#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
# Generated by GNU Autoconf 2.69 for qvcloud 1.0.
# Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
# This configure script is free software; the Free Software Foundation
# gives unlimited permission to copy, distribute and modify it.
## M4sh Initialization. ##
# Be more Bourne compatible
DUALCASE=1; export DUALCASE # for MKS sh
if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
  emulate sh
  NULLCMD=:
  # Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
  # is contrary to our usage.  Disable this feature.
  alias -g '${1+"$@"}'='"$@"'
  setopt NO_GLOB_SUBST
  case `(set -o) 2>/dev/null` in #(
  *posix*) :
    set -o posix ;; #(
as_nl='
export as_nl
# Printing a long string crashes Solaris 7 /usr/bin/printf.
as_echo='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo$as_echo
# Prefer a ksh shell builtin over an external printf program on Solaris,
# but without wasting forks for bash or zsh.
if test -z "$BASH_VERSION$ZSH_VERSION" \
    && (test "X`print -r -- $as_echo`" = "X$as_echo") 2>/dev/null; then
  as_echo='print -r --'
  as_echo_n='print -rn --'
elif (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
  as_echo='printf %s\n'
  as_echo_n='printf %s'
  if test "X`(/usr/ucb/echo -n -n $as_echo) 2>/dev/null`" = "X-n $as_echo"; then
    as_echo_body='eval /usr/ucb/echo -n "$1$as_nl"'
    as_echo_n='/usr/ucb/echo -n'
    as_echo_body='eval expr "X$1" : "X\\(.*\\)"'
    as_echo_n_body='eval
      arg=$1;
      case $arg in #(
      *"$as_nl"*)
	expr "X$arg" : "X\\(.*\\)$as_nl";
	arg=`expr "X$arg" : ".*$as_nl\\(.*\\)"`;;
      esac;
      expr "X$arg" : "X\\(.*\\)" | tr -d "$as_nl"
    export as_echo_n_body
    as_echo_n='sh -c $as_echo_n_body as_echo'
  export as_echo_body
  as_echo='sh -c $as_echo_body as_echo'
# The user is always right.
if test "${PATH_SEPARATOR+set}" != set; then
  PATH_SEPARATOR=:
  (PATH='/bin;/bin'; FPATH=$PATH; sh -c :) >/dev/null 2>&1 && {
    (PATH='/bin:/bin'; FPATH=$PATH; sh -c :) >/dev/null 2>&1 ||
      PATH_SEPARATOR=';'
# IFS
# We need space, tab and new line, in precisely that order.  Quoting is
# there to prevent editors from complaining about space-tab.
# (If _AS_PATH_WALK were called with IFS unset, it would disable word
# splitting by setting IFS to empty value.)
IFS=" ""	$as_nl"
# Find who we are.  Look in the path if we contain no directory separator.
as_myself=
case $0 in #((
  *[\\/]* ) as_myself=$0 ;;
  *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in $PATH
do
  IFS=$as_save_IFS
  test -z "$as_dir" && as_dir=.
    test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
IFS=$as_save_IFS
# We did not find ourselves, most probably we were run as `sh COMMAND'
# in which case we are not to be found in the path.
if test "x$as_myself" = x; then
  as_myself=$0
if test ! -f "$as_myself"; then
  $as_echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
  exit 1
# Unset variables that we do not need and which cause bugs (e.g. in
# pre-3.0 UWIN ksh).  But do not cause bugs in bash 2.01; the "|| exit 1"
# suppresses any "Segmentation fault" message there.  '((' could
# trigger a bug in pdksh 5.2.14.
for as_var in BASH_ENV ENV MAIL MAILPATH
do eval test x\${$as_var+set} = xset \
  && ( (unset $as_var) || exit 1) >/dev/null 2>&1 && unset $as_var || :
PS1='$ '
PS2='> '
PS4='+ '
# NLS nuisances.
LC_ALL=C
export LC_ALL
LANGUAGE=C
export LANGUAGE
# CDPATH.
(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
# Use a proper internal environment variable to ensure we don't fall
  # into an infinite loop, continuously re-executing ourselves.
  if test x"${_as_can_reexec}" != xno && test "x$CONFIG_SHELL" != x; then
    _as_can_reexec=no; export _as_can_reexec;
    # We cannot yet assume a decent shell, so we have to provide a
# neutralization value for shells without unset; and this also
# works around shells that cannot unset nonexistent variables.
# Preserve -v and -x to the replacement shell.
BASH_ENV=/dev/null
ENV=/dev/null
(unset BASH_ENV) >/dev/null 2>&1 && unset BASH_ENV ENV
case $- in # ((((
  *v*x* | *x*v* ) as_opts=-vx ;;
  *v* ) as_opts=-v ;;
  *x* ) as_opts=-x ;;
  * ) as_opts= ;;
exec $CONFIG_SHELL $as_opts "$as_myself" ${1+"$@"}
# Admittedly, this is quite paranoid, since all the known shells bail
# out after a failed `exec'.
$as_echo "$0: could not re-execute with $CONFIG_SHELL" >&2
as_fn_exit 255
  # We don't want this to propagate to other subprocesses.
          { _as_can_reexec=; unset _as_can_reexec;}
if test "x$CONFIG_SHELL" = x; then
  as_bourne_compatible="if test -n \"\${ZSH_VERSION+set}\" && (emulate sh) >/dev/null 2>&1; then :
  emulate sh
  NULLCMD=:
  # Pre-4.2 versions of Zsh do word splitting on \${1+\"\$@\"}, which
  alias -g '\${1+\"\$@\"}'='\"\$@\"'
  case \`(set -o) 2>/dev/null\` in #(
  *posix*) :
    set -o posix ;; #(
  as_required="as_fn_return () { (exit \$1); }
as_fn_success () { as_fn_return 0; }
as_fn_failure () { as_fn_return 1; }
as_fn_ret_success () { return 0; }
as_fn_ret_failure () { return 1; }
exitcode=0
as_fn_success || { exitcode=1; echo as_fn_success failed.; }
as_fn_failure && { exitcode=1; echo as_fn_failure succeeded.; }
as_fn_ret_success || { exitcode=1; echo as_fn_ret_success failed.; }
as_fn_ret_failure && { exitcode=1; echo as_fn_ret_failure succeeded.; }
if ( set x; as_fn_ret_success y && test x = \"\$1\" ); then :
  exitcode=1; echo positional parameters were not saved.
test x\$exitcode = x0 || exit 1
test -x / || exit 1"
  as_suggested="  as_lineno_1=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_1a=\$LINENO
  as_lineno_2=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_2a=\$LINENO
  eval 'test \"x\$as_lineno_1'\$as_run'\" != \"x\$as_lineno_2'\$as_run'\" &&
  test \"x\`expr \$as_lineno_1'\$as_run' + 1\`\" = \"x\$as_lineno_2'\$as_run'\"' || exit 1
  test -n \"\${ZSH_VERSION+set}\${BASH_VERSION+set}\" || (
    ECHO='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
    ECHO=\$ECHO\$ECHO\$ECHO\$ECHO\$ECHO
    ECHO=\$ECHO\$ECHO\$ECHO\$ECHO\$ECHO\$ECHO
    PATH=/empty FPATH=/empty; export PATH FPATH
    test \"X\`printf %s \$ECHO\`\" = \"X\$ECHO\" \\
      || test \"X\`print -r -- \$ECHO\`\" = \"X\$ECHO\" ) || exit 1
test \$(( 1 + 1 )) = 2 || exit 1"
  if (eval "$as_required") 2>/dev/null; then :
  as_have_required=yes
  as_have_required=no
  if test x$as_have_required = xyes && (eval "$as_suggested") 2>/dev/null; then :
as_found=false
for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
do
  IFS=$as_save_IFS
  as_found=:
  case $as_dir in #(
	   for as_base in sh bash ksh sh5; do
	     # Try only shells that exist, to save several forks.
	     as_shell=$as_dir/$as_base
	     if { test -f "$as_shell" || test -f "$as_shell.exe"; } &&
		    { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$as_shell"; } 2>/dev/null; then :
  CONFIG_SHELL=$as_shell as_have_required=yes
		   if { $as_echo "$as_bourne_compatible""$as_suggested" | as_run=a "$as_shell"; } 2>/dev/null; then :
  break 2
	   done;;
  as_found=false
$as_found || { if { test -f "$SHELL" || test -f "$SHELL.exe"; } &&
	      { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$SHELL"; } 2>/dev/null; then :
  CONFIG_SHELL=$SHELL as_have_required=yes
fi; }
IFS=$as_save_IFS
      if test "x$CONFIG_SHELL" != x; then :
  export CONFIG_SHELL
BASH_ENV=/dev/null
ENV=/dev/null
case $- in # ((((
  *v* ) as_opts=-v ;;
  *x* ) as_opts=-x ;;
  * ) as_opts= ;;
exit 255
    if test x$as_have_required = xno; then :
  $as_echo "$0: This script requires a shell more modern than all"
  $as_echo "$0: the shells that I found on your system."
  if test x${ZSH_VERSION+set} = xset ; then
    $as_echo "$0: In particular, zsh $ZSH_VERSION has bugs and should"
    $as_echo "$0: be upgraded to zsh 4.3.4 or later."
    $as_echo "$0: Please tell bug-autoconf@gnu.org about your system,
$0: including any error possibly output before this
$0: message. Then install a modern shell, or manually run
$0: the script under such a shell if you do have one."
  exit 1
SHELL=${CONFIG_SHELL-/bin/sh}
export SHELL
# Unset more variables known to interfere with behavior of common tools.
CLICOLOR_FORCE= GREP_OPTIONS=
unset CLICOLOR_FORCE GREP_OPTIONS
## M4sh Shell Functions. ##
# as_fn_unset VAR
# Portably unset VAR.
as_fn_unset ()
  { eval $1=; unset $1;}
as_unset=as_fn_unset
# as_fn_set_status STATUS
# Set $? to STATUS, without forking.
as_fn_set_status ()
  return $1
} # as_fn_set_status
# as_fn_exit STATUS
# Exit the shell with STATUS, even in a "trap 0" or "set -e" context.
as_fn_exit ()
  set +e
  as_fn_set_status $1
  exit $1
} # as_fn_exit
# as_fn_mkdir_p
# Create "$as_dir" as a directory, including parents if necessary.
as_fn_mkdir_p ()
  case $as_dir in #(
  -*) as_dir=./$as_dir;;
  test -d "$as_dir" || eval $as_mkdir_p || {
    as_dirs=
    while :; do
      case $as_dir in #(
      *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
      *) as_qdir=$as_dir;;
      as_dirs="'$as_qdir' $as_dirs"
      as_dir=`$as_dirname -- "$as_dir" ||
$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
	 X"$as_dir" : 'X\(//\)[^/]' \| \
	 X"$as_dir" : 'X\(//\)$' \| \
	 X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
$as_echo X"$as_dir" |
    sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
	    s//\1/
	    q
	  /^X\(\/\/\)[^/].*/{
	    s//\1/
	    q
	  /^X\(\/\/\)$/{
	    s//\1/
	    q
	  /^X\(\/\).*/{
	    s//\1/
	    q
	  s/.*/./; q'`
      test -d "$as_dir" && break
    test -z "$as_dirs" || eval "mkdir $as_dirs"
  } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
} # as_fn_mkdir_p
# as_fn_executable_p FILE
# Test if FILE is an executable regular file.
as_fn_executable_p ()
  test -f "$1" && test -x "$1"
} # as_fn_executable_p
# as_fn_append VAR VALUE
# Append the text in VALUE to the end of the definition contained in VAR. Take
# advantage of any shell optimizations that allow amortized linear growth over
# repeated appends, instead of the typical quadratic growth present in naive
# implementations.
if (eval "as_var=1; as_var+=2; test x\$as_var = x12") 2>/dev/null; then :
  eval 'as_fn_append ()
    eval $1+=\$2
  as_fn_append ()
    eval $1=\$$1\$2
fi # as_fn_append
# as_fn_arith ARG...
# Perform arithmetic evaluation on the ARGs, and store the result in the
# global $as_val. Take advantage of shells that can avoid forks. The arguments
# must be portable across $(()) and expr.
if (eval "test \$(( 1 + 1 )) = 2") 2>/dev/null; then :
  eval 'as_fn_arith ()
    as_val=$(( $* ))
  as_fn_arith ()
    as_val=`expr "$@" || test $? -eq 1`
fi # as_fn_arith
# as_fn_error STATUS ERROR [LINENO LOG_FD]
# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
# script with STATUS, using 1 if that was 0.
as_fn_error ()
  as_status=$1; test $as_status -eq 0 && as_status=1
  if test "$4"; then
    as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
    $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
  $as_echo "$as_me: error: $2" >&2
  as_fn_exit $as_status
} # as_fn_error
if expr a : '\(a\)' >/dev/null 2>&1 &&
   test "X`expr 00001 : '.*\(...\)'`" = X001; then
  as_expr=expr
  as_expr=false
if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
  as_basename=basename
  as_basename=false
if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
  as_dirname=dirname
  as_dirname=false
as_me=`$as_basename -- "$0" ||
$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
	 X"$0" : 'X\(//\)$' \| \
	 X"$0" : 'X\(/\)' \| . 2>/dev/null ||
$as_echo X/"$0" |
    sed '/^.*\/\([^/][^/]*\)\/*$/{
	    s//\1/
	    q
	  /^X\/\(\/\/\)$/{
	    s//\1/
	    q
	  /^X\/\(\/\).*/{
	    s//\1/
	    q
	  s/.*/./; q'`
# Avoid depending upon Character Ranges.
as_cr_letters='abcdefghijklmnopqrstuvwxyz'
as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
as_cr_Letters=$as_cr_letters$as_cr_LETTERS
as_cr_digits='0123456789'
as_cr_alnum=$as_cr_Letters$as_cr_digits
  as_lineno_1=$LINENO as_lineno_1a=$LINENO
  as_lineno_2=$LINENO as_lineno_2a=$LINENO
  eval 'test "x$as_lineno_1'$as_run'" != "x$as_lineno_2'$as_run'" &&
  test "x`expr $as_lineno_1'$as_run' + 1`" = "x$as_lineno_2'$as_run'"' || {
  # Blame Lee E. McMahon (1931-1989) for sed's syntax.  :-)
  sed -n '
    p
    /[$]LINENO/=
  ' <$as_myself |
    sed '
      s/[$]LINENO.*/&-/
      t lineno
      b
      :lineno
      N
      :loop
      s/[$]LINENO\([^'$as_cr_alnum'_].*\n\)\(.*\)/\2\1\2/
      t loop
      s/-\n.*//
    ' >$as_me.lineno &&
  chmod +x "$as_me.lineno" ||
    { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2; as_fn_exit 1; }
  # If we had to re-execute with $CONFIG_SHELL, we're ensured to have
  # already done that, so ensure we don't try to do so again and fall
  # in an infinite loop.  This has already happened in practice.
  # Don't try to exec as it changes $[0], causing all sort of problems
  # (the dirname of $[0] is not the place where we might find the
  # original and so on.  Autoconf is especially sensitive to this).
  . "./$as_me.lineno"
  # Exit status is that of the last command.
  exit
ECHO_C= ECHO_N= ECHO_T=
case `echo -n x` in #(((((
-n*)
  case `echo 'xy\c'` in
  *c*) ECHO_T='	';;	# ECHO_T is single tab character.
  xy)  ECHO_C='\c';;
  *)   echo `echo ksh88 bug on AIX 6.1` > /dev/null
       ECHO_T='	';;
  esac;;
  ECHO_N='-n';;
rm -f conf$$ conf$$.exe conf$$.file
if test -d conf$$.dir; then
  rm -f conf$$.dir/conf$$.file
  rm -f conf$$.dir
  mkdir conf$$.dir 2>/dev/null
if (echo >conf$$.file) 2>/dev/null; then
  if ln -s conf$$.file conf$$ 2>/dev/null; then
    as_ln_s='ln -s'
    # ... but there are two gotchas:
    # 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
    # 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
    # In both cases, we have to default to `cp -pR'.
    ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
      as_ln_s='cp -pR'
  elif ln conf$$.file conf$$ 2>/dev/null; then
    as_ln_s=ln
    as_ln_s='cp -pR'
  as_ln_s='cp -pR'
rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
rmdir conf$$.dir 2>/dev/null
if mkdir -p . 2>/dev/null; then
  as_mkdir_p='mkdir -p "$as_dir"'
  test -d ./-p && rmdir ./-p
  as_mkdir_p=false
as_test_x='test -x'
as_executable_p=as_fn_executable_p
# Sed expression to map a string onto a valid CPP name.
as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
# Sed expression to map a string onto a valid variable name.
as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
test -n "$DJDIR" || exec 7<&0 </dev/null
exec 6>&1
# Name of the host.
# hostname on some systems (SVR3.2, old GNU/Linux) returns a bogus exit status,
# so uname gets run too.
ac_hostname=`(hostname || uname -n) 2>/dev/null | sed 1q`
# Initializations.
ac_default_prefix=/usr/local
ac_clean_files=
ac_config_libobj_dir=.
LIBOBJS=
cross_compiling=no
subdirs=
MFLAGS=
MAKEFLAGS=
# Identity of this package.
PACKAGE_NAME='qvcloud'
PACKAGE_TARNAME='qvcloud'
PACKAGE_VERSION='1.0'
PACKAGE_STRING='qvcloud 1.0'
PACKAGE_BUGREPORT=''
PACKAGE_URL=''
ac_unique_file="src/NetWorkService.cpp"
# Factoring default headers for most tests.
ac_includes_default="\
#ifdef HAVE_SYS_TYPES_H
# include <sys/types.h>
#ifdef HAVE_SYS_STAT_H
# include <sys/stat.h>
#ifdef STDC_HEADERS
# include <stdlib.h>
# include <stddef.h>
# ifdef HAVE_STDLIB_H
# endif
#ifdef HAVE_STRING_H
# if !defined STDC_HEADERS && defined HAVE_MEMORY_H
#  include <memory.h>
# endif
# include <string.h>
#ifdef HAVE_STRINGS_H
# include <strings.h>
#ifdef HAVE_INTTYPES_H
# include <inttypes.h>
#ifdef HAVE_STDINT_H
# include <stdint.h>
#ifdef HAVE_UNISTD_H
# include <unistd.h>
#endif"
ac_subst_vars='am__EXEEXT_FALSE
am__EXEEXT_TRUE
LTLIBOBJS
LIBOBJS
LIB_DIR
CXXCPP
CPP
OTOOL64
OTOOL
LIPO
NMEDIT
DSYMUTIL
MANIFEST_TOOL
ac_ct_AR
AR
DLLTOOL
OBJDUMP
LN_S
NM
ac_ct_DUMPBIN
DUMPBIN
LD
FGREP
EGREP
GREP
SED
host_os
host_vendor
host_cpu
host
build_os
build_vendor
build_cpu
build
LIBTOOL
RANLIB
am__fastdepCXX_FALSE
am__fastdepCXX_TRUE
CXXDEPMODE
ac_ct_CXX
CXXFLAGS
CXX
am__fastdepCC_FALSE
am__fastdepCC_TRUE
CCDEPMODE
am__nodep
AMDEPBACKSLASH
AMDEP_FALSE
AMDEP_TRUE
am__quote
am__include
DEPDIR
OBJEXT
EXEEXT
ac_ct_CC
CPPFLAGS
LDFLAGS
CFLAGS
CC
AM_BACKSLASH
AM_DEFAULT_VERBOSITY
AM_DEFAULT_V
AM_V
am__untar
am__tar
AMTAR
am__leading_dot
SET_MAKE
AWK
mkdir_p
MKDIR_P
INSTALL_STRIP_PROGRAM
STRIP
install_sh
MAKEINFO
AUTOHEADER
AUTOMAKE
AUTOCONF
ACLOCAL
VERSION
PACKAGE
CYGPATH_W
am__isrc
INSTALL_DATA
INSTALL_SCRIPT
INSTALL_PROGRAM
target_alias
host_alias
build_alias
LIBS
ECHO_T
ECHO_N
ECHO_C
DEFS
mandir
localedir
libdir
psdir
pdfdir
dvidir
htmldir
infodir
docdir
oldincludedir
includedir
localstatedir
sharedstatedir
sysconfdir
datadir
datarootdir
libexecdir
sbindir
bindir
program_transform_name
prefix
exec_prefix
PACKAGE_URL
PACKAGE_BUGREPORT
PACKAGE_STRING
PACKAGE_VERSION
PACKAGE_TARNAME
PACKAGE_NAME
PATH_SEPARATOR
SHELL'
ac_subst_files=''
ac_user_opts='
enable_option_checking
enable_silent_rules
enable_dependency_tracking
enable_shared
enable_static
with_pic
enable_fast_install
with_gnu_ld
with_sysroot
enable_libtool_lock
with_platform
enable_platform
      ac_precious_vars='build_alias
host_alias
target_alias
CC
CFLAGS
LDFLAGS
LIBS
CPPFLAGS
CXX
CXXFLAGS
CCC
CPP
CXXCPP'
# Initialize some variables set by options.
ac_init_help=
ac_init_version=false
ac_unrecognized_opts=
ac_unrecognized_sep=
# The variables have the same names as the options, with
# dashes changed to underlines.
cache_file=/dev/null
exec_prefix=NONE
no_create=
no_recursion=
prefix=NONE
program_prefix=NONE
program_suffix=NONE
program_transform_name=s,x,x,
silent=
site=
srcdir=
verbose=
x_includes=NONE
x_libraries=NONE
# Installation directory options.
# These are left unexpanded so users can "make install exec_prefix=/foo"
# and all the variables that are supposed to be based on exec_prefix
# by default will actually change.
# Use braces instead of parens because sh, perl, etc. also accept them.
# (The list follows the same order as the GNU Coding Standards.)
bindir='${exec_prefix}/bin'
sbindir='${exec_prefix}/sbin'
libexecdir='${exec_prefix}/libexec'
datarootdir='${prefix}/share'
datadir='${datarootdir}'
sysconfdir='${prefix}/etc'
sharedstatedir='${prefix}/com'
localstatedir='${prefix}/var'
includedir='${prefix}/include'
oldincludedir='/usr/include'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
infodir='${datarootdir}/info'
htmldir='${docdir}'
dvidir='${docdir}'
pdfdir='${docdir}'
psdir='${docdir}'
libdir='${exec_prefix}/lib'
localedir='${datarootdir}/locale'
mandir='${datarootdir}/man'
ac_prev=
ac_dashdash=
for ac_option
do
  # If the previous option needs an argument, assign it.
  if test -n "$ac_prev"; then
    eval $ac_prev=\$ac_option
    ac_prev=
    continue
  case $ac_option in
  *=?*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
  *=)   ac_optarg= ;;
  *)    ac_optarg=yes ;;
  # Accept the important Cygnus configure options, so we can diagnose typos.
  case $ac_dashdash$ac_option in
    ac_dashdash=yes ;;
  -bindir | --bindir | --bindi | --bind | --bin | --bi)
    ac_prev=bindir ;;
  -bindir=* | --bindir=* | --bindi=* | --bind=* | --bin=* | --bi=*)
    bindir=$ac_optarg ;;
  -build | --build | --buil | --bui | --bu)
    ac_prev=build_alias ;;
  -build=* | --build=* | --buil=* | --bui=* | --bu=*)
    build_alias=$ac_optarg ;;
  -cache-file | --cache-file | --cache-fil | --cache-fi \
  | --cache-f | --cache- | --cache | --cach | --cac | --ca | --c)
    ac_prev=cache_file ;;
  -cache-file=* | --cache-file=* | --cache-fil=* | --cache-fi=* \
  | --cache-f=* | --cache-=* | --cache=* | --cach=* | --cac=* | --ca=* | --c=*)
    cache_file=$ac_optarg ;;
  --config-cache | -C)
    cache_file=config.cache ;;
  -datadir | --datadir | --datadi | --datad)
    ac_prev=datadir ;;
  -datadir=* | --datadir=* | --datadi=* | --datad=*)
    datadir=$ac_optarg ;;
  -datarootdir | --datarootdir | --datarootdi | --datarootd | --dataroot \
  | --dataroo | --dataro | --datar)
    ac_prev=datarootdir ;;
  -datarootdir=* | --datarootdir=* | --datarootdi=* | --datarootd=* \
  | --dataroot=* | --dataroo=* | --dataro=* | --datar=*)
    datarootdir=$ac_optarg ;;
  -disable-* | --disable-*)
    ac_useropt=`expr "x$ac_option" : 'x-*disable-\(.*\)'`
    # Reject names that are not valid shell variable names.
    expr "x$ac_useropt" : ".*[^-+._$as_cr_alnum]" >/dev/null &&
      as_fn_error $? "invalid feature name: $ac_useropt"
    ac_useropt_orig=$ac_useropt
    ac_useropt=`$as_echo "$ac_useropt" | sed 's/[-+.]/_/g'`
    case $ac_user_opts in
"enable_$ac_useropt"
      *) ac_unrecognized_opts="$ac_unrecognized_opts$ac_unrecognized_sep--disable-$ac_useropt_orig"
	 ac_unrecognized_sep=', ';;
    eval enable_$ac_useropt=no ;;
  -docdir | --docdir | --docdi | --doc | --do)
    ac_prev=docdir ;;
  -docdir=* | --docdir=* | --docdi=* | --doc=* | --do=*)
    docdir=$ac_optarg ;;
  -dvidir | --dvidir | --dvidi | --dvid | --dvi | --dv)
    ac_prev=dvidir ;;
  -dvidir=* | --dvidir=* | --dvidi=* | --dvid=* | --dvi=* | --dv=*)
    dvidir=$ac_optarg ;;
  -enable-* | --enable-*)
    ac_useropt=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'`
      *) ac_unrecognized_opts="$ac_unrecognized_opts$ac_unrecognized_sep--enable-$ac_useropt_orig"
    eval enable_$ac_useropt=\$ac_optarg ;;
  -exec-prefix | --exec_prefix | --exec-prefix | --exec-prefi \
  | --exec-pref | --exec-pre | --exec-pr | --exec-p | --exec- \
  | --exec | --exe | --ex)
    ac_prev=exec_prefix ;;
  -exec-prefix=* | --exec_prefix=* | --exec-prefix=* | --exec-prefi=* \
  | --exec-pref=* | --exec-pre=* | --exec-pr=* | --exec-p=* | --exec-=* \
  | --exec=* | --exe=* | --ex=*)
    exec_prefix=$ac_optarg ;;
  -gas | --gas | --ga | --g)
    # Obsolete; use --with-gas.
    with_gas=yes ;;
  -help | --help | --hel | --he | -h)
    ac_init_help=long ;;
  -help=r* | --help=r* | --hel=r* | --he=r* | -hr*)
    ac_init_help=recursive ;;
  -help=s* | --help=s* | --hel=s* | --he=s* | -hs*)
    ac_init_help=short ;;
  -host | --host | --hos | --ho)
    ac_prev=host_alias ;;
  -host=* | --host=* | --hos=* | --ho=*)
    host_alias=$ac_optarg ;;
  -htmldir | --htmldir | --htmldi | --htmld | --html | --htm | --ht)
    ac_prev=htmldir ;;
  -htmldir=* | --htmldir=* | --htmldi=* | --htmld=* | --html=* | --htm=* \
  | --ht=*)
    htmldir=$ac_optarg ;;
  -includedir | --includedir | --includedi | --included | --include \
  | --includ | --inclu | --incl | --inc)
    ac_prev=includedir ;;
  -includedir=* | --includedir=* | --includedi=* | --included=* | --include=* \
  | --includ=* | --inclu=* | --incl=* | --inc=*)
    includedir=$ac_optarg ;;
  -infodir | --infodir | --infodi | --infod | --info | --inf)
    ac_prev=infodir ;;
  -infodir=* | --infodir=* | --infodi=* | --infod=* | --info=* | --inf=*)
    infodir=$ac_optarg ;;
  -libdir | --libdir | --libdi | --libd)
    ac_prev=libdir ;;
  -libdir=* | --libdir=* | --libdi=* | --libd=*)
    libdir=$ac_optarg ;;
  -libexecdir | --libexecdir | --libexecdi | --libexecd | --libexec \
  | --libexe | --libex | --libe)
    ac_prev=libexecdir ;;
  -libexecdir=* | --libexecdir=* | --libexecdi=* | --libexecd=* | --libexec=* \
  | --libexe=* | --libex=* | --libe=*)
    libexecdir=$ac_optarg ;;
  -localedir | --localedir | --localedi | --localed | --locale)
    ac_prev=localedir ;;
  -localedir=* | --localedir=* | --localedi=* | --localed=* | --locale=*)
    localedir=$ac_optarg ;;
  -localstatedir | --localstatedir | --localstatedi | --localstated \
  | --localstate | --localstat | --localsta | --localst | --locals)
    ac_prev=localstatedir ;;
  -localstatedir=* | --localstatedir=* | --localstatedi=* | --localstated=* \
  | --localstate=* | --localstat=* | --localsta=* | --localst=* | --locals=*)
    localstatedir=$ac_optarg ;;
  -mandir | --mandir | --mandi | --mand | --man | --ma | --m)
    ac_prev=mandir ;;
  -mandir=* | --mandir=* | --mandi=* | --mand=* | --man=* | --ma=* | --m=*)
    mandir=$ac_optarg ;;
  -nfp | --nfp | --nf)
