【已解决】ECR6600-TS2D-TUYAOS-3.8.4版本,默认SDK编译失败
shelvin
编译失败LOG:
====== build app(tuyaos_demo_quickstart) begin =======
开始编译app
apps/tuyaos_demo_quickstart
tuyaos_demo_quickstart 1.0.0 eswin_ecr6600 apps/tuyaos_demo_quickstart
APP_BIN_NAME=tuyaos_demo_quickstart
APP_VERSION=1.0.0
TARGET_PLATFORM=eswin_ecr6600
APP_PATH=apps/tuyaos_demo_quickstart
USER_CMD=
USER_SW_VER=1.0.0
Start Compile
make[1]: 进入目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/Boards/ecr6600/tuya”
info text
echo w -- APP_NAME=tuyaos_demo_quickstart APP_VER=1.0.0 USER_CMD=
make -C /home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os BOARD_DIR=/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/Boards/ecr6600/tuya APP_NAME=tuyaos_demo_quickstart -w -- APP_NAME=tuyaos_demo_quickstart APP_VER=1.0.0 USER_CMD= pass1dep
make[2]: 进入目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os”
warning: FLASH_BOYA (defined at drivers/drivers/flash/Kconfig:99) has leading or trailing whitespace in its prompt
######################################generate config.h######################################
pass1dep:Boards/ecr6600/tuya/generated/config.h
make[2]: 离开目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os”
make[1]: 离开目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/Boards/ecr6600/tuya”
Start Compile /home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/Boards/ecr6600/tuya
info text
echo w -- APP_BIN_NAME=tuyaos_demo_quickstart EXTRA_SDK_DIR=/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS SDK_V=V2.0.0B06 APP_NAME=tuyaos_demo_quickstart APP_VER=1.0.0 USER_CMD=
make -C /home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os BOARD_DIR=/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/Boards/ecr6600/tuya APP_NAME=tuyaos_demo_quickstart -w -- APP_BIN_NAME=tuyaos_demo_quickstart EXTRA_SDK_DIR=/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS SDK_V=V2.0.0B06 APP_NAME=tuyaos_demo_quickstart APP_VER=1.0.0 USER_CMD= all
make[3]: 进入目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/components”
CC: health_monitor/health_monitor.c
CC: wifi_ctrl/wifi_sniffer.c
CC: cli/cli.c
CC: cli/cli_trace_stack.c
CC: cli/command/cmd_system.c
CC: cli/command/cmd_common.c
CC: cli/command/cmd_show.c
CC: cli/command/cmd_read.c
CC: cli/command/cmd_write.c
CC: cli/command/cmd_ble_amt_cli.c
CC: cli/command/cmd_wifi.c
CC: cli/command/cmd_wifi_amt_cli.c
CC: cli/command/cmd_system_debug.c
CC: cli/command/cmd_psm.c
CC: cli/command/cmd_nv.c
CC: ota/ota.c
CC: ota/http_ota.c
CC: nv/src/ef_env.c
CC: nv/src/easyflash.c
CC: nv/src/ef_iap.c
CC: nv/src/ef_log.c
CC: nv/src/ef_utils.c
CC: nv/port/ef_port.c
CC: platform_api/format_conversion.c
CC: platform_api/system_config.c
make[3]: 离开目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/components”
make[3]: 进入目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/Boards”
AS: ecr6600/common/chip_entry.S
CC: ecr6600/tuya/main.c
CC: ecr6600/common/chip_startup.c
CC: ecr6600/common/chip_pin_mux.c
CC: ecr6600/common/chip_clk_ctrl.c
CC: ecr6600/common/chip_config.c
CC: ecr6600/common/release_version.c
CC:ecr6600/tuya/generated/ld.script
make[3]: 离开目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/Boards”
make[3]: 进入目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/arch”
CC: andes/arch_cpu.c
CC: andes/arch_irq.c
CC: andes/arch_cache.c
make[3]: 离开目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/arch”
make[3]: 进入目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/os”
AS: freertos/FreeRTOS-Kernel/portable/ThirdParty/GCC/NDS32_ECR6600/irq.S
AS: freertos/FreeRTOS-Kernel/portable/ThirdParty/GCC/NDS32_ECR6600/portasm.S
CC: os_hal/os_hal_freertos.c
CC: freertos/FreeRTOS-Kernel/croutine.c
CC: freertos/FreeRTOS-Kernel/event_groups.c
CC: freertos/FreeRTOS-Kernel/list.c
CC: freertos/FreeRTOS-Kernel/queue.c
CC: freertos/FreeRTOS-Kernel/tasks.c
CC: freertos/FreeRTOS-Kernel/timers.c
CC: freertos/FreeRTOS-Kernel/stream_buffer.c
CC: freertos/FreeRTOS-Kernel/portable/ThirdParty/GCC/NDS32_ECR6600/port.c
CC: freertos/FreeRTOS-Kernel/portable/ThirdParty/GCC/NDS32_ECR6600/debug_core.c
CC: freertos/FreeRTOS-Kernel/portable/ThirdParty/GCC/NDS32_ECR6600/dump_core.c
CC: freertos/FreeRTOS-Kernel/portable/MemMang/heap_5.c
CC: os_psram/os_psram_mem.c
make[3]: 离开目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/os”
make[3]: 进入目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/apps”
make[3]: 离开目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/apps”
make[3]: 进入目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/drivers”
CC: hal/hal_uart.c
CC: hal/hal_pwm.c
CC: hal/hal_timer.c
CC: hal/hal_rtc.c
CC: hal/hal_flash.c
CC: hal/hal_gpio.c
CC: hal/hal_wdt.c
CC: hal/hal_system.c
CC: hal/hal_efuse.c
CC: hal/hal_aes.c
CC: hal/hal_hash.c
CC: hal/hal_trng.c
CC: hal/hal_adc.c
CC: drivers/wdt/wdt.c
CC: drivers/trng/trng.c
CC: drivers/gpio/gpio.c
CC: drivers/aes/aes.c
CC: drivers/sdio_slave/sdio_slave.c
CC: drivers/hash/hash.c
CC: drivers/dma/dma.c
CC: drivers/uart/uart.c
CC: drivers/ir/ir.c
CC: drivers/rtc/rtc.c
CC: drivers/spi_slave/spi_slave.c
CC: drivers/spi_master/spi_master.c
CC: drivers/pit/pit.c
CC: drivers/i2c/i2c.c
CC: drivers/ecc/ecc.c
CC: drivers/timer/timer.c
CC: drivers/i2s/i2s.c
CC: drivers/efuse/efuse.c
CC: drivers/flash/flash.c
CC: drivers/flash/flash_probe.c
CC: drivers/flash/flashid/flash_GD.c
CC: drivers/flash/flashid/flash_PUYA.c
CC: drivers/flash/flashid/flash_ZB.c
CC: drivers/flash/flashid/flash_XM.c
