Moes Matter and incorrect sensors reading in Homekit
darkaeden
Actually, something unusual today: the temperature reading is fine but the humidity reading became wrong.
Instead of correct showing 52degrees as in Tuya, it shows 5degrees in Homekit.
Can you please fix?
Thanks!
fangping.guo
Re: Moes Matter and incorrect sensors reading in Homekit
After modifying the configuration file for pid corresponding to ebf916649577f37eb1trkm on July 18, 2025 at 17:24 GMT+8, I did not make any changes.
Can you determine if the humidity display suddenly changed to an error after that, or if the error was there from the beginning but you didn't notice it?
darkaeden
Im not sure, there is no error in Tuya, but:
  • in Tuya the H is 51% (always correct)
  • on the small LCD screen of the sensor is 51% (always correct)
  • in Homekit is 5%
Temperature reading in Tuya, screen and Homekit is OK.
Thanks!
fangping.guo
Understood, I updated the configuration for humidity, please test again, thanks!
darkaeden
It now works, also himidity reading is correct!
Thanks again!
fangping.guo
:D