    # Obsolete; use --without-fp.
    with_fp=no ;;
  -no-create | --no-create | --no-creat | --no-crea | --no-cre \
  | --no-cr | --no-c | -n)
    no_create=yes ;;
  -no-recursion | --no-recursion | --no-recursio | --no-recursi \
  | --no-recurs | --no-recur | --no-recu | --no-rec | --no-re | --no-r)
    no_recursion=yes ;;
  -oldincludedir | --oldincludedir | --oldincludedi | --oldincluded \
  | --oldinclude | --oldinclud | --oldinclu | --oldincl | --oldinc \
  | --oldin | --oldi | --old | --ol | --o)
    ac_prev=oldincludedir ;;
  -oldincludedir=* | --oldincludedir=* | --oldincludedi=* | --oldincluded=* \
  | --oldinclude=* | --oldinclud=* | --oldinclu=* | --oldincl=* | --oldinc=* \
  | --oldin=* | --oldi=* | --old=* | --ol=* | --o=*)
    oldincludedir=$ac_optarg ;;
  -prefix | --prefix | --prefi | --pref | --pre | --pr | --p)
    ac_prev=prefix ;;
  -prefix=* | --prefix=* | --prefi=* | --pref=* | --pre=* | --pr=* | --p=*)
  -program-prefix | --program-prefix | --program-prefi | --program-pref \
  | --program-pre | --program-pr | --program-p)
    ac_prev=program_prefix ;;
  -program-prefix=* | --program-prefix=* | --program-prefi=* \
  | --program-pref=* | --program-pre=* | --program-pr=* | --program-p=*)
    program_prefix=$ac_optarg ;;
  -program-suffix | --program-suffix | --program-suffi | --program-suff \
  | --program-suf | --program-su | --program-s)
    ac_prev=program_suffix ;;
  -program-suffix=* | --program-suffix=* | --program-suffi=* \
  | --program-suff=* | --program-suf=* | --program-su=* | --program-s=*)
    program_suffix=$ac_optarg ;;
  -program-transform-name | --program-transform-name \
  | --program-transform-nam | --program-transform-na \
  | --program-transform-n | --program-transform- \
  | --program-transform | --program-transfor \
  | --program-transfo | --program-transf \
  | --program-trans | --program-tran \
  | --progr-tra | --program-tr | --program-t)
    ac_prev=program_transform_name ;;
  -program-transform-name=* | --program-transform-name=* \
  | --program-transform-nam=* | --program-transform-na=* \
  | --program-transform-n=* | --program-transform-=* \
  | --program-transform=* | --program-transfor=* \
  | --program-transfo=* | --program-transf=* \
  | --program-trans=* | --program-tran=* \
  | --progr-tra=* | --program-tr=* | --program-t=*)
    program_transform_name=$ac_optarg ;;
  -pdfdir | --pdfdir | --pdfdi | --pdfd | --pdf | --pd)
    ac_prev=pdfdir ;;
  -pdfdir=* | --pdfdir=* | --pdfdi=* | --pdfd=* | --pdf=* | --pd=*)
    pdfdir=$ac_optarg ;;
  -psdir | --psdir | --psdi | --psd | --ps)
    ac_prev=psdir ;;
  -psdir=* | --psdir=* | --psdi=* | --psd=* | --ps=*)
    psdir=$ac_optarg ;;
  -q | -quiet | --quiet | --quie | --qui | --qu | --q \
  | -silent | --silent | --silen | --sile | --sil)
    silent=yes ;;
  -sbindir | --sbindir | --sbindi | --sbind | --sbin | --sbi | --sb)
    ac_prev=sbindir ;;
  -sbindir=* | --sbindir=* | --sbindi=* | --sbind=* | --sbin=* \
  | --sbi=* | --sb=*)
    sbindir=$ac_optarg ;;
  -sharedstatedir | --sharedstatedir | --sharedstatedi \
  | --sharedstated | --sharedstate | --sharedstat | --sharedsta \
  | --sharedst | --shareds | --shared | --share | --shar \
  | --sha | --sh)
    ac_prev=sharedstatedir ;;
  -sharedstatedir=* | --sharedstatedir=* | --sharedstatedi=* \
  | --sharedstated=* | --sharedstate=* | --sharedstat=* | --sharedsta=* \
  | --sharedst=* | --shareds=* | --shared=* | --share=* | --shar=* \
  | --sha=* | --sh=*)
    sharedstatedir=$ac_optarg ;;
  -site | --site | --sit)
    ac_prev=site ;;
  -site=* | --site=* | --sit=*)
    site=$ac_optarg ;;
  -srcdir | --srcdir | --srcdi | --srcd | --src | --sr)
    ac_prev=srcdir ;;
  -srcdir=* | --srcdir=* | --srcdi=* | --srcd=* | --src=* | --sr=*)
    srcdir=$ac_optarg ;;
  -sysconfdir | --sysconfdir | --sysconfdi | --sysconfd | --sysconf \
  | --syscon | --sysco | --sysc | --sys | --sy)
    ac_prev=sysconfdir ;;
  -sysconfdir=* | --sysconfdir=* | --sysconfdi=* | --sysconfd=* | --sysconf=* \
  | --syscon=* | --sysco=* | --sysc=* | --sys=* | --sy=*)
    sysconfdir=$ac_optarg ;;
  -target | --target | --targe | --targ | --tar | --ta | --t)
    ac_prev=target_alias ;;
  -target=* | --target=* | --targe=* | --targ=* | --tar=* | --ta=* | --t=*)
    target_alias=$ac_optarg ;;
  -v | -verbose | --verbose | --verbos | --verbo | --verb)
    verbose=yes ;;
  -version | --version | --versio | --versi | --vers | -V)
    ac_init_version=: ;;
  -with-* | --with-*)
    ac_useropt=`expr "x$ac_option" : 'x-*with-\([^=]*\)'`
      as_fn_error $? "invalid package name: $ac_useropt"
"with_$ac_useropt"
      *) ac_unrecognized_opts="$ac_unrecognized_opts$ac_unrecognized_sep--with-$ac_useropt_orig"
    eval with_$ac_useropt=\$ac_optarg ;;
  -without-* | --without-*)
    ac_useropt=`expr "x$ac_option" : 'x-*without-\(.*\)'`
"with_$ac_useropt"
      *) ac_unrecognized_opts="$ac_unrecognized_opts$ac_unrecognized_sep--without-$ac_useropt_orig"
    eval with_$ac_useropt=no ;;
  --x)
    # Obsolete; use --with-x.
    with_x=yes ;;
  -x-includes | --x-includes | --x-include | --x-includ | --x-inclu \
  | --x-incl | --x-inc | --x-in | --x-i)
    ac_prev=x_includes ;;
  -x-includes=* | --x-includes=* | --x-include=* | --x-includ=* | --x-inclu=* \
  | --x-incl=* | --x-inc=* | --x-in=* | --x-i=*)
    x_includes=$ac_optarg ;;
  -x-libraries | --x-libraries | --x-librarie | --x-librari \
  | --x-librar | --x-libra | --x-libr | --x-lib | --x-li | --x-l)
    ac_prev=x_libraries ;;
  -x-libraries=* | --x-libraries=* | --x-librarie=* | --x-librari=* \
  | --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*)
    x_libraries=$ac_optarg ;;
  -*) as_fn_error $? "unrecognized option: \`$ac_option'
Try \`$0 --help' for more information"
    ac_envvar=`expr "x$ac_option" : 'x\([^=]*\)='`
    case $ac_envvar in #(
      '' | [0-9]* | *[!_$as_cr_alnum]* )
      as_fn_error $? "invalid variable name: \`$ac_envvar'" ;;
    eval $ac_envvar=\$ac_optarg
    export $ac_envvar ;;
    # FIXME: should be removed in autoconf 3.0.
    $as_echo "$as_me: WARNING: you should use --build, --host, --target" >&2
    expr "x$ac_option" : ".*[^-._$as_cr_alnum]" >/dev/null &&
      $as_echo "$as_me: WARNING: invalid host type: $ac_option" >&2
    : "${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}"
  ac_option=--`echo $ac_prev | sed 's/_/-/g'`
  as_fn_error $? "missing argument to $ac_option"
if test -n "$ac_unrecognized_opts"; then
  case $enable_option_checking in
    no) ;;
    fatal) as_fn_error $? "unrecognized options: $ac_unrecognized_opts" ;;
    *)     $as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2 ;;
# Check all directory arguments for consistency.
for ac_var in	exec_prefix prefix bindir sbindir libexecdir datarootdir \
		datadir sysconfdir sharedstatedir localstatedir includedir \
		oldincludedir docdir infodir htmldir dvidir pdfdir psdir \
		libdir localedir mandir
do
  eval ac_val=\$$ac_var
  # Remove trailing slashes.
  case $ac_val in
      ac_val=`expr "X$ac_val" : 'X\(.*[^/]\)' \| "X$ac_val" : 'X\(.*\)'`
      eval $ac_var=\$ac_val;;
  # Be sure to have absolute directory names.
  case $ac_val in
    [\\/$]* | ?:[\\/]* )  continue;;
    NONE | '' ) case $ac_var in *prefix ) continue;; esac;;
  as_fn_error $? "expected an absolute directory name for --$ac_var: $ac_val"
# There might be people who depend on the old broken behavior: `$host'
# used to hold the argument of --host etc.
# FIXME: To remove some day.
build=$build_alias
host=$host_alias
target=$target_alias
if test "x$host_alias" != x; then
  if test "x$build_alias" = x; then
    cross_compiling=maybe
  elif test "x$build_alias" != "x$host_alias"; then
    cross_compiling=yes
ac_tool_prefix=
test -n "$host_alias" && ac_tool_prefix=$host_alias-
test "$silent" = yes && exec 6>/dev/null
ac_pwd=`pwd` && test -n "$ac_pwd" &&
ac_ls_di=`ls -di .` &&
ac_pwd_ls_di=`cd "$ac_pwd" && ls -di .` ||
  as_fn_error $? "working directory cannot be determined"
test "X$ac_ls_di" = "X$ac_pwd_ls_di" ||
  as_fn_error $? "pwd does not report name of working directory"
# Find the source files, if location was not specified.
if test -z "$srcdir"; then
  ac_srcdir_defaulted=yes
  # Try the directory containing this script, then the parent directory.
  ac_confdir=`$as_dirname -- "$as_myself" ||
$as_expr X"$as_myself" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
	 X"$as_myself" : 'X\(//\)[^/]' \| \
	 X"$as_myself" : 'X\(//\)$' \| \
	 X"$as_myself" : 'X\(/\)' \| . 2>/dev/null ||
$as_echo X"$as_myself" |
	    s//\1/
	    q
	  /^X\(\/\/\)[^/].*/{
	    s//\1/
	    q
	  /^X\(\/\/\)$/{
	    s//\1/
	    q
	  /^X\(\/\).*/{
	    s//\1/
	    q
	  s/.*/./; q'`
  srcdir=$ac_confdir
  if test ! -r "$srcdir/$ac_unique_file"; then
    srcdir=..
  ac_srcdir_defaulted=no
  test "$ac_srcdir_defaulted" = yes && srcdir="$ac_confdir or .."
  as_fn_error $? "cannot find sources ($ac_unique_file) in $srcdir"
ac_msg="sources are in $srcdir, but \`cd $srcdir' does not work"
ac_abs_confdir=`(
	cd "$srcdir" && test -r "./$ac_unique_file" || as_fn_error $? "$ac_msg"
	pwd)`
# When building in place, set srcdir=.
if test "$ac_abs_confdir" = "$ac_pwd"; then
  srcdir=.
# Remove unnecessary trailing slashes from srcdir.
# Double slashes in file names in object file debugging info
# mess up M-x gdb in Emacs.
case $srcdir in
*/) srcdir=`expr "X$srcdir" : 'X\(.*[^/]\)' \| "X$srcdir" : 'X\(.*\)'`;;
for ac_var in $ac_precious_vars; do
  eval ac_env_${ac_var}_set=\${${ac_var}+set}
  eval ac_env_${ac_var}_value=\$${ac_var}
  eval ac_cv_env_${ac_var}_set=\${${ac_var}+set}
  eval ac_cv_env_${ac_var}_value=\$${ac_var}
# Report the --help message.
if test "$ac_init_help" = "long"; then
  # Omit some internal or obsolete options to make the list less imposing.
  # This message is too long to be a string in the A/UX 3.1 sh.
  cat <<_ACEOF
\`configure' configures qvcloud 1.0 to adapt to many kinds of systems.
Usage: $0 [OPTION]... [VAR=VALUE]...
To assign environment variables (e.g., CC, CFLAGS...), specify them as
VAR=VALUE.  See below for descriptions of some of the useful variables.
Defaults for the options are specified in brackets.
Configuration:
  -h, --help              display this help and exit
      --help=short        display options specific to this package
      --help=recursive    display the short help of all the included packages
  -V, --version           display version information and exit
  -q, --quiet, --silent   do not print \`checking ...' messages
      --cache-file=FILE   cache test results in FILE [disabled]
  -C, --config-cache      alias for \`--cache-file=config.cache'
  -n, --no-create         do not create output files
      --srcdir=DIR        find the sources in DIR [configure dir or \`..']
Installation directories:
  --prefix=PREFIX         install architecture-independent files in PREFIX
                          [$ac_default_prefix]
  --exec-prefix=EPREFIX   install architecture-dependent files in EPREFIX
                          [PREFIX]
By default, \`make install' will install all the files in
\`$ac_default_prefix/bin', \`$ac_default_prefix/lib' etc.  You can specify
an installation prefix other than \`$ac_default_prefix' using \`--prefix',
for instance \`--prefix=\$HOME'.
For better control, use the options below.
Fine tuning of the installation directories:
  --bindir=DIR            user executables [EPREFIX/bin]
  --sbindir=DIR           system admin executables [EPREFIX/sbin]
  --libexecdir=DIR        program executables [EPREFIX/libexec]
  --sysconfdir=DIR        read-only single-machine data [PREFIX/etc]
  --sharedstatedir=DIR    modifiable architecture-independent data [PREFIX/com]
  --localstatedir=DIR     modifiable single-machine data [PREFIX/var]
  --libdir=DIR            object code libraries [EPREFIX/lib]
  --includedir=DIR        C header files [PREFIX/include]
  --oldincludedir=DIR     C header files for non-gcc [/usr/include]
  --datarootdir=DIR       read-only arch.-independent data root [PREFIX/share]
  --datadir=DIR           read-only architecture-independent data [DATAROOTDIR]
  --infodir=DIR           info documentation [DATAROOTDIR/info]
  --localedir=DIR         locale-dependent data [DATAROOTDIR/locale]
  --mandir=DIR            man documentation [DATAROOTDIR/man]
  --docdir=DIR            documentation root [DATAROOTDIR/doc/qvcloud]
  --htmldir=DIR           html documentation [DOCDIR]
  --dvidir=DIR            dvi documentation [DOCDIR]
  --pdfdir=DIR            pdf documentation [DOCDIR]
  --psdir=DIR             ps documentation [DOCDIR]
_ACEOF
  cat <<\_ACEOF
Program names:
  --program-prefix=PREFIX            prepend PREFIX to installed program names
  --program-suffix=SUFFIX            append SUFFIX to installed program names
  --program-transform-name=PROGRAM   run sed PROGRAM on installed program names
System types:
  --build=BUILD     configure for building on BUILD [guessed]
  --host=HOST       cross-compile to build programs to run on HOST [BUILD]
_ACEOF
if test -n "$ac_init_help"; then
  case $ac_init_help in
     short | recursive ) echo "Configuration of qvcloud 1.0:";;
  cat <<\_ACEOF
Optional Features:
  --disable-option-checking  ignore unrecognized --enable/--with options
  --disable-FEATURE       do not include FEATURE (same as --enable-FEATURE=no)
  --enable-FEATURE[=ARG]  include FEATURE [ARG=yes]
  --enable-silent-rules   less verbose build output (undo: "make V=1")
  --disable-silent-rules  verbose build output (undo: "make V=0")
  --enable-dependency-tracking
                          do not reject slow dependency extractors
  --disable-dependency-tracking
                          speeds up one-time build
  --enable-shared[=PKGS]  build shared libraries [default=yes]
  --enable-static[=PKGS]  build static libraries [default=yes]
  --enable-fast-install[=PKGS]
                          optimize for fast installation [default=yes]
  --disable-libtool-lock  avoid locking (might break parallel builds)
  --platform           platform  <default=no>
Optional Packages:
  --with-PACKAGE[=ARG]    use PACKAGE [ARG=yes]
  --without-PACKAGE       do not use PACKAGE (same as --with-PACKAGE=no)
  --with-pic[=PKGS]       try to use only PIC/non-PIC objects [default=use
                          both]
  --with-gnu-ld           assume the C compiler uses GNU ld [default=no]
  --with-sysroot=DIR Search for dependent libraries within DIR
                        (or the compiler's sysroot if not specified).
  --with-platform=3520DV300/x86/AK3780C/xN32926/AK3761D
Some influential environment variables:
  CC          C compiler command
  CFLAGS      C compiler flags
  LDFLAGS     linker flags, e.g. -L<lib dir> if you have libraries in a
              nonstandard directory <lib dir>
  LIBS        libraries to pass to the linker, e.g. -l<library>
  CPPFLAGS    (Objective) C/C++ preprocessor flags, e.g. -I<include dir> if
              you have headers in a nonstandard directory <include dir>
  CXX         C++ compiler command
  CXXFLAGS    C++ compiler flags
  CPP         C preprocessor
  CXXCPP      C++ preprocessor
Use these variables to override the choices made by `configure' or to help
it to find libraries and programs with nonstandard names/locations.
Report bugs to the package provider.
_ACEOF
ac_status=$?
if test "$ac_init_help" = "recursive"; then
  # If there are subdirs, report their specific --help.
  for ac_dir in : $ac_subdirs_all; do test "x$ac_dir" = x: && continue
    test -d "$ac_dir" ||
      { cd "$srcdir" && ac_pwd=`pwd` && srcdir=. && test -d "$ac_dir"; } ||
      continue
    ac_builddir=.
case "$ac_dir" in
.) ac_dir_suffix= ac_top_builddir_sub=. ac_top_build_prefix= ;;
  ac_dir_suffix=/`$as_echo "$ac_dir" | sed 's|^\.[\\/]||'`
  # A ".." for each directory in $ac_dir_suffix.
  ac_top_builddir_sub=`$as_echo "$ac_dir_suffix" | sed 's|/[^\\/]*|/..|g;s|/||'`
  case $ac_top_builddir_sub in
  "") ac_top_builddir_sub=. ac_top_build_prefix= ;;
  *)  ac_top_build_prefix=$ac_top_builddir_sub/ ;;
  esac ;;
ac_abs_top_builddir=$ac_pwd
ac_abs_builddir=$ac_pwd$ac_dir_suffix
# for backward compatibility:
ac_top_builddir=$ac_top_build_prefix
case $srcdir in
  .)  # We are building in place.
    ac_srcdir=.
    ac_top_srcdir=$ac_top_builddir_sub
    ac_abs_top_srcdir=$ac_pwd ;;
  [\\/]* | ?:[\\/]* )  # Absolute name.
    ac_srcdir=$srcdir$ac_dir_suffix;
    ac_top_srcdir=$srcdir
    ac_abs_top_srcdir=$srcdir ;;
  *) # Relative name.
    ac_srcdir=$ac_top_build_prefix$srcdir$ac_dir_suffix
    ac_top_srcdir=$ac_top_build_prefix$srcdir
    ac_abs_top_srcdir=$ac_pwd/$srcdir ;;
ac_abs_srcdir=$ac_abs_top_srcdir$ac_dir_suffix
    cd "$ac_dir" || { ac_status=$?; continue; }
    # Check for guested configure.
    if test -f "$ac_srcdir/configure.gnu"; then
      echo &&
      $SHELL "$ac_srcdir/configure.gnu" --help=recursive
    elif test -f "$ac_srcdir/configure"; then
      echo &&
      $SHELL "$ac_srcdir/configure" --help=recursive
      $as_echo "$as_me: WARNING: no configuration information is in $ac_dir" >&2
    fi || ac_status=$?
    cd "$ac_pwd" || { ac_status=$?; break; }
test -n "$ac_init_help" && exit $ac_status
if $ac_init_version; then
  cat <<\_ACEOF
qvcloud configure 1.0
generated by GNU Autoconf 2.69
Copyright (C) 2012 Free Software Foundation, Inc.
_ACEOF
  exit
## Autoconf initialization. ##
# ac_fn_c_try_compile LINENO
# Try to compile conftest.$ac_ext, and return whether this succeeded.
ac_fn_c_try_compile ()
  as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
  rm -f conftest.$ac_objext
  if { { ac_try="$ac_compile"
case "(($ac_try" in
  *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
  *) ac_try_echo=$ac_try;;
eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
$as_echo "$ac_try_echo"; } >&5
  (eval "$ac_compile") 2>conftest.err
  ac_status=$?
  if test -s conftest.err; then
    grep -v '^ *+' conftest.err >conftest.er1
    cat conftest.er1 >&5
    mv -f conftest.er1 conftest.err
  $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
  test $ac_status = 0; } && {
	 test -z "$ac_c_werror_flag" ||
	 test ! -s conftest.err
       } && test -s conftest.$ac_objext; then :
  ac_retval=0
  $as_echo "$as_me: failed program was:" >&5
sed 's/^/| /' conftest.$ac_ext >&5
	ac_retval=1
  eval $as_lineno_stack; ${as_lineno_stack:+:} unset as_lineno
  as_fn_set_status $ac_retval
} # ac_fn_c_try_compile
# ac_fn_cxx_try_compile LINENO
ac_fn_cxx_try_compile ()
case "(($ac_try" in
  ac_status=$?
	 test -z "$ac_cxx_werror_flag" ||
  ac_retval=0
	ac_retval=1
} # ac_fn_cxx_try_compile
# ac_fn_c_try_link LINENO
# Try to link conftest.$ac_ext, and return whether this succeeded.
ac_fn_c_try_link ()
  rm -f conftest.$ac_objext conftest$ac_exeext
  if { { ac_try="$ac_link"
case "(($ac_try" in
  (eval "$ac_link") 2>conftest.err
  ac_status=$?
       } && test -s conftest$ac_exeext && {
	 test "$cross_compiling" = yes ||
	 test -x conftest$ac_exeext
       }; then :
  ac_retval=0
	ac_retval=1
  # Delete the IPA/IPO (Inter Procedural Analysis/Optimization) information
  # created by the PGI compiler (conftest_ipa8_conftest.oo), as it would
  # interfere with the next link command; also delete a directory that is
  # left behind by Apple's compiler.  We do this before executing the actions.
  rm -rf conftest.dSYM conftest_ipa8_conftest.oo
} # ac_fn_c_try_link
# ac_fn_c_check_header_compile LINENO HEADER VAR INCLUDES
# Tests whether HEADER exists and can be compiled using the include files in
# INCLUDES, setting the cache variable VAR accordingly.
ac_fn_c_check_header_compile ()
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for $2" >&5
$as_echo_n "checking for $2... " >&6; }
if eval \${$3+:} false; then :
  $as_echo_n "(cached) " >&6
  cat confdefs.h - <<_ACEOF >conftest.$ac_ext
/* end confdefs.h.  */
$4
#include <$2>
_ACEOF
if ac_fn_c_try_compile "$LINENO"; then :
  eval "$3=yes"
  eval "$3=no"
rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
eval ac_res=\$$3
	       { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_res" >&5
$as_echo "$ac_res" >&6; }
} # ac_fn_c_check_header_compile
# ac_fn_c_try_cpp LINENO
# Try to preprocess conftest.$ac_ext, and return whether this succeeded.
ac_fn_c_try_cpp ()
  if { { ac_try="$ac_cpp conftest.$ac_ext"
case "(($ac_try" in
  (eval "$ac_cpp conftest.$ac_ext") 2>conftest.err
  ac_status=$?
  test $ac_status = 0; } > conftest.i && {
	 test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
       }; then :
  ac_retval=0
    ac_retval=1
} # ac_fn_c_try_cpp
# ac_fn_c_try_run LINENO
# Try to link conftest.$ac_ext, and return whether this succeeded. Assumes
# that executables *can* be run.
ac_fn_c_try_run ()
case "(($ac_try" in
  (eval "$ac_link") 2>&5
  ac_status=$?
  test $ac_status = 0; } && { ac_try='./conftest$ac_exeext'
  { { case "(($ac_try" in
  (eval "$ac_try") 2>&5
  ac_status=$?
  test $ac_status = 0; }; }; then :
  ac_retval=0
  $as_echo "$as_me: program exited with status $ac_status" >&5
       ac_retval=$ac_status
} # ac_fn_c_try_run
# ac_fn_c_check_func LINENO FUNC VAR
# Tests whether FUNC exists, setting the cache variable VAR accordingly
ac_fn_c_check_func ()
/* Define $2 to an innocuous variant, in case <limits.h> declares $2.
   For example, HP-UX 11i <limits.h> declares gettimeofday.  */
#define $2 innocuous_$2
/* System header to define __stub macros and hopefully few prototypes,
    which can conflict with char $2 (); below.
    Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
    <limits.h> exists even on freestanding compilers.  */
#ifdef __STDC__
# include <limits.h>
# include <assert.h>
#undef $2
/* Override any GCC internal prototype to avoid an error.
   Use char because int might match the return type of a GCC
   builtin and then its argument prototype would still apply.  */
extern "C"
char $2 ();
/* The GNU C library defines this for functions which it implements
    to always fail with ENOSYS.  Some functions are actually named
    something starting with __ and the normal name is an alias.  */
#if defined __stub_$2 || defined __stub___$2
choke me
int
main ()
return $2 ();
_ACEOF
if ac_fn_c_try_link "$LINENO"; then :
  eval "$3=yes"
  eval "$3=no"
rm -f core conftest.err conftest.$ac_objext \
    conftest$ac_exeext conftest.$ac_ext
eval ac_res=\$$3
} # ac_fn_c_check_func
# ac_fn_cxx_try_cpp LINENO
ac_fn_cxx_try_cpp ()
case "(($ac_try" in
  ac_status=$?
	 test -z "$ac_cxx_preproc_warn_flag$ac_cxx_werror_flag" ||
       }; then :
  ac_retval=0
    ac_retval=1
} # ac_fn_cxx_try_cpp
# ac_fn_cxx_try_link LINENO
ac_fn_cxx_try_link ()
case "(($ac_try" in
  ac_status=$?
       }; then :
  ac_retval=0
	ac_retval=1
} # ac_fn_cxx_try_link
# ac_fn_c_check_type LINENO TYPE VAR INCLUDES
# Tests whether TYPE exists after having included INCLUDES, setting cache
# variable VAR accordingly.
ac_fn_c_check_type ()
  eval "$3=no"
$4
int
main ()
if (sizeof ($2))
_ACEOF
$4
int
main ()
if (sizeof (($2)))
_ACEOF
  eval "$3=yes"
eval ac_res=\$$3
} # ac_fn_c_check_type
cat >config.log <<_ACEOF
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by qvcloud $as_me 1.0, which was
generated by GNU Autoconf 2.69.  Invocation command line was
  $ $0 $@
_ACEOF
exec 5>>config.log
cat <<_ASUNAME
## Platform. ##
hostname = `(hostname || uname -n) 2>/dev/null | sed 1q`
uname -m = `(uname -m) 2>/dev/null || echo unknown`
uname -r = `(uname -r) 2>/dev/null || echo unknown`
uname -s = `(uname -s) 2>/dev/null || echo unknown`
uname -v = `(uname -v) 2>/dev/null || echo unknown`
/usr/bin/uname -p = `(/usr/bin/uname -p) 2>/dev/null || echo unknown`
/bin/uname -X     = `(/bin/uname -X) 2>/dev/null     || echo unknown`
/bin/arch              = `(/bin/arch) 2>/dev/null              || echo unknown`
/usr/bin/arch -k       = `(/usr/bin/arch -k) 2>/dev/null       || echo unknown`
/usr/convex/getsysinfo = `(/usr/convex/getsysinfo) 2>/dev/null || echo unknown`
/usr/bin/hostinfo      = `(/usr/bin/hostinfo) 2>/dev/null      || echo unknown`
/bin/machine           = `(/bin/machine) 2>/dev/null           || echo unknown`
/usr/bin/oslevel       = `(/usr/bin/oslevel) 2>/dev/null       || echo unknown`
/bin/universe          = `(/bin/universe) 2>/dev/null          || echo unknown`
_ASUNAME
for as_dir in $PATH
do
  IFS=$as_save_IFS
    $as_echo "PATH: $as_dir"
IFS=$as_save_IFS
} >&5
cat >&5 <<_ACEOF
## Core tests. ##
_ACEOF
# Keep a trace of the command line.
# Strip out --no-create and --no-recursion so they do not pile up.
# Strip out --silent because we don't want to record it for future runs.
# Also quote any args containing shell meta-characters.
# Make two passes to allow for proper duplicate-argument suppression.
ac_configure_args=
ac_configure_args0=
ac_configure_args1=
ac_must_keep_next=false
for ac_pass in 1 2
do
  for ac_arg
  do
    case $ac_arg in
    -no-create | --no-c* | -n | -no-recursion | --no-r*) continue ;;
      continue ;;
      ac_arg=`$as_echo "$ac_arg" | sed "s/'/'\\\\\\\\''/g"` ;;
    case $ac_pass in
    1) as_fn_append ac_configure_args0 " '$ac_arg'" ;;
    2)
      as_fn_append ac_configure_args1 " '$ac_arg'"
      if test $ac_must_keep_next = true; then
	ac_must_keep_next=false # Got value, back to normal.
	case $ac_arg in
	  *=* | --config-cache | -C | -disable-* | --disable-* \
	  | -enable-* | --enable-* | -gas | --g* | -nfp | --nf* \
	  | -q | -quiet | --q* | -silent | --sil* | -v | -verb* \
	  | -with-* | --with-* | -without-* | --without-* | --x)
	    case "$ac_configure_args0 " in
	      "$ac_configure_args1"*" '$ac_arg' "* ) continue ;;
	  -* ) ac_must_keep_next=true ;;
      as_fn_append ac_configure_args " '$ac_arg'"
{ ac_configure_args0=; unset ac_configure_args0;}
{ ac_configure_args1=; unset ac_configure_args1;}
# When interrupted or exit'd, cleanup temporary files, and complete
# config.log.  We remove comments because anyway the quotes in there
# would cause problems or look ugly.
# WARNING: Use '\'' to represent an apostrophe within the trap.
# WARNING: Do not start the trap code with a newline, due to a FreeBSD 4.0 bug.
trap 'exit_status=$?
