# Makefile.in generated by automake 1.14.1 from Makefile.am.
# src/Makefile.  Generated from Makefile.in by configure.
# Copyright (C) 1994-2013 Free Software Foundation, Inc.
# This Makefile.in is free software; the Free Software Foundation
# gives unlimited permission to copy and/or distribute it,
# with or without modifications, as long as this notice is preserved.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY, to the extent permitted by law; without
# even the implied warranty of MERCHANTABILITY or FITNESS FOR A
# PARTICULAR PURPOSE.
am__is_gnu_make = test -n '$(MAKEFILE_LIST)' && test -n '$(MAKELEVEL)'
am__make_running_with_option = \
  case $${target_option-} in \
      *) echo "am__make_running_with_option: internal error: invalid" \
              "target option '$${target_option-}' specified" >&2; \
         exit 1;; \
  esac; \
  has_opt=no; \
  sane_makeflags=$$MAKEFLAGS; \
  if $(am__is_gnu_make); then \
    sane_makeflags=$$MFLAGS; \
  else \
    case $$MAKEFLAGS in \
        bs=\\; \
        sane_makeflags=`printf '%s\n' "$$MAKEFLAGS" \
          | sed "s/$$bs$$bs[$$bs $$bs	]*//g"`;; \
    esac; \
  fi; \
  skip_next=no; \
  strip_trailopt () \
    flg=`printf '%s\n' "$$flg" | sed "s/$$1.*$$//"`; \
  for flg in $$sane_makeflags; do \
    test $$skip_next = yes && { skip_next=no; continue; }; \
    case $$flg in \
      *=*|--*) continue;; \
        -*I) strip_trailopt 'I'; skip_next=yes;; \
      -*I?*) strip_trailopt 'I';; \
        -*O) strip_trailopt 'O'; skip_next=yes;; \
      -*O?*) strip_trailopt 'O';; \
        -*l) strip_trailopt 'l'; skip_next=yes;; \
      -*l?*) strip_trailopt 'l';; \
      -[dEDm]) skip_next=yes;; \
      -[JT]) skip_next=yes;; \
    esac; \
    case $$flg in \
      *$$target_option*) has_opt=yes; break;; \
    esac; \
  done; \
  test $$has_opt = yes
am__make_dryrun = (target_option=n; $(am__make_running_with_option))
am__make_keepgoing = (target_option=k; $(am__make_running_with_option))
pkgdatadir = $(datadir)/qvcloud
pkgincludedir = $(includedir)/qvcloud
pkglibdir = $(libdir)/qvcloud
pkglibexecdir = $(libexecdir)/qvcloud
am__cd = CDPATH="$${ZSH_VERSION+.}$(PATH_SEPARATOR)" && cd
install_sh_DATA = $(install_sh) -c -m 644
install_sh_PROGRAM = $(install_sh) -c
install_sh_SCRIPT = $(install_sh) -c
INSTALL_HEADER = $(INSTALL_DATA)
transform = $(program_transform_name)
NORMAL_INSTALL = :
PRE_INSTALL = :
POST_INSTALL = :
NORMAL_UNINSTALL = :
PRE_UNINSTALL = :
POST_UNINSTALL = :
build_triplet = x86_64-pc-linux-gnu
host_triplet = arm-anykav500-linux-gnueabi
subdir = src
DIST_COMMON = $(srcdir)/Makefile.in $(srcdir)/Makefile.am \
	$(top_srcdir)/depcomp $(include_HEADERS)
ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
am__aclocal_m4_deps = $(top_srcdir)/configure.ac
am__configure_deps = $(am__aclocal_m4_deps) $(CONFIGURE_DEPENDENCIES) \
	$(ACLOCAL_M4)
mkinstalldirs = $(install_sh) -d
CONFIG_HEADER = $(top_builddir)/config.h
