/utilities/include -I../include/base/include -I../include/vendor/adapter/uart/include -I../include/vendor/adapter/flash/include -I../include/vendor/adapter/rtc/include -I../include/vendor/adapter/i2c/include -I../include/vendor/adapter/security/include -I../include/vendor/adapter/bluetooth/include -I../include/vendor/adapter/timer/include -I../include/vendor/adapter/adc/include -I../include/vendor/adapter/gpio/include -I../include/vendor/adapter/wakeup/include -I../components/tal_xfifo/include -I../components/tal_sdk_test/include -I../apps/tuyaos_demo_beacon_remoter/include -E -o Lst/source_phy_plus_phy.i ../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source/phy_plus_phy.c
csky-elfabiv2-gcc -mcpu=ck802 -D_PHY_DEBUG -DSERV_GGS=0 -DSERV_GATT_SERV=0 -DSERV_DEV_INFO=0 -DPHY_MCU_TYPE=MCU_BUMBEE_CK802 -DOSAL_CBTIMER_NUM_TASKS=1 -DHCI_TL_NONE=1 -DOSALMEM_METRICS=0 -D_DEF_DEBUG_INFO=0 -DCFG_WDT_ENABLE=1 -DCFG_SLEEP_MODE=PWR_MODE_SLEEP -DUSE_ROMSYM_ALIAS=1 -DHOST_CONFIG=4 -Os -g3 -Wall -ffunction-sections -Wno-unused-but-set-variable -Wno-unused-function -Wno-unused-variable -ffunction-sections -ffunction-sections -fdata-sections -DADV_NCONN_CFG=0x01 -DADV_CONN_CFG=0x02 -DSCAN_CFG=0x04 -DINIT_CFG=0x08 -DBROADCASTER_CFG=0x01 -DOBSERVER_CFG=0x02 -DPERIPHERAL_CFG=0x04 -DCENTRAL_CFG=0x08 -pipe -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dfl -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/host -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dwc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/controller -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/pwm_light -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/ctrap -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/secure -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver_rom/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/ck802 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/interface/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/crc16 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/misc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/hci -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/osal/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/register -I../vendor/phy6230_adv/tuyaos/include -I../vendor/phy6230_adv/tuyaos/bluetooth -I../include/vendor/adapter/system/include -I../include/components/tal_beacon_remoter2/include -I../include/vendor/adapter/spi/include -I../include/vendor/adapter/pwm/include -I../include/components/tal_xxtea/include -I../include/vendor/adapter/watchdog/include -I../include/vendor/adapter/utilities/include -I../include/base/include -I../include/vendor/adapter/uart/include -I../include/vendor/adapter/flash/include -I../include/vendor/adapter/rtc/include -I../include/vendor/adapter/i2c/include -I../include/vendor/adapter/security/include -I../include/vendor/adapter/bluetooth/include -I../include/vendor/adapter/timer/include -I../include/vendor/adapter/adc/include -I../include/vendor/adapter/gpio/include -I../include/vendor/adapter/wakeup/include -I../components/tal_xfifo/include -I../components/tal_sdk_test/include -I../apps/tuyaos_demo_beacon_remoter/include -E -o Lst/source_OSAL_PhyPlusPhy.i ../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source/OSAL_PhyPlusPhy.c
csky-elfabiv2-gcc -mcpu=ck802 -D_PHY_DEBUG -DSERV_GGS=0 -DSERV_GATT_SERV=0 -DSERV_DEV_INFO=0 -DPHY_MCU_TYPE=MCU_BUMBEE_CK802 -DOSAL_CBTIMER_NUM_TASKS=1 -DHCI_TL_NONE=1 -DOSALMEM_METRICS=0 -D_DEF_DEBUG_INFO=0 -DCFG_WDT_ENABLE=1 -DCFG_SLEEP_MODE=PWR_MODE_SLEEP -DUSE_ROMSYM_ALIAS=1 -DHOST_CONFIG=4 -Os -g3 -Wall -ffunction-sections -Wno-unused-but-set-variable -Wno-unused-function -Wno-unused-variable -ffunction-sections -ffunction-sections -fdata-sections -DADV_NCONN_CFG=0x01 -DADV_CONN_CFG=0x02 -DSCAN_CFG=0x04 -DINIT_CFG=0x08 -DBROADCASTER_CFG=0x01 -DOBSERVER_CFG=0x02 -DPERIPHERAL_CFG=0x04 -DCENTRAL_CFG=0x08 -pipe -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dfl -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/host -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dwc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/controller -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/pwm_light -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/ctrap -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/secure -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver_rom/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/ck802 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/interface/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/crc16 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/misc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/hci -../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source/main.c:32:24: fatal error: app_config.h: No such file or directory
#include "app_config.h"
I../vendor/phy6230_adv/sdk/phy6230c_adv_sdk/components/osal/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/register -I../vendor/phy623o0_adv/tuyaos/include -I../vendor/phmy6230_adv/tuyaos/bluetooth -I../include/vendor/adapter/system/include -I../include/components/tal_beacon_remoter2/include -I../include/vendor/adapter/spi/include -I../include/vendor/adapter/pwm/include -I../include/components/tal_xxtea/include -I../incpliude/vendor/adapter/watchdog/include -I../include/vendor/adapter/utilities/include -I../include/base/incllaude -I../include/vendor/adapter/uart/include -I../include/vendor/adapter/flash/include -I../include/vendor/adapter/rtc/include -I../include/vendor/adapter/i2c/include -I../include/vendor/adapter/securtityi/include -I../include/vendor/adapter/bluetooth/include -I../include/vendor/adapter/timer/include -I../include/vendor/adapter/adc/include -I../include/vendor/adapter/gpio/include -I../include/vendor/adapter/wakeup/include -I../components/tal_xfifo/include -I../components/tal_sdk_test/include -I../apps/tuyaos_odemo_beacon_remoter/include -E -o Lst/source_low_power.i ../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/nsource/low_power.c
terminated.