  # Save into config.log some information that might help in debugging.
    echo
    $as_echo "## ---------------- ##
## Cache variables. ##
    echo
    # The following way of writing the cache mishandles newlines in values,
  for ac_var in `(set) 2>&1 | sed -n '\''s/^\([a-zA-Z_][a-zA-Z0-9_]*\)=.*/\1/p'\''`; do
    case $ac_val in #(
    *${as_nl}*)
      case $ac_var in #(
      *_cv_*) { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: cache variable $ac_var contains a newline" >&5
$as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
      case $ac_var in #(
      _ | IFS | as_nl) ;; #(
      BASH_ARGV | BASH_SOURCE) eval $ac_var= ;; #(
      *) { eval $ac_var=; unset $ac_var;} ;;
      esac ;;
  (set) 2>&1 |
    case $as_nl`(ac_space='\'' '\''; set) 2>&1` in #(
    *${as_nl}ac_space=\ *)
      sed -n \
	"s/'\''/'\''\\\\'\'''\''/g;
	  s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\''\\2'\''/p"
      sed -n "/^[_$as_cr_alnum]*_cv_[_$as_cr_alnum]*=/p"
    esac |
    sort
    echo
    $as_echo "## ----------------- ##
## Output variables. ##
    echo
    for ac_var in $ac_subst_vars
    do
      case $ac_val in
      *\'\''*) ac_val=`$as_echo "$ac_val" | sed "s/'\''/'\''\\\\\\\\'\'''\''/g"`;;
      $as_echo "$ac_var='\''$ac_val'\''"
    done | sort
    echo
    if test -n "$ac_subst_files"; then
      $as_echo "## ------------------- ##
## File substitutions. ##
      echo
      for ac_var in $ac_subst_files
      do
	case $ac_val in
      done | sort
      echo
    if test -s confdefs.h; then
      $as_echo "## ----------- ##
## confdefs.h. ##
      echo
      cat confdefs.h
      echo
    test "$ac_signal" != 0 &&
      $as_echo "$as_me: caught signal $ac_signal"
    $as_echo "$as_me: exit $exit_status"
  } >&5
  rm -f core *.core core.conftest.* &&
    rm -f -r conftest* confdefs* conf$$* $ac_clean_files &&
    exit $exit_status
' 0
for ac_signal in 1 2 13 15; do
  trap 'ac_signal='$ac_signal'; as_fn_exit 1' $ac_signal
ac_signal=0
# confdefs.h avoids OS command line length limits that DEFS can exceed.
rm -f -r conftest* confdefs.h
$as_echo "/* confdefs.h */" > confdefs.h
# Predefined preprocessor variables.
cat >>confdefs.h <<_ACEOF
#define PACKAGE_NAME "$PACKAGE_NAME"
_ACEOF
#define PACKAGE_TARNAME "$PACKAGE_TARNAME"
_ACEOF
#define PACKAGE_VERSION "$PACKAGE_VERSION"
_ACEOF
#define PACKAGE_STRING "$PACKAGE_STRING"
_ACEOF
#define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT"
_ACEOF
#define PACKAGE_URL "$PACKAGE_URL"
_ACEOF
# Let the site file select an alternate cache file if it wants to.
# Prefer an explicitly selected file to automatically selected ones.
ac_site_file1=NONE
ac_site_file2=NONE
if test -n "$CONFIG_SITE"; then
  # We do not want a PATH search for config.site.
  case $CONFIG_SITE in #((
    -*)  ac_site_file1=./$CONFIG_SITE;;
    */*) ac_site_file1=$CONFIG_SITE;;
elif test "x$prefix" != xNONE; then
  ac_site_file1=$prefix/share/config.site
  ac_site_file2=$prefix/etc/config.site
  ac_site_file1=$ac_default_prefix/share/config.site
  ac_site_file2=$ac_default_prefix/etc/config.site
for ac_site_file in "$ac_site_file1" "$ac_site_file2"
do
  test "x$ac_site_file" = xNONE && continue
  if test /dev/null != "$ac_site_file" && test -r "$ac_site_file"; then
    { $as_echo "$as_me:${as_lineno-$LINENO}: loading site script $ac_site_file" >&5
$as_echo "$as_me: loading site script $ac_site_file" >&6;}
    sed 's/^/| /' "$ac_site_file" >&5
    . "$ac_site_file" \
      || { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
as_fn_error $? "failed to load site script $ac_site_file
See \`config.log' for more details" "$LINENO" 5; }
if test -r "$cache_file"; then
  # Some versions of bash will fail to source /dev/null (special files
  # actually), so we avoid doing that.  DJGPP emulates it as a regular file.
  if test /dev/null != "$cache_file" && test -f "$cache_file"; then
    { $as_echo "$as_me:${as_lineno-$LINENO}: loading cache $cache_file" >&5
$as_echo "$as_me: loading cache $cache_file" >&6;}
    case $cache_file in
      [\\/]* | ?:[\\/]* ) . "$cache_file";;
      *)                      . "./$cache_file";;
  { $as_echo "$as_me:${as_lineno-$LINENO}: creating cache $cache_file" >&5
$as_echo "$as_me: creating cache $cache_file" >&6;}
  >$cache_file
# Check that the precious variables saved in the cache have kept the same
# value.
ac_cache_corrupted=false
  eval ac_old_set=\$ac_cv_env_${ac_var}_set
  eval ac_new_set=\$ac_env_${ac_var}_set
  eval ac_old_val=\$ac_cv_env_${ac_var}_value
  eval ac_new_val=\$ac_env_${ac_var}_value
  case $ac_old_set,$ac_new_set in
    set,)
      { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
$as_echo "$as_me: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&2;}
      ac_cache_corrupted=: ;;
    ,set)
      { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was not set in the previous run" >&5
$as_echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
      if test "x$ac_old_val" != "x$ac_new_val"; then
	# differences in whitespace do not lead to failure.
	ac_old_val_w=`echo x $ac_old_val`
	ac_new_val_w=`echo x $ac_new_val`
	if test "$ac_old_val_w" != "$ac_new_val_w"; then
	  { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' has changed since the previous run:" >&5
$as_echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;}
	  { $as_echo "$as_me:${as_lineno-$LINENO}: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&5
$as_echo "$as_me: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&2;}
	  eval $ac_var=\$ac_old_val
	{ $as_echo "$as_me:${as_lineno-$LINENO}:   former value:  \`$ac_old_val'" >&5
$as_echo "$as_me:   former value:  \`$ac_old_val'" >&2;}
	{ $as_echo "$as_me:${as_lineno-$LINENO}:   current value: \`$ac_new_val'" >&5
$as_echo "$as_me:   current value: \`$ac_new_val'" >&2;}
      fi;;
  # Pass precious variables to config.status.
  if test "$ac_new_set" = set; then
    case $ac_new_val in
    *\'*) ac_arg=$ac_var=`$as_echo "$ac_new_val" | sed "s/'/'\\\\\\\\''/g"` ;;
    *) ac_arg=$ac_var=$ac_new_val ;;
    case " $ac_configure_args " in
      *" '$ac_arg' "*) ;; # Avoid dups.  Use of quotes ensures accuracy.
      *) as_fn_append ac_configure_args " '$ac_arg'" ;;
if $ac_cache_corrupted; then
  { $as_echo "$as_me:${as_lineno-$LINENO}: error: changes in the environment can compromise the build" >&5
$as_echo "$as_me: error: changes in the environment can compromise the build" >&2;}
  as_fn_error $? "run \`make distclean' and/or \`rm $cache_file' and start over" "$LINENO" 5
## Main body of script. ##
ac_ext=c
ac_cpp='$CPP $CPPFLAGS'
ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
ac_compiler_gnu=$ac_cv_c_compiler_gnu
ac_config_headers="$ac_config_headers config.h"
am__api_version='1.14'
ac_aux_dir=
for ac_dir in "$srcdir" "$srcdir/.." "$srcdir/../.."; do
  if test -f "$ac_dir/install-sh"; then
    ac_aux_dir=$ac_dir
    ac_install_sh="$ac_aux_dir/install-sh -c"
    break
  elif test -f "$ac_dir/install.sh"; then
    ac_aux_dir=$ac_dir
    ac_install_sh="$ac_aux_dir/install.sh -c"
    break
  elif test -f "$ac_dir/shtool"; then
    ac_aux_dir=$ac_dir
    ac_install_sh="$ac_aux_dir/shtool install -c"
    break
if test -z "$ac_aux_dir"; then
  as_fn_error $? "cannot find install-sh, install.sh, or shtool in \"$srcdir\" \"$srcdir/..\" \"$srcdir/../..\"" "$LINENO" 5
# These three variables are undocumented and unsupported,
# and are intended to be withdrawn in a future Autoconf release.
# They can cause serious problems if a builder's source tree is in a directory
# whose full name contains unusual characters.
ac_config_guess="$SHELL $ac_aux_dir/config.guess"  # Please don't use this var.
ac_config_sub="$SHELL $ac_aux_dir/config.sub"  # Please don't use this var.
ac_configure="$SHELL $ac_aux_dir/configure"  # Please don't use this var.
# Find a good install program.  We prefer a C program (faster),
# so one script is as good as another.  But avoid the broken or
# incompatible versions:
# SysV /etc/install, /usr/sbin/install
# SunOS /usr/etc/install
# IRIX /sbin/install
# AIX /bin/install
# AmigaOS /C/install, which installs bootblocks on floppy discs
# AIX 4 /usr/bin/installbsd, which doesn't work without a -g flag
# AFS /usr/afsws/bin/install, which mishandles nonexistent args
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# OS/2's system install, which has a completely different semantic
# ./install, which can be erroneously created by make from ./install.sh.
# Reject install programs that cannot install multiple files.
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a BSD-compatible install" >&5
$as_echo_n "checking for a BSD-compatible install... " >&6; }
if test -z "$INSTALL"; then
if ${ac_cv_path_install+:} false; then :
for as_dir in $PATH
do
  IFS=$as_save_IFS
    # Account for people who put trailing slashes in PATH elements.
case $as_dir/ in #((
  ./ | .// | /[cC]/* | \
  /etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \
  ?:[\\/]os2[\\/]install[\\/]* | ?:[\\/]OS2[\\/]INSTALL[\\/]* | \
  /usr/ucb/* ) ;;
    # OSF1 and SCO ODT 3.0 have their own names for install.
    # Don't use installbsd from OSF since it installs stuff as root
    # by default.
    for ac_prog in ginstall scoinst install; do
      for ac_exec_ext in '' $ac_executable_extensions; do
	if as_fn_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
	  if test $ac_prog = install &&
	    grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
	    # AIX install.  It has an incompatible calling convention.
	  elif test $ac_prog = install &&
	    grep pwplus "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
	    # program-specific install script used by HP pwplus--don't use.
	    rm -rf conftest.one conftest.two conftest.dir
	    echo one > conftest.one
	    echo two > conftest.two
	    mkdir conftest.dir
	    if "$as_dir/$ac_prog$ac_exec_ext" -c conftest.one conftest.two "`pwd`/conftest.dir" &&
	      test -s conftest.one && test -s conftest.two &&
	      test -s conftest.dir/conftest.one &&
	      test -s conftest.dir/conftest.two
	    then
	      ac_cv_path_install="$as_dir/$ac_prog$ac_exec_ext -c"
	      break 3
IFS=$as_save_IFS
  if test "${ac_cv_path_install+set}" = set; then
    INSTALL=$ac_cv_path_install
    # As a last resort, use the slow shell script.  Don't cache a
    # value for INSTALL within a source directory, because that will
    # break other packages using the cache if that directory is
    # removed, or if the value is a relative name.
    INSTALL=$ac_install_sh
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $INSTALL" >&5
$as_echo "$INSTALL" >&6; }
# Use test -z because SunOS4 sh mishandles braces in ${var-val}.
# It thinks the first close brace ends the variable substitution.
test -z "$INSTALL_PROGRAM" && INSTALL_PROGRAM='${INSTALL}'
test -z "$INSTALL_SCRIPT" && INSTALL_SCRIPT='${INSTALL}'
test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644'
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether build environment is sane" >&5
$as_echo_n "checking whether build environment is sane... " >&6; }
# Reject unsafe characters in $srcdir or the absolute working directory
# name.  Accept space and tab only in the latter.
am_lf='
case `pwd` in
  *[\\\"\#\$\&\'\`$am_lf]*)
    as_fn_error $? "unsafe absolute working directory name" "$LINENO" 5;;
case $srcdir in
  *[\\\"\#\$\&\'\`$am_lf\ \	]*)
    as_fn_error $? "unsafe srcdir value: '$srcdir'" "$LINENO" 5;;
# Do 'set' in a subshell so we don't clobber the current shell's
# arguments.  Must try -L first in case configure is actually a
# symlink; some systems play weird games with the mod time of symlinks
# (eg FreeBSD returns the mod time of the symlink's containing
# directory).
if (
   am_has_slept=no
   for am_try in 1 2; do
     echo "timestamp, slept: $am_has_slept" > conftest.file
     set X `ls -Lt "$srcdir/configure" conftest.file 2> /dev/null`
     if test "$*" = "X"; then
	# -L didn't work.
	set X `ls -t "$srcdir/configure" conftest.file`
     if test "$*" != "X $srcdir/configure conftest.file" \
	&& test "$*" != "X conftest.file $srcdir/configure"; then
	# If neither matched, then we have a broken ls.  This can happen
	# if, for instance, CONFIG_SHELL is bash and it inherits a
	# broken ls alias from the environment.  This has actually
	# happened.  Such a system could not be considered "sane".
	as_fn_error $? "ls -t appears to fail.  Make sure there is not a broken
  alias in your environment" "$LINENO" 5
     if test "$2" = conftest.file || test $am_try -eq 2; then
       break
     # Just in case.
     sleep 1
     am_has_slept=yes
then
   # Ok.
   as_fn_error $? "newly created file is older than distributed files!
Check your system clock" "$LINENO" 5
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
$as_echo "yes" >&6; }
# If we didn't sleep, we still need to ensure time stamps of config.status and
# generated files are strictly newer.
am_sleep_pid=
if grep 'slept: no' conftest.file >/dev/null 2>&1; then
  ( sleep 1 ) &
  am_sleep_pid=$!
rm -f conftest.file
test "$program_prefix" != NONE &&
  program_transform_name="s&^&$program_prefix&;$program_transform_name"
# Use a double $ so make ignores it.
test "$program_suffix" != NONE &&
  program_transform_name="s&\$&$program_suffix&;$program_transform_name"
# Double any \ or $.
# By default was `s,x,x', remove it if useless.
ac_script='s/[\\$]/&&/g;s/;s,x,x,$//'
program_transform_name=`$as_echo "$program_transform_name" | sed "$ac_script"`
# expand $ac_aux_dir to an absolute path
am_aux_dir=`cd $ac_aux_dir && pwd`
if test x"${MISSING+set}" != xset; then
  case $am_aux_dir in
    MISSING="\${SHELL} \"$am_aux_dir/missing\"" ;;
    MISSING="\${SHELL} $am_aux_dir/missing" ;;
# Use eval to expand $SHELL
if eval "$MISSING --is-lightweight"; then
  am_missing_run="$MISSING "
  am_missing_run=
  { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: 'missing' script is too old or missing" >&5
$as_echo "$as_me: WARNING: 'missing' script is too old or missing" >&2;}
if test x"${install_sh}" != xset; then
  case $am_aux_dir in
    install_sh="\${SHELL} '$am_aux_dir/install-sh'" ;;
    install_sh="\${SHELL} $am_aux_dir/install-sh"
# Installed binaries are usually stripped using 'strip' when the user
# run "make install-strip".  However 'strip' might not be the right
# tool to use in cross-compilation environments, therefore Automake
# will honor the 'STRIP' environment variable to overrule this program.
if test "$cross_compiling" != no; then
  if test -n "$ac_tool_prefix"; then
  # Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
set dummy ${ac_tool_prefix}strip; ac_word=$2
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
$as_echo_n "checking for $ac_word... " >&6; }
if ${ac_cv_prog_STRIP+:} false; then :
  if test -n "$STRIP"; then
  ac_cv_prog_STRIP="$STRIP" # Let the user override the test.
as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in $PATH
do
  IFS=$as_save_IFS
  test -z "$as_dir" && as_dir=.
  if as_fn_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
    ac_cv_prog_STRIP="${ac_tool_prefix}strip"
    $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
    break 2
IFS=$as_save_IFS
STRIP=$ac_cv_prog_STRIP
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $STRIP" >&5
$as_echo "$STRIP" >&6; }
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
$as_echo "no" >&6; }
if test -z "$ac_cv_prog_STRIP"; then
  ac_ct_STRIP=$STRIP
  # Extract the first word of "strip", so it can be a program name with args.
set dummy strip; ac_word=$2
if ${ac_cv_prog_ac_ct_STRIP+:} false; then :
  if test -n "$ac_ct_STRIP"; then
  ac_cv_prog_ac_ct_STRIP="$ac_ct_STRIP" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_STRIP="strip"
    break 2
IFS=$as_save_IFS
ac_ct_STRIP=$ac_cv_prog_ac_ct_STRIP
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_STRIP" >&5
$as_echo "$ac_ct_STRIP" >&6; }
  if test "x$ac_ct_STRIP" = x; then
    STRIP=":"
    case $cross_compiling:$ac_tool_warned in
yes:)
{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using cross tools not prefixed with host triplet" >&5
$as_echo "$as_me: WARNING: using cross tools not prefixed with host triplet" >&2;}
ac_tool_warned=yes ;;
    STRIP=$ac_ct_STRIP
  STRIP="$ac_cv_prog_STRIP"
INSTALL_STRIP_PROGRAM="\$(install_sh) -c -s"
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a thread-safe mkdir -p" >&5
$as_echo_n "checking for a thread-safe mkdir -p... " >&6; }
if test -z "$MKDIR_P"; then
  if ${ac_cv_path_mkdir+:} false; then :
for as_dir in $PATH$PATH_SEPARATOR/opt/sfw/bin
do
  IFS=$as_save_IFS
    for ac_prog in mkdir gmkdir; do
	   as_fn_executable_p "$as_dir/$ac_prog$ac_exec_ext" || continue
	   case `"$as_dir/$ac_prog$ac_exec_ext" --version 2>&1` in #(
	     'mkdir (GNU coreutils) '* | \
	     'mkdir (coreutils) '* | \
	     'mkdir (fileutils) '4.1*)
	       ac_cv_path_mkdir=$as_dir/$ac_prog$ac_exec_ext
	       break 3;;
IFS=$as_save_IFS
  test -d ./--version && rmdir ./--version
  if test "${ac_cv_path_mkdir+set}" = set; then
    MKDIR_P="$ac_cv_path_mkdir -p"
    # value for MKDIR_P within a source directory, because that will
    MKDIR_P="$ac_install_sh -d"
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $MKDIR_P" >&5
$as_echo "$MKDIR_P" >&6; }
for ac_prog in gawk mawk nawk awk
do
  # Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
if ${ac_cv_prog_AWK+:} false; then :
  if test -n "$AWK"; then
  ac_cv_prog_AWK="$AWK" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_AWK="$ac_prog"
    break 2
IFS=$as_save_IFS
AWK=$ac_cv_prog_AWK
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $AWK" >&5
$as_echo "$AWK" >&6; }
  test -n "$AWK" && break
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether ${MAKE-make} sets \$(MAKE)" >&5
$as_echo_n "checking whether ${MAKE-make} sets \$(MAKE)... " >&6; }
set x ${MAKE-make}
ac_make=`$as_echo "$2" | sed 's/+/p/g; s/[^a-zA-Z0-9_]/_/g'`
if eval \${ac_cv_prog_make_${ac_make}_set+:} false; then :
  cat >conftest.make <<\_ACEOF
SHELL = /bin/sh
all:
	@echo '@@@%%%=$(MAKE)=@@@%%%'
_ACEOF
# GNU make sometimes prints "make[1]: Entering ...", which would confuse us.
case `${MAKE-make} -f conftest.make 2>/dev/null` in
    eval ac_cv_prog_make_${ac_make}_set=yes;;
    eval ac_cv_prog_make_${ac_make}_set=no;;
rm -f conftest.make
if eval test \$ac_cv_prog_make_${ac_make}_set = yes; then
  SET_MAKE=
  SET_MAKE="MAKE=${MAKE-make}"
rm -rf .tst 2>/dev/null
mkdir .tst 2>/dev/null
if test -d .tst; then
  am__leading_dot=.
  am__leading_dot=_
rmdir .tst 2>/dev/null
# Check whether --enable-silent-rules was given.
if test "${enable_silent_rules+set}" = set; then :
  enableval=$enable_silent_rules;
case $enable_silent_rules in # (((
  yes) AM_DEFAULT_VERBOSITY=0;;
   no) AM_DEFAULT_VERBOSITY=1;;
    *) AM_DEFAULT_VERBOSITY=1;;
am_make=${MAKE-make}
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $am_make supports nested variables" >&5
$as_echo_n "checking whether $am_make supports nested variables... " >&6; }
if ${am_cv_make_support_nested_variables+:} false; then :
  if $as_echo 'TRUE=$(BAR$(V))
BAR0=false
BAR1=true
V=1
am__doit:
	@$(TRUE)
.PHONY: am__doit' | $am_make -f - >/dev/null 2>&1; then
  am_cv_make_support_nested_variables=yes
  am_cv_make_support_nested_variables=no
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $am_cv_make_support_nested_variables" >&5
$as_echo "$am_cv_make_support_nested_variables" >&6; }
if test $am_cv_make_support_nested_variables = yes; then
    AM_V='$(V)'
  AM_DEFAULT_V='$(AM_DEFAULT_VERBOSITY)'
  AM_V=$AM_DEFAULT_VERBOSITY
  AM_DEFAULT_V=$AM_DEFAULT_VERBOSITY
AM_BACKSLASH='\'
if test "`cd $srcdir && pwd`" != "`pwd`"; then
  # Use -I$(srcdir) only when $(srcdir) != ., so that make's output
  # is not polluted with repeated "-I."
  am__isrc=' -I$(srcdir)'
  # test to see if srcdir already configured
  if test -f $srcdir/config.status; then
    as_fn_error $? "source directory already configured; run \"make distclean\" there first" "$LINENO" 5
# test whether we have cygpath
if test -z "$CYGPATH_W"; then
  if (cygpath --version) >/dev/null 2>/dev/null; then
    CYGPATH_W='cygpath -w'
    CYGPATH_W=echo
# Define the identity of the package.
 PACKAGE='qvcloud'
 VERSION='1.0'
#define PACKAGE "$PACKAGE"
_ACEOF
#define VERSION "$VERSION"
_ACEOF
# Some tools Automake needs.
ACLOCAL=${ACLOCAL-"${am_missing_run}aclocal-${am__api_version}"}
AUTOCONF=${AUTOCONF-"${am_missing_run}autoconf"}
AUTOMAKE=${AUTOMAKE-"${am_missing_run}automake-${am__api_version}"}
AUTOHEADER=${AUTOHEADER-"${am_missing_run}autoheader"}
MAKEINFO=${MAKEINFO-"${am_missing_run}makeinfo"}
# For better backward compatibility.  To be removed once Automake 1.9.x
# dies out for good.  For more background, see:
# <http://lists.gnu.org/archive/html/automake/2012-07/msg00001.html>
# <http://lists.gnu.org/archive/html/automake/2012-07/msg00014.html>
mkdir_p='$(MKDIR_P)'
# We need awk for the "check" target.  The system "awk" is bad on
# some platforms.
# Always define AMTAR for backward compatibility.  Yes, it's still used
# in the wild :-(  We should find a proper way to deprecate it ...
AMTAR='$${TAR-tar}'
# We'll loop over all known methods to create a tar archive until one works.
_am_tools='gnutar  pax cpio none'
am__tar='$${TAR-tar} chof - "$$tardir"' am__untar='$${TAR-tar} xf -'
# POSIX will say in a future version that running "rm -f" with no argument
# is OK; and we want to be able to make that assumption in our Makefile
# recipes.  So use an aggressive probe to check that the usage we want is
# actually supported "in the wild" to an acceptable degree.
# See automake bug#10828.
# To make any issue more visible, cause the running configure to be aborted
# by default if the 'rm' program in use doesn't match our expectations; the
# user can still override this though.
if rm -f && rm -fr && rm -rf; then : OK; else
  cat >&2 <<'END'
Oops!
Your 'rm' program seems unable to run without file operands specified
on the command line, even when the '-f' option is present.  This is contrary
to the behaviour of most rm programs out there, and not conforming with
the upcoming POSIX standard: <http://austingroupbugs.net/view.php?id=542>
Please tell bug-automake@gnu.org about your system, including the value
of your $PATH and any error possibly output before this message.  This
can help us improve future automake versions.
END
  if test x"$ACCEPT_INFERIOR_RM_PROGRAM" = x"yes"; then
    echo 'Configuration will proceed anyway, since you have set the' >&2
    echo 'ACCEPT_INFERIOR_RM_PROGRAM variable to "yes"' >&2
    echo >&2
    cat >&2 <<'END'
Aborting the configuration process, to ensure you take notice of the issue.
You can download and install GNU coreutils to get an 'rm' implementation
that behaves properly: <http://www.gnu.org/software/coreutils/>.
If you want to complete the configuration process using your problematic
'rm' anyway, export the environment variable ACCEPT_INFERIOR_RM_PROGRAM
to "yes", and re-run configure.
END
    as_fn_error $? "Your 'rm' program is bad, sorry." "$LINENO" 5
# Checks for programs.
ac_ext=c
  # Extract the first word of "${ac_tool_prefix}gcc", so it can be a program name with args.
set dummy ${ac_tool_prefix}gcc; ac_word=$2
if ${ac_cv_prog_CC+:} false; then :
  if test -n "$CC"; then
  ac_cv_prog_CC="$CC" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_CC="${ac_tool_prefix}gcc"
    break 2
IFS=$as_save_IFS
CC=$ac_cv_prog_CC
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $CC" >&5
$as_echo "$CC" >&6; }
if test -z "$ac_cv_prog_CC"; then
  ac_ct_CC=$CC
  # Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
if ${ac_cv_prog_ac_ct_CC+:} false; then :
  if test -n "$ac_ct_CC"; then
  ac_cv_prog_ac_ct_CC="$ac_ct_CC" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_CC="gcc"
    break 2
IFS=$as_save_IFS
ac_ct_CC=$ac_cv_prog_ac_ct_CC
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_CC" >&5
$as_echo "$ac_ct_CC" >&6; }
  if test "x$ac_ct_CC" = x; then
    CC=""
yes:)
    CC=$ac_ct_CC
  CC="$ac_cv_prog_CC"
if test -z "$CC"; then
    # Extract the first word of "${ac_tool_prefix}cc", so it can be a program name with args.
set dummy ${ac_tool_prefix}cc; ac_word=$2
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_CC="${ac_tool_prefix}cc"
    break 2
IFS=$as_save_IFS
CC=$ac_cv_prog_CC
  # Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
  ac_prog_rejected=no
for as_dir in $PATH
do
  IFS=$as_save_IFS
    if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then
       ac_prog_rejected=yes
       continue
    ac_cv_prog_CC="cc"
    break 2
IFS=$as_save_IFS
if test $ac_prog_rejected = yes; then
  # We found a bogon in the path, so make sure we never use it.
  set dummy $ac_cv_prog_CC
  shift
  if test $# != 0; then
    # We chose a different compiler from the bogus one.
    # However, it has the same basename, so the bogon will be chosen
    # first if we set CC to just the basename; use the full file name.
    shift
    ac_cv_prog_CC="$as_dir/$ac_word${1+' '}$@"
CC=$ac_cv_prog_CC
  for ac_prog in cl.exe
  do
    # Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
set dummy $ac_tool_prefix$ac_prog; ac_word=$2
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
    break 2
IFS=$as_save_IFS
CC=$ac_cv_prog_CC
    test -n "$CC" && break
  ac_ct_CC=$CC
do
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_CC="$ac_prog"
    break 2
IFS=$as_save_IFS
  test -n "$ac_ct_CC" && break
    CC=""
yes:)
    CC=$ac_ct_CC
test -z "$CC" && { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
as_fn_error $? "no acceptable C compiler found in \$PATH
# Provide some information about the compiler.
$as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler version" >&5
set X $ac_compile
ac_compiler=$2
for ac_option in --version -v -V -qversion; do
  { { ac_try="$ac_compiler $ac_option >&5"
case "(($ac_try" in
  (eval "$ac_compiler $ac_option >&5") 2>conftest.err
  ac_status=$?
    sed '10a\
... rest of stderr output deleted ...
         10q' conftest.err >conftest.er1
  rm -f conftest.er1 conftest.err
int
main ()
_ACEOF
ac_clean_files_save=$ac_clean_files
ac_clean_files="$ac_clean_files a.out a.out.dSYM a.exe b.out"
# Try to create an executable without -o first, disregard a.out.
# It will help us diagnose broken compilers, and finding out an intuition
# of exeext.
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the C compiler works" >&5
$as_echo_n "checking whether the C compiler works... " >&6; }
ac_link_default=`$as_echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
# The possible output files:
ac_files="a.out conftest.exe conftest a.exe a_out.exe b.out conftest.*"
ac_rmfiles=
for ac_file in $ac_files
do
  case $ac_file in
    *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf | *.dSYM | *.o | *.obj ) ;;
    * ) ac_rmfiles="$ac_rmfiles $ac_file";;
rm -f $ac_rmfiles
if { { ac_try="$ac_link_default"
case "(($ac_try" in
  (eval "$ac_link_default") 2>&5
  ac_status=$?
  test $ac_status = 0; }; then :
  # Autoconf-2.13 could set the ac_cv_exeext variable to `no'.
# So ignore a value of `no', otherwise this would lead to `EXEEXT = no'
# in a Makefile.  We should not override ac_cv_exeext if it was cached,
# so that the user can short-circuit this test for compilers unknown to
# Autoconf.
for ac_file in $ac_files ''
do
  test -f "$ac_file" || continue
  case $ac_file in
    [ab].out )
	# We found the default executable, but exeext='' is most
	# certainly right.
	break;;
	if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no;
	then :; else
	   ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
	# We set ac_cv_exeext here because the later test for it is not
	# safe: cross compilers may not add the suffix if given an `-o'
	# argument, so we may need to know it at that point already.
	# Even if this section looks crufty: it has the advantage of
	# actually working.
	break;;
	break;;
test "$ac_cv_exeext" = no && ac_cv_exeext=
  ac_file=''
if test -z "$ac_file"; then :
as_fn_error 77 "C compiler cannot create executables
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler default output file name" >&5
$as_echo_n "checking for C compiler default output file name... " >&6; }
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_file" >&5
$as_echo "$ac_file" >&6; }
ac_exeext=$ac_cv_exeext
rm -f -r a.out a.out.dSYM a.exe conftest$ac_cv_exeext b.out
ac_clean_files=$ac_clean_files_save
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of executables" >&5
$as_echo_n "checking for suffix of executables... " >&6; }
case "(($ac_try" in
  ac_status=$?
  # If both `conftest.exe' and `conftest' are `present' (well, observable)
# catch `conftest.exe'.  For instance with Cygwin, `ls conftest' will
# work properly (i.e., refer to `conftest.exe'), while it won't with
# `rm'.
for ac_file in conftest.exe conftest conftest.*; do
  case $ac_file in
    *.* ) ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
	  break;;
    * ) break;;
as_fn_error $? "cannot compute suffix of executables: cannot compile and link
rm -f conftest conftest$ac_cv_exeext
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_exeext" >&5
$as_echo "$ac_cv_exeext" >&6; }
rm -f conftest.$ac_ext
EXEEXT=$ac_cv_exeext
ac_exeext=$EXEEXT
int
main ()
FILE *f = fopen ("conftest.out", "w");
 return ferror (f) || fclose (f) != 0;
_ACEOF
ac_clean_files="$ac_clean_files conftest.out"
# Check that the compiler produces executables we can run.  If not, either
# the compiler is broken, or we cross compile.
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are cross compiling" >&5
$as_echo_n "checking whether we are cross compiling... " >&6; }
if test "$cross_compiling" != yes; then
case "(($ac_try" in
  ac_status=$?
  if { ac_try='./conftest$ac_cv_exeext'
  ac_status=$?
    cross_compiling=no
    if test "$cross_compiling" = maybe; then
	cross_compiling=yes
as_fn_error $? "cannot run C compiled programs.