CONFIG_CLEAN_FILES =
CONFIG_CLEAN_VPATH_FILES =
am__vpath_adj_setup = srcdirstrip=`echo "$(srcdir)" | sed 's|.|.|g'`;
am__vpath_adj = case $$p in \
    $(srcdir)/*) f=`echo "$$p" | sed "s|^$$srcdirstrip/||"`;; \
    *) f=$$p;; \
  esac;
am__strip_dir = f=`echo $$p | sed -e 's|^.*/||'`;
am__install_max = 40
am__nobase_strip_setup = \
  srcdirstrip=`echo "$(srcdir)" | sed 's/[].[^$$\\*|]/\\\\&/g'`
am__nobase_strip = \
  for p in $$list; do echo "$$p"; done | sed -e "s|$$srcdirstrip/||"
am__nobase_list = $(am__nobase_strip_setup); \
  for p in $$list; do echo "$$p $$p"; done | \
  sed "s| $$srcdirstrip/| |;"' / .*\//!s/ .*/ ./; s,\( .*\)/[^/]*$$,\1,' | \
  $(AWK) 'BEGIN { files["."] = "" } { files[$$2] = files[$$2] " " $$1; \
    if (++n[$$2] == $(am__install_max)) \
      { print $$2, files[$$2]; n[$$2] = 0; files[$$2] = "" } } \
    END { for (dir in files) print dir, files[dir] }'
am__base_list = \
  sed '$$!N;$$!N;$$!N;$$!N;$$!N;$$!N;$$!N;s/\n/ /g' | \
  sed '$$!N;$$!N;$$!N;$$!N;s/\n/ /g'
am__uninstall_files_from_dir = { \
  test -z "$$files" \
    || { test ! -d "$$dir" && test ! -f "$$dir" && test ! -r "$$dir"; } \
    || { echo " ( cd '$$dir' && rm -f" $$files ")"; \
         $(am__cd) "$$dir" && rm -f $$files; }; \
am__installdirs = "$(DESTDIR)$(libdir)" "$(DESTDIR)$(includedir)"
LTLIBRARIES = $(lib_LTLIBRARIES)
libqvcloud_la_LIBADD =
am_libqvcloud_la_OBJECTS = libqvcloud_la-QVCloud.lo
libqvcloud_la_OBJECTS = $(am_libqvcloud_la_OBJECTS)
AM_V_lt = $(am__v_lt_$(V))
am__v_lt_ = $(am__v_lt_$(AM_DEFAULT_VERBOSITY))
am__v_lt_0 = --silent
am__v_lt_1 =
libqvcloud_la_LINK = $(LIBTOOL) $(AM_V_lt) --tag=CXX \
	$(AM_LIBTOOLFLAGS) $(LIBTOOLFLAGS) --mode=link $(CXXLD) \
	$(libqvcloud_la_CXXFLAGS) $(CXXFLAGS) $(AM_LDFLAGS) $(LDFLAGS) \
	-o $@
AM_V_P = $(am__v_P_$(V))
am__v_P_ = $(am__v_P_$(AM_DEFAULT_VERBOSITY))
am__v_P_0 = false
am__v_P_1 = :
AM_V_GEN = $(am__v_GEN_$(V))
am__v_GEN_ = $(am__v_GEN_$(AM_DEFAULT_VERBOSITY))
am__v_GEN_0 = @echo "  GEN     " $@;
am__v_GEN_1 =
AM_V_at = $(am__v_at_$(V))
am__v_at_ = $(am__v_at_$(AM_DEFAULT_VERBOSITY))
am__v_at_0 = @
am__v_at_1 =
DEFAULT_INCLUDES = -I. -I$(top_builddir)
depcomp = $(SHELL) $(top_srcdir)/depcomp
am__depfiles_maybe = depfiles
am__mv = mv -f
CXXCOMPILE = $(CXX) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) \
	$(AM_CPPFLAGS) $(CPPFLAGS) $(AM_CXXFLAGS) $(CXXFLAGS)
LTCXXCOMPILE = $(LIBTOOL) $(AM_V_lt) --tag=CXX $(AM_LIBTOOLFLAGS) \
	$(LIBTOOLFLAGS) --mode=compile $(CXX) $(DEFS) \
	$(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) \
AM_V_CXX = $(am__v_CXX_$(V))
am__v_CXX_ = $(am__v_CXX_$(AM_DEFAULT_VERBOSITY))
am__v_CXX_0 = @echo "  CXX     " $@;
am__v_CXX_1 =
CXXLD = $(CXX)
CXXLINK = $(LIBTOOL) $(AM_V_lt) --tag=CXX $(AM_LIBTOOLFLAGS) \
	$(LIBTOOLFLAGS) --mode=link $(CXXLD) $(AM_CXXFLAGS) \
	$(CXXFLAGS) $(AM_LDFLAGS) $(LDFLAGS) -o $@
AM_V_CXXLD = $(am__v_CXXLD_$(V))
am__v_CXXLD_ = $(am__v_CXXLD_$(AM_DEFAULT_VERBOSITY))
