How to create a Delphi application for Windows
Developer Platform features usage and feedback.
denisdouglas
I'm new to this and have little programming knowledge. I want to create a very simple Windows application in Delphi with just one button to turn a Switch on and off.
So far, I haven't been able to connect the Switch to the controller.
In the example below there are 3 buttons. One to Connect, one to Turn On and one to Turn Off.
unit Unit1;
interface
uses
  Winapi.Windows, Winapi.Messages, System.SysUtils, System.Variants,
  System.Classes, Vcl.Graphics, Vcl.Controls, Vcl.Forms, Vcl.Dialogs,
  Vcl.StdCtrls, System.Net.HttpClient, System.JSON, System.NetEncoding, System.DateUtils;
type
  TForm1 = class(TForm)
    BtnConectar: TButton;
    BtnLigar: TButton;
    BtnDesligar: TButton;
    MemoLog: TMemo;
    procedure BtnConectarClick(Sender: TObject);
    procedure BtnLigarClick(Sender: TObject);
    procedure BtnDesligarClick(Sender: TObject);
  private
    FToken: string;
    function GetAccessToken: string;
    procedure SendCommand(const Code: string; const Value: Variant);
    procedure Log(const Msg: string);
  public
  end;
var
  Form1: TForm1;
const
  ACCESS_ID     = 'My_ACCESS_ID';
  ACCESS_SECRET = 'My_ACCESS_SECRET';
  DEVICE_ID     = 'My_DEVICE_ID';
  API_URL       = 'https://openapi.tuyaus.com';
implementation
{$R *.dfm}
procedure TForm1.Log(const Msg: string);
begin
  MemoLog.Lines.Add(FormatDateTime('hh:nn:ss', Now) + ' - ' + Msg);
end;
function TForm1.GetAccessToken: string;
var
  Client: THTTPClient;
  Response: IHTTPResponse;
  JSONResp: TJSONObject;
  URL: string;
begin
  Result := '';
  Client := THTTPClient.Create;
  try
    URL := API_URL + '/v1.0/token?grant_type=1';
// Atenção: Pode ser necessário implementar assinatura HMAC
Client.CustomHeaders['client_id'] := ACCESS_ID;
Client.CustomHeaders['sign_method'] := 'HMAC-SHA256';
Client.CustomHeaders['t'] := IntToStr(DateTimeToUnix(Now) * 1000);
Response := Client.Get(URL);
if Response.StatusCode = 200 then
begin
  JSONResp := TJSONObject.ParseJSONValue(Response.ContentAsString) as TJSONObject;
  try
    Result := JSONResp.GetValue<TJSONObject>('result').GetValue<string>('access_token');
    Log('Token obtido com sucesso.');
  finally
    JSONResp.Free;
  end;
end
else
  Log('Erro ao obter token: ' + Response.StatusCode.ToString);
  finally
    Client.Free;
  end;
end;
procedure TForm1.SendCommand(const Code: string; const Value: Variant);
var
  Command, Commands: TJSONObject;
  URL: string;
begin
  if FToken = '' then
  begin
    Log('Erro: Token não encontrado. Conecte-se primeiro.');
    Exit;
  end;
  try
    URL := Format('%s/v1.0/devices/%s/commands', [API_URL, DEVICE_ID]);
Command := TJSONObject.Create;
Command.AddPair('code', Code);
if VarIsBool(Value) then
  Command.AddPair('value', TJSONBool.Create(Value))
else
  Command.AddPair('value', TJSONString.Create(VarToStr(Value)));
Commands := TJSONObject.Create;
Commands.AddPair('commands', TJSONArray.Create(Command));
Client.CustomHeaders['Authorization'] := 'Bearer ' + FToken;
Response := Client.Post(URL, TStringStream.Create(Commands.ToJSON, TEncoding.UTF8), nil);
  Log('Comando "' + Code + '" enviado com sucesso.')
else
  Log('Erro ao enviar comando: ' + Response.StatusCode.ToString);
  finally
    Client.Free;
    Commands.Free;
  end;
end;
procedure TForm1.BtnConectarClick(Sender: TObject);
begin
  FToken := GetAccessToken;
end;
procedure TForm1.BtnLigarClick(Sender: TObject);
begin
  SendCommand('switch_1', True);
end;
procedure TForm1.BtnDesligarClick(Sender: TObject);
begin
  SendCommand('switch_1', False);
end;
end.