csky-elfabiv2-gcc -mcpu=ck802 -D_PHY_DEBUG -DSERV_GGS=0 -DSERV_GATT_SERV=0 -DSERV_DEV_INFO=0 -DPHY_MCU_TYPE=MCU_BUMBEE_CK802 -DOSAL_CBTIMER_NUM_TASKS=1 -DHCI_TL_NONE=1 -DOSALMEM_METRICS=0 -D_DEF_DEBUG_INFO_=0 -DCFG_WDT_ENABLE=1 -DCFG_SLEEP_MODE=PWR_MODE_SLEEP -DUSE_ROMSYM_ALIAS=1 -DHOST_CONFIG=4 -Os -g3 -Wall -ffunction-sections -Wno-unused-but-set-variable -Wno-unused-function -Wno-unused-variable -ffunction-sections -ffunction-sections -fdata-sections -DADV_NCONN_CFG=0x01 -DADV_CONN_CFG=0x02 -DSCAN_CFG=0x04 -DINIT_CFG=0x08 -DBROADCASTER_CFG=0x01 -DOBSERVER_CFG=0x02 -DPERIPHERAL_CFG=0x04 -DCENTRAL_CFG=0x08 -pipe -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dfl -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/host -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/dwc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/controller -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/pwm_light -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/ctrap -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/secure -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/profiles/phy_plus_phy -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver/source -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/driver_rom/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/ck802 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/interface/inc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/libraries/crc16 -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/misc -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/ble/hci -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/osal/include -I../vendor/phy6230_adv/sdk/phy6230_adv_sdk/components/arch/register -I../vendor/phy6230_adv/tuyaos/include -I../vendor/phy6230_adv/tuyaos/bluetooth -I../include/vendor/adapter/system/include -I../include/components/tal_beacon_remoter2/include -I../include/vendor/adapter/spi/include -I../include/vendor/adapter/pwm/include -I../include/components/tal_xxtea/include -I../include/vendor/adapter/watchdog/include -I../include/vendor/adapter/utilities/include -I../include/base/include -I../include/vendor/adapter/uart/include -I../include/vendor/adapter/flash/include -I../include/vendor/adapter/rtc/include -I../include/vendor/adapter/i2c/include -I../include/vendor/adapter/security/include -I../include/vendor/adapter/bluetooth/include -I../include/vendor/adapter/timer/include -I../include/vendor/adapter/adc/include -I../include/vendor/adapter/gpio/include -I../include/vendor/adapter/wakeup/include -I../components/tal_xfifo/include -I../components/tal_sdk_test/include -I../apps/tuyaos_demo_beacon_remoter/include -E -o Lst/ck802_board_init.i ck802/board_init.c
Demo.mk:160: recipe for target 'Lst/source_main.i' failed
make[1]: *** [Lst/source_main.i] Error 1
make[1]: *** Waiting for unfinished jobs....
../vendor/phy6230_adv/sdk/phy6230_adv_sdk/example/PhyPlusPhy/snrf_nos/source/low_power.c:20:24: fatal error: app_config.h: No such file or directory
compilation terminated.
Demo.mk:175: recipe for target 'Lst/source_low_power.i' failed
make[1]: *** [Lst/source_low_power.i] Error 1
make[1]: Leaving directory 'C:/Users/Lingke/Documents/tuya/Projects/PHY6230_TuyaOS-3.9.5/software/TuyaOS/.log'
cdkws.mk:9: recipe for target 'Project_Build' failed
make: *** [Project_Build] Error 2[cmd]
:/C-Sky/CDK/CSKY/MinGW/csky-abiv2-elf-toolchain/bin/csky-elfabiv2-objcopy.exe -O binary ./Obj/Demo.elf ./Obj/Demo.bin
系统找不到指定的路径。
MAX Stack Usage:==========================
RES Usage:================================
build end, create final fw...
copy ./.log/Obj/Demo_phy6230.hexo -> UG
build fail
