我自己模拟postman的pre-req javascript逻辑写了一套python代码,最后的请求参数都是一摸一样的,同样也是不行。都是报sign invalid. 请问是为什么,今天弄了一个晚上,有点崩溃。。
postman可以请求成功,但是postman生成的python代码不行
Re: postman可以请求成功,但是postman生成的python代码不行
import requests
import json
url = "https://openapi.tuyacn.com/v1.0/devices ... value=true"
payload = json.dumps({
"commands": [
"code": "switch_1",
"value": True
headers = {
'client_id': 'ed8gtgj49j8ydsdtrjr9',
'access_token': ********************************',
'sign': '***********************',
't': '1736613094839',
'sign_method': 'HMAC-SHA256',
'Content-Type': 'application/json',
'nonce': '',
'stringToSign': ''
response = requests.request("POST", url, headers=headers, data=payload)
print(response.text)
这种设备指令下发的代码,打星号的都是和postman中console看到的一摸一样,还是会报错
qiufeng.yu
你好,云开发平台针对 python 开发者也提供了相应的 SDK,你可以在这里找到:https://developer.tuya.com/cn/docs/iot/ ... 09frvx48db
使用起来也很简单,比如查询设备信息:
def main():
from tuya_connector import (
TuyaOpenAPI,
ACCESS_ID = "你的云项目 ClientId"
ACCESS_KEY = "你的云项目 SecretKey"
API_ENDPOINT = "https://openapi.tuyacn.com"
# Init openapi and connect
openapi = TuyaOpenAPI(API_ENDPOINT, ACCESS_ID, ACCESS_KEY)
openapi.connect()
# Call any API from Tuya
response = openapi.get("/v1.1/iot-03/devices/{你的设备 ID}")
# 打印 response
print(response)
if __name__ == "__main__":
main()
当然你也可以参考这个 SDK 里的签名逻辑,代码在 openapi.py 文件里:
def _calculate_sign(
self,
method: str,
path: str,
params: Optional[Dict[str, Any]] = None,
body: Optional[Dict[str, Any]] = None,
) -> Tuple[str, int]:
# HTTPMethod
str_to_sign = method
str_to_sign += "\n"
# Content-SHA256
content_to_sha256 = (
"" if body is None or len(body.keys()) == 0 else json.dumps(body)
str_to_sign += (
hashlib.sha256(content_to_sha256.encode(
"utf8")).hexdigest().lower()
str_to_sign += "\n"
# Header
str_to_sign += "\n"
# URL
str_to_sign += path
if params is not None and len(params.keys()) > 0:
str_to_sign += "?"
query_builder = ""
params_keys = sorted(params.keys())
for key in params_keys:
query_builder += f"{key}={params[key]}&"
str_to_sign += query_builder[:-1]
# Sign
t = int(time.time() * 1000)
message = self.access_id
if self.token_info is not None:
message += self.token_info.access_token
message += str(t) + str_to_sign
sign = (
hmac.new(
self.access_secret.encode("utf8"),
msg=message.encode("utf8"),
digestmod=hashlib.sha256,
.hexdigest()
.upper()
return sign, t