am__v_CXXLD_0 = @echo "  CXXLD   " $@;
am__v_CXXLD_1 =
SOURCES = $(libqvcloud_la_SOURCES)
DIST_SOURCES = $(libqvcloud_la_SOURCES)
am__can_run_installinfo = \
  case $$AM_UPDATE_INFO_DIR in \
    n|no|NO) false;; \
    *) (install-info --version) >/dev/null 2>&1;; \
HEADERS = $(include_HEADERS)
am__tagged_files = $(HEADERS) $(SOURCES) $(TAGS_FILES) $(LISP)
# Read a list of newline-separated strings from the standard input,
# and print each of them once, without duplicates.  Input order is
# *not* preserved.
am__uniquify_input = $(AWK) '\
  BEGIN { nonempty = 0; } \
  { items[$$0] = 1; nonempty = 1; } \
  END { if (nonempty) { for (i in items) print i; }; } \
# Make sure the list of sources is unique.  This is necessary because,
# e.g., the same source file might be shared among _SOURCES variables
# for different programs/libraries.
am__define_uniq_tagged_files = \
  list='$(am__tagged_files)'; \
  unique=`for i in $$list; do \
    if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \
  done | $(am__uniquify_input)`
ETAGS = etags
CTAGS = ctags
DISTFILES = $(DIST_COMMON) $(DIST_SOURCES) $(TEXINFOS) $(EXTRA_DIST)
ACLOCAL = ${SHELL} /mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/source/missing aclocal-1.14
AMTAR = $${TAR-tar}
AM_DEFAULT_VERBOSITY = 1
AR = arm-anykav500-linux-gnueabi-ar
AUTOCONF = ${SHELL} /mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/source/missing autoconf
AUTOHEADER = ${SHELL} /mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/source/missing autoheader
AUTOMAKE = ${SHELL} /mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/source/missing automake-1.14
AWK = gawk
CC = arm-anykav500-linux-gnueabi-gcc
CCDEPMODE = depmode=gcc3
CFLAGS = -Wall -funwind-tables -g -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0/glib -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0 -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/glib-2.0/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/nopoll -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/gstreamer-1.0  -DPLATFORM_AK3761D=1 -DDEV_ids=1
CPP = arm-anykav500-linux-gnueabi-gcc  -E
CPPFLAGS = -g -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0/glib -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0 -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/glib-2.0/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/nopoll -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/gstreamer-1.0
CXX = arm-anykav500-linux-gnueabi-g++
CXXCPP = arm-anykav500-linux-gnueabi-g++  -E
CXXDEPMODE = depmode=gcc3
CXXFLAGS = -g -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0/glib -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/glib-2.0 -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/glib-2.0/include -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/nopoll -I/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/include/gstreamer-1.0