If you meant to cross compile, use \`--host'.
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $cross_compiling" >&5
$as_echo "$cross_compiling" >&6; }
rm -f conftest.$ac_ext conftest$ac_cv_exeext conftest.out
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of object files" >&5
$as_echo_n "checking for suffix of object files... " >&6; }
if ${ac_cv_objext+:} false; then :
int
main ()
_ACEOF
rm -f conftest.o conftest.obj
case "(($ac_try" in
  (eval "$ac_compile") 2>&5
  ac_status=$?
  for ac_file in conftest.o conftest.obj conftest.*; do
  test -f "$ac_file" || continue;
  case $ac_file in
    *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf | *.dSYM ) ;;
    *) ac_cv_objext=`expr "$ac_file" : '.*\.\(.*\)'`
       break;;
as_fn_error $? "cannot compute suffix of object files: cannot compile
rm -f conftest.$ac_cv_objext conftest.$ac_ext
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_objext" >&5
$as_echo "$ac_cv_objext" >&6; }
OBJEXT=$ac_cv_objext
ac_objext=$OBJEXT
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU C compiler" >&5
$as_echo_n "checking whether we are using the GNU C compiler... " >&6; }
if ${ac_cv_c_compiler_gnu+:} false; then :
int
main ()
#ifndef __GNUC__
       choke me
_ACEOF
  ac_compiler_gnu=yes
  ac_compiler_gnu=no
ac_cv_c_compiler_gnu=$ac_compiler_gnu
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_compiler_gnu" >&5
$as_echo "$ac_cv_c_compiler_gnu" >&6; }
if test $ac_compiler_gnu = yes; then
  GCC=yes
  GCC=
ac_test_CFLAGS=${CFLAGS+set}
ac_save_CFLAGS=$CFLAGS
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CC accepts -g" >&5
$as_echo_n "checking whether $CC accepts -g... " >&6; }
if ${ac_cv_prog_cc_g+:} false; then :
  ac_save_c_werror_flag=$ac_c_werror_flag
   ac_c_werror_flag=yes
   ac_cv_prog_cc_g=no
   CFLAGS="-g"
int
main ()
_ACEOF
  ac_cv_prog_cc_g=yes
  CFLAGS=""
int
main ()
_ACEOF
  ac_c_werror_flag=$ac_save_c_werror_flag
	 CFLAGS="-g"
int
main ()
_ACEOF
  ac_cv_prog_cc_g=yes
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_g" >&5
$as_echo "$ac_cv_prog_cc_g" >&6; }
if test "$ac_test_CFLAGS" = set; then
  CFLAGS=$ac_save_CFLAGS
elif test $ac_cv_prog_cc_g = yes; then
  if test "$GCC" = yes; then
    CFLAGS="-g -O2"
    CFLAGS="-g"
    CFLAGS="-O2"
    CFLAGS=
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $CC option to accept ISO C89" >&5
$as_echo_n "checking for $CC option to accept ISO C89... " >&6; }
if ${ac_cv_prog_cc_c89+:} false; then :
  ac_cv_prog_cc_c89=no
ac_save_CC=$CC
#include <stdarg.h>
struct stat;
/* Most of the following tests are stolen from RCS 5.7's src/conf.sh.  */
struct buf { int x; };
FILE * (*rcsopen) (struct buf *, struct stat *, int);
static char *e (p, i)
     char **p;
     int i;
  return p[i];
static char *f (char * (*g) (char **, int), char **p, ...)
  char *s;
  va_list v;
  va_start (v,p);
  s = g (p, va_arg (v,int));
  va_end (v);
  return s;
/* OSF 4.0 Compaq cc is some sort of almost-ANSI by default.  It has
   function prototypes and stuff, but not '\xHH' hex character constants.
   These don't provoke an error unfortunately, instead are silently treated
   as 'x'.  The following induces an error, until -std is added to get
   proper ANSI mode.  Curiously '\x00'!='x' always comes out true, for an
   array size at least.  It's necessary to write '\x00'==0 to get something
   that's true only with -std.  */
int osf4_cc_array ['\x00' == 0 ? 1 : -1];
/* IBM C 6 for AIX is almost-ANSI by default, but it replaces macro parameters
   inside strings and character constants.  */
#define FOO(x) 'x'
int xlc6_cc_array[FOO(a) == 'x' ? 1 : -1];
int test (int i, double x);
struct s1 {int (*f) (int a);};
struct s2 {int (*f) (double a);};
int pairnames (int, char **, FILE *(*)(struct buf *, struct stat *, int), int, int);
int argc;
char **argv;
int
main ()
return f (e, argv, 0) != argv[0]  ||  f (e, argv, 1) != argv[1];
_ACEOF
for ac_arg in '' -qlanglvl=extc89 -qlanglvl=ansi -std \
	-Ae "-Aa -D_HPUX_SOURCE" "-Xc -D__EXTENSIONS__"
do
  CC="$ac_save_CC $ac_arg"
  ac_cv_prog_cc_c89=$ac_arg
  test "x$ac_cv_prog_cc_c89" != "xno" && break
CC=$ac_save_CC
# AC_CACHE_VAL
case "x$ac_cv_prog_cc_c89" in
  x)
    { $as_echo "$as_me:${as_lineno-$LINENO}: result: none needed" >&5
$as_echo "none needed" >&6; } ;;
  xno)
    { $as_echo "$as_me:${as_lineno-$LINENO}: result: unsupported" >&5
$as_echo "unsupported" >&6; } ;;
    CC="$CC $ac_cv_prog_cc_c89"
    { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_c89" >&5
$as_echo "$ac_cv_prog_cc_c89" >&6; } ;;
if test "x$ac_cv_prog_cc_c89" != xno; then :
ac_ext=c
ac_ext=c
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CC understands -c and -o together" >&5
$as_echo_n "checking whether $CC understands -c and -o together... " >&6; }
if ${am_cv_prog_cc_c_o+:} false; then :
int
main ()
_ACEOF
  # Make sure it works both with $CC and with simple cc.
  # Following AC_PROG_CC_C_O, we do the test twice because some
  # compilers refuse to overwrite an existing .o file with -o,
  # though they will create one.
  am_cv_prog_cc_c_o=yes
  for am_i in 1 2; do
    if { echo "$as_me:$LINENO: $CC -c conftest.$ac_ext -o conftest2.$ac_objext" >&5
   ($CC -c conftest.$ac_ext -o conftest2.$ac_objext) >&5 2>&5
   ac_status=$?
   echo "$as_me:$LINENO: \$? = $ac_status" >&5
   (exit $ac_status); } \
         && test -f conftest2.$ac_objext; then
      : OK
      am_cv_prog_cc_c_o=no
      break
  rm -f core conftest*
  unset am_i
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $am_cv_prog_cc_c_o" >&5
$as_echo "$am_cv_prog_cc_c_o" >&6; }
if test "$am_cv_prog_cc_c_o" != yes; then
   # Losing compiler, so override with the script.
   # FIXME: It is wrong to rewrite CC.
   # But if we don't then we get into trouble of one sort or another.
   # A longer-term fix would be to have automake use am__CC in this case,
   # and then we could set am__CC="\$(top_srcdir)/compile \$(CC)"
   CC="$am_aux_dir/compile $CC"
ac_ext=c
DEPDIR="${am__leading_dot}deps"
ac_config_commands="$ac_config_commands depfiles"
cat > confinc << 'END'
am__doit:
	@echo this is the am__doit target
.PHONY: am__doit
END
# If we don't find an include directive, just comment out the code.
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for style of include used by $am_make" >&5
$as_echo_n "checking for style of include used by $am_make... " >&6; }
am__include="#"
am__quote=
_am_result=none
# First try GNU make style include.
echo "include confinc" > confmf
# Ignore all kinds of additional output from 'make'.
case `$am_make -s -f confmf 2> /dev/null` in #(
*the\ am__doit\ target*)
  am__include=include
  am__quote=
  _am_result=GNU
# Now try BSD make style include.
if test "$am__include" = "#"; then
   echo '.include "confinc"' > confmf
     am__include=.include
     am__quote="\""
     _am_result=BSD
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $_am_result" >&5
$as_echo "$_am_result" >&6; }
rm -f confinc confmf
# Check whether --enable-dependency-tracking was given.
if test "${enable_dependency_tracking+set}" = set; then :
  enableval=$enable_dependency_tracking;
if test "x$enable_dependency_tracking" != xno; then
  am_depcomp="$ac_aux_dir/depcomp"
  AMDEPBACKSLASH='\'
  am__nodep='_no'
  AMDEP_TRUE=
  AMDEP_FALSE='#'
  AMDEP_TRUE='#'
  AMDEP_FALSE=
depcc="$CC"   am_compiler_list=
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking dependency style of $depcc" >&5
$as_echo_n "checking dependency style of $depcc... " >&6; }
if ${am_cv_CC_dependencies_compiler_type+:} false; then :
  if test -z "$AMDEP_TRUE" && test -f "$am_depcomp"; then
  # We make a subdir and do the tests there.  Otherwise we can end up
  # making bogus files that we don't know about and never remove.  For
  # instance it was reported that on HP-UX the gcc test will end up
  # making a dummy file named 'D' -- because '-MD' means "put the output
  # in D".
  rm -rf conftest.dir
  mkdir conftest.dir
  # Copy depcomp to subdir because otherwise we won't find it if we're
  # using a relative directory.
  cp "$am_depcomp" conftest.dir
  cd conftest.dir
  # We will build objects and dependencies in a subdirectory because
  # it helps to detect inapplicable dependency modes.  For instance
  # both Tru64's cc and ICC support -MD to output dependencies as a
  # side effect of compilation, but ICC will put the dependencies in
  # the current directory while Tru64 will put them in the object
  # directory.
  mkdir sub
  am_cv_CC_dependencies_compiler_type=none
  if test "$am_compiler_list" = ""; then
     am_compiler_list=`sed -n 's/^#*\([a-zA-Z0-9]*\))$/\1/p' < ./depcomp`
  am__universal=false
  case " $depcc " in #(
     *\ -arch\ *\ -arch\ *) am__universal=true ;;
  for depmode in $am_compiler_list; do
    # Setup a source with many dependencies, because some compilers
    # like to wrap large dependency lists on column 80 (with \), and
    # we should not choose a depcomp mode which is confused by this.
    # We need to recreate these files for each test, as the compiler may
    # overwrite some of them when testing with obscure command lines.
    # This happens at least with the AIX C compiler.
    : > sub/conftest.c
    for i in 1 2 3 4 5 6; do
      echo '#include "conftst'$i'.h"' >> sub/conftest.c
      # Using ": > sub/conftst$i.h" creates only sub/conftst1.h with
      # Solaris 10 /bin/sh.
      echo '/* dummy */' > sub/conftst$i.h
    echo "${am__include} ${am__quote}sub/conftest.Po${am__quote}" > confmf
    # We check with '-c' and '-o' for the sake of the "dashmstdout"
    # mode.  It turns out that the SunPro C++ compiler does not properly
    # handle '-M -o', and we need to detect this.  Also, some Intel
    # versions had trouble with output in subdirs.
    am__obj=sub/conftest.${OBJEXT-o}
    am__minus_obj="-o $am__obj"
    case $depmode in
    gcc)
      # This depmode causes a compiler race in universal mode.
      test "$am__universal" = false || continue
    nosideeffect)
      # After this tag, mechanisms are not by side-effect, so they'll
      # only be used when explicitly requested.
      if test "x$enable_dependency_tracking" = xyes; then
	continue
	break
    msvc7 | msvc7msys | msvisualcpp | msvcmsys)
      # This compiler won't grok '-c -o', but also, the minuso test has
      # not run yet.  These depmodes are late enough in the game, and
      # so weak that their functioning should not be impacted.
      am__obj=conftest.${OBJEXT-o}
      am__minus_obj=
    none) break ;;
    if depmode=$depmode \
       source=sub/conftest.c object=$am__obj \
       depfile=sub/conftest.Po tmpdepfile=sub/conftest.TPo \
       $SHELL ./depcomp $depcc -c $am__minus_obj sub/conftest.c \
         >/dev/null 2>conftest.err &&
       grep sub/conftst1.h sub/conftest.Po > /dev/null 2>&1 &&
       grep sub/conftst6.h sub/conftest.Po > /dev/null 2>&1 &&
       grep $am__obj sub/conftest.Po > /dev/null 2>&1 &&
       ${MAKE-make} -s -f confmf > /dev/null 2>&1; then
      # icc doesn't choke on unknown options, it will just issue warnings
      # or remarks (even with -Werror).  So we grep stderr for any message
      # that says an option was ignored or not supported.
      # When given -MP, icc 7.0 and 7.1 complain thusly:
      #   icc: Command line warning: ignoring option '-M'; no argument required
      # The diagnosis changed in icc 8.0:
      #   icc: Command line remark: option '-MP' not supported
      if (grep 'ignoring option' conftest.err ||
          grep 'not supported' conftest.err) >/dev/null 2>&1; then :; else
        am_cv_CC_dependencies_compiler_type=$depmode
        break
  cd ..
  rm -rf conftest.dir
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $am_cv_CC_dependencies_compiler_type" >&5
$as_echo "$am_cv_CC_dependencies_compiler_type" >&6; }
CCDEPMODE=depmode=$am_cv_CC_dependencies_compiler_type
 if
  test "x$enable_dependency_tracking" != xno \
  && test "$am_cv_CC_dependencies_compiler_type" = gcc3; then
  am__fastdepCC_TRUE=
  am__fastdepCC_FALSE='#'
  am__fastdepCC_TRUE='#'
ac_ext=cpp
ac_cpp='$CXXCPP $CPPFLAGS'
ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
if test -z "$CXX"; then
  if test -n "$CCC"; then
    CXX=$CCC
  for ac_prog in g++ c++ gpp aCC CC cxx cc++ cl.exe FCC KCC RCC xlC_r xlC
  do
if ${ac_cv_prog_CXX+:} false; then :
  if test -n "$CXX"; then
  ac_cv_prog_CXX="$CXX" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_CXX="$ac_tool_prefix$ac_prog"
    break 2
IFS=$as_save_IFS
CXX=$ac_cv_prog_CXX
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $CXX" >&5
$as_echo "$CXX" >&6; }
    test -n "$CXX" && break
  ac_ct_CXX=$CXX
do
if ${ac_cv_prog_ac_ct_CXX+:} false; then :
  if test -n "$ac_ct_CXX"; then
  ac_cv_prog_ac_ct_CXX="$ac_ct_CXX" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_CXX="$ac_prog"
    break 2
IFS=$as_save_IFS
ac_ct_CXX=$ac_cv_prog_ac_ct_CXX
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_CXX" >&5
$as_echo "$ac_ct_CXX" >&6; }
  test -n "$ac_ct_CXX" && break
  if test "x$ac_ct_CXX" = x; then
    CXX="g++"
yes:)
    CXX=$ac_ct_CXX
$as_echo "$as_me:${as_lineno-$LINENO}: checking for C++ compiler version" >&5
set X $ac_compile
ac_compiler=$2
case "(($ac_try" in
  ac_status=$?
    sed '10a\
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU C++ compiler" >&5
$as_echo_n "checking whether we are using the GNU C++ compiler... " >&6; }
if ${ac_cv_cxx_compiler_gnu+:} false; then :
int
main ()
#ifndef __GNUC__
       choke me
_ACEOF
if ac_fn_cxx_try_compile "$LINENO"; then :
  ac_compiler_gnu=yes
  ac_compiler_gnu=no
ac_cv_cxx_compiler_gnu=$ac_compiler_gnu
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_cxx_compiler_gnu" >&5
$as_echo "$ac_cv_cxx_compiler_gnu" >&6; }
  GXX=yes
  GXX=
ac_test_CXXFLAGS=${CXXFLAGS+set}
ac_save_CXXFLAGS=$CXXFLAGS
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CXX accepts -g" >&5
$as_echo_n "checking whether $CXX accepts -g... " >&6; }
if ${ac_cv_prog_cxx_g+:} false; then :
  ac_save_cxx_werror_flag=$ac_cxx_werror_flag
   ac_cxx_werror_flag=yes
   ac_cv_prog_cxx_g=no
   CXXFLAGS="-g"
int
main ()
_ACEOF
  ac_cv_prog_cxx_g=yes
  CXXFLAGS=""
int
main ()
_ACEOF
  ac_cxx_werror_flag=$ac_save_cxx_werror_flag
	 CXXFLAGS="-g"
int
main ()
_ACEOF
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cxx_g" >&5
$as_echo "$ac_cv_prog_cxx_g" >&6; }
if test "$ac_test_CXXFLAGS" = set; then
  CXXFLAGS=$ac_save_CXXFLAGS
elif test $ac_cv_prog_cxx_g = yes; then
  if test "$GXX" = yes; then
    CXXFLAGS="-g -O2"
    CXXFLAGS="-g"
    CXXFLAGS="-O2"
    CXXFLAGS=
ac_ext=c
depcc="$CXX"  am_compiler_list=
if ${am_cv_CXX_dependencies_compiler_type+:} false; then :
  # in D".
  rm -rf conftest.dir
  mkdir conftest.dir
  cd conftest.dir
  # directory.
  mkdir sub
  am_cv_CXX_dependencies_compiler_type=none
  am__universal=false
    : > sub/conftest.c
    case $depmode in
    gcc)
    nosideeffect)
	continue
	break
      am__minus_obj=
    none) break ;;
        am_cv_CXX_dependencies_compiler_type=$depmode
        break
  cd ..
  rm -rf conftest.dir
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $am_cv_CXX_dependencies_compiler_type" >&5
$as_echo "$am_cv_CXX_dependencies_compiler_type" >&6; }
CXXDEPMODE=depmode=$am_cv_CXX_dependencies_compiler_type
 if
  && test "$am_cv_CXX_dependencies_compiler_type" = gcc3; then
  am__fastdepCXX_TRUE=
  am__fastdepCXX_FALSE='#'
  am__fastdepCXX_TRUE='#'
  # Extract the first word of "${ac_tool_prefix}ranlib", so it can be a program name with args.
set dummy ${ac_tool_prefix}ranlib; ac_word=$2
if ${ac_cv_prog_RANLIB+:} false; then :
  if test -n "$RANLIB"; then
  ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_RANLIB="${ac_tool_prefix}ranlib"
    break 2
IFS=$as_save_IFS
RANLIB=$ac_cv_prog_RANLIB
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $RANLIB" >&5
$as_echo "$RANLIB" >&6; }
if test -z "$ac_cv_prog_RANLIB"; then
  ac_ct_RANLIB=$RANLIB
  # Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
if ${ac_cv_prog_ac_ct_RANLIB+:} false; then :
  if test -n "$ac_ct_RANLIB"; then
  ac_cv_prog_ac_ct_RANLIB="$ac_ct_RANLIB" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_RANLIB="ranlib"
    break 2
IFS=$as_save_IFS
ac_ct_RANLIB=$ac_cv_prog_ac_ct_RANLIB
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_RANLIB" >&5
$as_echo "$ac_ct_RANLIB" >&6; }
  if test "x$ac_ct_RANLIB" = x; then
    RANLIB=":"
yes:)
    RANLIB=$ac_ct_RANLIB
  RANLIB="$ac_cv_prog_RANLIB"
case `pwd` in
    { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Libtool does not cope well with whitespace in \`pwd\`" >&5
$as_echo "$as_me: WARNING: Libtool does not cope well with whitespace in \`pwd\`" >&2;} ;;
macro_version='2.4.2'
macro_revision='1.3337'
ltmain="$ac_aux_dir/ltmain.sh"
# Make sure we can run config.sub.
$SHELL "$ac_aux_dir/config.sub" sun4 >/dev/null 2>&1 ||
  as_fn_error $? "cannot run $SHELL $ac_aux_dir/config.sub" "$LINENO" 5
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking build system type" >&5
$as_echo_n "checking build system type... " >&6; }
if ${ac_cv_build+:} false; then :
  ac_build_alias=$build_alias
test "x$ac_build_alias" = x &&
  ac_build_alias=`$SHELL "$ac_aux_dir/config.guess"`
  as_fn_error $? "cannot guess build type; you must specify one" "$LINENO" 5
ac_cv_build=`$SHELL "$ac_aux_dir/config.sub" $ac_build_alias` ||
  as_fn_error $? "$SHELL $ac_aux_dir/config.sub $ac_build_alias failed" "$LINENO" 5
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_build" >&5
$as_echo "$ac_cv_build" >&6; }
case $ac_cv_build in
*) as_fn_error $? "invalid value of canonical build" "$LINENO" 5;;
build=$ac_cv_build
ac_save_IFS=$IFS; IFS='-'
set x $ac_cv_build
shift
build_cpu=$1
build_vendor=$2
shift; shift
# Remember, the first character of IFS is used to create $*,
# except with old shells:
build_os=$*
IFS=$ac_save_IFS
case $build_os in *\ *) build_os=`echo "$build_os" | sed 's/ /-/g'`;; esac
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking host system type" >&5
$as_echo_n "checking host system type... " >&6; }
if ${ac_cv_host+:} false; then :
  if test "x$host_alias" = x; then
  ac_cv_host=$ac_cv_build
  ac_cv_host=`$SHELL "$ac_aux_dir/config.sub" $host_alias` ||
    as_fn_error $? "$SHELL $ac_aux_dir/config.sub $host_alias failed" "$LINENO" 5
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_host" >&5
$as_echo "$ac_cv_host" >&6; }
case $ac_cv_host in
*) as_fn_error $? "invalid value of canonical host" "$LINENO" 5;;
host=$ac_cv_host
set x $ac_cv_host
shift
host_cpu=$1
host_vendor=$2
shift; shift
host_os=$*
IFS=$ac_save_IFS
case $host_os in *\ *) host_os=`echo "$host_os" | sed 's/ /-/g'`;; esac
# Backslashify metacharacters that are still active within
# double-quoted strings.
sed_quote_subst='s/\(["`$\\]\)/\\\1/g'
# Same as above, but do not quote variable references.
double_quote_subst='s/\(["`\\]\)/\\\1/g'
# Sed substitution to delay expansion of an escaped shell variable in a
# double_quote_subst'ed string.
delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
# Sed substitution to delay expansion of an escaped single quote.
delay_single_quote_subst='s/'\''/'\'\\\\\\\'\''/g'
# Sed substitution to avoid accidental globbing in evaled expressions
no_glob_subst='s/\*/\\\*/g'
ECHO='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
ECHO=$ECHO$ECHO$ECHO$ECHO$ECHO
ECHO=$ECHO$ECHO$ECHO$ECHO$ECHO$ECHO
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to print strings" >&5
$as_echo_n "checking how to print strings... " >&6; }
# Test print first, because it will be a builtin if present.
if test "X`( print -r -- -n ) 2>/dev/null`" = X-n && \
   test "X`print -r -- $ECHO 2>/dev/null`" = "X$ECHO"; then
  ECHO='print -r --'
elif test "X`printf %s $ECHO 2>/dev/null`" = "X$ECHO"; then
  ECHO='printf %s\n'
  # Use this function as a fallback that always works.
  func_fallback_echo ()
    eval 'cat <<_LTECHO_EOF
$1
_LTECHO_EOF'
  ECHO='func_fallback_echo'
# func_echo_all arg...
# Invoke $ECHO with all args, space-separated.
func_echo_all ()
    $ECHO ""
case "$ECHO" in
  printf*) { $as_echo "$as_me:${as_lineno-$LINENO}: result: printf" >&5
$as_echo "printf" >&6; } ;;
  print*) { $as_echo "$as_me:${as_lineno-$LINENO}: result: print -r" >&5
$as_echo "print -r" >&6; } ;;
  *) { $as_echo "$as_me:${as_lineno-$LINENO}: result: cat" >&5
$as_echo "cat" >&6; } ;;
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a sed that does not truncate output" >&5
$as_echo_n "checking for a sed that does not truncate output... " >&6; }
if ${ac_cv_path_SED+:} false; then :
            ac_script=s/aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa/bbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb/
     for ac_i in 1 2 3 4 5 6 7; do
       ac_script="$ac_script$as_nl$ac_script"
     echo "$ac_script" 2>/dev/null | sed 99q >conftest.sed
     { ac_script=; unset ac_script;}
     if test -z "$SED"; then
  ac_path_SED_found=false
  # Loop through the user's path and test for each of PROGNAME-LIST
for as_dir in $PATH
do
  IFS=$as_save_IFS
    for ac_prog in sed gsed; do
      ac_path_SED="$as_dir/$ac_prog$ac_exec_ext"
      as_fn_executable_p "$ac_path_SED" || continue
# Check for GNU ac_path_SED and select it if it is found.
  # Check for GNU $ac_path_SED
case `"$ac_path_SED" --version 2>&1` in
*GNU*)
  ac_cv_path_SED="$ac_path_SED" ac_path_SED_found=:;;
  ac_count=0
  $as_echo_n 0123456789 >"conftest.in"
  while :
  do
    cat "conftest.in" "conftest.in" >"conftest.tmp"
    mv "conftest.tmp" "conftest.in"
    cp "conftest.in" "conftest.nl"
    $as_echo '' >> "conftest.nl"
    "$ac_path_SED" -f conftest.sed < "conftest.nl" >"conftest.out" 2>/dev/null || break
    diff "conftest.out" "conftest.nl" >/dev/null 2>&1 || break
    as_fn_arith $ac_count + 1 && ac_count=$as_val
    if test $ac_count -gt ${ac_path_SED_max-0}; then
      # Best one so far, save it but keep looking for a better one
      ac_path_SED_max=$ac_count
    # 10*(2^10) chars as input seems more than enough
    test $ac_count -gt 10 && break
  rm -f conftest.in conftest.tmp conftest.nl conftest.out;;
      $ac_path_SED_found && break 3
IFS=$as_save_IFS
  if test -z "$ac_cv_path_SED"; then
    as_fn_error $? "no acceptable sed could be found in \$PATH" "$LINENO" 5
  ac_cv_path_SED=$SED
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_SED" >&5
$as_echo "$ac_cv_path_SED" >&6; }
 SED="$ac_cv_path_SED"
  rm -f conftest.sed
test -z "$SED" && SED=sed
Xsed="$SED -e 1s/^X//"
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for grep that handles long lines and -e" >&5
$as_echo_n "checking for grep that handles long lines and -e... " >&6; }
if ${ac_cv_path_GREP+:} false; then :
  if test -z "$GREP"; then
  ac_path_GREP_found=false
for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin
do
  IFS=$as_save_IFS
    for ac_prog in grep ggrep; do
      ac_path_GREP="$as_dir/$ac_prog$ac_exec_ext"
      as_fn_executable_p "$ac_path_GREP" || continue
# Check for GNU ac_path_GREP and select it if it is found.
  # Check for GNU $ac_path_GREP
case `"$ac_path_GREP" --version 2>&1` in
*GNU*)
  ac_cv_path_GREP="$ac_path_GREP" ac_path_GREP_found=:;;
  ac_count=0
  while :
  do
    $as_echo 'GREP' >> "conftest.nl"
    "$ac_path_GREP" -e 'GREP$' -e '-(cannot match)-' < "conftest.nl" >"conftest.out" 2>/dev/null || break
    if test $ac_count -gt ${ac_path_GREP_max-0}; then
      ac_path_GREP_max=$ac_count
      $ac_path_GREP_found && break 3
IFS=$as_save_IFS
  if test -z "$ac_cv_path_GREP"; then
    as_fn_error $? "no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
  ac_cv_path_GREP=$GREP
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_GREP" >&5
$as_echo "$ac_cv_path_GREP" >&6; }
 GREP="$ac_cv_path_GREP"
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for egrep" >&5
$as_echo_n "checking for egrep... " >&6; }
if ${ac_cv_path_EGREP+:} false; then :
  $as_echo_n "(cached) " >&6
  if echo a | $GREP -E '(a|b)' >/dev/null 2>&1
   then ac_cv_path_EGREP="$GREP -E"
     if test -z "$EGREP"; then
  ac_path_EGREP_found=false
do
  IFS=$as_save_IFS
    for ac_prog in egrep; do
      ac_path_EGREP="$as_dir/$ac_prog$ac_exec_ext"
      as_fn_executable_p "$ac_path_EGREP" || continue
# Check for GNU ac_path_EGREP and select it if it is found.
  # Check for GNU $ac_path_EGREP
case `"$ac_path_EGREP" --version 2>&1` in
*GNU*)
  ac_cv_path_EGREP="$ac_path_EGREP" ac_path_EGREP_found=:;;
  ac_count=0
  while :
  do
    $as_echo 'EGREP' >> "conftest.nl"
    "$ac_path_EGREP" 'EGREP$' < "conftest.nl" >"conftest.out" 2>/dev/null || break
    if test $ac_count -gt ${ac_path_EGREP_max-0}; then
      ac_path_EGREP_max=$ac_count
      $ac_path_EGREP_found && break 3
IFS=$as_save_IFS
  if test -z "$ac_cv_path_EGREP"; then
    as_fn_error $? "no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
  ac_cv_path_EGREP=$EGREP
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_EGREP" >&5
$as_echo "$ac_cv_path_EGREP" >&6; }
 EGREP="$ac_cv_path_EGREP"
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for fgrep" >&5
$as_echo_n "checking for fgrep... " >&6; }
if ${ac_cv_path_FGREP+:} false; then :
  if echo 'ab*c' | $GREP -F 'ab*c' >/dev/null 2>&1
   then ac_cv_path_FGREP="$GREP -F"
     if test -z "$FGREP"; then
  ac_path_FGREP_found=false
do
  IFS=$as_save_IFS
    for ac_prog in fgrep; do
      ac_path_FGREP="$as_dir/$ac_prog$ac_exec_ext"
      as_fn_executable_p "$ac_path_FGREP" || continue
# Check for GNU ac_path_FGREP and select it if it is found.
  # Check for GNU $ac_path_FGREP
case `"$ac_path_FGREP" --version 2>&1` in
*GNU*)
  ac_cv_path_FGREP="$ac_path_FGREP" ac_path_FGREP_found=:;;
  ac_count=0
  while :
  do
    $as_echo 'FGREP' >> "conftest.nl"
    "$ac_path_FGREP" FGREP < "conftest.nl" >"conftest.out" 2>/dev/null || break
    if test $ac_count -gt ${ac_path_FGREP_max-0}; then
      ac_path_FGREP_max=$ac_count
      $ac_path_FGREP_found && break 3
IFS=$as_save_IFS
  if test -z "$ac_cv_path_FGREP"; then
    as_fn_error $? "no acceptable fgrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
  ac_cv_path_FGREP=$FGREP
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_FGREP" >&5
$as_echo "$ac_cv_path_FGREP" >&6; }
 FGREP="$ac_cv_path_FGREP"
test -z "$GREP" && GREP=grep
# Check whether --with-gnu-ld was given.
if test "${with_gnu_ld+set}" = set; then :
  withval=$with_gnu_ld; test "$withval" = no || with_gnu_ld=yes
  with_gnu_ld=no
ac_prog=ld
  # Check if gcc -print-prog-name=ld gives a path.
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for ld used by $CC" >&5
$as_echo_n "checking for ld used by $CC... " >&6; }
  case $host in
  *-*-mingw*)
    # gcc leaves a trailing carriage return which upsets mingw
    ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
    ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
  case $ac_prog in
    # Accept absolute paths.
      re_direlt='/[^/][^/]*/\.\./'
      # Canonicalize the pathname of ld
      ac_prog=`$ECHO "$ac_prog"| $SED 's%\\\\%/%g'`
      while $ECHO "$ac_prog" | $GREP "$re_direlt" > /dev/null 2>&1; do
	ac_prog=`$ECHO $ac_prog| $SED "s%$re_direlt%/%"`
      test -z "$LD" && LD="$ac_prog"
    # If it fails, then pretend we aren't using GCC.
    ac_prog=ld
    # If it is relative, then search for the first ld in PATH.
    with_gnu_ld=unknown
elif test "$with_gnu_ld" = yes; then
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for GNU ld" >&5
$as_echo_n "checking for GNU ld... " >&6; }
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for non-GNU ld" >&5
$as_echo_n "checking for non-GNU ld... " >&6; }
if ${lt_cv_path_LD+:} false; then :
  if test -z "$LD"; then
  lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
  for ac_dir in $PATH; do
    IFS="$lt_save_ifs"
    test -z "$ac_dir" && ac_dir=.
    if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
      lt_cv_path_LD="$ac_dir/$ac_prog"
      # Check to see if the program is GNU ld.  I'd rather use --version,
      # but apparently some variants of GNU ld only accept -v.
      # Break only if it was the GNU/non-GNU ld that we prefer.
      case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
      *GNU* | *'with BFD'*)
	test "$with_gnu_ld" != no && break
	test "$with_gnu_ld" != yes && break
  IFS="$lt_save_ifs"
  lt_cv_path_LD="$LD" # Let the user override the test with a path.
