Hello Tuya Team,
I am currently migrating my setup from the Moes Zigbee 3.0 Wired Smart Gateway (firmware v1.18.2 VID: a31376ee48780e85e48qwt) to the Moes Tuya Matter Zigbee Hub (firmware v1.13.10 VID: a33757912bf7088fc0s55k) and I am facing two issues:
Issue 1 – Dual-Channel Drivers Not Working
When I pair a dual-channel driver to the Matter Hub, it is visible in the Tuya app as a sub-device (Switch 1 + Switch 2).
However, ON/OFF/Dimming does not work at all via the Matter hub.
Even if I only use Switch 1, it does not trigger the light to turn on/off.
For now, I have had to move 3 drivers back to the old Zigbee 3.0 hub to restore functionality.
Affected Virtual IDs:
a323320b488ff3a998fu9b
a36576016782e992cdldcx
a3110dbbdab0cdbab7eyvb
Issue 2 – Devices Not Exposed to Matter Controllers
Lights paired to the Matter Hub are not exposed as controllable devices in Google Home/Home Assistant/Apple Home.
Only the Matter hub itself (or some Tuya “scenes”) appear, not the individual lights.
Request
Can you confirm if dual-channel Zigbee light drivers are currently supported in the Tuya Matter Bridge framework?
If not, can this be prioritized for a firmware update?
If logs or additional info (PID, DPID mapping, etc.) are needed, I am happy to provide them.
Thank you for your support