CYGPATH_W = echo
DEFS = -DHAVE_CONFIG_H
DEPDIR = .deps
DLLTOOL = false
DSYMUTIL =
DUMPBIN =
ECHO_C =
ECHO_N = -n
ECHO_T =
EGREP = /bin/grep -E
EXEEXT =
FGREP = /bin/grep -F
GREP = /bin/grep
INSTALL = /usr/bin/install -c
INSTALL_DATA = ${INSTALL} -m 644
INSTALL_PROGRAM = ${INSTALL}
INSTALL_SCRIPT = ${INSTALL}
INSTALL_STRIP_PROGRAM = $(install_sh) -c -s
LD = arm-anykav500-linux-gnueabi-ld
LDFLAGS = -L/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib  -L/mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install/lib/gstreamer-1.0
LIBOBJS =
LIBS =
LIBTOOL = $(SHELL) $(top_builddir)/libtool
LIB_DIR = ak3761d
LIPO =
LN_S = ln -s
LTLIBOBJS =
MAKEINFO = ${SHELL} /mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/source/missing makeinfo
MANIFEST_TOOL = :
MKDIR_P = /bin/mkdir -p
NM = arm-anykav500-linux-gnueabi-nm
NMEDIT =
OBJDUMP = arm-anykav500-linux-gnueabi-objdump
OBJEXT = o
OTOOL =
OTOOL64 =
PACKAGE = qvcloud
PACKAGE_BUGREPORT =
PACKAGE_NAME = qvcloud
PACKAGE_STRING = qvcloud 1.0
PACKAGE_TARNAME = qvcloud
PACKAGE_URL =
PACKAGE_VERSION = 1.0
PATH_SEPARATOR = :
RANLIB = arm-anykav500-linux-gnueabi-ranlib
SED = /bin/sed
SET_MAKE =
SHELL = /bin/sh
STRIP = arm-anykav500-linux-gnueabi-strip
VERSION = 1.0
abs_builddir = /mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/source/src
abs_srcdir = /mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/source/src
abs_top_builddir = /mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/source
abs_top_srcdir = /mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/source
ac_ct_AR =
ac_ct_CC =
ac_ct_CXX =
ac_ct_DUMPBIN =
am__include = include
am__leading_dot = .
am__quote =
am__tar = $${TAR-tar} chof - "$$tardir"
am__untar = $${TAR-tar} xf -
bindir = ${exec_prefix}/bin
build = x86_64-pc-linux-gnu
build_alias = x86_64-linux-gnu
build_cpu = x86_64
build_os = linux-gnu
build_vendor = pc
builddir = .
datadir = ${datarootdir}
datarootdir = ${prefix}/share
docdir = ${datarootdir}/doc/${PACKAGE_TARNAME}
dvidir = ${docdir}
exec_prefix = ${prefix}
host = arm-anykav500-linux-gnueabi
host_alias = arm-anykav500-linux-gnueabi
host_cpu = arm
host_os = linux-gnueabi
host_vendor = anykav500
htmldir = ${docdir}
includedir = ${prefix}/include
infodir = ${datarootdir}/info
install_sh = ${SHELL} /mnt/sda/home/gunyingjie/work/version/94B1/app/public/custom/cloud/cloud-2.2/source/install-sh
libdir = ${exec_prefix}/lib
libexecdir = ${exec_prefix}/libexec
localedir = ${datarootdir}/locale
localstatedir = ${prefix}/var
mandir = ${datarootdir}/man
mkdir_p = $(MKDIR_P)
oldincludedir = /usr/include
pdfdir = ${docdir}
prefix = /mnt/sda/home/gunyingjie/work/version/94B1/build/ak3761d/install
program_transform_name = s,x,x,
psdir = ${docdir}
sbindir = ${exec_prefix}/sbin
sharedstatedir = ${prefix}/com
srcdir = .
sysconfdir = ${prefix}/etc
target_alias = arm-anykav500-linux-gnueabi
top_build_prefix = ../
top_builddir = ..
top_srcdir = ..
