FIX EXPORT MATTER
Itsmetons
Please, Fix export device matter
The device is a switch with temperature sensor, when I export through the zemismart hub it is recognised as two switches
Brand: Mumubiz
Model: TYZGTH16A-D1RF
Wireless: Zigbee
Input: AC85-250V 50/60Hz
Max.load: 3000W/16A
Working temperatrue: -20°C70°C
Radio Frequency: 433Mhz
fangping.guo
Re: FIX EXPORT MATTER
Hello, please provide the corresponding device IDs for the problematic devices.
Itsmetons
Hi, this is the Device ID eb554c3b0e2f9959aegae6
fangping.guo
Hello, I have already added a bridge file for the device. It should display as a composite device of a thermometer and a hygrometer.
Itsmetons
Great, it worked, it showed up as a thermometer / hygrometer, but it also has a switch. Is it possible to export the switch as well?
fangping.guo
I confirm that the device has been configured as a temperature and humidity sensor and a switch, and its name is "TempHumiSensorSwitch". If it is not properly displaying the switch, could you take a screenshot to show me the Matter ecosystem details? Also, would it be convenient for you to verify it in other Matter ecosystems?
Itsmetons
In SmartThings, only one device appears, which displays the temperature and humidity. However, if I change the driver for this device to a switch, the On/Off functions work normally, but the temperature and humidity readings disappear.
In Google Home, three devices appear: one temperature sensor, one humidity sensor, and one switch, but the On/Off functions don't work.
See the attachments
fangping.guo
Can you provide a new device virtual ID? I want to view the device logs.
