如题:
在幻彩灯带 CBU bk7213n 的SDK里如何增加红外解码功能,有没有demo呢?思路是怎么样的?1.用过定时器,发现解码不灵敏.2.用GPIO中断+定时器,还是不灵敏。
Re: 在幻彩灯带 CBU bk7213n 的SDK里如何增加红外解码功能,有没有demo呢?
接收用了程序ir demo里的#define IR_DEV_RECV_PIN TUYA_GPIO_NUM_6 // PWM0
PA6引脚接到了红外接收头,编译烧录,按下遥控,没有相关的解码打印?是什么原因呢?
[01-01 00:08:04 ty E][tdl_ir_dev_manage.c:1303] ret:-26369
[01-01 00:08:04 ty E][example_drv_ir.c:74] ret:-26369
[01-01 00:08:04 ty D][example_drv_ir.c:90] ir timecode recv running
[01-01 00:08:06 ty E][example_drv_ir.c:72] ret:-4
[01-01 00:08:09 ty E][tdl_ir_dev_manage.c:1303] ret:-26369
[01-01 00:08:09 ty E][example_drv_ir.c:74] ret:-26369
[01-01 00:08:09 ty D][example_drv_ir.c:90] ir timecode recv running
[01-01 00:08:11 ty E][example_drv_ir.c:72] ret:-4
[01-01 00:08:14 ty E][tdl_ir_dev_manage.c:1303] ret:-26369
[01-01 00:08:14 ty E][example_drv_ir.c:74] ret:-26369
[01-01 00:08:14 ty D][example_drv_ir.c:90] ir timecode recv running
[01-01 00:08:15 ty D][lr:0x6b7d5] feed watchdog
[01-01 00:08:16 ty E][example_drv_ir.c:72] ret:-4
[01-01 00:08:19 ty E][tdl_ir_dev_manage.c:1303] ret:-26369
[01-01 00:08:19 ty E][example_drv_ir.c:74] ret:-26369
[01-01 00:08:19 ty D][example_drv_ir.c:90] ir timecode recv running
[01-01 00:08:21 ty E][example_drv_ir.c:72] ret:-4
[01-01 00:08:24 ty E][tdl_ir_dev_manage.c:1303] ret:-26369
[01-01 00:08:24 ty E][example_drv_ir.c:74] ret:-26369
[01-01 00:08:24 ty D][example_drv_ir.c:90] ir timecode recv running
[01-01 00:08:26 ty E][example_drv_ir.c:72] ret:-4
[01-01 00:08:29 ty E][tdl_ir_dev_manage.c:1303] ret:-26369
[01-01 00:08:29 ty E][example_drv_ir.c:74] ret:-26369
[01-01 00:08:29 ty D][example_drv_ir.c:90] ir timecode recv running
[01-01 00:08:31 ty E][example_drv_ir.c:72] ret:-4
[01-01 00:08:34 ty E][tdl_ir_dev_manage.c:1303] ret:-26369
[01-01 00:08:34 ty E][example_drv_ir.c:74] ret:-26369
[01-01 00:08:34 ty D][example_drv_ir.c:90] ir timecode recv running
[01-01 00:08:35 ty D][lr:0x6b7d5] feed watchdog
[01-01 00:08:36 ty E][example_drv_ir.c:72] ret:-4
[01-01 00:08:39 ty E][tdl_ir_dev_manage.c:1303] ret:-26369
[01-01 00:08:39 ty E][example_drv_ir.c:74] ret:-26369
