Issue when using Tuya Slider Component
Mywatt Dev
  • Tuya MiniApp Tools version information: 0.5.15
  • The versions of @ray-js/ray: 1.4.45, @ray-js/panel-sdk: 1.10.0
  • Mobile device information: Andriod
  • Related code:
import React from "react";
import Slider from "@ray-js/components-ty-slider";
const TempSet = () => {
 const handleChange = (...args) => console.log(args);
 return (
  <Slider
   min={1}
   max={100}
   isShowTicks={false}
   maxTrackHeight="20rpx"
   maxTrackRadius="14rpx"
   minTrackHeight="20rpx"
   minTrackColor="linear-gradient(to left, #87abf2 11.6%, #4b7ee2)"
   maxTrackColor="#f4faff"
   thumbHeight="56rpx"
   thumbWidth="77rpx"
   thumbRadius="48rpx"
   thumbBoxShadowStyle="14rpx 14rpx 30rpx rgba(158, 184, 210, 0.45)"
   thumbColor="linear-gradient(225deg, #FDFEFF 13%, #D5E3F3 96%)"
   onChange={handleChange}
  • Log information:
  • Problem description (reproduction steps):
    • Install the package @ray-js/components-ty-slider@1.10.7.
    • Create a component using the code from above and start the project.
  • expected outcome:
    Circle Slider to appear on the Page
  • actual results:
    The App doesn't start and has error logs
Muzzzhi
Re: Issue when using Tuya Slider Component
import React from 'react';
import Slider from '@ray-js/components-ty-slider';
export default function Home() {
  return (
    <Slider
      style={{ marginTop: 20 }}
      step={25}
      isShowTicks
      maxTrackHeight="8px"
      maxTrackRadius="8px"
      minTrackHeight="8px"
      minTrackColor="linear-gradient(to right, #158CFB, orange)"
      maxTrackTickHeight="4px"
      maxTrackTickWidth="4px"
      maxTrackTickRadius="2px"
      minTrackTickHeight="4px"
      minTrackTickWidth="4px"
      minTrackTickRadius="2px"
package.json
  "name": "app",
  "version": "1.0.0",
  "private": true,
  "devDependencies": {
    "@ray-js/cli": "latest",
    "@types/react": "^17.0.24",
    "@types/react-dom": "^17.0.9",
    "core-js": "^3.19.1",
    "react": "^17.0.2",
    "react-dom": "^17.0.2"
  "dependencies": {
    "@ray-js/components-ty-slider": "^0.2.40",
    "@ray-js/panel-sdk": "^1.10.0",
    "@ray-js/ray": "^1.4.45"
The version check is normal. It is recommended to delete the lock file and reinstall dependencies. "@ray-js/components-ty-slider" should not exist in version 1.10.7. You can use version 0.2.40 instead.
Mywatt Dev
I have installed the recommended version and I still see the error same error.
Muzzzhi
Mywatt Dev 2024年 Apr 4日 14:20
I tried using your dependency but found no problem.
:!: It seems that a lock is being placed on an incompatible version. Try deleting the lock file and re-installing the yarn dependency. If there are still problems, post git repository or you can send out the lock file.
Mywatt Dev
I have attached the package-lock.json.
package-lock.json.txt
(2.22 MiB) Downloaded 509 times
Muzzzhi
Mywatt Dev 2024年 Apr 5日 23:53
Oh, look at the lock file because of the sub-dependency problem of @ray-js/panel-sdk, you can first use 'npm install --legacy-peer-deps' or' yarn 'to install the dependency, we will update @ray-js/panel-sdk.
Muzzzhi
Muzzzhi 2024年 Apr 7日 11:13
We upgraded @ray-js/panel-sdk, using version 1.10.2 to confirm.
