Zigbee Locks via Matter in Home Assistant
qiusui
RebelMagpie 2025年 Mar 26日 11:45
Any update in this please?
As far as I know, the locks haven't been updated yet.
RebelMagpie
Re: Zigbee Locks via Matter in Home Assistant
Do you know if there are any plans to update the schema? It seems inconceivable that you'd be able to unlock, but not lock, the device.
Please let me know if there are any plans to implement the "lock" action via Matter. If it's going to stay the same as it is, I will need to move on and look elsewhere for a compliant deadbolt lock.
qiusui
RebelMagpie 2025年 Apr 21日 07:29
Hi RebelMagpie,
Sorry to have kept you waiting for so long.
I need to reconfirm your current requirements with you again in order to better solve your problem.
As I understand it, the device you have a problem with now is deadbolt, and you can operate it normally (lock/unlock) in the tuya App. However, on HA, it can only be unlocked but not locked. So the current problem is how to lock the deadbolt device on HA, right?
Please provide me with the id of the latest door bolt equipment.
RebelMagpie
Thank you qiusui,
You have it exactly right. The locks work fine in the Tuya app, but connected to Home Assistant via Matter, they can only be unlocked. When I try to lock them, they time out.
All 3 behave consistently.
IDs:
bf17b2f494f86f27a86y53
bf54c1fb3033c3a86bo843
bf1a49463c1549e684d6wd
qiusui
Ok, I've got it. Give me some time to analyze the reasons.
qiusui
RebelMagpie 2025年 Apr 22日 05:27
Thank you qiusui,
IDs:
Hi RebelMagpie,
I have attempted to update this type of door bolt.
Please try: Select a door lock, remove it first, restart it, reconfigure the gateway, and perform the bridging and door lock opening and closing operations.
Observe to see if there are any new phenomena and tell me in time.
If your result is comforting, then do the same for the other door locks. If not, then tell me the new specific situation again.
RebelMagpie
Thanks qiusui,
I followed your instructions:
Removed lock from tuya app and removed all data
Confirmed it was removed from Home Assistant
Removed and reinserted batteries to restart the lock
Re-added to TUYA app
Confirmed that the unit locked and locked successfully with Tuya app
Locked and unlocked with the button on the unit
Locked and unlocked again with the Tuya app
In Home Assistant, they lock shows up as new Matter lock
From HA, the lock can be unlocked but not locked. When attempting to lock, it times out after 30 seconds and the unit stays unlocked.
If I lock from the Tuya app, or manually at the lock, HA can unlock it successfully.
In summary, the behaviour has not changed.
The ID of they unit I tested is bfe5eae7f1585756c8lxxg
Thank you for your assistance. I hope we can get this resolved.
qiusui
RebelMagpie 2025年 Apr 23日 18:10
Thanks qiusui,
RebelMagpie,
Please use HA to perform the unlocking and locking operations again tomorrow, and record your local time as accurately as possible to the second. Then tell me the corresponding door lock id, and I will analyze the gateway log. Thank you very much.
qiusui
I think the two of us can agree on a time period to stay online so that we can communicate at any time. But there is a time difference between us. What time do you think is more suitable for you to be online in Beijing time?
qiusui
We should have already analyzed the reason why the lock cannot be made. The lock function for this category is indeed not supported. However, we can implement it by modifying the code.
I will contact our product manager tomorrow to discuss the subsequent arrangements.
But if this requirement is a special need of yours, you may need to pay some customization fees. However, I'm not very familiar with these cost-related matters. After all, I'm just a development engineer. I'd better communicate with the product manager tomorrow and then tell you. Wait for my reply.