AUTOMAKE_OPTIONS = foreign
lib_LTLIBRARIES = libqvcloud.la
libqvcloud_la_CFLAGS = -DLINUX
libqvcloud_la_CXXFLAGS = -DLINUX
libqvcloud_la_SOURCES = QVCloud.cpp
include_HEADERS = QVCloud.h
all: all-am
.SUFFIXES:
.SUFFIXES: .cpp .lo .o .obj
$(srcdir)/Makefile.in:  $(srcdir)/Makefile.am  $(am__configure_deps)
	@for dep in $?; do \
	  case '$(am__configure_deps)' in \
	    *$$dep*) \
	      ( cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh ) \
	        && { if test -f $@; then exit 0; else break; fi; }; \
	      exit 1;; \
	  esac; \
	done; \
	echo ' cd $(top_srcdir) && $(AUTOMAKE) --foreign src/Makefile'; \
	$(am__cd) $(top_srcdir) && \
.PRECIOUS: Makefile
Makefile: $(srcdir)/Makefile.in $(top_builddir)/config.status
	@case '$?' in \
	  *config.status*) \
	    cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh;; \
	    echo ' cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe)'; \
	    cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe);; \
	esac;
$(top_builddir)/config.status: $(top_srcdir)/configure $(CONFIG_STATUS_DEPENDENCIES)
$(top_srcdir)/configure:  $(am__configure_deps)
$(ACLOCAL_M4):  $(am__aclocal_m4_deps)
$(am__aclocal_m4_deps):
install-libLTLIBRARIES: $(lib_LTLIBRARIES)
	@$(NORMAL_INSTALL)
	@list='$(lib_LTLIBRARIES)'; test -n "$(libdir)" || list=; \
	list2=; for p in $$list; do \
	  if test -f $$p; then \
	    list2="$$list2 $$p"; \
	  else :; fi; \
	done; \
	test -z "$$list2" || { \
	  echo " $(MKDIR_P) '$(DESTDIR)$(libdir)'"; \
	  $(MKDIR_P) "$(DESTDIR)$(libdir)" || exit 1; \
	  echo " $(LIBTOOL) $(AM_LIBTOOLFLAGS) $(LIBTOOLFLAGS) --mode=install $(INSTALL) $(INSTALL_STRIP_FLAG) $$list2 '$(DESTDIR)$(libdir)'"; \
	  $(LIBTOOL) $(AM_LIBTOOLFLAGS) $(LIBTOOLFLAGS) --mode=install $(INSTALL) $(INSTALL_STRIP_FLAG) $$list2 "$(DESTDIR)$(libdir)"; \
uninstall-libLTLIBRARIES:
	@$(NORMAL_UNINSTALL)
	  $(am__strip_dir) \
	  echo " $(LIBTOOL) $(AM_LIBTOOLFLAGS) $(LIBTOOLFLAGS) --mode=uninstall rm -f '$(DESTDIR)$(libdir)/$$f'"; \
	  $(LIBTOOL) $(AM_LIBTOOLFLAGS) $(LIBTOOLFLAGS) --mode=uninstall rm -f "$(DESTDIR)$(libdir)/$$f"; \
clean-libLTLIBRARIES:
	-test -z "$(lib_LTLIBRARIES)" || rm -f $(lib_LTLIBRARIES)
	@list='$(lib_LTLIBRARIES)'; \
	locs=`for p in $$list; do echo $$p; done | \
	      sed 's|^[^/]*$$|.|; s|/[^/]*$$||; s|$$|/so_locations|' | \
	      sort -u`; \
	test -z "$$locs" || { \
	  echo rm -f $${locs}; \
	  rm -f $${locs}; \
libqvcloud.la: $(libqvcloud_la_OBJECTS) $(libqvcloud_la_DEPENDENCIES) $(EXTRA_libqvcloud_la_DEPENDENCIES)
	$(AM_V_CXXLD)$(libqvcloud_la_LINK) -rpath $(libdir) $(libqvcloud_la_OBJECTS) $(libqvcloud_la_LIBADD) $(LIBS)
