Tuya Zigbee Devices not Published on Matter properly
Hollako
Hello,
I recently bougth several Zigbee Devices in order to use them with Zemismart M6 Hub then to publish them on Home Assistant via Matter. However i could add them to Smart Life App but some of them are published to Matter partially (not all the function are added) and some other are not added at all. here is below a list of these devices with their ID:
M8-2: bf71466f5039d799e35wwz (2 Switches can be configured as scenes)
M8-3: bf39c13bcee447de39cxgq (3 Switches can be configured as scenes)
M8-6: bf15d91880a9100adcwoa9 (4 Switches can be configured as scenes and 2 dedicated scenes)
Knob Dimmer: bf435586fadb05500aanzd (2 Switches can be configured as scenes + Knob Dimmer Control)
M8-Pro: bf742d57841a1981ee49dd (4 Switches can be configured as scenes with small LCD)
LCD Panel: bfefe26c24d2610569pona (4 Switches can be configured with Display Screen)
M9-Pro: bfe56a1475b9bc5a43m0rn (4 Switches can be configured as scenes and 4 dedicated scenes)
M9 Keypad: bfc543878bee9f3ee9gljr (4 Switches can be configured as scenes with LCD)
Please some help in order to make these devices work over Matter.
Regards,
huangxh
Re: Tuya Zigbee Devices not Published on Matter properly
Hollako 2025年 Jun 20日 16:07
Hello,
Regards,
Thank you for your feedback. The combined switch for the toggle switch and the scene, since a time can only have one state, only one mapping from the scene or the toggle switch to matter was made. What suggestions do you have?
Some of the devices are custom-developed functions that have not been incorporated into Matter.
thanks.
Hollako
Hello again,
Actually, my main concern is to have the toggle switches published to Matter, scenes are less priority since they will control other toggle switches. so is it possible to publish the devices i mentioned to Matters?
Thank you in advance for the support.
Regards,
Hollako
Hello,
Any updates please? could you these keypad switches to Matter ?
Regards,
huangxh
We are still confirming.because somebody likes the scene function.
Hollako
Dear,
The scene will still working without any issue. You can configure the scene inside the Smart Life App. however, the switch relay are not shown in the at all in Home Assistant.
On the other side, it's not possible to pulish both Switch Relays and Scenes. what is the issues with that ?
Regards.
Hollako
Hi Again,
In addition to my previous email, let me note that the M8 Pro Keypad is working very good with Home Assistant and it's showing both Relays and Scenes via Matter Integration. Here is attached pictures for the the M8 Pro and the integration with Home Assistant via Matter. It's working Good!!
So the other Keypads should be the same, showing both Relays and Scenes.
Regards,
huangxh
Thank you for your feedback. We need to take a few days to check it. Thank you.
Hollako
Hello Dears,
Any updates please regarding the devices mentioned previously?
Thank you in advance.
