T5 3.12.11 tuyaos_demo_ai_multimodal无法运行
四大皆空
只修改了UUID、authkey,烧录进去后看着boot没加载起来,怎么回事
一线长天
Re: T5 3.12.11 tuyaos_demo_ai_multimodal无法运行
是否工程有做过其他改动,需要完整clean下。或者重新下载一下。只改动uuid/authkey不会触发图示的异常。
四大皆空
没有做修改, 申请了3.12.12的SDK编译 这个demo,编译不过
vendor/T5/tuyaos/tuyaos_adapter/include/asr/libtutuClear/libtutuClear.a(tutu_t2f.o) uses 32-bit enums yet the output is to use variable-size enums; use of enum values across objects may fail
/home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld: warning: /home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/tuyaos/tuyaos_adapter/include/asr/libtutuClear/libtutuClear.a(tutu_vtrgr.o) uses 32-bit enums yet the output is to use variable-size enums; use of enum values across objects may fail
/home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld: warning: /home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/tuyaos/tuyaos_adapter/include/asr/libtutuClear/libtutuClear.a(tutu_basicop.o) uses 32-bit enums yet the output is to use variable-size enums; use of enum values across objects may fail
/home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld: warning: /home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/tuyaos/tuyaos_adapter/include/asr/libtutuClear/libtutuClear.a(tutu_comm.o) uses 32-bit enums yet the output is to use variable-size enums; use of enum values across objects may fail
/home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld: warning: /home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/tuyaos/tuyaos_adapter/include/asr/libtutuClear/libtutuClear.a(tutu_diagnostics.o) uses 32-bit enums yet the output is to use variable-size enums; use of enum values across objects may fail
/home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld: warning: /home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/tuyaos/tuyaos_adapter/include/asr/libtutuClear/libtutuClear.a(tutu_fft_lib.o) uses 32-bit enums yet the output is to use variable-size enums; use of enum values across objects may fail
/home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld: armino/tuyaos_adapter/libtuyaos_adapter.a(tkl_lvgl.c.obj): in function lvgl_event_open_handle':
/home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/tuyaos/tuyaos_adapter/src/system/tkl_lvgl.c:261: undefined reference to
tuya_gui_main'
/home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld: /home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/tuyaos/tuyaos_adapter/src/system/tkl_lvgl.c:268: undefined reference to tuya_gui_resume'
lvgl_event_close_handle':
/home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/tuyaos/tuyaos_adapter/src/system/tkl_lvgl.c:291: undefined reference to `tuya_gui_pause'
ninja: build stopped: subcommand failed.
ninja failed with exit code 1
make[2]: *** [Makefile:132: bk7258_cp1] Error 2
make[2]: Leaving directory '/home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/t5_os/bk_idk'
make[1]: *** [Makefile:81: bk7258] Error 2
make[1]: Leaving directory '/home/share/samba/Projects/T5_3.12.12/software/TuyaOS/vendor/T5/t5_os'
make failed
build.sh: 260: exit: Illegal number: -1
make: *** [/home/share/samba/Projects/T5_3.12.12/software/TuyaOS/scripts/mk/app.mk:195: app_by_name] Error 2
undefined reference to 'tuya_gui_main'
void tuya_gui_pause(void)
//! TODO:
void tuya_gui_resume(void)
//! TODO:
void tuya_gui_main(void)
//! TODO:
找个地方定义这三个空函数。你是真只改了uuid么?
四大皆空
连uuid都没改,没有任何修改,直接编译的