mostlyclean-compile:
	-rm -f *.$(OBJEXT)
distclean-compile:
	-rm -f *.tab.c
include ./$(DEPDIR)/libqvcloud_la-QVCloud.Plo
.cpp.o:
	$(AM_V_CXX)depbase=`echo $@ | sed 's|[^/]*$$|$(DEPDIR)/&|;s|\.o$$||'`;\
	$(CXXCOMPILE) -MT $@ -MD -MP -MF $$depbase.Tpo -c -o $@ $< &&\
	$(am__mv) $$depbase.Tpo $$depbase.Po
#	$(AM_V_CXX)source='$<' object='$@' libtool=no \
#	DEPDIR=$(DEPDIR) $(CXXDEPMODE) $(depcomp) \
#	$(AM_V_CXX_no)$(CXXCOMPILE) -c -o $@ $<
.cpp.obj:
	$(AM_V_CXX)depbase=`echo $@ | sed 's|[^/]*$$|$(DEPDIR)/&|;s|\.obj$$||'`;\
	$(CXXCOMPILE) -MT $@ -MD -MP -MF $$depbase.Tpo -c -o $@ `$(CYGPATH_W) '$<'` &&\
#	$(AM_V_CXX_no)$(CXXCOMPILE) -c -o $@ `$(CYGPATH_W) '$<'`
.cpp.lo:
	$(AM_V_CXX)depbase=`echo $@ | sed 's|[^/]*$$|$(DEPDIR)/&|;s|\.lo$$||'`;\
	$(LTCXXCOMPILE) -MT $@ -MD -MP -MF $$depbase.Tpo -c -o $@ $< &&\
	$(am__mv) $$depbase.Tpo $$depbase.Plo
#	$(AM_V_CXX)source='$<' object='$@' libtool=yes \
#	$(AM_V_CXX_no)$(LTCXXCOMPILE) -c -o $@ $<
libqvcloud_la-QVCloud.lo: QVCloud.cpp
	$(AM_V_CXX)$(LIBTOOL) $(AM_V_lt) --tag=CXX $(AM_LIBTOOLFLAGS) $(LIBTOOLFLAGS) --mode=compile $(CXX) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(libqvcloud_la_CXXFLAGS) $(CXXFLAGS) -MT libqvcloud_la-QVCloud.lo -MD -MP -MF $(DEPDIR)/libqvcloud_la-QVCloud.Tpo -c -o libqvcloud_la-QVCloud.lo `test -f 'QVCloud.cpp' || echo '$(srcdir)/'`QVCloud.cpp
	$(AM_V_at)$(am__mv) $(DEPDIR)/libqvcloud_la-QVCloud.Tpo $(DEPDIR)/libqvcloud_la-QVCloud.Plo
#	$(AM_V_CXX)source='QVCloud.cpp' object='libqvcloud_la-QVCloud.lo' libtool=yes \
#	$(AM_V_CXX_no)$(LIBTOOL) $(AM_V_lt) --tag=CXX $(AM_LIBTOOLFLAGS) $(LIBTOOLFLAGS) --mode=compile $(CXX) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(libqvcloud_la_CXXFLAGS) $(CXXFLAGS) -c -o libqvcloud_la-QVCloud.lo `test -f 'QVCloud.cpp' || echo '$(srcdir)/'`QVCloud.cpp
mostlyclean-libtool:
	-rm -f *.lo
clean-libtool:
	-rm -rf .libs _libs
install-includeHEADERS: $(include_HEADERS)
	@$(NORMAL_INSTALL)
	@list='$(include_HEADERS)'; test -n "$(includedir)" || list=; \
	if test -n "$$list"; then \
	  echo " $(MKDIR_P) '$(DESTDIR)$(includedir)'"; \
	  $(MKDIR_P) "$(DESTDIR)$(includedir)" || exit 1; \
	fi; \
	  if test -f "$$p"; then d=; else d="$(srcdir)/"; fi; \
	  echo "$$d$$p"; \
	done | $(am__base_list) | \
	while read files; do \
	  echo " $(INSTALL_HEADER) $$files '$(DESTDIR)$(includedir)'"; \
	  $(INSTALL_HEADER) $$files "$(DESTDIR)$(includedir)" || exit $$?; \
uninstall-includeHEADERS:
	files=`for p in $$list; do echo $$p; done | sed -e 's|^.*/||'`; \
	dir='$(DESTDIR)$(includedir)'; $(am__uninstall_files_from_dir)
	$(am__define_uniq_tagged_files); mkid -fID $$unique
tags: tags-am
