【已处理】【中控】中控屏运行时程序崩溃
yez
开发包:NX5_TuyaOS-3.10.10
gdb抓到错误位置为ssl_msg.c:1817
#0 0xb4bcb300 in send () from /lib/libpthread.so.0
#1 0xb65f7562 in mbedtls_ssl_flush_output (ssl=0xb3d84bd0)
at /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/lib_tls/src/mbedtls/ssl_msg.c:1817
#2 0xb65f7820 in mbedtls_ssl_write_record (ssl=ssl@entry=0xb3d84bd0, force_flush=force_flush@entry=1 '\001')
at /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/lib_tls/src/mbedtls/ssl_msg.c:2517
#3 0xb65f79be in ssl_write_real (len=96, buf=0xb3b0ebd8 "2^", ssl=0xb3d84bd0)
---Type <return> to continue, or q <return> to quit---
at /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/lib_tls/src/mbedtls/ssl_msg.c:5375
#4 mbedtls_ssl_write (ssl=ssl@entry=0xb3d84bd0, buf=buf@entry=0xb3b0ebd8 "2^", len=len@entry=96)
at /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/lib_tls/src/mbedtls/ssl_msg.c:5414
#5 0xb6594554 in tuya_tls_write (tls_handler=0xb3d84bd0, buf=0xb3b0ebd8 "2^", len=96)
at /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/svc_tuya_cloud/src/tls/tuya_tls.c:1806
#6 0xb665462c in mqtt_transport_send (socket_info=0xb3d5e778, buf=0xb3b0ebd8, length=96)
at /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/svc_tuya_cloud/src/mqtt/mqtt_client.c:984
#7 0xb669ebd0 in mqtt_pub_msg_with_qos (broker=broker@entry=0xb3d5e778,
topic=topic@entry=0xb67dfbec <s_log_seq_ctx+4> "log/log_seq/6c7578cd8b7482a3a7bvoy",
msg=msg@entry=0xb3d8afb8 "mqtt | 3.10.10 | 07-28 04:05:53 | erc:0 | [9:99 | 50:-1]", m_len=m_len@entry=56,
retain=retain@entry=0 '\000', qos=qos@entry=1 '\001', message_id=338)
at /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/lib_mqtt/src/libemqtt.c:470
#8 0xb66568ea in mqtt_publish_async (hand=0xb3d5e778,
topic=0xb67dfbec <s_log_seq_ctx+4> "log/log_seq/6c7578cd8b7482a3a7bvoy", qos=qos@entry=1 '\001',
data=data@entry=0xb3d8afb8 "mqtt | 3.10.10 | 07-28 04:05:53 | erc:0 | [9:99 | 50:-1]", len=len@entry=56,
to_lmt=to_lmt@entry=6, cb=cb@entry=0xb6596729 <
mqc_custom_async_cb>, prv_data=prv_data@entry=0xb3b14208)
at /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/svc_tuya_cloud/src/mqtt/mqtt_client.c:2037
#9 0xb659814a in mqc_custom_pub_async (data=0xb3d8afb8 "mqtt | 3.10.10 | 07-28 04:05:53 | erc:0 | [9:99 | 50:-1]",
len=56, topic=<optimized out>, qos=<optimized out>, timeout=6, cb=0xb6596729 <__mqc_custom_async_cb>,
prv_data=0xb3b14208)
at /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/svc_tuya_cloud/src/mqtt/mqc_app.c:1499
#10 0xb65981ba in mqc_custom_pub_sync (
data=data@entry=0xb3d8afb8 "mqtt | 3.10.10 | 07-28 04:05:53 | erc:0 | [9:99 | 50:-1]", len=56,
timeout=timeout@entry=6)
at /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/svc_tuya_cloud/src/mqtt/mqc_app.c:1519
#11 0xb6594dd6 in __log_seq_upload_log (p_log=0xb3d8afb8 "mqtt | 3.10.10 | 07-28 04:05:53 | erc:0 | [9:99 | 50:-1]")
at /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/svc_tuya_cloud/src/log_seq/log_seq.c:741
#12 0xb65951a2 in __mid_log_seq_handle_cb (msg=0xb3d8afb8)
at /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/svc_tuya_cloud/src/log_seq/log_seq.c:814
#13 0xb660a8de in __work_thread_cb (data=0xb3d1e6f0)
at /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/tal_system/src/os/tal_workqueue.c:52
#14 0xb6609e72 in __WrapRunFunc (pArg=0xb3d1e760)
at /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/tal_system/src/os/tal_thread.c:205
#15 0xb6521e98 in _tkl_thread_wrap_func () from /data/user/lib/libhome.so
#16 0xb4bc44b8 in start_thread () from /lib/libpthread.so.0
#17 0xb49e942c in ?? () from /lib/libc.so.6
telnet - 涂鸦_2025-07-28_11_41_16.rar
(361.4 KiB) Downloaded 1701 times
luoji
Re: 【求助】【中控】中控屏运行时程序崩溃
已反馈给中台
yez
今天再次出现程序崩溃
Thread 35 "wq_highpri" received signal SIGSEGV, Segmentation fault.
[Switching to LWP 26167]
0xb66bfa22 in lan_cluster_recv_udp_raw_search_msg_rsg (
udp_search_raw_msg_cb=0xb67044d5 <tuya_lan_pro_on_discover_msg>)
at /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/svc_gw_base/src/lan_cluster_node_search.c:206
206 /root/workspace_temp/cde/ci_gw_technology_group/tuyaos-gw-integrated/components/svc_gw_base/src/lan_cluster_node_search.c: No such file or directory.
#0 0xb66bfa22 in lan_cluster_recv_udp_raw_search_msg_rsg (
#1 0xb66f6642 in tuya_lan_dev_list_core_mod_init ()
telnet - 涂鸦_2025-07-30_8_37_11.rar
(27.6 KiB) Downloaded 1662 times
square005
我们排查情况看没有发现异常,怀疑可能被踩内存了,建议可以使用一些工具来做辅助排查,比如内存消毒,valgrind等