LD="$lt_cv_path_LD"
if test -n "$LD"; then
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $LD" >&5
$as_echo "$LD" >&6; }
test -z "$LD" && as_fn_error $? "no acceptable ld found in \$PATH" "$LINENO" 5
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if the linker ($LD) is GNU ld" >&5
$as_echo_n "checking if the linker ($LD) is GNU ld... " >&6; }
if ${lt_cv_prog_gnu_ld+:} false; then :
  # I'd rather use --version here, but apparently some GNU lds only accept -v.
case `$LD -v 2>&1 </dev/null` in
  lt_cv_prog_gnu_ld=yes
  lt_cv_prog_gnu_ld=no
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_gnu_ld" >&5
$as_echo "$lt_cv_prog_gnu_ld" >&6; }
with_gnu_ld=$lt_cv_prog_gnu_ld
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for BSD- or MS-compatible name lister (nm)" >&5
$as_echo_n "checking for BSD- or MS-compatible name lister (nm)... " >&6; }
if ${lt_cv_path_NM+:} false; then :
  if test -n "$NM"; then
  lt_cv_path_NM="$NM"
  lt_nm_to_check="${ac_tool_prefix}nm"
  if test -n "$ac_tool_prefix" && test "$build" = "$host"; then
    lt_nm_to_check="$lt_nm_to_check nm"
  for lt_tmp_nm in $lt_nm_to_check; do
    for ac_dir in $PATH /usr/ccs/bin/elf /usr/ccs/bin /usr/ucb /bin; do
      IFS="$lt_save_ifs"
      tmp_nm="$ac_dir/$lt_tmp_nm"
      if test -f "$tmp_nm" || test -f "$tmp_nm$ac_exeext" ; then
	# Check to see if the nm accepts a BSD-compat flag.
	# Adding the `sed 1q' prevents false positives on HP-UX, which says:
	#   nm: unknown option "B" ignored
	# Tru64's nm complains that /dev/null is an invalid object file
	case `"$tmp_nm" -B /dev/null 2>&1 | sed '1q'` in
	*/dev/null* | *'Invalid file or object type'*)
	  lt_cv_path_NM="$tmp_nm -B"
	  break
	  case `"$tmp_nm" -p /dev/null 2>&1 | sed '1q'` in
	  */dev/null*)
	    lt_cv_path_NM="$tmp_nm -p"
	    break
	    lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
	    continue # so that we can try to find one that supports BSD flags
    IFS="$lt_save_ifs"
  : ${lt_cv_path_NM=no}
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_path_NM" >&5
$as_echo "$lt_cv_path_NM" >&6; }
if test "$lt_cv_path_NM" != "no"; then
  NM="$lt_cv_path_NM"
  # Didn't find any BSD compatible name lister, look for dumpbin.
  if test -n "$DUMPBIN"; then :
  for ac_prog in dumpbin "link -dump"
  do
if ${ac_cv_prog_DUMPBIN+:} false; then :
  ac_cv_prog_DUMPBIN="$DUMPBIN" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_DUMPBIN="$ac_tool_prefix$ac_prog"
    break 2
IFS=$as_save_IFS
DUMPBIN=$ac_cv_prog_DUMPBIN
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $DUMPBIN" >&5
$as_echo "$DUMPBIN" >&6; }
    test -n "$DUMPBIN" && break
if test -z "$DUMPBIN"; then
  ac_ct_DUMPBIN=$DUMPBIN
do
if ${ac_cv_prog_ac_ct_DUMPBIN+:} false; then :
  if test -n "$ac_ct_DUMPBIN"; then
  ac_cv_prog_ac_ct_DUMPBIN="$ac_ct_DUMPBIN" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_DUMPBIN="$ac_prog"
    break 2
IFS=$as_save_IFS
ac_ct_DUMPBIN=$ac_cv_prog_ac_ct_DUMPBIN
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_DUMPBIN" >&5
$as_echo "$ac_ct_DUMPBIN" >&6; }
  test -n "$ac_ct_DUMPBIN" && break
  if test "x$ac_ct_DUMPBIN" = x; then
    DUMPBIN=":"
yes:)
    DUMPBIN=$ac_ct_DUMPBIN
    case `$DUMPBIN -symbols /dev/null 2>&1 | sed '1q'` in
    *COFF*)
      DUMPBIN="$DUMPBIN -symbols"
      DUMPBIN=:
  if test "$DUMPBIN" != ":"; then
    NM="$DUMPBIN"
test -z "$NM" && NM=nm
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking the name lister ($NM) interface" >&5
$as_echo_n "checking the name lister ($NM) interface... " >&6; }
if ${lt_cv_nm_interface+:} false; then :
  lt_cv_nm_interface="BSD nm"
  echo "int some_variable = 0;" > conftest.$ac_ext
  (eval echo "\"\$as_me:$LINENO: $ac_compile\"" >&5)
  (eval "$ac_compile" 2>conftest.err)
  cat conftest.err >&5
  (eval echo "\"\$as_me:$LINENO: $NM \\\"conftest.$ac_objext\\\"\"" >&5)
  (eval "$NM \"conftest.$ac_objext\"" 2>conftest.err > conftest.out)
  (eval echo "\"\$as_me:$LINENO: output\"" >&5)
  cat conftest.out >&5
  if $GREP 'External.*some_variable' conftest.out > /dev/null; then
    lt_cv_nm_interface="MS dumpbin"
  rm -f conftest*
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_nm_interface" >&5
$as_echo "$lt_cv_nm_interface" >&6; }
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether ln -s works" >&5
$as_echo_n "checking whether ln -s works... " >&6; }
LN_S=$as_ln_s
if test "$LN_S" = "ln -s"; then
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: no, using $LN_S" >&5
$as_echo "no, using $LN_S" >&6; }
# find the maximum length of command line arguments
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking the maximum length of command line arguments" >&5
$as_echo_n "checking the maximum length of command line arguments... " >&6; }
if ${lt_cv_sys_max_cmd_len+:} false; then :
    i=0
  teststring="ABCD"
  case $build_os in
  msdosdjgpp*)
    # On DJGPP, this test can blow up pretty badly due to problems in libc
    # (any single argument exceeding 2000 bytes causes a buffer overrun
    # during glob expansion).  Even if it were fixed, the result of this
    # check would be larger than it should be.
    lt_cv_sys_max_cmd_len=12288;    # 12K is about right
  gnu*)
    # Under GNU Hurd, this test is not required because there is
    # no limit to the length of command line arguments.
    # Libtool will interpret -1 as no limit whatsoever
    lt_cv_sys_max_cmd_len=-1;
  cygwin* | mingw* | cegcc*)
    # On Win9x/ME, this test blows up -- it succeeds, but takes
    # about 5 minutes as the teststring grows exponentially.
    # Worse, since 9x/ME are not pre-emptively multitasking,
    # you end up with a "frozen" computer, even though with patience
    # the test eventually succeeds (with a max line length of 256k).
    # Instead, let's just punt: use the minimum linelength reported by
    # all of the supported platforms: 8192 (on NT/2K/XP).
    lt_cv_sys_max_cmd_len=8192;
  mint*)
    # On MiNT this can take a long time and run out of memory.
  amigaos*)
    # On AmigaOS with pdksh, this test takes hours, literally.
    # So we just punt and use a minimum line length of 8192.
  netbsd* | freebsd* | openbsd* | darwin* | dragonfly*)
    # This has been around since 386BSD, at least.  Likely further.
    if test -x /sbin/sysctl; then
      lt_cv_sys_max_cmd_len=`/sbin/sysctl -n kern.argmax`
    elif test -x /usr/sbin/sysctl; then
      lt_cv_sys_max_cmd_len=`/usr/sbin/sysctl -n kern.argmax`
      lt_cv_sys_max_cmd_len=65536	# usable default for all BSDs
    # And add a safety zone
    lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 4`
    lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \* 3`
  interix*)
    # We know the value 262144 and hardcode it with a safety zone (like BSD)
    lt_cv_sys_max_cmd_len=196608
  os2*)
    # The test takes a long time on OS/2.
  osf*)
    # Dr. Hans Ekkehard Plesser reports seeing a kernel panic running configure
    # due to this test when exec_disable_arg_limit is 1 on Tru64. It is not
    # nice to cause kernel panics so lets avoid the loop below.
    # First set a reasonable default.
    lt_cv_sys_max_cmd_len=16384
    if test -x /sbin/sysconfig; then
      case `/sbin/sysconfig -q proc exec_disable_arg_limit` in
        *1*) lt_cv_sys_max_cmd_len=-1 ;;
  sco3.2v5*)
    lt_cv_sys_max_cmd_len=102400
  sysv5* | sco5v6* | sysv4.2uw2*)
    kargmax=`grep ARG_MAX /etc/conf/cf.d/stune 2>/dev/null`
    if test -n "$kargmax"; then
      lt_cv_sys_max_cmd_len=`echo $kargmax | sed 's/.*[	 ]//'`
      lt_cv_sys_max_cmd_len=32768
    lt_cv_sys_max_cmd_len=`(getconf ARG_MAX) 2> /dev/null`
    if test -n "$lt_cv_sys_max_cmd_len" && \
	test undefined != "$lt_cv_sys_max_cmd_len"; then
      # Make teststring a little bigger before we do anything with it.
      # a 1K string should be a reasonable start.
      for i in 1 2 3 4 5 6 7 8 ; do
        teststring=$teststring$teststring
      SHELL=${SHELL-${CONFIG_SHELL-/bin/sh}}
      # If test is not a shell built-in, we'll probably end up computing a
      # maximum length that is only half of the actual maximum length, but
      # we can't tell.
      while { test "X"`env echo "$teststring$teststring" 2>/dev/null` \
	         = "X$teststring$teststring"; } >/dev/null 2>&1 &&
	      test $i != 17 # 1/2 MB should be enough
      do
        i=`expr $i + 1`
      # Only check the string length outside the loop.
      lt_cv_sys_max_cmd_len=`expr "X$teststring" : ".*" 2>&1`
      teststring=
      # Add a significant safety factor because C++ compilers can tack on
      # massive amounts of additional arguments before passing them to the
      # linker.  It appears as though 1/2 is a usable value.
      lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 2`
if test -n $lt_cv_sys_max_cmd_len ; then
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_sys_max_cmd_len" >&5
$as_echo "$lt_cv_sys_max_cmd_len" >&6; }
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: none" >&5
$as_echo "none" >&6; }
max_cmd_len=$lt_cv_sys_max_cmd_len
: ${CP="cp -f"}
: ${MV="mv -f"}
: ${RM="rm -f"}
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the shell understands some XSI constructs" >&5
$as_echo_n "checking whether the shell understands some XSI constructs... " >&6; }
# Try some XSI features
xsi_shell=no
( _lt_dummy="a/b/c"
  test "${_lt_dummy##*/},${_lt_dummy%/*},${_lt_dummy#??}"${_lt_dummy%"$_lt_dummy"}, \
      = c,a/b,b/c, \
    && eval 'test $(( 1 + 1 )) -eq 2 \
    && test "${#_lt_dummy}" -eq 5' ) >/dev/null 2>&1 \
  && xsi_shell=yes
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $xsi_shell" >&5
$as_echo "$xsi_shell" >&6; }
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the shell understands \"+=\"" >&5
$as_echo_n "checking whether the shell understands \"+=\"... " >&6; }
lt_shell_append=no
( foo=bar; set foo baz; eval "$1+=\$2" && test "$foo" = barbaz ) \
    >/dev/null 2>&1 \
  && lt_shell_append=yes
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_shell_append" >&5
$as_echo "$lt_shell_append" >&6; }
if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
  lt_unset=unset
  lt_unset=false
# test EBCDIC or ASCII
case `echo X|tr X '\101'` in
 A) # ASCII based system
    # \n is not interpreted correctly by Solaris 8 /usr/ucb/tr
  lt_SP2NL='tr \040 \012'
  lt_NL2SP='tr \015\012 \040\040'
 *) # EBCDIC based system
  lt_SP2NL='tr \100 \n'
  lt_NL2SP='tr \r\n \100\100'
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to convert $build file names to $host format" >&5
$as_echo_n "checking how to convert $build file names to $host format... " >&6; }
if ${lt_cv_to_host_file_cmd+:} false; then :
  case $host in
  *-*-mingw* )
    case $build in
      *-*-mingw* ) # actually msys
        lt_cv_to_host_file_cmd=func_convert_file_msys_to_w32
      *-*-cygwin* )
        lt_cv_to_host_file_cmd=func_convert_file_cygwin_to_w32
      * ) # otherwise, assume *nix
        lt_cv_to_host_file_cmd=func_convert_file_nix_to_w32
  *-*-cygwin* )
    case $build in
        lt_cv_to_host_file_cmd=func_convert_file_msys_to_cygwin
      *-*-cygwin* )
        lt_cv_to_host_file_cmd=func_convert_file_noop
        lt_cv_to_host_file_cmd=func_convert_file_nix_to_cygwin
  * ) # unhandled hosts (and "normal" native builds)
to_host_file_cmd=$lt_cv_to_host_file_cmd
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_to_host_file_cmd" >&5
$as_echo "$lt_cv_to_host_file_cmd" >&6; }
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to convert $build file names to toolchain format" >&5
$as_echo_n "checking how to convert $build file names to toolchain format... " >&6; }
if ${lt_cv_to_tool_file_cmd+:} false; then :
  #assume ordinary cross tools, or native build.
lt_cv_to_tool_file_cmd=func_convert_file_noop
case $host in
  *-*-mingw* )
    case $build in
        lt_cv_to_tool_file_cmd=func_convert_file_msys_to_w32
to_tool_file_cmd=$lt_cv_to_tool_file_cmd
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_to_tool_file_cmd" >&5
$as_echo "$lt_cv_to_tool_file_cmd" >&6; }
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $LD option to reload object files" >&5
$as_echo_n "checking for $LD option to reload object files... " >&6; }
if ${lt_cv_ld_reload_flag+:} false; then :
  lt_cv_ld_reload_flag='-r'
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_ld_reload_flag" >&5
$as_echo "$lt_cv_ld_reload_flag" >&6; }
reload_flag=$lt_cv_ld_reload_flag
case $reload_flag in
*) reload_flag=" $reload_flag" ;;
reload_cmds='$LD$reload_flag -o $output$reload_objs'
case $host_os in
  cygwin* | mingw* | pw32* | cegcc*)
    if test "$GCC" != yes; then
      reload_cmds=false
  darwin*)
      reload_cmds='$LTCC $LTCFLAGS -nostdlib ${wl}-r -o $output$reload_objs'
  # Extract the first word of "${ac_tool_prefix}objdump", so it can be a program name with args.
set dummy ${ac_tool_prefix}objdump; ac_word=$2
if ${ac_cv_prog_OBJDUMP+:} false; then :
  if test -n "$OBJDUMP"; then
  ac_cv_prog_OBJDUMP="$OBJDUMP" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    for ac_exec_ext in '' $ac_executable_extensions; do
    ac_cv_prog_OBJDUMP="${ac_tool_prefix}objdump"
    break 2
IFS=$as_save_IFS
OBJDUMP=$ac_cv_prog_OBJDUMP
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $OBJDUMP" >&5
$as_echo "$OBJDUMP" >&6; }
if test -z "$ac_cv_prog_OBJDUMP"; then
  ac_ct_OBJDUMP=$OBJDUMP
  # Extract the first word of "objdump", so it can be a program name with args.
set dummy objdump; ac_word=$2
if ${ac_cv_prog_ac_ct_OBJDUMP+:} false; then :
  if test -n "$ac_ct_OBJDUMP"; then
  ac_cv_prog_ac_ct_OBJDUMP="$ac_ct_OBJDUMP" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_OBJDUMP="objdump"
    break 2
IFS=$as_save_IFS
ac_ct_OBJDUMP=$ac_cv_prog_ac_ct_OBJDUMP
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_OBJDUMP" >&5
$as_echo "$ac_ct_OBJDUMP" >&6; }
  if test "x$ac_ct_OBJDUMP" = x; then
    OBJDUMP="false"
yes:)
    OBJDUMP=$ac_ct_OBJDUMP
  OBJDUMP="$ac_cv_prog_OBJDUMP"
test -z "$OBJDUMP" && OBJDUMP=objdump
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to recognize dependent libraries" >&5
$as_echo_n "checking how to recognize dependent libraries... " >&6; }
if ${lt_cv_deplibs_check_method+:} false; then :
  lt_cv_file_magic_cmd='$MAGIC_CMD'
lt_cv_file_magic_test_file=
lt_cv_deplibs_check_method='unknown'
# Need to set the preceding variable on all platforms that support
# interlibrary dependencies.
# 'none' -- dependencies not supported.
# `unknown' -- same as none, but documents that we really don't know.
# 'pass_all' -- all dependencies passed with no checks.
# 'test_compile' -- check by making test program.
# 'file_magic [[regex]]' -- check by looking for files in library path
# which responds to the $file_magic_cmd with a given extended regex.
# If you have `file' or equivalent on your system and you're not sure
# whether `pass_all' will *always* work, you probably want this one.
case $host_os in
aix[4-9]*)
  lt_cv_deplibs_check_method=pass_all
beos*)
bsdi[45]*)
  lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib)'
  lt_cv_file_magic_cmd='/usr/bin/file -L'
  lt_cv_file_magic_test_file=/shlib/libc.so
cygwin*)
  # func_win32_libid is a shell function defined in ltmain.sh
  lt_cv_deplibs_check_method='file_magic ^x86 archive import|^x86 DLL'
  lt_cv_file_magic_cmd='func_win32_libid'
mingw* | pw32*)
  # Base MSYS/MinGW do not provide the 'file' command needed by
  # func_win32_libid shell function, so use a weaker test based on 'objdump',
  # unless we find 'file', for example because we are cross-compiling.
  # func_win32_libid assumes BSD nm, so disallow it if using MS dumpbin.
  if ( test "$lt_cv_nm_interface" = "BSD nm" && file / ) >/dev/null 2>&1; then
    # Keep this pattern in sync with the one in func_win32_libid.
    lt_cv_deplibs_check_method='file_magic file format (pei*-i386(.*architecture: i386)?|pe-arm-wince|pe-x86-64)'
    lt_cv_file_magic_cmd='$OBJDUMP -f'
cegcc*)
  # use the weaker test based on 'objdump'. See mingw*.
  lt_cv_deplibs_check_method='file_magic file format pe-arm-.*little(.*architecture: arm)?'
darwin* | rhapsody*)
freebsd* | dragonfly*)
  if echo __ELF__ | $CC -E - | $GREP __ELF__ > /dev/null; then
    case $host_cpu in
    i*86 )
      # Not sure whether the presence of OpenBSD here was a mistake.
      # Let's accept both of them until this is cleared up.
      lt_cv_deplibs_check_method='file_magic (FreeBSD|OpenBSD|DragonFly)/i[3-9]86 (compact )?demand paged shared library'
      lt_cv_file_magic_cmd=/usr/bin/file
      lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
haiku*)
hpux10.20* | hpux11*)
  case $host_cpu in
  ia64*)
    lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - IA64'
    lt_cv_file_magic_test_file=/usr/lib/hpux32/libc.so
  hppa*64*)
    lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF[ -][0-9][0-9])(-bit)?( [LM]SB)? shared object( file)?[, -]* PA-RISC [0-9]\.[0-9]'
    lt_cv_file_magic_test_file=/usr/lib/pa20_64/libc.sl
    lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|PA-RISC[0-9]\.[0-9]) shared library'
    lt_cv_file_magic_test_file=/usr/lib/libc.sl
interix[3-9]*)
  # PIC code is broken on Interix 3.x, that's why |\.a not |_pic\.a here
  lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|\.a)$'
irix5* | irix6* | nonstopux*)
  case $LD in
  *-32|*"-32 ") libmagic=32-bit;;
  *-n32|*"-n32 ") libmagic=N32;;
  *-64|*"-64 ") libmagic=64-bit;;
  *) libmagic=never-match;;
# This must be glibc/ELF.
linux* | k*bsd*-gnu | kopensolaris*-gnu | gnu*)
netbsd* | netbsdelf*-gnu)
    lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|_pic\.a)$'
    lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|_pic\.a)$'
newos6*)
  lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (executable|dynamic lib)'
  lt_cv_file_magic_test_file=/usr/lib/libnls.so
*nto* | *qnx*)
openbsd*)
  if test -z "`echo __ELF__ | $CC -E - | $GREP __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
    lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|\.so|_pic\.a)$'
osf3* | osf4* | osf5*)
rdos*)
solaris*)
sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
sysv4 | sysv4.3*)
  case $host_vendor in
  motorola)
    lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib) M[0-9][0-9]* Version [0-9]'
    lt_cv_file_magic_test_file=`echo /usr/lib/libc.so*`
  ncr)
  sequent)
    lt_cv_file_magic_cmd='/bin/file'
    lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [LM]SB (shared object|dynamic lib )'
  sni)
    lt_cv_deplibs_check_method="file_magic ELF [0-9][0-9]*-bit [LM]SB dynamic lib"
    lt_cv_file_magic_test_file=/lib/libc.so
  siemens)
  pc)
tpf*)
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_deplibs_check_method" >&5
$as_echo "$lt_cv_deplibs_check_method" >&6; }
file_magic_glob=
want_nocaseglob=no
if test "$build" = "$host"; then
  case $host_os in
  mingw* | pw32*)
    if ( shopt | grep nocaseglob ) >/dev/null 2>&1; then
      want_nocaseglob=yes
      file_magic_glob=`echo aAbBcCdDeEfFgGhHiIjJkKlLmMnNoOpPqQrRsStTuUvVwWxXyYzZ | $SED -e "s/\(..\)/s\/[\1]\/[\1]\/g;/g"`
file_magic_cmd=$lt_cv_file_magic_cmd
deplibs_check_method=$lt_cv_deplibs_check_method
test -z "$deplibs_check_method" && deplibs_check_method=unknown
if test -n "$ac_tool_prefix"; then
  # Extract the first word of "${ac_tool_prefix}dlltool", so it can be a program name with args.
set dummy ${ac_tool_prefix}dlltool; ac_word=$2
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
$as_echo_n "checking for $ac_word... " >&6; }
if ${ac_cv_prog_DLLTOOL+:} false; then :
  if test -n "$DLLTOOL"; then
  ac_cv_prog_DLLTOOL="$DLLTOOL" # Let the user override the test.
as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in $PATH
do
  IFS=$as_save_IFS
  test -z "$as_dir" && as_dir=.
  if as_fn_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
    ac_cv_prog_DLLTOOL="${ac_tool_prefix}dlltool"
    $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
    break 2
IFS=$as_save_IFS
DLLTOOL=$ac_cv_prog_DLLTOOL
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $DLLTOOL" >&5
$as_echo "$DLLTOOL" >&6; }
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
$as_echo "no" >&6; }
if test -z "$ac_cv_prog_DLLTOOL"; then
  ac_ct_DLLTOOL=$DLLTOOL
  # Extract the first word of "dlltool", so it can be a program name with args.
set dummy dlltool; ac_word=$2
if ${ac_cv_prog_ac_ct_DLLTOOL+:} false; then :
  if test -n "$ac_ct_DLLTOOL"; then
  ac_cv_prog_ac_ct_DLLTOOL="$ac_ct_DLLTOOL" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_DLLTOOL="dlltool"
    break 2
IFS=$as_save_IFS
ac_ct_DLLTOOL=$ac_cv_prog_ac_ct_DLLTOOL
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_DLLTOOL" >&5
$as_echo "$ac_ct_DLLTOOL" >&6; }
  if test "x$ac_ct_DLLTOOL" = x; then
    DLLTOOL="false"
    case $cross_compiling:$ac_tool_warned in
yes:)
{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using cross tools not prefixed with host triplet" >&5
$as_echo "$as_me: WARNING: using cross tools not prefixed with host triplet" >&2;}
ac_tool_warned=yes ;;
    DLLTOOL=$ac_ct_DLLTOOL
  DLLTOOL="$ac_cv_prog_DLLTOOL"
test -z "$DLLTOOL" && DLLTOOL=dlltool
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to associate runtime and link libraries" >&5
$as_echo_n "checking how to associate runtime and link libraries... " >&6; }
if ${lt_cv_sharedlib_from_linklib_cmd+:} false; then :
  lt_cv_sharedlib_from_linklib_cmd='unknown'
case $host_os in
  # two different shell functions defined in ltmain.sh
  # decide which to use based on capabilities of $DLLTOOL
  case `$DLLTOOL --help 2>&1` in
  *--identify-strict*)
    lt_cv_sharedlib_from_linklib_cmd=func_cygming_dll_for_implib
    lt_cv_sharedlib_from_linklib_cmd=func_cygming_dll_for_implib_fallback
  # fallback: assume linklib IS sharedlib
  lt_cv_sharedlib_from_linklib_cmd="$ECHO"
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_sharedlib_from_linklib_cmd" >&5
$as_echo "$lt_cv_sharedlib_from_linklib_cmd" >&6; }
sharedlib_from_linklib_cmd=$lt_cv_sharedlib_from_linklib_cmd
test -z "$sharedlib_from_linklib_cmd" && sharedlib_from_linklib_cmd=$ECHO
  for ac_prog in ar
  do
if ${ac_cv_prog_AR+:} false; then :
  if test -n "$AR"; then
  ac_cv_prog_AR="$AR" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_AR="$ac_tool_prefix$ac_prog"
    break 2
IFS=$as_save_IFS
AR=$ac_cv_prog_AR
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $AR" >&5
$as_echo "$AR" >&6; }
    test -n "$AR" && break
if test -z "$AR"; then
  ac_ct_AR=$AR
  for ac_prog in ar
do
  # Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
if ${ac_cv_prog_ac_ct_AR+:} false; then :
  if test -n "$ac_ct_AR"; then
  ac_cv_prog_ac_ct_AR="$ac_ct_AR" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_AR="$ac_prog"
    break 2
IFS=$as_save_IFS
ac_ct_AR=$ac_cv_prog_ac_ct_AR
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_AR" >&5
$as_echo "$ac_ct_AR" >&6; }
  test -n "$ac_ct_AR" && break
  if test "x$ac_ct_AR" = x; then
    AR="false"
yes:)
    AR=$ac_ct_AR
: ${AR=ar}
: ${AR_FLAGS=cru}
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for archiver @FILE support" >&5
$as_echo_n "checking for archiver @FILE support... " >&6; }
if ${lt_cv_ar_at_file+:} false; then :
  lt_cv_ar_at_file=no
   cat confdefs.h - <<_ACEOF >conftest.$ac_ext
/* end confdefs.h.  */
int
main ()
_ACEOF
if ac_fn_c_try_compile "$LINENO"; then :
  echo conftest.$ac_objext > conftest.lst
      lt_ar_try='$AR $AR_FLAGS libconftest.a @conftest.lst >&5'
      { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$lt_ar_try\""; } >&5
  (eval $lt_ar_try) 2>&5
  ac_status=$?