TAGS: tags
tags-am: $(TAGS_DEPENDENCIES) $(am__tagged_files)
	set x; \
	here=`pwd`; \
	$(am__define_uniq_tagged_files); \
	shift; \
	if test -z "$(ETAGS_ARGS)$$*$$unique"; then :; else \
	  test -n "$$unique" || unique=$$empty_fix; \
	  if test $$# -gt 0; then \
	    $(ETAGS) $(ETAGSFLAGS) $(AM_ETAGSFLAGS) $(ETAGS_ARGS) \
	      "$$@" $$unique; \
	  else \
	      $$unique; \
	  fi; \
ctags: ctags-am
CTAGS: ctags
ctags-am: $(TAGS_DEPENDENCIES) $(am__tagged_files)
	test -z "$(CTAGS_ARGS)$$unique" \
	  || $(CTAGS) $(CTAGSFLAGS) $(AM_CTAGSFLAGS) $(CTAGS_ARGS) \
	     $$unique
GTAGS:
	here=`$(am__cd) $(top_builddir) && pwd` \
	  && $(am__cd) $(top_srcdir) \
	  && gtags -i $(GTAGS_ARGS) "$$here"
cscopelist: cscopelist-am
cscopelist-am: $(am__tagged_files)
	case "$(srcdir)" in \
	  [\\/]* | ?:[\\/]*) sdir="$(srcdir)" ;; \
	  *) sdir=$(subdir)/$(srcdir) ;; \
	esac; \
	  if test -f "$$i"; then \
	    echo "$(subdir)/$$i"; \
	  else \
	    echo "$$sdir/$$i"; \
	  fi; \
	done >> $(top_builddir)/cscope.files
distclean-tags:
	-rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
distdir: $(DISTFILES)
	@srcdirstrip=`echo "$(srcdir)" | sed 's/[].[^$$\\*]/\\\\&/g'`; \
	topsrcdirstrip=`echo "$(top_srcdir)" | sed 's/[].[^$$\\*]/\\\\&/g'`; \
	list='$(DISTFILES)'; \
	  dist_files=`for file in $$list; do echo $$file; done | \
	  sed -e "s|^$$srcdirstrip/||;t" \
	      -e "s|^$$topsrcdirstrip/|$(top_builddir)/|;t"`; \
	case $$dist_files in \
	  */*) $(MKDIR_P) `echo "$$dist_files" | \
			   sed '/\//!d;s|^|$(distdir)/|;s,/[^/]*$$,,' | \
			   sort -u` ;; \
	esac; \
	for file in $$dist_files; do \
	  if test -f $$file || test -d $$file; then d=.; else d=$(srcdir); fi; \
	  if test -d $$d/$$file; then \
	    dir=`echo "/$$file" | sed -e 's,/[^/]*$$,,'`; \
	    if test -d "$(distdir)/$$file"; then \
	      find "$(distdir)/$$file" -type d ! -perm -700 -exec chmod u+rwx {} \;; \
	    fi; \
	    if test -d $(srcdir)/$$file && test $$d != $(srcdir); then \
	      cp -fpR $(srcdir)/$$file "$(distdir)$$dir" || exit 1; \
	    fi; \
	    cp -fpR $$d/$$file "$(distdir)$$dir" || exit 1; \
	  else \
	    test -f "$(distdir)/$$file" \
	    || cp -p $$d/$$file "$(distdir)/$$file" \
	    || exit 1; \
	  fi; \
check-am: all-am
check: check-am
all-am: Makefile $(LTLIBRARIES) $(HEADERS)
installdirs:
	for dir in "$(DESTDIR)$(libdir)" "$(DESTDIR)$(includedir)"; do \
	  test -z "$$dir" || $(MKDIR_P) "$$dir"; \
install: install-am
install-exec: install-exec-am
install-data: install-data-am
uninstall: uninstall-am
install-am: all-am
	@$(MAKE) $(AM_MAKEFLAGS) install-exec-am install-data-am
installcheck: installcheck-am
