Smart Heat Pump returns RAW data.
Let's chat here.
flynth
I'm trying to develop Home Assistant integration for a Smart Heat Pump. Unfortunately as it is often with such things the manufacturer is very supportive, but not able to provide any technical info. They are using tuya integration. Great, right! (As Tuya has lots of open info). Well yes, and no.
The problem is the device returns lots of RAW data like shown below. And who can make any sense of this? It is obvious that this is base64 encoded binary, and to some extent certain things are explained by the things data model (that for example 108 is zone2_func_info - whatever this means). Unfortunately it does not help at all in decoding the information.
The manufacturer publishes a mini app in Smart Things App, so it can be viewed and controlled from it. But despite being able to log all this data to MQTT I have no idea how to decode it... If anyone can help I'd be very glad.
  "108": "AQEBAQAAADICAQIBBAEAAAAAAAAAMwQBAwAFAQCjADUDAQQBAAEAAwA0AMgAyQDKAwEFAAABAAMAAADIAMkAygcBBgAAAgcBBwAAAAcBCAAAAAcBCQAAAAcBCgAAAAcBCwAAAAcBDAAAAAcBDQAAAAcBDgAAAAcBDwAAAAcBEAAAAAcBEQAAAAcBEgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=="
07/11/2024 6:45:50 PM
{"108":"AQEBAQAAADICAQIBBAEAAAAAAAAAMwQBAwAFAQCjADUDAQQBAAEAAwA0AMgAyQDKAwEFAAABAAMAAADIAMkAygcBBgAAAgcBBwAAAAcBCAAAAAcBCQAAAAcBCgAAAAcBCwAAAAcBDAAAAAcBDQAAAAcBDgAAAAcBDwAAAAcBEAAAAAcBEQAAAAcBEgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=="}
07/11/2024 6:45:50 PM(-0.01 seconds)
07/11/2024 6:45:50 PM(-0 seconds)
07/11/2024 6:45:49 PM(-0.02 seconds)
{"106":"AQEBAQABADICAQIBBAEACwAUAAUAMwQBAwAFAQCjADUDAQQBAAEAAwA0AMgAyQDKAwEFAAABAAMAAADIAMkAygcBBgAAAgcBBwAAAAcBCAAAAAcBCQAAAAcBCgAAAAcBCwAAAAcBDAAAAAcBDQAAAAcBDgAAAAcBDwAAAAcBEAAAAAcBEQAAAAcBEgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=="}
07/11/2024 6:45:49 PM(-0 seconds)
Essagl
Re: Smart Heat Pump returns RAW data.
I also geht RAW Data from a Heatpump
manufactored by aircal.
You can find the way to decode the RAW Data in the GitHub repository for the method to get the control Parameters of the pump.
https://github.com/essagl/tuya-spring-b ... mp-adapter
Hope this helps
