Devices are not exported to Home Assistant as Matter
JorgeFrancisco
Can anyone help me with these devices not exporting as Matter? I'm using HUB M6 Zemismart
Type: 4 Switch Touch with 2 Outlet
ebe34bd6eee3d7ae2anclu
eb6da3e88ecb973c3az20k
ebbbaab8df3a6d3afbcaqf
Type: 6 Switch Touch
ebe91e7bac7d3f050dcqva
eb4bdc327252db60ecqrsf
eb770a185d8031643c1t2k
qiusui
Re: Devices are not exported to Home Assistant as Matter
Hi,
I have updated the configuration of these devices. They have all been configured as six-way switches. Please remove the devices and reconfigure them to observe if there are any changes.
JorgeFrancisco
Thanks, they all work fine now!
Could you please check these Sonoff Temperature and Humidity sensors? They are showing wrong values ​​when exporting.
Model (SONOFF SNZB-02D)
eb62727b2dd8da53a1vlrt
eb64206d4efdc044a3ji4a
ebbc9564a415131e5bkrmq
And can you check these 2 dimmers 2CH that are not exporting?
eb0fe569fecd8fb1fes3al
eb3e2329e34454c4cfyqif
JorgeFrancisco
OK values: 21 C / 74 %
Wrong values: 7,4 C / 10 %
JorgeFrancisco
JorgeFrancisco 2025年 May 23日 17:08
Could someone please check?
qiusui
Don't worry. I should be able to help you fix this problem. Please wait patiently.
qiusui
Hi JorgeFrancisco,
I have updated the configuration. Please remove these devices, reconfigure the gateway, and then perform the bridging operation so that the configuration takes effect.
Give it a try. If there are still any questions, please leave a message to tell me.
JorgeFrancisco
Temperature values ​​are ok, but humidity values ​​need to be multiplied by 10
qiusui
ok, It's a minor problem. I'll fix it immediately.
JorgeFrancisco
Hi qiusui,
Thank you!!!!
Would it be possible to correct the battery level? The value shown in the Platform API is 60%, but what is shown as matter is 12%.