install-strip:
	if test -z '$(STRIP)'; then \
	  $(MAKE) $(AM_MAKEFLAGS) INSTALL_PROGRAM="$(INSTALL_STRIP_PROGRAM)" \
	    install_sh_PROGRAM="$(INSTALL_STRIP_PROGRAM)" INSTALL_STRIP_FLAG=-s \
	      install; \
	else \
	    "INSTALL_PROGRAM_ENV=STRIPPROG='$(STRIP)'" install; \
mostlyclean-generic:
clean-generic:
distclean-generic:
	-test -z "$(CONFIG_CLEAN_FILES)" || rm -f $(CONFIG_CLEAN_FILES)
	-test . = "$(srcdir)" || test -z "$(CONFIG_CLEAN_VPATH_FILES)" || rm -f $(CONFIG_CLEAN_VPATH_FILES)
maintainer-clean-generic:
	@echo "This command is intended for maintainers to use"
	@echo "it deletes files that may require special tools to rebuild."
clean: clean-am
clean-am: clean-generic clean-libLTLIBRARIES clean-libtool \
	mostlyclean-am
distclean: distclean-am
	-rm -rf ./$(DEPDIR)
	-rm -f Makefile
distclean-am: clean-am distclean-compile distclean-generic \
	distclean-tags
dvi: dvi-am
dvi-am:
html: html-am
html-am:
info: info-am
info-am:
install-data-am: install-includeHEADERS
install-dvi: install-dvi-am
install-dvi-am:
install-exec-am: install-libLTLIBRARIES
install-html: install-html-am
install-html-am:
install-info: install-info-am
install-info-am:
install-man:
install-pdf: install-pdf-am
install-pdf-am:
install-ps: install-ps-am
install-ps-am:
installcheck-am:
maintainer-clean: maintainer-clean-am
	-rm -rf ./$(DEPDIR)
	-rm -f Makefile
maintainer-clean-am: distclean-am maintainer-clean-generic
mostlyclean: mostlyclean-am
mostlyclean-am: mostlyclean-compile mostlyclean-generic \
	mostlyclean-libtool
pdf: pdf-am
pdf-am:
ps: ps-am
ps-am:
uninstall-am: uninstall-includeHEADERS uninstall-libLTLIBRARIES
.MAKE: install-am install-strip
.PHONY: CTAGS GTAGS TAGS all all-am check check-am clean clean-generic \
	clean-libLTLIBRARIES clean-libtool cscopelist-am ctags \
	ctags-am distclean distclean-compile distclean-generic \
	distclean-libtool distclean-tags distdir dvi dvi-am html \
	html-am info info-am install install-am install-data \
	install-data-am install-dvi install-dvi-am install-exec \
	install-exec-am install-html install-html-am \
	install-includeHEADERS install-info install-info-am \
	install-libLTLIBRARIES install-man install-pdf install-pdf-am \
	install-ps install-ps-am install-strip installcheck \
	installcheck-am installdirs maintainer-clean \
	maintainer-clean-generic mostlyclean mostlyclean-compile \
	mostlyclean-generic mostlyclean-libtool pdf pdf-am ps ps-am \
	tags tags-am uninstall uninstall-am uninstall-includeHEADERS \
# Tell versions [3.59,3.63) of GNU make to not export all variables.
# Otherwise a system limit (for SysV at least) may be exceeded.
.NOEXPORT:
