guyingjie@tdk:cloud$ make sa
cd cloud-2.2/sample; \
        CFLAGS="-Wall -funwind-tables -g -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0/glib -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0 -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/glib-2.0/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/nopoll -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/gstreamer-1.0  -DPLATFORM_AK3761D="1" -DDEV_ids="1"" CXXFLAGS="-g -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0/glib -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0 -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/glib-2.0/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/nopoll -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/gstreamer-1.0  " CPPFLAGS="-g -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0/glib -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0 -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/glib-2.0/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/nopoll -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/gstreamer-1.0  " LDFLAGS="-L/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib  -L/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/gstreamer-1.0 " CC="arm-anykav500-linux-gnueabi-gcc " PKG_CONFIG_PATH=/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/pkgconfig \
        ./configure  --target=arm-anykav500-linux-gnueabi --host=arm-anykav500-linux-gnueabi --build=x86_64-linux-gnu --prefix=/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install  --enable-static --disable-shared; \
        make; \
        make install; \
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for arm-anykav500-linux-gnueabi-strip... arm-anykav500-linux-gnueabi-strip
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... yes
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether arm-anykav500-linux-gnueabi-g++  accepts -g... yes
checking for style of include used by make... GNU
checking dependency style of arm-anykav500-linux-gnueabi-g++ ... gcc3
checking for gawk... (cached) gawk
checking for arm-anykav500-linux-gnueabi-gcc... arm-anykav500-linux-gnueabi-gcc
checking whether we are using the GNU C compiler... yes
checking whether arm-anykav500-linux-gnueabi-gcc  accepts -g... yes
checking for arm-anykav500-linux-gnueabi-gcc  option to accept ISO C89... none needed
checking whether arm-anykav500-linux-gnueabi-gcc  understands -c and -o together... yes
checking dependency style of arm-anykav500-linux-gnueabi-gcc ... gcc3
checking how to run the C preprocessor... arm-anykav500-linux-gnueabi-gcc  -E
checking whether ln -s works... yes
checking whether make sets $(MAKE)... (cached) yes
checking for arm-anykav500-linux-gnueabi-ranlib... arm-anykav500-linux-gnueabi-ranlib
checking build system type... x86_64-pc-linux-gnu
checking host system type... arm-anykav500-linux-gnueabi
checking how to print strings... printf
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by arm-anykav500-linux-gnueabi-gcc ... arm-anykav500-linux-gnueabi-ld
checking if the linker (arm-anykav500-linux-gnueabi-ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... arm-anykav500-linux-gnueabi-nm
checking the name lister (arm-anykav500-linux-gnueabi-nm ) interface... BSD nm
checking the maximum length of command line arguments... 3458764513820540925
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-pc-linux-gnu file names to arm-anykav500-linux-gnueabi format... func_convert_file_noop
checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop
checking for arm-anykav500-linux-gnueabi-ld option to reload object files... -r
checking for arm-anykav500-linux-gnueabi-objdump... arm-anykav500-linux-gnueabi-objdump
checking how to recognize dependent libraries... pass_all
checking for arm-anykav500-linux-gnueabi-dlltool... no
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for arm-anykav500-linux-gnueabi-ar... arm-anykav500-linux-gnueabi-ar
checking for archiver @FILE support... @
checking for arm-anykav500-linux-gnueabi-strip... (cached) arm-anykav500-linux-gnueabi-strip
checking for arm-anykav500-linux-gnueabi-ranlib... (cached) arm-anykav500-linux-gnueabi-ranlib
checking command to parse arm-anykav500-linux-gnueabi-nm  output from arm-anykav500-linux-gnueabi-gcc  object... ok
checking for sysroot... no
checking for arm-anykav500-linux-gnueabi-mt... no
checking for mt... mt
configure: WARNING: using cross tools not prefixed with host triplet
checking if mt is a manifest tool... no
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if arm-anykav500-linux-gnueabi-gcc  supports -fno-rtti -fno-exceptions... no
checking for arm-anykav500-linux-gnueabi-gcc  option to produce PIC... -fPIC -DPIC
checking if arm-anykav500-linux-gnueabi-gcc  PIC flag -fPIC -DPIC works... yes
checking if arm-anykav500-linux-gnueabi-gcc  static flag -static works... yes
checking if arm-anykav500-linux-gnueabi-gcc  supports -c -o file.o... yes
checking if arm-anykav500-linux-gnueabi-gcc  supports -c -o file.o... (cached) yes
checking whether the arm-anykav500-linux-gnueabi-gcc  linker (arm-anykav500-linux-gnueabi-ld) supports shared libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
checking how to run the C++ preprocessor... arm-anykav500-linux-gnueabi-g++  -E
checking for ld used by arm-anykav500-linux-gnueabi-g++ ... arm-anykav500-linux-gnueabi-ld
checking whether the arm-anykav500-linux-gnueabi-g++  linker (arm-anykav500-linux-gnueabi-ld) supports shared libraries... yes