  $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
      if test "$ac_status" -eq 0; then
	# Ensure the archiver fails upon bogus file names.
	rm -f conftest.$ac_objext libconftest.a
  ac_status=$?
	if test "$ac_status" -ne 0; then
          lt_cv_ar_at_file=@
      rm -f conftest.* libconftest.a
rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_ar_at_file" >&5
$as_echo "$lt_cv_ar_at_file" >&6; }
if test "x$lt_cv_ar_at_file" = xno; then
  archiver_list_spec=
  archiver_list_spec=$lt_cv_ar_at_file
  # Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
set dummy ${ac_tool_prefix}strip; ac_word=$2
if ${ac_cv_prog_STRIP+:} false; then :
  if test -n "$STRIP"; then
  ac_cv_prog_STRIP="$STRIP" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_STRIP="${ac_tool_prefix}strip"
    break 2
IFS=$as_save_IFS
STRIP=$ac_cv_prog_STRIP
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $STRIP" >&5
$as_echo "$STRIP" >&6; }
if test -z "$ac_cv_prog_STRIP"; then
  ac_ct_STRIP=$STRIP
  # Extract the first word of "strip", so it can be a program name with args.
set dummy strip; ac_word=$2
if ${ac_cv_prog_ac_ct_STRIP+:} false; then :
  if test -n "$ac_ct_STRIP"; then
  ac_cv_prog_ac_ct_STRIP="$ac_ct_STRIP" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_STRIP="strip"
    break 2
IFS=$as_save_IFS
ac_ct_STRIP=$ac_cv_prog_ac_ct_STRIP
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_STRIP" >&5
$as_echo "$ac_ct_STRIP" >&6; }
  if test "x$ac_ct_STRIP" = x; then
    STRIP=":"
yes:)
    STRIP=$ac_ct_STRIP
  STRIP="$ac_cv_prog_STRIP"
test -z "$STRIP" && STRIP=:
for as_dir in $PATH
do
  IFS=$as_save_IFS
    break 2
IFS=$as_save_IFS
for as_dir in $PATH
do
  IFS=$as_save_IFS
    break 2
IFS=$as_save_IFS
    RANLIB=":"
yes:)
test -z "$RANLIB" && RANLIB=:
# Determine commands to create old-style static archives.
old_archive_cmds='$AR $AR_FLAGS $oldlib$oldobjs'
old_postinstall_cmds='chmod 644 $oldlib'
old_postuninstall_cmds=
  case $host_os in
  openbsd*)
    old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB -t \$tool_oldlib"
    old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB \$tool_oldlib"
  old_archive_cmds="$old_archive_cmds~\$RANLIB \$tool_oldlib"
case $host_os in
  darwin*)
    lock_old_archive_extraction=yes ;;
    lock_old_archive_extraction=no ;;
# If no C compiler was specified, use CC.
LTCC=${LTCC-"$CC"}
# If no C compiler flags were specified, use CFLAGS.
LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
# Allow CC to be a program name with arguments.
compiler=$CC
# Check for command to grab the raw symbol name followed by C symbol from nm.
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking command to parse $NM output from $compiler object" >&5
$as_echo_n "checking command to parse $NM output from $compiler object... " >&6; }
if ${lt_cv_sys_global_symbol_pipe+:} false; then :
# These are sane defaults that work on at least a few old systems.
# [They come from Ultrix.  What could be older than Ultrix?!! ;)]
# Character class describing NM global symbol codes.
symcode='[BCDEGRST]'
# Regexp to match symbols that can be accessed directly from C.
sympat='\([_A-Za-z][_A-Za-z0-9]*\)'
# Define system-specific variables.
case $host_os in
aix*)
  symcode='[BCDT]'
  symcode='[ABCDGISTW]'
hpux*)
  if test "$host_cpu" = ia64; then
    symcode='[ABCDEGRST]'
irix* | nonstopux*)
osf*)
  symcode='[BCDEGQRST]'
solaris*)
  symcode='[BDRT]'
sco3.2v5*)
  symcode='[DT]'
sysv4.2uw2*)
  symcode='[DT]'
sysv5* | sco5v6* | unixware* | OpenUNIX*)
  symcode='[ABDT]'
sysv4)
  symcode='[DFNSTU]'
# If we're using GNU nm, then use its standard symbol codes.
case `$NM -V 2>&1` in
  symcode='[ABCDGIRSTW]' ;;
# Transform an extracted symbol line into a proper C declaration.
# Some systems (esp. on ia64) link data and code symbols differently,
# so use this general approach.
lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern int \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
# Transform an extracted symbol line into symbol name and symbol address
lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\)[ ]*$/  {\\\"\1\\\", (void *) 0},/p' -e 's/^$symcode* \([^ ]*\) \([^ ]*\)$/  {\"\2\", (void *) \&\2},/p'"
lt_cv_sys_global_symbol_to_c_name_address_lib_prefix="sed -n -e 's/^: \([^ ]*\)[ ]*$/  {\\\"\1\\\", (void *) 0},/p' -e 's/^$symcode* \([^ ]*\) \(lib[^ ]*\)$/  {\"\2\", (void *) \&\2},/p' -e 's/^$symcode* \([^ ]*\) \([^ ]*\)$/  {\"lib\2\", (void *) \&\2},/p'"
# Handle CRLF in mingw tool chain
opt_cr=
case $build_os in
mingw*)
  opt_cr=`$ECHO 'x\{0,1\}' | tr x '\015'` # option cr in regexp
# Try without a prefix underscore, then with it.
for ac_symprfx in "" "_"; do
  # Transform symcode, sympat, and symprfx into a raw symbol and a C symbol.
  symxfrm="\\1 $ac_symprfx\\2 \\2"
  # Write the raw and C identifiers.
  if test "$lt_cv_nm_interface" = "MS dumpbin"; then
    # Fake it for dumpbin and say T for any non-static function
    # and D for any global variable.
    # Also find C++ and __fastcall symbols from MSVC++,
    # which start with @ or ?.
    lt_cv_sys_global_symbol_pipe="$AWK '"\
"     {last_section=section; section=\$ 3};"\
"     /^COFF SYMBOL TABLE/{for(i in hide) delete hide[i]};"\
"     /Section length .*#relocs.*(pick any)/{hide[last_section]=1};"\
"     \$ 0!~/External *\|/{next};"\
"     / 0+ UNDEF /{next}; / UNDEF \([^|]\)*()/{next};"\
"     {if(hide[section]) next};"\
"     {f=0}; \$ 0~/\(\).*\|/{f=1}; {printf f ? \"T \" : \"D \"};"\
"     {split(\$ 0, a, /\||\r/); split(a[2], s)};"\
"     s[1]~/^[@?]/{print s[1], s[1]; next};"\
"     s[1]~prfx {split(s[1],t,\"@\"); print t[1], substr(t[1],length(prfx))}"\
"     ' prfx=^$ac_symprfx"
    lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[	 ]\($symcode$symcode*\)[	 ][	 ]*$ac_symprfx$sympat$opt_cr$/$symxfrm/p'"
  lt_cv_sys_global_symbol_pipe="$lt_cv_sys_global_symbol_pipe | sed '/ __gnu_lto/d'"
  # Check to see that the pipe works correctly.
  pipe_works=no
  rm -f conftest*
  cat > conftest.$ac_ext <<_LT_EOF
char nm_test_var;
void nm_test_func(void);
void nm_test_func(void){}
int main(){nm_test_var='a';nm_test_func();return(0);}
_LT_EOF
  if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_compile\""; } >&5
  (eval $ac_compile) 2>&5
  ac_status=$?
  test $ac_status = 0; }; then
    # Now try to grab the symbols.
    nlist=conftest.nm
    if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$NM conftest.$ac_objext \| "$lt_cv_sys_global_symbol_pipe" \> $nlist\""; } >&5
  (eval $NM conftest.$ac_objext \| "$lt_cv_sys_global_symbol_pipe" \> $nlist) 2>&5
  ac_status=$?
  test $ac_status = 0; } && test -s "$nlist"; then
      # Try sorting and uniquifying the output.
      if sort "$nlist" | uniq > "$nlist"T; then
	mv -f "$nlist"T "$nlist"
	rm -f "$nlist"T
      # Make sure that we snagged all the symbols we need.
      if $GREP ' nm_test_var$' "$nlist" >/dev/null; then
	if $GREP ' nm_test_func$' "$nlist" >/dev/null; then
	  cat <<_LT_EOF > conftest.$ac_ext
/* Keep this code in sync between libtool.m4, ltmain, lt_system.h, and tests.  */
#if defined(_WIN32) || defined(__CYGWIN__) || defined(_WIN32_WCE)
/* DATA imports from DLLs on WIN32 con't be const, because runtime
   relocations are performed -- see ld's documentation on pseudo-relocs.  */
# define LT_DLSYM_CONST
#elif defined(__osf__)
/* This system does not cope well with relocations in const data.  */
# define LT_DLSYM_CONST const
_LT_EOF
	  # Now generate the symbol file.
	  eval "$lt_cv_sys_global_symbol_to_cdecl"' < "$nlist" | $GREP -v main >> conftest.$ac_ext'
	  cat <<_LT_EOF >> conftest.$ac_ext
/* The mapping between symbol names and symbols.  */
LT_DLSYM_CONST struct {
  const char *name;
  void       *address;
lt__PROGRAM__LTX_preloaded_symbols[] =
  { "@PROGRAM@", (void *) 0 },
_LT_EOF
	  $SED "s/^$symcode$symcode* \(.*\) \(.*\)$/  {\"\2\", (void *) \&\2},/" < "$nlist" | $GREP -v main >> conftest.$ac_ext
	  cat <<\_LT_EOF >> conftest.$ac_ext
  {0, (void *) 0}
/* This works around a problem in FreeBSD linker */
#ifdef FREEBSD_WORKAROUND
static const void *lt_preloaded_setup() {
  return lt__PROGRAM__LTX_preloaded_symbols;
_LT_EOF
	  # Now try linking the two files.
	  mv conftest.$ac_objext conftstm.$ac_objext
	  lt_globsym_save_LIBS=$LIBS
	  lt_globsym_save_CFLAGS=$CFLAGS
	  LIBS="conftstm.$ac_objext"
	  CFLAGS="$CFLAGS$lt_prog_compiler_no_builtin_flag"
	  if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_link\""; } >&5
  (eval $ac_link) 2>&5
  ac_status=$?
  test $ac_status = 0; } && test -s conftest${ac_exeext}; then
	    pipe_works=yes
	  LIBS=$lt_globsym_save_LIBS
	  CFLAGS=$lt_globsym_save_CFLAGS
	  echo "cannot find nm_test_func in $nlist" >&5
	echo "cannot find nm_test_var in $nlist" >&5
      echo "cannot run $lt_cv_sys_global_symbol_pipe" >&5
    echo "$progname: failed program was:" >&5
    cat conftest.$ac_ext >&5
  rm -rf conftest* conftst*
  # Do not use the global_symbol_pipe unless it works.
  if test "$pipe_works" = yes; then
    break
if test -z "$lt_cv_sys_global_symbol_pipe"; then
if test -z "$lt_cv_sys_global_symbol_pipe$lt_cv_sys_global_symbol_to_cdecl"; then
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: failed" >&5
$as_echo "failed" >&6; }
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: ok" >&5
$as_echo "ok" >&6; }
# Response file support.
  nm_file_list_spec='@'
elif $NM --help 2>/dev/null | grep '[@]FILE' >/dev/null; then
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for sysroot" >&5
$as_echo_n "checking for sysroot... " >&6; }
# Check whether --with-sysroot was given.
if test "${with_sysroot+set}" = set; then :
  withval=$with_sysroot;
  with_sysroot=no
lt_sysroot=
case ${with_sysroot} in #(
 yes)
     lt_sysroot=`$CC --print-sysroot 2>/dev/null`
   lt_sysroot=`echo "$with_sysroot" | sed -e "$sed_quote_subst"`
 no|'')
   { $as_echo "$as_me:${as_lineno-$LINENO}: result: ${with_sysroot}" >&5
$as_echo "${with_sysroot}" >&6; }
   as_fn_error $? "The sysroot must be an absolute path." "$LINENO" 5
 { $as_echo "$as_me:${as_lineno-$LINENO}: result: ${lt_sysroot:-no}" >&5
$as_echo "${lt_sysroot:-no}" >&6; }
# Check whether --enable-libtool-lock was given.
if test "${enable_libtool_lock+set}" = set; then :
  enableval=$enable_libtool_lock;
test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
# Some flags need to be propagated to the compiler or linker for good
# libtool support.
case $host in
ia64-*-hpux*)
  # Find out which ABI we are using.
  echo 'int i;' > conftest.$ac_ext
  ac_status=$?
    case `/usr/bin/file conftest.$ac_objext` in
      *ELF-32*)
	HPUX_IA64_MODE="32"
      *ELF-64*)
	HPUX_IA64_MODE="64"
  rm -rf conftest*
*-*-irix6*)
  echo '#line '$LINENO' "configure"' > conftest.$ac_ext
  ac_status=$?
    if test "$lt_cv_prog_gnu_ld" = yes; then
	*32-bit*)
	  LD="${LD-ld} -melf32bsmip"
	*N32*)
	  LD="${LD-ld} -melf32bmipn32"
	*64-bit*)
	  LD="${LD-ld} -melf64bmip"
	*32-bit*)
	  LD="${LD-ld} -32"
	*N32*)
	  LD="${LD-ld} -n32"
	*64-bit*)
	  LD="${LD-ld} -64"
  rm -rf conftest*
x86_64-*kfreebsd*-gnu|x86_64-*linux*|powerpc*-*linux*| \
s390*-*linux*|s390*-*tpf*|sparc*-*linux*)
  ac_status=$?
    case `/usr/bin/file conftest.o` in
      *32-bit*)
	case $host in
	  x86_64-*kfreebsd*-gnu)
	    LD="${LD-ld} -m elf_i386_fbsd"
	  x86_64-*linux*)
	      *x86-64*)
		LD="${LD-ld} -m elf32_x86_64"
		LD="${LD-ld} -m elf_i386"
	  powerpc64le-*)
	    LD="${LD-ld} -m elf32lppclinux"
	  powerpc64-*)
	    LD="${LD-ld} -m elf32ppclinux"
	  s390x-*linux*)
	    LD="${LD-ld} -m elf_s390"
	  sparc64-*linux*)
	    LD="${LD-ld} -m elf32_sparc"
      *64-bit*)
	case $host in
	    LD="${LD-ld} -m elf_x86_64_fbsd"
	  x86_64-*linux*)
	    LD="${LD-ld} -m elf_x86_64"
	  powerpcle-*)
	    LD="${LD-ld} -m elf64lppc"
	  powerpc-*)
	    LD="${LD-ld} -m elf64ppc"
	  s390*-*linux*|s390*-*tpf*)
	    LD="${LD-ld} -m elf64_s390"
	  sparc*-*linux*)
	    LD="${LD-ld} -m elf64_sparc"
  rm -rf conftest*
*-*-sco3.2v5*)
  # On SCO OpenServer 5, we need -belf to get full-featured binaries.
  SAVE_CFLAGS="$CFLAGS"
  CFLAGS="$CFLAGS -belf"
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the C compiler needs -belf" >&5
$as_echo_n "checking whether the C compiler needs -belf... " >&6; }
if ${lt_cv_cc_needs_belf+:} false; then :
  ac_ext=c
ac_cpp='$CPP $CPPFLAGS'
ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
ac_compiler_gnu=$ac_cv_c_compiler_gnu
int
main ()
_ACEOF
if ac_fn_c_try_link "$LINENO"; then :
  lt_cv_cc_needs_belf=yes
  lt_cv_cc_needs_belf=no
rm -f core conftest.err conftest.$ac_objext \
    conftest$ac_exeext conftest.$ac_ext
     ac_ext=c
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_cc_needs_belf" >&5
$as_echo "$lt_cv_cc_needs_belf" >&6; }
  if test x"$lt_cv_cc_needs_belf" != x"yes"; then
    # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
    CFLAGS="$SAVE_CFLAGS"
*-*solaris*)
  ac_status=$?
    *64-bit*)
      case $lt_cv_prog_gnu_ld in
      yes*)
        case $host in
        i?86-*-solaris*)
        sparc*-*-solaris*)
        # GNU ld 2.21 introduced _sol2 emulations.  Use them if available.
        if ${LD-ld} -V | grep _sol2 >/dev/null 2>&1; then
          LD="${LD-ld}_sol2"
	if ${LD-ld} -64 -r -o conftest2.o conftest.o >/dev/null 2>&1; then
	  LD="${LD-ld} -64"
  rm -rf conftest*
need_locks="$enable_libtool_lock"
  # Extract the first word of "${ac_tool_prefix}mt", so it can be a program name with args.
set dummy ${ac_tool_prefix}mt; ac_word=$2
if ${ac_cv_prog_MANIFEST_TOOL+:} false; then :
  if test -n "$MANIFEST_TOOL"; then
  ac_cv_prog_MANIFEST_TOOL="$MANIFEST_TOOL" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_MANIFEST_TOOL="${ac_tool_prefix}mt"
    break 2
IFS=$as_save_IFS
MANIFEST_TOOL=$ac_cv_prog_MANIFEST_TOOL
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $MANIFEST_TOOL" >&5
$as_echo "$MANIFEST_TOOL" >&6; }
if test -z "$ac_cv_prog_MANIFEST_TOOL"; then
  ac_ct_MANIFEST_TOOL=$MANIFEST_TOOL
  # Extract the first word of "mt", so it can be a program name with args.
set dummy mt; ac_word=$2
if ${ac_cv_prog_ac_ct_MANIFEST_TOOL+:} false; then :
  if test -n "$ac_ct_MANIFEST_TOOL"; then
  ac_cv_prog_ac_ct_MANIFEST_TOOL="$ac_ct_MANIFEST_TOOL" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_MANIFEST_TOOL="mt"
    break 2
IFS=$as_save_IFS
ac_ct_MANIFEST_TOOL=$ac_cv_prog_ac_ct_MANIFEST_TOOL
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_MANIFEST_TOOL" >&5
$as_echo "$ac_ct_MANIFEST_TOOL" >&6; }
  if test "x$ac_ct_MANIFEST_TOOL" = x; then
    MANIFEST_TOOL=":"
yes:)
    MANIFEST_TOOL=$ac_ct_MANIFEST_TOOL
  MANIFEST_TOOL="$ac_cv_prog_MANIFEST_TOOL"
test -z "$MANIFEST_TOOL" && MANIFEST_TOOL=mt
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $MANIFEST_TOOL is a manifest tool" >&5
$as_echo_n "checking if $MANIFEST_TOOL is a manifest tool... " >&6; }
if ${lt_cv_path_mainfest_tool+:} false; then :
  lt_cv_path_mainfest_tool=no
  echo "$as_me:$LINENO: $MANIFEST_TOOL '-?'" >&5
  $MANIFEST_TOOL '-?' 2>conftest.err > conftest.out
  if $GREP 'Manifest Tool' conftest.out > /dev/null; then
    lt_cv_path_mainfest_tool=yes
  rm -f conftest*
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_path_mainfest_tool" >&5
$as_echo "$lt_cv_path_mainfest_tool" >&6; }
if test "x$lt_cv_path_mainfest_tool" != xyes; then
  MANIFEST_TOOL=:
  case $host_os in
    rhapsody* | darwin*)
  # Extract the first word of "${ac_tool_prefix}dsymutil", so it can be a program name with args.
set dummy ${ac_tool_prefix}dsymutil; ac_word=$2
if ${ac_cv_prog_DSYMUTIL+:} false; then :
  if test -n "$DSYMUTIL"; then
  ac_cv_prog_DSYMUTIL="$DSYMUTIL" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_DSYMUTIL="${ac_tool_prefix}dsymutil"
    break 2
IFS=$as_save_IFS
DSYMUTIL=$ac_cv_prog_DSYMUTIL
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $DSYMUTIL" >&5
$as_echo "$DSYMUTIL" >&6; }
if test -z "$ac_cv_prog_DSYMUTIL"; then
  ac_ct_DSYMUTIL=$DSYMUTIL
  # Extract the first word of "dsymutil", so it can be a program name with args.
set dummy dsymutil; ac_word=$2
if ${ac_cv_prog_ac_ct_DSYMUTIL+:} false; then :
  if test -n "$ac_ct_DSYMUTIL"; then
  ac_cv_prog_ac_ct_DSYMUTIL="$ac_ct_DSYMUTIL" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_DSYMUTIL="dsymutil"
    break 2
IFS=$as_save_IFS
ac_ct_DSYMUTIL=$ac_cv_prog_ac_ct_DSYMUTIL
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_DSYMUTIL" >&5
$as_echo "$ac_ct_DSYMUTIL" >&6; }
  if test "x$ac_ct_DSYMUTIL" = x; then
    DSYMUTIL=":"
yes:)
    DSYMUTIL=$ac_ct_DSYMUTIL
  DSYMUTIL="$ac_cv_prog_DSYMUTIL"
  # Extract the first word of "${ac_tool_prefix}nmedit", so it can be a program name with args.
set dummy ${ac_tool_prefix}nmedit; ac_word=$2
if ${ac_cv_prog_NMEDIT+:} false; then :
  if test -n "$NMEDIT"; then
  ac_cv_prog_NMEDIT="$NMEDIT" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_NMEDIT="${ac_tool_prefix}nmedit"
    break 2
IFS=$as_save_IFS
NMEDIT=$ac_cv_prog_NMEDIT
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $NMEDIT" >&5
$as_echo "$NMEDIT" >&6; }
if test -z "$ac_cv_prog_NMEDIT"; then
  ac_ct_NMEDIT=$NMEDIT
  # Extract the first word of "nmedit", so it can be a program name with args.
set dummy nmedit; ac_word=$2
if ${ac_cv_prog_ac_ct_NMEDIT+:} false; then :
  if test -n "$ac_ct_NMEDIT"; then
  ac_cv_prog_ac_ct_NMEDIT="$ac_ct_NMEDIT" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_NMEDIT="nmedit"
    break 2
IFS=$as_save_IFS
ac_ct_NMEDIT=$ac_cv_prog_ac_ct_NMEDIT
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_NMEDIT" >&5
$as_echo "$ac_ct_NMEDIT" >&6; }
  if test "x$ac_ct_NMEDIT" = x; then
    NMEDIT=":"
yes:)
    NMEDIT=$ac_ct_NMEDIT
  NMEDIT="$ac_cv_prog_NMEDIT"
  # Extract the first word of "${ac_tool_prefix}lipo", so it can be a program name with args.
set dummy ${ac_tool_prefix}lipo; ac_word=$2
if ${ac_cv_prog_LIPO+:} false; then :
  if test -n "$LIPO"; then
  ac_cv_prog_LIPO="$LIPO" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_LIPO="${ac_tool_prefix}lipo"
    break 2
IFS=$as_save_IFS
LIPO=$ac_cv_prog_LIPO
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $LIPO" >&5
$as_echo "$LIPO" >&6; }
if test -z "$ac_cv_prog_LIPO"; then
  ac_ct_LIPO=$LIPO
  # Extract the first word of "lipo", so it can be a program name with args.
set dummy lipo; ac_word=$2
if ${ac_cv_prog_ac_ct_LIPO+:} false; then :
  if test -n "$ac_ct_LIPO"; then
  ac_cv_prog_ac_ct_LIPO="$ac_ct_LIPO" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_LIPO="lipo"
    break 2
IFS=$as_save_IFS
ac_ct_LIPO=$ac_cv_prog_ac_ct_LIPO
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_LIPO" >&5
$as_echo "$ac_ct_LIPO" >&6; }
  if test "x$ac_ct_LIPO" = x; then
    LIPO=":"
yes:)
    LIPO=$ac_ct_LIPO
  LIPO="$ac_cv_prog_LIPO"
  # Extract the first word of "${ac_tool_prefix}otool", so it can be a program name with args.
set dummy ${ac_tool_prefix}otool; ac_word=$2
if ${ac_cv_prog_OTOOL+:} false; then :
  if test -n "$OTOOL"; then
  ac_cv_prog_OTOOL="$OTOOL" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_OTOOL="${ac_tool_prefix}otool"
    break 2
IFS=$as_save_IFS
OTOOL=$ac_cv_prog_OTOOL
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $OTOOL" >&5
$as_echo "$OTOOL" >&6; }
if test -z "$ac_cv_prog_OTOOL"; then
  ac_ct_OTOOL=$OTOOL
  # Extract the first word of "otool", so it can be a program name with args.
set dummy otool; ac_word=$2
if ${ac_cv_prog_ac_ct_OTOOL+:} false; then :
  if test -n "$ac_ct_OTOOL"; then
  ac_cv_prog_ac_ct_OTOOL="$ac_ct_OTOOL" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_OTOOL="otool"
    break 2
IFS=$as_save_IFS
ac_ct_OTOOL=$ac_cv_prog_ac_ct_OTOOL
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_OTOOL" >&5
$as_echo "$ac_ct_OTOOL" >&6; }
  if test "x$ac_ct_OTOOL" = x; then
    OTOOL=":"
yes:)
    OTOOL=$ac_ct_OTOOL
  OTOOL="$ac_cv_prog_OTOOL"
  # Extract the first word of "${ac_tool_prefix}otool64", so it can be a program name with args.
set dummy ${ac_tool_prefix}otool64; ac_word=$2
if ${ac_cv_prog_OTOOL64+:} false; then :
  if test -n "$OTOOL64"; then
  ac_cv_prog_OTOOL64="$OTOOL64" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_OTOOL64="${ac_tool_prefix}otool64"
    break 2
IFS=$as_save_IFS
OTOOL64=$ac_cv_prog_OTOOL64
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $OTOOL64" >&5
$as_echo "$OTOOL64" >&6; }
if test -z "$ac_cv_prog_OTOOL64"; then
  ac_ct_OTOOL64=$OTOOL64
  # Extract the first word of "otool64", so it can be a program name with args.
set dummy otool64; ac_word=$2
if ${ac_cv_prog_ac_ct_OTOOL64+:} false; then :
  if test -n "$ac_ct_OTOOL64"; then
  ac_cv_prog_ac_ct_OTOOL64="$ac_ct_OTOOL64" # Let the user override the test.
for as_dir in $PATH
do
  IFS=$as_save_IFS
    ac_cv_prog_ac_ct_OTOOL64="otool64"
    break 2
IFS=$as_save_IFS
ac_ct_OTOOL64=$ac_cv_prog_ac_ct_OTOOL64
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_OTOOL64" >&5
$as_echo "$ac_ct_OTOOL64" >&6; }
  if test "x$ac_ct_OTOOL64" = x; then
    OTOOL64=":"
yes:)
    OTOOL64=$ac_ct_OTOOL64
  OTOOL64="$ac_cv_prog_OTOOL64"
    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for -single_module linker flag" >&5
$as_echo_n "checking for -single_module linker flag... " >&6; }
if ${lt_cv_apple_cc_single_mod+:} false; then :
  lt_cv_apple_cc_single_mod=no
      if test -z "${LT_MULTI_MODULE}"; then
	# By default we will add the -single_module flag. You can override
	# by either setting the environment variable LT_MULTI_MODULE
	# non-empty at configure time, or by adding -multi_module to the
	# link flags.
	rm -rf libconftest.dylib*
	echo "int foo(void){return 1;}" > conftest.c
	echo "$LTCC $LTCFLAGS $LDFLAGS -o libconftest.dylib \
-dynamiclib -Wl,-single_module conftest.c" >&5
	  -dynamiclib -Wl,-single_module conftest.c 2>conftest.err
        _lt_result=$?
	# If there is a non-empty error log, and "single_module"
	# appears in it, assume the flag caused a linker warning
        if test -s conftest.err && $GREP single_module conftest.err; then
	# Otherwise, if the output was created with a 0 exit code from
	# the compiler, it worked.
	elif test -f libconftest.dylib && test $_lt_result -eq 0; then
	  lt_cv_apple_cc_single_mod=yes
	rm -f conftest.*
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_apple_cc_single_mod" >&5
$as_echo "$lt_cv_apple_cc_single_mod" >&6; }
    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for -exported_symbols_list linker flag" >&5
$as_echo_n "checking for -exported_symbols_list linker flag... " >&6; }
if ${lt_cv_ld_exported_symbols_list+:} false; then :
  lt_cv_ld_exported_symbols_list=no
      save_LDFLAGS=$LDFLAGS
      echo "_main" > conftest.sym
      LDFLAGS="$LDFLAGS -Wl,-exported_symbols_list,conftest.sym"
int
main ()
_ACEOF
  lt_cv_ld_exported_symbols_list=yes
	LDFLAGS="$save_LDFLAGS"
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_ld_exported_symbols_list" >&5
$as_echo "$lt_cv_ld_exported_symbols_list" >&6; }
    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for -force_load linker flag" >&5
$as_echo_n "checking for -force_load linker flag... " >&6; }
if ${lt_cv_ld_force_load+:} false; then :
  lt_cv_ld_force_load=no
      cat > conftest.c << _LT_EOF
int forced_loaded() { return 2;}
_LT_EOF
      echo "$LTCC $LTCFLAGS -c -o conftest.o conftest.c" >&5
      $LTCC $LTCFLAGS -c -o conftest.o conftest.c 2>&5
      echo "$AR cru libconftest.a conftest.o" >&5
      $AR cru libconftest.a conftest.o 2>&5
      echo "$RANLIB libconftest.a" >&5
      $RANLIB libconftest.a 2>&5
int main() { return 0;}
_LT_EOF
      echo "$LTCC $LTCFLAGS $LDFLAGS -o conftest conftest.c -Wl,-force_load,./libconftest.a" >&5
      $LTCC $LTCFLAGS $LDFLAGS -o conftest conftest.c -Wl,-force_load,./libconftest.a 2>conftest.err
      _lt_result=$?