CC: drivers/flash/flashid/flash_XT.c
CC: drivers/flash/flashid/flash_FM.c
CC: drivers/flash/flashid/flash_HUABANG.c
CC: drivers/flash/flashid/flash_EN.c
CC: drivers/flash/flashid/flash_TH.c
CC: drivers/flash/flashid/flash_BOYA.c
CC: drivers/encrypt_lock/encrypt_lock.c
CC: drivers/adc/adc.c
CC: drivers/pwm/pwm.c
make[3]: 离开目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/drivers”
make[3]: 进入目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os”
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/nds32le-elf-gcc -nostartfiles -nostdlib -Lbuild/tuyaos_demo_quickstart/libs -L./libs -L/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/libs -o build/tuyaos_demo_quickstart/tuyaos_demo_quickstart.elf -Wl,--whole-archive -ltuyaos_demo_quickstart -ltuyaapp_components -ltuyaapp_drivers -ltuyaos -ltuyaos_adapter -lapps -larch -lboard -lcomponents -ldrivers -los -lps_ble -lpsm -lps_wifi -lversion -Wl,--no-whole-archive -TBoards/ecr6600/tuya/generated/ld.script -nostartfiles -nostdlib -Wl,--gc-sections -ffunction-sections -fdata-sections -fno-delete-null-pointer-checks -mcmodel=large -Os -landes -Wl,-Map=build/tuyaos_demo_quickstart/tuyaos_demo_quickstart.map
build/tuyaos_demo_quickstart/libs/libos.a(os_hal_freertos.o): In function strdup':
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os/os/os_hal/os_hal_freertos.c:363: multiple definition of
strdup'
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/libs/libtuyaos_demo_quickstart.a(split.c.o):/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/apps/tuyaos_demo_quickstart/src/libqrencode/split.c:45: first defined here
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: Disabling relaxation: it will not work with multiple definitions
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libpsm.a(psm_system.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(hal_rf_6600.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(phy_custom_rf.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(rxl_hwdesc.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(mm_timer.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_ble.a(sch_arb.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_ble.a(sch_plan.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_ble.a(lld_adv.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_ble.a(lld_scan.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_ble.a(lld.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_ble.a(rwip_driver.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(mm.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(ps.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(amt.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(amt_interface.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(psm_module_interface.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(dbg_cli.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(mac_rec.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(fhost_hostapd_ioctl.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_ble.a(llm.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_ble.a(rwip.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_ble.a(uart_adapt.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(vif_mgmt.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(mm_bcn.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(me_task.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(sm.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(scanu.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(hsu.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libps_wifi.a(fhost_cntrl.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-fflush.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-findfp.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-fstatr.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-nano-mallocr.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-sbrkr.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-vsnprintf.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-w_pow.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-writer.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-closer.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-isattyr.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-lseekr.o): warning: FP_BASE setting insns relaxation failed.
/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/toolchain/nds32le-elf-mculib-v3s/bin/../lib/gcc/nds32le-elf/8.2.0/../../../../nds32le-elf/bin/ld: ./libs/libandes.a(lib_a-readr.o): warning: FP_BASE setting insns relaxation failed.
make[3]: *** [Makefile:207:build/tuyaos_demo_quickstart/tuyaos_demo_quickstart.elf] 错误 1
make[3]: 离开目录“/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/vendor/eswin_ecr6600/eswin_ecr6600_os”
make[2]: *** [Makefile:114:all] 错误 2
make[1]: *** [makefile:11:all] 错误 2
make: *** [/home/tony/Documents/XieXu/ECR6600-TS2D_TuyaOS-3.8.4/software/TuyaOS/scripts/mk/app.mk:191:app_by_name] 错误 2
JSHANG
Re: ECR6600-TS2D-TUYAOS-3.8.4版本,默认SDK编译失败
tuyaos_demo_quickstart/src/libqrencode/split.c:45 strdup 重复定义,先把这个去掉试试。
shelvin
第42行:
修改前编译失败的定义如下:
#if !HAVE_STRDUP
#undef strdup
char *strdup(const char *s)
size_t len = strlen(s) + 1;
void *newstring = malloc(len);
if(newstring == NULL) return NULL;
return (char *)memcpy(newstring, s, len);
#endif
改成下面的代码,编译成功
#if HAVE_STRDUP
#undef strdup
#endif