checking for arm-anykav500-linux-gnueabi-g++  option to produce PIC... -fPIC -DPIC
checking if arm-anykav500-linux-gnueabi-g++  PIC flag -fPIC -DPIC works... yes
checking if arm-anykav500-linux-gnueabi-g++  static flag -static works... yes
checking if arm-anykav500-linux-gnueabi-g++  supports -c -o file.o... yes
checking if arm-anykav500-linux-gnueabi-g++  supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking for unistd.h... (cached) yes
checking for GNU libc compatible malloc... no
checking for memset... yes
checking for arm-anykav500-linux-gnueabi-pkg-config... no
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for QVCLOUD... yes
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
make[1]: Entering directory `/mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/sample'
make  all-recursive
make[2]: Entering directory `/mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/sample'
Making all in src
make[3]: Entering directory `/mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/sample/src'
arm-anykav500-linux-gnueabi-gcc  -DHAVE_CONFIG_H -I. -I..   -g -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0/glib -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0 -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/glib-2.0/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/nopoll -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/gstreamer-1.0    -Wall -funwind-tables -g -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0/glib -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0 -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/glib-2.0/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/nopoll -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/gstreamer-1.0  -DPLATFORM_AK3761D=1 -DDEV_ids=1 -MT main.o -MD -MP -MF .deps/main.Tpo -c -o main.o main.c
mv -f .deps/main.Tpo .deps/main.Po
/bin/sh ../libtool  --tag=CC   --mode=link arm-anykav500-linux-gnueabi-gcc   -Wall -funwind-tables -g -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0/glib -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0 -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/glib-2.0/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/nopoll -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/gstreamer-1.0  -DPLATFORM_AK3761D=1 -DDEV_ids=1  -L/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib  -L/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/gstreamer-1.0  -o sample main.o -L/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib -lpthread -lstdc++ -lqvcloud -ltuya_iot -lrt -ldl
libtool: link: arm-anykav500-linux-gnueabi-gcc -Wall -funwind-tables -g -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0/glib -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0 -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/glib-2.0/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/nopoll -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/gstreamer-1.0 -DPLATFORM_AK3761D=1 -DDEV_ids=1 -o sample main.o  -L/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib -L/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/gstreamer-1.0 -lpthread -lm /mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libqvcloud.a /opt/arm-anykav500-linux-gnueabi/arm-anykav500-linux-gnueabi/lib/libstdc++.so -ltuya_iot -lrt -ldl -Wl,-rpath -Wl,/opt/arm-anykav500-linux-gnueabi/arm-anykav500-linux-gnueabi/lib -Wl,-rpath -Wl,/opt/arm-anykav500-linux-gnueabi/arm-anykav500-linux-gnueabi/lib
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_ipc_cloud_storage.c.o): In function `__cloud_storage_iot_event_trigger_callback':
/root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/svc_cloud_storage/src/tuya_ipc_cloud_storage.c:1600: undefined reference to `tuya_ipc_get_snapshot_cb'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_ipc_stream_storage.c.o): In function `__thread_disk_monitor':
/root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/svc_local_storage/src/tuya_ipc_stream_storage.c:1554: undefined reference to `tuya_ipc_sd_get_status'
/root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/svc_local_storage/src/tuya_ipc_stream_storage.c:1584: undefined reference to `tuya_ipc_sd_get_mode_config'
/root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/svc_local_storage/src/tuya_ipc_stream_storage.c:1599: undefined reference to `tuya_ipc_sd_get_mode_config'
/root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/svc_local_storage/src/tuya_ipc_stream_storage.c:1608: undefined reference to `tuya_ipc_sd_get_capacity'
/root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/svc_local_storage/src/tuya_ipc_stream_storage.c:1638: undefined reference to `tuya_ipc_sd_remount'
/root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/svc_local_storage/src/tuya_ipc_stream_storage.c:1640: undefined reference to `tuya_ipc_sd_get_mode_config'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_ipc_stream_storage.c.o): In function `__ss_make_test_dirs':
/root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/svc_local_storage/src/tuya_ipc_stream_storage.c:467: undefined reference to `tuya_ipc_sd_get_capacity'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_ipc_stream_storage.c.o): In function `__ss_put_image':
/root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/svc_local_storage/src/tuya_ipc_stream_storage.c:1147: undefined reference to `tuya_ipc_get_snapshot_cb'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_ipc_doorbell.c.o): In function `__doorbell_status_change_callback':