      if test -s conftest.err && $GREP force_load conftest.err; then
      elif test -f conftest && test $_lt_result -eq 0 && $GREP forced_load conftest >/dev/null 2>&1 ; then
	lt_cv_ld_force_load=yes
        rm -f conftest.err libconftest.a conftest conftest.c
        rm -rf conftest.dSYM
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_ld_force_load" >&5
$as_echo "$lt_cv_ld_force_load" >&6; }
    case $host_os in
    rhapsody* | darwin1.[012])
      _lt_dar_allow_undefined='${wl}-undefined ${wl}suppress' ;;
    darwin1.*)
      _lt_dar_allow_undefined='${wl}-flat_namespace ${wl}-undefined ${wl}suppress' ;;
    darwin*) # darwin 5.x on
      # if running on 10.5 or later, the deployment target defaults
      # to the OS version, if on x86, and 10.4, the deployment
      # target defaults to 10.4. Don't you love it?
      case ${MACOSX_DEPLOYMENT_TARGET-10.0},$host in
	10.0,*86*-darwin8*|10.0,*-darwin[91]*)
	  _lt_dar_allow_undefined='${wl}-undefined ${wl}dynamic_lookup' ;;
	10.[012]*)
	10.*)
    if test "$lt_cv_apple_cc_single_mod" = "yes"; then
      _lt_dar_single_mod='$single_module'
    if test "$lt_cv_ld_exported_symbols_list" = "yes"; then
      _lt_dar_export_syms=' ${wl}-exported_symbols_list,$output_objdir/${libname}-symbols.expsym'
      _lt_dar_export_syms='~$NMEDIT -s $output_objdir/${libname}-symbols.expsym ${lib}'
    if test "$DSYMUTIL" != ":" && test "$lt_cv_ld_force_load" = "no"; then
      _lt_dsymutil='~$DSYMUTIL $lib || :'
      _lt_dsymutil=
ac_ext=c
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to run the C preprocessor" >&5
$as_echo_n "checking how to run the C preprocessor... " >&6; }
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
  CPP=
if test -z "$CPP"; then
  if ${ac_cv_prog_CPP+:} false; then :
      # Double quotes because CPP needs to be expanded
    for CPP in "$CC -E" "$CC -E -traditional-cpp" "/lib/cpp"
    do
      ac_preproc_ok=false
for ac_c_preproc_warn_flag in '' yes
do
  # Use a header file that comes with gcc, so configuring glibc
  # with a fresh cross-compiler works.
  # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
  # <limits.h> exists even on freestanding compilers.
  # On the NeXT, cc -E runs the code through the compiler's parser,
  # not just through cpp. "Syntax error" is here to catch this case.
#ifdef __STDC__
# include <limits.h>
# include <assert.h>
		     Syntax error
_ACEOF
if ac_fn_c_try_cpp "$LINENO"; then :
  # Broken: fails on valid input.
continue
rm -f conftest.err conftest.i conftest.$ac_ext
  # OK, works on sane cases.  Now check whether nonexistent headers
  # can be detected and how.
#include <ac_nonexistent.h>
_ACEOF
  # Broken: success on invalid input.
continue
  # Passes both tests.
ac_preproc_ok=:
break
# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
rm -f conftest.i conftest.err conftest.$ac_ext
if $ac_preproc_ok; then :
  break
    ac_cv_prog_CPP=$CPP
  CPP=$ac_cv_prog_CPP
  ac_cv_prog_CPP=$CPP
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $CPP" >&5
$as_echo "$CPP" >&6; }
ac_preproc_ok=false
do
#ifdef __STDC__
		     Syntax error
_ACEOF
continue
_ACEOF
continue
ac_preproc_ok=:
break
  { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
as_fn_error $? "C preprocessor \"$CPP\" fails sanity check
See \`config.log' for more details" "$LINENO" 5; }
ac_ext=c
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for ANSI C header files" >&5
$as_echo_n "checking for ANSI C header files... " >&6; }
if ${ac_cv_header_stdc+:} false; then :
#include <stdarg.h>
#include <float.h>
int
main ()
_ACEOF
  ac_cv_header_stdc=yes
  ac_cv_header_stdc=no
if test $ac_cv_header_stdc = yes; then
  # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
_ACEOF
if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
  $EGREP "memchr" >/dev/null 2>&1; then :
rm -f conftest*
  # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
_ACEOF
  $EGREP "free" >/dev/null 2>&1; then :
rm -f conftest*
  # /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
  if test "$cross_compiling" = yes; then :
#include <ctype.h>
#if ((' ' & 0x0FF) == 0x020)
# define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
# define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
# define ISLOWER(c) \
		   (('a' <= (c) && (c) <= 'i') \
		     || ('j' <= (c) && (c) <= 'r') \
		     || ('s' <= (c) && (c) <= 'z'))
# define TOUPPER(c) (ISLOWER(c) ? ((c) | 0x40) : (c))
#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
int
main ()
  int i;
  for (i = 0; i < 256; i++)
    if (XOR (islower (i), ISLOWER (i))
	|| toupper (i) != TOUPPER (i))
      return 2;
_ACEOF
if ac_fn_c_try_run "$LINENO"; then :
rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext \
  conftest.$ac_objext conftest.beam conftest.$ac_ext
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_header_stdc" >&5
$as_echo "$ac_cv_header_stdc" >&6; }
$as_echo "#define STDC_HEADERS 1" >>confdefs.h
# On IRIX 5.3, sys/types and inttypes.h are conflicting.
for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
		  inttypes.h stdint.h unistd.h
do :
  as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
ac_fn_c_check_header_compile "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default
if eval test \"x\$"$as_ac_Header"\" = x"yes"; then :
  cat >>confdefs.h <<_ACEOF
#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
_ACEOF
for ac_header in dlfcn.h
do :
  ac_fn_c_check_header_compile "$LINENO" "dlfcn.h" "ac_cv_header_dlfcn_h" "$ac_includes_default
if test "x$ac_cv_header_dlfcn_h" = xyes; then :
#define HAVE_DLFCN_H 1
_ACEOF
func_stripname_cnf ()
  case ${2} in
  .*) func_stripname_result=`$ECHO "${3}" | $SED "s%^${1}%%; s%\\\\${2}\$%%"`;;
  *)  func_stripname_result=`$ECHO "${3}" | $SED "s%^${1}%%; s%${2}\$%%"`;;
} # func_stripname_cnf
# Set options
        enable_dlopen=no
  enable_win32_dll=no
            # Check whether --enable-shared was given.
if test "${enable_shared+set}" = set; then :
  enableval=$enable_shared; p=${PACKAGE-default}
    case $enableval in
    yes) enable_shared=yes ;;
    no) enable_shared=no ;;
      enable_shared=no
      # Look at the argument we got.  We use all the common list separators.
      lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
      for pkg in $enableval; do
	IFS="$lt_save_ifs"
	if test "X$pkg" = "X$p"; then
	  enable_shared=yes
      IFS="$lt_save_ifs"
  enable_shared=yes
  # Check whether --enable-static was given.
if test "${enable_static+set}" = set; then :
  enableval=$enable_static; p=${PACKAGE-default}
    case $enableval in
    yes) enable_static=yes ;;
    no) enable_static=no ;;
     enable_static=no
	IFS="$lt_save_ifs"
	  enable_static=yes
      IFS="$lt_save_ifs"
  enable_static=yes
# Check whether --with-pic was given.
if test "${with_pic+set}" = set; then :
  withval=$with_pic; lt_p=${PACKAGE-default}
    case $withval in
    yes|no) pic_mode=$withval ;;
      pic_mode=default
      for lt_pkg in $withval; do
	IFS="$lt_save_ifs"
	if test "X$lt_pkg" = "X$lt_p"; then
	  pic_mode=yes
      IFS="$lt_save_ifs"
  pic_mode=default
test -z "$pic_mode" && pic_mode=default
  # Check whether --enable-fast-install was given.
if test "${enable_fast_install+set}" = set; then :
  enableval=$enable_fast_install; p=${PACKAGE-default}
    case $enableval in
    yes) enable_fast_install=yes ;;
    no) enable_fast_install=no ;;
	IFS="$lt_save_ifs"
      IFS="$lt_save_ifs"
# This can be used to rebuild libtool when needed
LIBTOOL_DEPS="$ltmain"
# Always use our own libtool.
LIBTOOL='$(SHELL) $(top_builddir)/libtool'
test -z "$LN_S" && LN_S="ln -s"
if test -n "${ZSH_VERSION+set}" ; then
   setopt NO_GLOB_SUBST
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for objdir" >&5
$as_echo_n "checking for objdir... " >&6; }
if ${lt_cv_objdir+:} false; then :
  $as_echo_n "(cached) " >&6
  rm -f .libs 2>/dev/null
mkdir .libs 2>/dev/null
if test -d .libs; then
  lt_cv_objdir=.libs
  # MS-DOS does not allow filenames that begin with a dot.
  lt_cv_objdir=_libs
rmdir .libs 2>/dev/null
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_objdir" >&5
$as_echo "$lt_cv_objdir" >&6; }
objdir=$lt_cv_objdir
#define LT_OBJDIR "$lt_cv_objdir/"
_ACEOF
case $host_os in
aix3*)
  # AIX sometimes has problems with the GCC collect2 program.  For some
  # reason, if we set the COLLECT_NAMES environment variable, the problems
  # vanish in a puff of smoke.
  if test "X${COLLECT_NAMES+set}" != Xset; then
    COLLECT_NAMES=
    export COLLECT_NAMES
# Global variables:
ofile=libtool
can_build_shared=yes
# All known linkers require a `.a' archive for static linking (except MSVC,
# which needs '.lib').
libext=a
with_gnu_ld="$lt_cv_prog_gnu_ld"
old_CC="$CC"
old_CFLAGS="$CFLAGS"
# Set sane defaults for various variables
test -z "$CC" && CC=cc
test -z "$LTCC" && LTCC=$CC
test -z "$LTCFLAGS" && LTCFLAGS=$CFLAGS
test -z "$LD" && LD=ld
test -z "$ac_objext" && ac_objext=o
for cc_temp in $compiler""; do
  case $cc_temp in
    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
    *) break;;
cc_basename=`$ECHO "$cc_temp" | $SED "s%.*/%%; s%^$host_alias-%%"`
# Only perform the check for file, if the check method requires it
test -z "$MAGIC_CMD" && MAGIC_CMD=file
case $deplibs_check_method in
file_magic*)
  if test "$file_magic_cmd" = '$MAGIC_CMD'; then
    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for ${ac_tool_prefix}file" >&5
$as_echo_n "checking for ${ac_tool_prefix}file... " >&6; }
if ${lt_cv_path_MAGIC_CMD+:} false; then :
  case $MAGIC_CMD in
  lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
  lt_save_MAGIC_CMD="$MAGIC_CMD"
  ac_dummy="/usr/bin$PATH_SEPARATOR$PATH"
  for ac_dir in $ac_dummy; do
    IFS="$lt_save_ifs"
    if test -f $ac_dir/${ac_tool_prefix}file; then
      lt_cv_path_MAGIC_CMD="$ac_dir/${ac_tool_prefix}file"
      if test -n "$file_magic_test_file"; then
	"file_magic "*)
	  file_magic_regex=`expr "$deplibs_check_method" : "file_magic \(.*\)"`
	  MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
	  if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
	    $EGREP "$file_magic_regex" > /dev/null; then
	    cat <<_LT_EOF 1>&2
*** Warning: the command libtool uses to detect shared libraries,
*** $file_magic_cmd, produces output that libtool cannot recognize.
*** The result is that libtool may fail to recognize shared libraries
*** as such.  This will affect the creation of libtool libraries that
*** depend on shared libraries, but programs linked with such libtool
*** libraries will work regardless of this problem.  Nevertheless, you
*** may want to report the problem to your system manager and/or to
*** bug-libtool@gnu.org
_LT_EOF
	  fi ;;
      break
  IFS="$lt_save_ifs"
  MAGIC_CMD="$lt_save_MAGIC_CMD"
if test -n "$MAGIC_CMD"; then
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $MAGIC_CMD" >&5
$as_echo "$MAGIC_CMD" >&6; }
if test -z "$lt_cv_path_MAGIC_CMD"; then
    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for file" >&5
$as_echo_n "checking for file... " >&6; }
  case $MAGIC_CMD in
    IFS="$lt_save_ifs"
    if test -f $ac_dir/file; then
      lt_cv_path_MAGIC_CMD="$ac_dir/file"
	"file_magic "*)
	    cat <<_LT_EOF 1>&2
_LT_EOF
	  fi ;;
      break
  IFS="$lt_save_ifs"
    MAGIC_CMD=:
# Use C for the default configuration in the libtool script
lt_save_CC="$CC"
ac_ext=c
# Source file extension for C test sources.
ac_ext=c
# Object file extension for compiled C test sources.
objext=o
objext=$objext
# Code to be used in simple compile tests
lt_simple_compile_test_code="int some_variable = 0;"
# Code to be used in simple link tests
lt_simple_link_test_code='int main(){return(0);}'
LTCC=${LTCC-"$CC"}
compiler=$CC
# Save the default compiler, since it gets overwritten when the other
# tags are being tested, and _LT_TAGVAR(compiler, []) is a NOP.
compiler_DEFAULT=$CC
# save warnings/boilerplate of simple test code
ac_outfile=conftest.$ac_objext
echo "$lt_simple_compile_test_code" >conftest.$ac_ext
eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
_lt_compiler_boilerplate=`cat conftest.err`
$RM conftest*
echo "$lt_simple_link_test_code" >conftest.$ac_ext
eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
_lt_linker_boilerplate=`cat conftest.err`
$RM -r conftest*
if test -n "$compiler"; then
lt_prog_compiler_no_builtin_flag=
if test "$GCC" = yes; then
  case $cc_basename in
  nvcc*)
    lt_prog_compiler_no_builtin_flag=' -Xcompiler -fno-builtin' ;;
    lt_prog_compiler_no_builtin_flag=' -fno-builtin' ;;
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
$as_echo_n "checking if $compiler supports -fno-rtti -fno-exceptions... " >&6; }
if ${lt_cv_prog_compiler_rtti_exceptions+:} false; then :
  lt_cv_prog_compiler_rtti_exceptions=no
   echo "$lt_simple_compile_test_code" > conftest.$ac_ext
   lt_compiler_flag="-fno-rtti -fno-exceptions"
   # Insert the option either (1) after the last *FLAGS variable, or
   # (2) before a word containing "conftest.", or (3) at the end.
   # Note that $ac_compile itself does not contain backslashes and begins
   # with a dollar sign (not a hyphen), so the echo should work correctly.
   # The option is referenced via a variable to avoid confusing sed.
   lt_compile=`echo "$ac_compile" | $SED \
   -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
   -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
   -e 's:$: $lt_compiler_flag:'`
   (eval echo "\"\$as_me:$LINENO: $lt_compile\"" >&5)
   (eval "$lt_compile" 2>conftest.err)
   ac_status=$?
   echo "$as_me:$LINENO: \$? = $ac_status" >&5
   if (exit $ac_status) && test -s "$ac_outfile"; then
     # The compiler can only warn and ignore the option if not recognized
     # So say no if there are warnings other than the usual output.
     $ECHO "$_lt_compiler_boilerplate" | $SED '/^$/d' >conftest.exp
     $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
     if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
       lt_cv_prog_compiler_rtti_exceptions=yes
   $RM conftest*
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
$as_echo "$lt_cv_prog_compiler_rtti_exceptions" >&6; }
if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
    lt_prog_compiler_no_builtin_flag="$lt_prog_compiler_no_builtin_flag -fno-rtti -fno-exceptions"
  lt_prog_compiler_wl=
lt_prog_compiler_pic=
lt_prog_compiler_static=
    lt_prog_compiler_wl='-Wl,'
    lt_prog_compiler_static='-static'
    case $host_os in
      aix*)
      # All AIX code is PIC.
	# AIX 5 now supports IA64 processor
	lt_prog_compiler_static='-Bstatic'
    amigaos*)
      case $host_cpu in
      powerpc)
            # see comment about AmigaOS4 .so support
            lt_prog_compiler_pic='-fPIC'
      m68k)
            # FIXME: we need at least 68020 code to build shared libraries, but
            # adding the `-m68020' flag to GCC prevents building anything better,
            # like `-m68040'.
            lt_prog_compiler_pic='-m68020 -resident32 -malways-restore-a4'
    beos* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
      # PIC is the default for these OSes.
    mingw* | cygwin* | pw32* | os2* | cegcc*)
      # This hack is so that the source file can tell whether it is being
      # built for inclusion in a dll (and should export symbols for example).
      # Although the cygwin gcc ignores -fPIC, still need this for old-style
      # (--disable-auto-import) libraries
      lt_prog_compiler_pic='-DDLL_EXPORT'
      # PIC is the default on this platform
      # Common symbols not allowed in MH_DYLIB files
      lt_prog_compiler_pic='-fno-common'
    haiku*)
      # PIC is the default for Haiku.
      # The "-static" flag exists, but is broken.
    hpux*)
      # PIC is the default for 64-bit PA HP-UX, but not for 32-bit
      # PA HP-UX.  On IA64 HP-UX, PIC is the default but the pic flag
      # sets the default TLS model and affects inlining.
      case $host_cpu in
      hppa*64*)
	# +Z the default
    interix[3-9]*)
      # Interix 3.x gcc -fpic/-fPIC options generate broken code.
      # Instead, we relocate shared libraries at runtime.
    msdosdjgpp*)
      # Just because we use GCC doesn't mean we suddenly get shared libraries
      # on systems that don't support them.
      lt_prog_compiler_can_build_shared=no
      enable_shared=no
    *nto* | *qnx*)
      # QNX uses GNU C++, but need to define -shared option too, otherwise
      # it will coredump.
      lt_prog_compiler_pic='-fPIC -shared'
    sysv4*MP*)
      if test -d /usr/nec; then
	lt_prog_compiler_pic=-Kconform_pic
    nvcc*) # Cuda Compiler Driver 2.2
      lt_prog_compiler_wl='-Xlinker '
      if test -n "$lt_prog_compiler_pic"; then
        lt_prog_compiler_pic="-Xcompiler $lt_prog_compiler_pic"
    # PORTME Check for flag to pass linker flags through the system compiler.
    case $host_os in
    aix*)
	lt_prog_compiler_static='-bnso -bI:/lib/syscalls.exp'
    hpux9* | hpux10* | hpux11*)
      # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
      # not for PA HP-UX.
      case $host_cpu in
      hppa*64*|ia64*)
	# +Z the default
	lt_prog_compiler_pic='+Z'
      # Is there a better lt_prog_compiler_static that works with the bundled CC?
      lt_prog_compiler_static='${wl}-a ${wl}archive'
      # PIC (with -KPIC) is the default.
      lt_prog_compiler_static='-non_shared'
      # old Intel for x86_64 which still supported -KPIC.
      ecc*)
	lt_prog_compiler_pic='-KPIC'
      # icc used to be incompatible with GCC.
      # ICC 10 doesn't accept -KPIC any more.
      icc* | ifort*)
      # Lahey Fortran 8.1.
      lf95*)
	lt_prog_compiler_pic='--shared'
	lt_prog_compiler_static='--static'
      nagfor*)
	# NAG Fortran compiler
	lt_prog_compiler_wl='-Wl,-Wl,,'
	lt_prog_compiler_pic='-PIC'
      pgcc* | pgf77* | pgf90* | pgf95* | pgfortran*)
        # Portland Group compilers (*not* the Pentium gcc compiler,
	# which looks to be a dead project)
	lt_prog_compiler_pic='-fpic'
      ccc*)
        # All Alpha code is PIC.
      xl* | bgxl* | bgf* | mpixl*)
	# IBM XL C 8.0/Fortran 10.1, 11.1 on PPC and BlueGene
	lt_prog_compiler_pic='-qpic'
	lt_prog_compiler_static='-qstaticlink'
	case `$CC -V 2>&1 | sed 5q` in
	*Sun\ Ceres\ Fortran* | *Sun*Fortran*\ [1-7].* | *Sun*Fortran*\ 8.[0-3]*)
	  # Sun Fortran 8.3 passes all unrecognized flags to the linker
	  lt_prog_compiler_wl=''
	*Sun\ F* | *Sun*Fortran*)
	  lt_prog_compiler_wl='-Qoption ld '
	*Sun\ C*)
	  # Sun C 5.9
        *Intel*\ [CF]*Compiler*)
	*Portland\ Group*)
    newsos6)
    *nto* | *qnx*)
      # it will coredump.
      # All OSF/1 code is PIC.
    rdos*)
    solaris*)
      f77* | f90* | f95* | sunf77* | sunf90* | sunf95*)
	lt_prog_compiler_wl='-Qoption ld ';;
	lt_prog_compiler_wl='-Wl,';;
    sunos4*)
    sysv4 | sysv4.2uw2* | sysv4.3*)
    sysv4*MP*)
      if test -d /usr/nec ;then
	lt_prog_compiler_pic='-Kconform_pic'
    sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
    unicos*)
    uts4*)
      lt_prog_compiler_pic='-pic'
case $host_os in
  # For platforms which do not support PIC, -DPIC is meaningless:
  *djgpp*)
    lt_prog_compiler_pic="$lt_prog_compiler_pic -DPIC"
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $compiler option to produce PIC" >&5
$as_echo_n "checking for $compiler option to produce PIC... " >&6; }
if ${lt_cv_prog_compiler_pic+:} false; then :
  lt_cv_prog_compiler_pic=$lt_prog_compiler_pic
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_pic" >&5
$as_echo "$lt_cv_prog_compiler_pic" >&6; }
lt_prog_compiler_pic=$lt_cv_prog_compiler_pic
# Check to make sure the PIC flag actually works.
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler PIC flag $lt_prog_compiler_pic works" >&5
$as_echo_n "checking if $compiler PIC flag $lt_prog_compiler_pic works... " >&6; }
if ${lt_cv_prog_compiler_pic_works+:} false; then :
  lt_cv_prog_compiler_pic_works=no
   lt_compiler_flag="$lt_prog_compiler_pic -DPIC"
   ac_status=$?
   cat conftest.err >&5
       lt_cv_prog_compiler_pic_works=yes
   $RM conftest*
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_pic_works" >&5
$as_echo "$lt_cv_prog_compiler_pic_works" >&6; }
if test x"$lt_cv_prog_compiler_pic_works" = xyes; then
    case $lt_prog_compiler_pic in
     *) lt_prog_compiler_pic=" $lt_prog_compiler_pic" ;;
# Check to make sure the static flag actually works.
wl=$lt_prog_compiler_wl eval lt_tmp_static_flag=\"$lt_prog_compiler_static\"
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler static flag $lt_tmp_static_flag works" >&5
$as_echo_n "checking if $compiler static flag $lt_tmp_static_flag works... " >&6; }
if ${lt_cv_prog_compiler_static_works+:} false; then :
  lt_cv_prog_compiler_static_works=no
   save_LDFLAGS="$LDFLAGS"
   LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
   echo "$lt_simple_link_test_code" > conftest.$ac_ext
   if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
     # The linker can only warn and ignore the option if not recognized
     if test -s conftest.err; then
       # Append any errors to the config.log.
       cat conftest.err 1>&5
       $ECHO "$_lt_linker_boilerplate" | $SED '/^$/d' > conftest.exp
       if diff conftest.exp conftest.er2 >/dev/null; then
         lt_cv_prog_compiler_static_works=yes
   $RM -r conftest*
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_static_works" >&5
$as_echo "$lt_cv_prog_compiler_static_works" >&6; }
if test x"$lt_cv_prog_compiler_static_works" = xyes; then
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler supports -c -o file.$ac_objext" >&5
$as_echo_n "checking if $compiler supports -c -o file.$ac_objext... " >&6; }
if ${lt_cv_prog_compiler_c_o+:} false; then :
  lt_cv_prog_compiler_c_o=no
   $RM -r conftest 2>/dev/null
   mkdir conftest
   cd conftest
   mkdir out
   lt_compiler_flag="-o out/conftest2.$ac_objext"
   (eval "$lt_compile" 2>out/conftest.err)
   ac_status=$?
   cat out/conftest.err >&5
   if (exit $ac_status) && test -s out/conftest2.$ac_objext
   then
     $ECHO "$_lt_compiler_boilerplate" | $SED '/^$/d' > out/conftest.exp
     $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
     if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
       lt_cv_prog_compiler_c_o=yes
   chmod u+w . 2>&5
   $RM conftest*
   # SGI C++ compiler will create directory out/ii_files/ for
   # template instantiation
   test -d out/ii_files && $RM out/ii_files/* && rmdir out/ii_files
   $RM out/* && rmdir out
   cd ..
   $RM -r conftest
   $RM conftest*
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_c_o" >&5
$as_echo "$lt_cv_prog_compiler_c_o" >&6; }
   mkdir conftest
   cd conftest
   mkdir out
   ac_status=$?
   then
   chmod u+w . 2>&5
   $RM conftest*
   cd ..
   $RM -r conftest
   $RM conftest*
hard_links="nottested"
if test "$lt_cv_prog_compiler_c_o" = no && test "$need_locks" != no; then
  # do not overwrite the value of need_locks provided by the user
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking if we can lock with hard links" >&5
$as_echo_n "checking if we can lock with hard links... " >&6; }
  hard_links=yes
  $RM conftest*
  ln conftest.a conftest.b 2>/dev/null && hard_links=no
  touch conftest.a
  ln conftest.a conftest.b 2>&5 || hard_links=no
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $hard_links" >&5
$as_echo "$hard_links" >&6; }
  if test "$hard_links" = no; then
    { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
$as_echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
    need_locks=warn
  need_locks=no
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the $compiler linker ($LD) supports shared libraries" >&5
$as_echo_n "checking whether the $compiler linker ($LD) supports shared libraries... " >&6; }
  runpath_var=
  allow_undefined_flag=
  always_export_symbols=no
  archive_cmds=
  archive_expsym_cmds=
  compiler_needs_object=no
  enable_shared_with_static_runtimes=no
  export_dynamic_flag_spec=
  export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
  hardcode_automatic=no
  hardcode_direct=no
  hardcode_direct_absolute=no
  hardcode_libdir_flag_spec=
  hardcode_libdir_separator=
  hardcode_minus_L=no
  hardcode_shlibpath_var=unsupported
  inherit_rpath=no
  link_all_deplibs=unknown
  module_cmds=
  module_expsym_cmds=
  old_archive_from_new_cmds=
  old_archive_from_expsyms_cmds=
  thread_safe_flag_spec=
  whole_archive_flag_spec=
  # include_expsyms should be a list of space-separated symbols to be *always*
  # included in the symbol list
  include_expsyms=
  # exclude_expsyms can be an extended regexp of symbols to exclude
  # it will be wrapped by ` (' and `)$', so one must not match beginning or
  # end of line.  Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
  # as well as any symbol that contains `d'.
  exclude_expsyms='_GLOBAL_OFFSET_TABLE_|_GLOBAL__F[ID]_.*'
  # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
  # platforms (ab)use it in PIC code, but their linkers get confused if
  # the symbol is explicitly referenced.  Since portable code cannot
  # rely on this symbol name, it's probably fine to never include it in
  # preloaded symbol tables.
  # Exclude shared library initialization/finalization symbols.
  extract_expsyms_cmds=
  case $host_os in
  cygwin* | mingw* | pw32* | cegcc*)
    # FIXME: the MSVC++ port hasn't been tested in a loooong time
    # When not using gcc, we currently assume that we are using
    # Microsoft Visual C++.
    if test "$GCC" != yes; then
      with_gnu_ld=no
  interix*)
    # we just hope/assume this is gcc and not c89 (= MSVC++)
    with_gnu_ld=yes
  openbsd*)
    with_gnu_ld=no
  linux* | k*bsd*-gnu | gnu*)
    link_all_deplibs=no
  ld_shlibs=yes
  # On some targets, GNU ld is compatible enough with the native linker
  # that we're better off using the native interface for both.
  lt_use_gnu_ld_interface=no
  if test "$with_gnu_ld" = yes; then
    case $host_os in
      aix*)
	# The AIX port of GNU ld has always aspired to compatibility
	# with the native linker.  However, as the warning in the GNU ld
	# block says, versions before 2.19.5* couldn't really create working
	# shared libraries, regardless of the interface used.
	case `$LD -v 2>&1` in
	  *\ \(GNU\ Binutils\)\ 2.19.5*) ;;
	  *\ \(GNU\ Binutils\)\ 2.[2-9]*) ;;
	  *\ \(GNU\ Binutils\)\ [3-9]*) ;;
	    lt_use_gnu_ld_interface=yes
  if test "$lt_use_gnu_ld_interface" = yes; then
    # If archive_cmds runs LD, not CC, wlarc should be empty
    wlarc='${wl}'
    # Set some defaults for GNU ld with shared library support. These
    # are reset later if shared libraries are not supported. Putting them
    # here allows them to be overridden if necessary.
    runpath_var=LD_RUN_PATH
    hardcode_libdir_flag_spec='${wl}-rpath ${wl}$libdir'
    export_dynamic_flag_spec='${wl}--export-dynamic'
    # ancient GNU ld didn't support --whole-archive et. al.
    if $LD --help 2>&1 | $GREP 'no-whole-archive' > /dev/null; then
      whole_archive_flag_spec="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
    supports_anon_versioning=no
      *GNU\ gold*) supports_anon_versioning=yes ;;
      *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
      *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
      *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
      *\ 2.11.*) ;; # other 2.11 versions
    # See if GNU ld supports shared libraries.
    case $host_os in
    aix[3-9]*)
      # On AIX/PPC, the GNU linker is very broken
      if test "$host_cpu" != ia64; then
	ld_shlibs=no
	cat <<_LT_EOF 1>&2
*** Warning: the GNU linker, at least up to release 2.19, is reported
*** to be unable to reliably create shared libraries on AIX.
*** Therefore, libtool is disabling shared libraries support.  If you
*** really care for shared libraries, you may want to install binutils
*** 2.20 or above, or modify your PATH so that a non-GNU linker is found.
*** You will then need to restart the configuration process.
_LT_EOF
    amigaos*)
      case $host_cpu in
      powerpc)
            archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
            archive_expsym_cmds=''
      m68k)
            archive_cmds='$RM $output_objdir/a2ixlibrary.data~$ECHO "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$ECHO "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$ECHO "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$ECHO "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
            hardcode_libdir_flag_spec='-L$libdir'
            hardcode_minus_L=yes
    beos*)
      if $LD --help 2>&1 | $GREP ': supported targets:.* elf' > /dev/null; then
	allow_undefined_flag=unsupported
	# Joseph Beckenbach <jrb3@best.com> says some releases of gcc
	# support --undefined.  This deserves some investigation.  FIXME
	archive_cmds='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
	ld_shlibs=no
      # _LT_TAGVAR(hardcode_libdir_flag_spec, ) is actually meaningless,
      # as there is no search path for DLLs.
      export_dynamic_flag_spec='${wl}--export-all-symbols'
      enable_shared_with_static_runtimes=yes
      export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS][ ]/s/.*[ ]\([^ ]*\)/\1 DATA/;s/^.*[ ]__nm__\([^ ]*\)[ ][^ ]*/\1 DATA/;/^I[ ]/d;/^[AITW][ ]/s/.* //'\'' | sort | uniq > $export_symbols'
      exclude_expsyms='[_]+GLOBAL_OFFSET_TABLE_|[_]+GLOBAL__[FID]_.*|[_]+head_[A-Za-z0-9_]+_dll|[A-Za-z0-9_]+_dll_iname'
      if $LD --help 2>&1 | $GREP 'auto-import' > /dev/null; then
        archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
	# If the export-symbols file already is a .def file (1st line
	# is EXPORTS), use it as is; otherwise, prepend...
	archive_expsym_cmds='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
	  cp $export_symbols $output_objdir/$soname.def;
	  echo EXPORTS > $output_objdir/$soname.def;
	  cat $export_symbols >> $output_objdir/$soname.def;
	fi~
	$CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
	ld_shlibs=no
    haiku*)
      link_all_deplibs=yes
    interix[3-9]*)
      hardcode_direct=no
      hardcode_shlibpath_var=no
      hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
      export_dynamic_flag_spec='${wl}-E'
      # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
      # Instead, shared libraries are loaded at an image base (0x10000000 by
      # default) and relocated if they conflict, which is a slow very memory
      # consuming and fragmenting process.  To avoid this, we pick a random,
      # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
      # time.  Moving up from 0x10000000 also allows more sbrk(2) space.
      archive_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
      archive_expsym_cmds='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
    gnu* | linux* | tpf* | k*bsd*-gnu | kopensolaris*-gnu)
      tmp_diet=no
      if test "$host_os" = linux-dietlibc; then
	  diet\ *) tmp_diet=yes;;	# linux-dietlibc with static linking (!diet-dyn)
      if $LD --help 2>&1 | $EGREP ': supported targets:.* elf' > /dev/null \
	 && test "$tmp_diet" = no
      then
	tmp_addflag=' $pic_flag'
	tmp_sharedflag='-shared'
	case $cc_basename,$host_cpu in
        pgcc*)				# Portland Group C compiler
	  whole_archive_flag_spec='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; func_echo_all \"$new_convenience\"` ${wl}--no-whole-archive'
					# Portland Group f77 and f90 compilers
	  tmp_addflag=' $pic_flag -Mnomain' ;;
	ecc*,ia64* | icc*,ia64*)	# Intel C compiler on ia64
	  tmp_addflag=' -i_dynamic' ;;
	efc*,ia64* | ifort*,ia64*)	# Intel Fortran compiler on ia64
	  tmp_addflag=' -i_dynamic -nofor_main' ;;
	ifc* | ifort*)			# Intel Fortran compiler
	  tmp_addflag=' -nofor_main' ;;
	lf95*)				# Lahey Fortran 8.1
	  tmp_sharedflag='--shared' ;;
	xl[cC]* | bgxl[cC]* | mpixl[cC]*) # IBM XL C 8.0 on PPC (deal with xlf below)
	  tmp_sharedflag='-qmkshrobj'
	  tmp_addflag= ;;
	  compiler_needs_object=yes
	*Sun\ C*)			# Sun C 5.9
	  whole_archive_flag_spec='${wl}--whole-archive`new_convenience=; for conv in $convenience\"\"; do test -z \"$conv\" || new_convenience=\"$new_convenience,$conv\"; done; func_echo_all \"$new_convenience\"` ${wl}--no-whole-archive'
	  tmp_sharedflag='-G' ;;
	*Sun\ F*)			# Sun Fortran 8.3
	archive_cmds='$CC '"$tmp_sharedflag""$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
        if test "x$supports_anon_versioning" = xyes; then
          archive_expsym_cmds='echo "{ global:" > $output_objdir/$libname.ver~
	    cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
	    echo "local: *; };" >> $output_objdir/$libname.ver~
	    $CC '"$tmp_sharedflag""$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
	xlf* | bgf* | bgxlf* | mpixlf*)
	  # IBM XL Fortran 10.1 on PPC cannot create shared libs itself
	  whole_archive_flag_spec='--whole-archive$convenience --no-whole-archive'
	  archive_cmds='$LD -shared $libobjs $deplibs $linker_flags -soname $soname -o $lib'
	      $LD -shared $libobjs $deplibs $linker_flags -soname $soname -version-script $output_objdir/$libname.ver -o $lib'
        ld_shlibs=no
    netbsd* | netbsdelf*-gnu)
      if echo __ELF__ | $CC -E - | $GREP __ELF__ >/dev/null; then
	archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
	wlarc=
	archive_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
	archive_expsym_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
    solaris*)
