This zigbee window motor actuator is not showing the open/close % value in home assistant or SmartThings shared via matter hub. Always 100% state.
MOES Tuya ZigBee-empujador de ventana corredera inteligente, abridor automático, aplicación de carga Solar, Control remoto, compatible con Alexa y Google Home
https://a.aliexpress.com/_EwWJGYm
Zibgee Window motor
Zibgee Window motor
Re: Zibgee Window motor
Sergitovall 2025年 Jun 27日 13:42This zigbee window motor actuator is not showing the open/close % value in home assistant or SmartThings shared via matter hub. Always 100% state.
Please provide the device ID of the gateway. Thanks.
Done! Thabks