/root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/svc_ipc_doorbell/src/tuya_ipc_doorbell.c:141: undefined reference to `tuya_ipc_doorbell_event'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wired.c.o):/root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_os_adapter/OS_adapter_linux/src/system/tuya_os_adapt_wired.c:16: undefined reference to `tuya_adapter_wired_get_ip'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wired.c.o):(.data.rel.ro.m_tuya_os_wired_intfs+0x4): undefined reference to `tuya_adapter_wired_get_mac'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wired.c.o):(.data.rel.ro.m_tuya_os_wired_intfs+0x8): undefined reference to `tuya_adapter_wired_set_mac'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wired.c.o):(.data.rel.ro.m_tuya_os_wired_intfs+0xc): undefined reference to `tuya_adapter_wired_wifi_set_station_connect'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wired.c.o):(.data.rel.ro.m_tuya_os_wired_intfs+0x10): undefined reference to `tuya_adapter_wired_wifi_station_get_conn_ap_rssi'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wired.c.o):(.data.rel.ro.m_tuya_os_wired_intfs+0x14): undefined reference to `tuya_adapter_wired_get_nw_stat'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wired.c.o):(.data.rel.ro.m_tuya_os_wired_intfs+0x18): undefined reference to `tuya_adapter_wired_if_connect_internet'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wired.c.o):(.data.rel.ro.m_tuya_os_wired_intfs+0x1c): undefined reference to `tuya_adapter_wired_wifi_need_cfg'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wired.c.o):(.data.rel.ro.m_tuya_os_wired_intfs+0x20): undefined reference to `tuya_adapter_wired_station_conn'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):/root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_os_adapter/OS_adapter_linux/src/system/tuya_os_adapt_wifi.c:14: undefined reference to `tuya_adapter_wifi_all_ap_scan'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x4): undefined reference to `tuya_adapter_wifi_assign_ap_scan'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x8): undefined reference to `tuya_adapter_wifi_release_ap'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0xc): undefined reference to `tuya_adapter_wifi_set_cur_channel'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x10): undefined reference to `tuya_adapter_wifi_get_cur_channel'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x14): undefined reference to `tuya_adapter_wifi_sniffer_set'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x18): undefined reference to `tuya_adapter_wifi_get_ip'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x1c): undefined reference to `tuya_adapter_wifi_set_mac'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x20): undefined reference to `tuya_adapter_wifi_get_mac'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x24): undefined reference to `tuya_adapter_wifi_set_work_mode'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x28): undefined reference to `tuya_adapter_wifi_get_work_mode'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x2c): undefined reference to `tuya_adapter_wifi_ap_start'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x30): undefined reference to `tuya_adapter_wifi_ap_stop'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x34): undefined reference to `tuya_adapter_wifi_get_connected_ap_info_v2'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x38): undefined reference to `tuya_adapter_wifi_fast_station_connect_v2'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x3c): undefined reference to `tuya_adapter_wifi_station_connect'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x40): undefined reference to `tuya_adapter_wifi_station_disconnect'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x44): undefined reference to `tuya_adapter_wifi_station_get_conn_ap_rssi'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x48): undefined reference to `tuya_adapter_wifi_get_bssid'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x4c): undefined reference to `tuya_adapter_wifi_station_get_status'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x50): undefined reference to `tuya_adapter_wifi_set_country_code'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x54): undefined reference to `tuya_adapter_wifi_send_mgnt'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x58): undefined reference to `tuya_adapter_wifi_register_recv_mgnt_callback'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x5c): undefined reference to `tuya_adapter_wifi_set_lp_mode'
/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/libtuya_iot.a(tuya_os_adapt_wifi.c.o):(.data.rel.ro.m_tuya_os_wifi_intfs+0x60): undefined reference to `tuya_adapter_wifi_rf_calibrated'
collect2: error: ld returned 1 exit status
make[3]: *** [sample] Error 1
make[3]: Leaving directory `/mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/sample/src'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/sample'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/sample'
Making install in src
make[2]: Entering directory `/mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/sample/src'
make[2]: *** [sample] Error 1
make[2]: Leaving directory `/mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/sample/src'
make[1]: *** [install-recursive] Error 1
make: *** [sa] Error 2