      if $LD -v 2>&1 | $GREP 'BFD 2\.8' > /dev/null; then
	ld_shlibs=no
	cat <<_LT_EOF 1>&2
*** Warning: The releases 2.8.* of the GNU linker cannot reliably
*** create shared libraries on Solaris systems.  Therefore, libtool
*** is disabling shared libraries support.  We urge you to upgrade GNU
*** binutils to release 2.9.1 or newer.  Another option is to modify
*** your PATH or compiler configuration so that the native linker is
*** used, and then restart.
_LT_EOF
      elif $LD --help 2>&1 | $GREP ': supported targets:.* elf' > /dev/null; then
	ld_shlibs=no
    sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
        *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
	ld_shlibs=no
	cat <<_LT_EOF 1>&2
*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
*** reliably create shared libraries on SCO systems.  Therefore, libtool
*** binutils to release 2.16.91.0.3 or newer.  Another option is to modify
_LT_EOF
	  # For security reasons, it is highly recommended that you always
	  # use absolute paths for naming shared libraries, and exclude the
	  # DT_RUNPATH tag from executables and libraries.  But doing so
	  # requires that you compile everything twice, which is a pain.
	    archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
	    ld_shlibs=no
    sunos4*)
      archive_cmds='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
      wlarc=
      hardcode_direct=yes
	ld_shlibs=no
    if test "$ld_shlibs" = no; then
      runpath_var=
    # PORTME fill in a description of your system's linker (not GNU ld)
    case $host_os in
    aix3*)
      always_export_symbols=yes
      archive_expsym_cmds='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
      # Note: this linker hardcodes the directories in LIBPATH if there
      # are no directories specified by -L.
      if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
	# Neither direct hardcoding nor static linking is supported with a
	# broken collect2.
	hardcode_direct=unsupported
    aix[4-9]*)
	# On IA64, the linker does run time linking by default, so we don't
	# have to do anything special.
	aix_use_runtimelinking=no
	exp_sym_flag='-Bexport'
	no_entry_flag=""
	# If we're using GNU nm, then we don't want the "-C" option.
	# -C means demangle to AIX nm, but means don't demangle with GNU nm
	# Also, AIX nm treats weak defined symbols like other global
	# defined symbols, whereas GNU nm marks them as "W".
	if $NM -V 2>&1 | $GREP 'GNU' > /dev/null; then
	  export_symbols_cmds='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$ 2 == "T") || (\$ 2 == "D") || (\$ 2 == "B") || (\$ 2 == "W")) && (substr(\$ 3,1,1) != ".")) { print \$ 3 } }'\'' | sort -u > $export_symbols'
	  export_symbols_cmds='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$ 2 == "T") || (\$ 2 == "D") || (\$ 2 == "B")) && (substr(\$ 3,1,1) != ".")) { print \$ 3 } }'\'' | sort -u > $export_symbols'
	# Test if we are trying to use run time linking or normal
	# AIX style linking. If -brtl is somewhere in LDFLAGS, we
	# need to do runtime linking.
	case $host_os in aix4.[23]|aix4.[23].*|aix[5-9]*)
	  for ld_flag in $LDFLAGS; do
	  if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
	    aix_use_runtimelinking=yes
	    break
	exp_sym_flag='-bexport'
	no_entry_flag='-bnoentry'
      # When large executables or shared objects are built, AIX ld can
      # have problems creating the table of contents.  If linking a library
      # or program results in "error TOC overflow" add -mminimal-toc to
      # CXXFLAGS/CFLAGS for g++/gcc.  In the cases where that is not
      # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
      archive_cmds=''
      hardcode_direct=yes
      hardcode_direct_absolute=yes
      hardcode_libdir_separator=':'
      file_list_spec='${wl}-f,'
	case $host_os in aix4.[012]|aix4.[012].*)
	# We only want to do this on AIX 4.2 and lower, the check
	# below for broken collect2 doesn't work under 4.3+
	  collect2name=`${CC} -print-prog-name=collect2`
	  if test -f "$collect2name" &&
	   strings "$collect2name" | $GREP resolve_lib_name >/dev/null
	  then
	  # We have reworked collect2
	  # We have old collect2
	  # It fails to find uninstalled libraries when the uninstalled
	  # path is not listed in the libpath.  Setting hardcode_minus_L
	  # to unsupported forces relinking
	shared_flag='-shared'
	if test "$aix_use_runtimelinking" = yes; then
	  shared_flag="$shared_flag "'${wl}-G'
	link_all_deplibs=no
	# not using gcc
	# VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
	# chokes on -Wl,-G. The following line is correct:
	  shared_flag='-G'
	    shared_flag='${wl}-G'
	    shared_flag='${wl}-bM:SRE'
      export_dynamic_flag_spec='${wl}-bexpall'
      # It seems that -bexpall does not export symbols beginning with
      # underscore (_), so it is better to generate a list of symbols to export.
	# Warning - without using the other runtime loading flags (-brtl),
	# -berok will link without error, but may produce a broken library.
	allow_undefined_flag='-berok'
        # Determine the default libpath from the value encoded in an
        # empty executable.
        if test "${lt_cv_aix_libpath+set}" = set; then
  aix_libpath=$lt_cv_aix_libpath
  if ${lt_cv_aix_libpath_+:} false; then :
  cat confdefs.h - <<_ACEOF >conftest.$ac_ext
/* end confdefs.h.  */
int
main ()
_ACEOF
  lt_aix_libpath_sed='
      /Import File Strings/,/^$/ {
	  /^0/ {
	      s/^0  *\([^ ]*\) *$/\1/
	      p
  lt_cv_aix_libpath_=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e "$lt_aix_libpath_sed"`
  # Check for a 64-bit object if we didn't find anything.
  if test -z "$lt_cv_aix_libpath_"; then
    lt_cv_aix_libpath_=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e "$lt_aix_libpath_sed"`
    lt_cv_aix_libpath_="/usr/lib:/lib"
  aix_libpath=$lt_cv_aix_libpath_
        hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:'"$aix_libpath"
        archive_expsym_cmds='$CC -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then func_echo_all "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
	if test "$host_cpu" = ia64; then
	  hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
	  allow_undefined_flag="-z nodefs"
	  archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
	 # empty executable.
int
main ()
_ACEOF
	  /^0/ {
	      p
	  # Warning - without using the other run time loading flags,
	  no_undefined_flag=' ${wl}-bernotok'
	  allow_undefined_flag=' ${wl}-berok'
	    # We only use this code for GNU lds that support --whole-archive.
	    whole_archive_flag_spec='${wl}--whole-archive$convenience ${wl}--no-whole-archive'
	    # Exported symbols can be pulled into shared objects from archives
	    whole_archive_flag_spec='$convenience'
	  archive_cmds_need_lc=yes
	  # This is similar to how AIX traditionally builds its shared libraries.
	  archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
    amigaos*)
      case $host_cpu in
      powerpc)
      m68k)
    bsdi[45]*)
      export_dynamic_flag_spec=-rdynamic
      # hardcode_libdir_flag_spec is actually meaningless, as there is
      # no search path for DLLs.
      cl*)
	# Native MSVC
	hardcode_libdir_flag_spec=' '
	file_list_spec='@'
	# Tell ltmain to make .lib files, not .a files.
	libext=lib
	# Tell ltmain to make .dll files, not .so files.
	shrext_cmds=".dll"
	# FIXME: Setting linknames here is a bad hack.
	archive_cmds='$CC -o $output_objdir/$soname $libobjs $compiler_flags $deplibs -Wl,-dll~linknames='
	    sed -n -e 's/\\\\\\\(.*\\\\\\\)/-link\\\ -EXPORT:\\\\\\\1/' -e '1\\\!p' < $export_symbols > $output_objdir/$soname.exp;
	    sed -e 's/\\\\\\\(.*\\\\\\\)/-link\\\ -EXPORT:\\\\\\\1/' < $export_symbols > $output_objdir/$soname.exp;
	  fi~
	  $CC -o $tool_output_objdir$soname $libobjs $compiler_flags $deplibs "@$tool_output_objdir$soname.exp" -Wl,-DLL,-IMPLIB:"$tool_output_objdir$libname.dll.lib"~
	  linknames='
	# The linker will not automatically build a static lib if we build a DLL.
	# _LT_TAGVAR(old_archive_from_new_cmds, )='true'
	exclude_expsyms='_NULL_IMPORT_DESCRIPTOR|_IMPORT_DESCRIPTOR_.*'
	export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS][ ]/s/.*[ ]\([^ ]*\)/\1,DATA/'\'' | $SED -e '\''/^[AITW][ ]/s/.*[ ]//'\'' | sort | uniq > $export_symbols'
	# Don't use ranlib
	old_postinstall_cmds='chmod 644 $oldlib'
	postlink_cmds='lt_outputfile="@OUTPUT@"~
	  lt_tool_outputfile="@TOOL_OUTPUT@"~
	  case $lt_outputfile in
	    *.exe|*.EXE) ;;
	      lt_outputfile="$lt_outputfile.exe"
	      lt_tool_outputfile="$lt_tool_outputfile.exe"
	  esac~
	  if test "$MANIFEST_TOOL" != ":" && test -f "$lt_outputfile.manifest"; then
	    $MANIFEST_TOOL -manifest "$lt_tool_outputfile.manifest" -outputresource:"$lt_tool_outputfile" || exit 1;
	    $RM "$lt_outputfile.manifest";
	  fi'
	# Assume MSVC wrapper
	libext=lib
	shrext_cmds=".dll"
	archive_cmds='$CC -o $lib $libobjs $compiler_flags `func_echo_all "$deplibs" | $SED '\''s/ -lc$//'\''` -link -dll~linknames='
	# The linker will automatically build a .lib file if we build a DLL.
	old_archive_from_new_cmds='true'
	# FIXME: Should let the user specify the lib program.
	old_archive_cmds='lib -OUT:$oldlib$oldobjs$old_deplibs'
    darwin* | rhapsody*)
  archive_cmds_need_lc=no
  hardcode_direct=no
  hardcode_automatic=yes
  if test "$lt_cv_ld_force_load" = "yes"; then
    whole_archive_flag_spec='`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience ${wl}-force_load,$conv\"; done; func_echo_all \"$new_convenience\"`'
    whole_archive_flag_spec=''
  allow_undefined_flag="$_lt_dar_allow_undefined"
     ifort*) _lt_dar_can_shared=yes ;;
     *) _lt_dar_can_shared=$GCC ;;
  if test "$_lt_dar_can_shared" = "yes"; then
    output_verbose_link_cmd=func_echo_all
    archive_cmds="\$CC -dynamiclib \$allow_undefined_flag -o \$lib \$libobjs \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring $_lt_dar_single_mod${_lt_dsymutil}"
    module_cmds="\$CC \$allow_undefined_flag -o \$lib -bundle \$libobjs \$deplibs \$compiler_flags${_lt_dsymutil}"
    archive_expsym_cmds="sed 's,^,_,' < \$export_symbols > \$output_objdir/\${libname}-symbols.expsym~\$CC -dynamiclib \$allow_undefined_flag -o \$lib \$libobjs \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring ${_lt_dar_single_mod}${_lt_dar_export_syms}${_lt_dsymutil}"
    module_expsym_cmds="sed -e 's,^,_,' < \$export_symbols > \$output_objdir/\${libname}-symbols.expsym~\$CC \$allow_undefined_flag -o \$lib -bundle \$libobjs \$deplibs \$compiler_flags${_lt_dar_export_syms}${_lt_dsymutil}"
  ld_shlibs=no
    dgux*)
      archive_cmds='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
    # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
    # support.  Future versions do this automatically, but an explicit c++rt0.o
    # does not break anything, and helps significantly (at the cost of a little
    # extra space).
    freebsd2.2*)
      archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
      hardcode_libdir_flag_spec='-R$libdir'
      hardcode_direct=yes
    # Unfortunately, older versions of FreeBSD 2 do not have this feature.
    freebsd2.*)
      archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
      hardcode_direct=yes
    # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
    freebsd* | dragonfly*)
      archive_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
      hardcode_direct=yes
    hpux9*)
	archive_cmds='$RM $output_objdir/$soname~$CC -shared $pic_flag ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
	archive_cmds='$RM $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
      hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
      hardcode_libdir_separator=:
      hardcode_direct=yes
      # hardcode_minus_L: Not really in the search PATH,
      # but as the default location of the library.
    hpux10*)
      if test "$GCC" = yes && test "$with_gnu_ld" = no; then
	archive_cmds='$CC -shared $pic_flag ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
	archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
      if test "$with_gnu_ld" = no; then
	hardcode_direct=yes
    hpux11*)
	case $host_cpu in
	hppa*64*)
	  archive_cmds='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
	ia64*)
	  archive_cmds='$CC -shared $pic_flag ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
	case $host_cpu in
	hppa*64*)
	  archive_cmds='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
	ia64*)
	  archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
	  # Older versions of the 11.00 compiler do not understand -b yet
	  # (HP92453-01 A.11.01.20 doesn't, HP92453-01 B.11.X.35175-35176.GP does)
	  { $as_echo "$as_me:${as_lineno-$LINENO}: checking if $CC understands -b" >&5
$as_echo_n "checking if $CC understands -b... " >&6; }
if ${lt_cv_prog_compiler__b+:} false; then :
  lt_cv_prog_compiler__b=no
   LDFLAGS="$LDFLAGS -b"
         lt_cv_prog_compiler__b=yes
   $RM -r conftest*
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler__b" >&5
$as_echo "$lt_cv_prog_compiler__b" >&6; }
if test x"$lt_cv_prog_compiler__b" = xyes; then
    archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
	case $host_cpu in
	hppa*64*|ia64*)
	  hardcode_direct=no
	  hardcode_direct=yes
    irix5* | irix6* | nonstopux*)
	archive_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
	# Try to use the -exported_symbol ld option, if it does not
	# work, assume that -exports_file does not work either and
	# implicitly export all symbols.
	# This should be the same for all languages, so no per-tag cache variable.
	{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the $host_os linker accepts -exported_symbol" >&5
$as_echo_n "checking whether the $host_os linker accepts -exported_symbol... " >&6; }
if ${lt_cv_irix_exported_symbol+:} false; then :
	   LDFLAGS="$LDFLAGS -shared ${wl}-exported_symbol ${wl}foo ${wl}-update_registry ${wl}/dev/null"
int foo (void) { return 0; }
_ACEOF
if ac_fn_c_try_link "$LINENO"; then :
  lt_cv_irix_exported_symbol=yes
  lt_cv_irix_exported_symbol=no
rm -f core conftest.err conftest.$ac_objext \
    conftest$ac_exeext conftest.$ac_ext
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_irix_exported_symbol" >&5
$as_echo "$lt_cv_irix_exported_symbol" >&6; }
	if test "$lt_cv_irix_exported_symbol" = yes; then
          archive_expsym_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations ${wl}-exports_file ${wl}$export_symbols -o $lib'
	archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
	archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -exports_file $export_symbols -o $lib'
      archive_cmds_need_lc='no'
      inherit_rpath=yes
	archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'  # a.out
	archive_cmds='$LD -shared -o $lib $libobjs $deplibs $linker_flags'      # ELF
      hardcode_direct=yes
    newsos6)
      hardcode_direct=yes
    *nto* | *qnx*)
    openbsd*)
      if test -f /usr/libexec/ld.so; then
	hardcode_direct=yes
	if test -z "`echo __ELF__ | $CC -E - | $GREP __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
	  archive_expsym_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
	  case $host_os in
	   openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
	ld_shlibs=no
    os2*)
      archive_cmds='$ECHO "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$ECHO "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~echo DATA >> $output_objdir/$libname.def~echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
      old_archive_from_new_cmds='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
    osf3*)
	allow_undefined_flag=' ${wl}-expect_unresolved ${wl}\*'
	archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
	allow_undefined_flag=' -expect_unresolved \*'
	archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
    osf4* | osf5*)	# as osf3* with the addition of -msym flag
	archive_cmds='$CC -shared${allow_undefined_flag} $pic_flag $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
	archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags -msym -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
	archive_expsym_cmds='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; printf "%s\\n" "-hidden">> $lib.exp~
	$CC -shared${allow_undefined_flag} ${wl}-input ${wl}$lib.exp $compiler_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && $ECHO "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib~$RM $lib.exp'
	# Both c and cxx compiler support -rpath directly
	hardcode_libdir_flag_spec='-rpath $libdir'
    solaris*)
      no_undefined_flag=' -z defs'
	wlarc='${wl}'
	archive_cmds='$CC -shared $pic_flag ${wl}-z ${wl}text ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
	archive_expsym_cmds='echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~echo "local: *; };" >> $lib.exp~
	  $CC -shared $pic_flag ${wl}-z ${wl}text ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$RM $lib.exp'
	case `$CC -V 2>&1` in
	*"Compilers 5.0"*)
	  wlarc=''
	  archive_cmds='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
	  $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$RM $lib.exp'
	  wlarc='${wl}'
	  archive_cmds='$CC -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $compiler_flags'
	  $CC -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $compiler_flags~$RM $lib.exp'
      case $host_os in
      solaris2.[0-5] | solaris2.[0-5].*) ;;
	# The compiler driver will combine and reorder linker options,
	# but understands `-z linker_flag'.  GCC discards it without `$wl',
	# but is careful enough not to reorder.
	# Supported since Solaris 2.6 (maybe 2.5.1?)
	  whole_archive_flag_spec='${wl}-z ${wl}allextract$convenience ${wl}-z ${wl}defaultextract'
	  whole_archive_flag_spec='-z allextract$convenience -z defaultextract'
    sunos4*)
      if test "x$host_vendor" = xsequent; then
	# Use $CC to link under sequent, because it throws in some extra .o
	# files that make .init and .fini sections work.
	archive_cmds='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
	archive_cmds='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
      hardcode_direct=yes
    sysv4)
      case $host_vendor in
	sni)
	  hardcode_direct=yes # is this really true???
	siemens)
	  ## LD is ld it makes a PLAMLIB
	  ## CC just makes a GrossModule.
	  archive_cmds='$LD -G -o $lib $libobjs $deplibs $linker_flags'
	  reload_cmds='$CC -r -o $output$reload_objs'
	  hardcode_direct=no
	motorola)
	  hardcode_direct=no #Motorola manual says yes, but my tests say they lie
      runpath_var='LD_RUN_PATH'
    sysv4.3*)
      export_dynamic_flag_spec='-Bexport'
    sysv4*MP*)
	hardcode_runpath_var=yes
	ld_shlibs=yes
    sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7* | sco3.2v5.0.[024]*)
      no_undefined_flag='${wl}-z,text'
	archive_cmds='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
	archive_expsym_cmds='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
	archive_cmds='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
	archive_expsym_cmds='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
    sysv5* | sco3.2v5* | sco5v6*)
      # Note: We can NOT use -z defs as we might desire, because we do not
      # link with -lc, and that would cause any symbols used from libc to
      # always be unresolved, which means just about no library would
      # ever link correctly.  If we're not using GNU ld we use -z text
      # though, which does catch some bad symbols but isn't as heavy-handed
      # as -z defs.
      allow_undefined_flag='${wl}-z,nodefs'
      hardcode_libdir_flag_spec='${wl}-R,$libdir'
      export_dynamic_flag_spec='${wl}-Bexport'
    uts4*)
      ld_shlibs=no
    if test x$host_vendor = xsni; then
      case $host in
      sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
	export_dynamic_flag_spec='${wl}-Blargedynsym'
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ld_shlibs" >&5
$as_echo "$ld_shlibs" >&6; }
test "$ld_shlibs" = no && can_build_shared=no
with_gnu_ld=$with_gnu_ld
# Do we need to explicitly link libc?
case "x$archive_cmds_need_lc" in
x|xyes)
  # Assume -lc should be added
  if test "$enable_shared" = yes && test "$GCC" = yes; then
    case $archive_cmds in
      # FIXME: we may have to deal with multi-command sequences.
    '$CC '*)
      # Test whether the compiler implicitly links with -lc since on some
      # systems, -lgcc has to come before -lc. If gcc already passes -lc
      # to ld, don't add -lc before -lgcc.
      { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether -lc should be explicitly linked in" >&5
$as_echo_n "checking whether -lc should be explicitly linked in... " >&6; }
if ${lt_cv_archive_cmds_need_lc+:} false; then :
  $RM conftest*
	if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_compile\""; } >&5
  (eval $ac_compile) 2>&5
  ac_status=$?
  $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
  test $ac_status = 0; } 2>conftest.err; then
	  soname=conftest
	  lib=conftest
	  libobjs=conftest.$ac_objext
	  deplibs=
	  pic_flag=$lt_prog_compiler_pic
	  compiler_flags=-v
	  linker_flags=-v
	  verstring=
	  output_objdir=.
	  libname=conftest
	  lt_save_allow_undefined_flag=$allow_undefined_flag
	  if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$archive_cmds 2\>\&1 \| $GREP \" -lc \" \>/dev/null 2\>\&1\""; } >&5
  (eval $archive_cmds 2\>\&1 \| $GREP \" -lc \" \>/dev/null 2\>\&1) 2>&5
  ac_status=$?
	  then
	    lt_cv_archive_cmds_need_lc=no
	    lt_cv_archive_cmds_need_lc=yes
	  allow_undefined_flag=$lt_save_allow_undefined_flag
	$RM conftest*
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_archive_cmds_need_lc" >&5
$as_echo "$lt_cv_archive_cmds_need_lc" >&6; }
      archive_cmds_need_lc=$lt_cv_archive_cmds_need_lc
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking dynamic linker characteristics" >&5
$as_echo_n "checking dynamic linker characteristics... " >&6; }
  case $host_os in
    darwin*) lt_awk_arg="/^libraries:/,/LR/" ;;
    *) lt_awk_arg="/^libraries:/" ;;
  case $host_os in
    mingw* | cegcc*) lt_sed_strip_eq="s,=\([A-Za-z]:\),\1,g" ;;
    *) lt_sed_strip_eq="s,=/,/,g" ;;
  lt_search_path_spec=`$CC -print-search-dirs | awk $lt_awk_arg | $SED -e "s/^libraries://" -e $lt_sed_strip_eq`
  case $lt_search_path_spec in
    # if the path contains ";" then we assume it to be the separator
    # otherwise default to the standard path separator (i.e. ":") - it is
    # assumed that no part of a normal pathname contains ";" but that should
    # okay in the real world where ";" in dirpaths is itself problematic.
    lt_search_path_spec=`$ECHO "$lt_search_path_spec" | $SED 's/;/ /g'`
    lt_search_path_spec=`$ECHO "$lt_search_path_spec" | $SED "s/$PATH_SEPARATOR/ /g"`
  # Ok, now we have the path, separated by spaces, we can step through it
  # and add multilib dir if necessary.
  lt_tmp_lt_search_path_spec=
  lt_multi_os_dir=`$CC $CPPFLAGS $CFLAGS $LDFLAGS -print-multi-os-directory 2>/dev/null`
  for lt_sys_path in $lt_search_path_spec; do
    if test -d "$lt_sys_path/$lt_multi_os_dir"; then
      lt_tmp_lt_search_path_spec="$lt_tmp_lt_search_path_spec $lt_sys_path/$lt_multi_os_dir"
      test -d "$lt_sys_path" && \
	lt_tmp_lt_search_path_spec="$lt_tmp_lt_search_path_spec $lt_sys_path"
  lt_search_path_spec=`$ECHO "$lt_tmp_lt_search_path_spec" | awk '
BEGIN {RS=" "; FS="/|\n";} {
  lt_foo="";
  lt_count=0;
  for (lt_i = NF; lt_i > 0; lt_i--) {
    if ($lt_i != "" && $lt_i != ".") {
      if ($lt_i == "..") {
        lt_count++;
        if (lt_count == 0) {
          lt_foo="/" $lt_i lt_foo;
          lt_count--;
  if (lt_foo != "") { lt_freq[lt_foo]++; }
  if (lt_freq[lt_foo] == 1) { print lt_foo; }
  # AWK program above erroneously prepends '/' to C:/dos/paths
  # for these hosts.
  case $host_os in
    mingw* | cegcc*) lt_search_path_spec=`$ECHO "$lt_search_path_spec" |\
      $SED 's,/\([A-Za-z]:\),\1,g'` ;;
  sys_lib_search_path_spec=`$ECHO "$lt_search_path_spec" | $lt_NL2SP`
  sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
library_names_spec=
libname_spec='lib$name'
soname_spec=
shrext_cmds=".so"
postinstall_cmds=
postuninstall_cmds=
finish_cmds=
finish_eval=
shlibpath_var=
shlibpath_overrides_runpath=unknown
version_type=none
dynamic_linker="$host_os ld.so"
sys_lib_dlsearch_path_spec="/lib /usr/lib"
need_lib_prefix=unknown
hardcode_into_libs=no
# when you set need_version to no, make sure it does not cause -set_version
# flags to be left without arguments
need_version=unknown
case $host_os in
aix3*)
  version_type=linux # correct to gnu/linux during the next big refactor
  library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
  shlibpath_var=LIBPATH
  # AIX 3 has no versioning support, so we append a major version to the name.
  soname_spec='${libname}${release}${shared_ext}$major'
aix[4-9]*)
  need_lib_prefix=no
  need_version=no
  hardcode_into_libs=yes
    # AIX 5 supports IA64
    library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
    shlibpath_var=LD_LIBRARY_PATH
    # With GCC up to 2.95.x, collect2 would create an import file
    # for dependence libraries.  The import file would start with
    # the line `#! .'.  This would cause the generated library to
    # depend on `.', always an invalid library.  This was fixed in
    # development snapshots of GCC prior to 3.0.
    case $host_os in
      aix4 | aix4.[01] | aix4.[01].*)
      if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
	   echo ' yes '
	   echo '#endif'; } | ${CC} -E - | $GREP yes > /dev/null; then
	can_build_shared=no
    # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
    # soname into executable. Probably we can add versioning support to
    # collect2, so additional links can be useful in future.
      # If using run time linking (on AIX 4.2 or later) use lib<name>.so
      # instead of lib<name>.a to let people know that these are not
      # typical AIX shared libraries.
      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
      # We preserve .a as extension for shared libraries through AIX4.2
      # and later when we are not doing run time linking.
      library_names_spec='${libname}${release}.a $libname.a'
amigaos*)
  case $host_cpu in
  powerpc)
    # Since July 2007 AmigaOS4 officially supports .so libraries.
    # When compiling the executable, add -use-dynld -Lsobjs: to the compileline.
  m68k)
    library_names_spec='$libname.ixlibrary $libname.a'
    # Create ${libname}_ixlibrary.a entries in /sys/libs.
    finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`func_echo_all "$lib" | $SED '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $RM /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
beos*)
  library_names_spec='${libname}${shared_ext}'
  shlibpath_var=LIBRARY_PATH
bsdi[45]*)
  need_version=no
  finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
  sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
  sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
  # the default ld.so.conf also contains /usr/contrib/lib and
  # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
  # libtool to hard-code these into programs
  version_type=windows
  shrext_cmds=".dll"
  need_version=no
  need_lib_prefix=no
  case $GCC,$cc_basename in
  yes,*)
    # gcc
    library_names_spec='$libname.dll.a'
    # DLL is installed to $(libdir)/../bin by postinstall_cmds
    postinstall_cmds='base_file=`basename \${file}`~
      dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i; echo \$dlname'\''`~
      dldir=$destdir/`dirname \$dlpath`~
      test -d \$dldir || mkdir -p \$dldir~
      $install_prog $dir/$dlname \$dldir/$dlname~
      chmod a+x \$dldir/$dlname~
      if test -n '\''$stripme'\'' && test -n '\''$striplib'\''; then
        eval '\''$striplib \$dldir/$dlname'\'' || exit \$?;
      fi'
    postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
      dlpath=$dir/\$dldll~
       $RM \$dlpath'
    shlibpath_overrides_runpath=yes
    case $host_os in
    cygwin*)
      # Cygwin DLLs use 'cyg' prefix rather than 'lib'
      soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
      sys_lib_search_path_spec="$sys_lib_search_path_spec /usr/lib/w32api"
    mingw* | cegcc*)
      # MinGW DLLs use traditional 'lib' prefix
      soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
    pw32*)
      # pw32 DLLs use 'pw' prefix rather than 'lib'
      library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
    dynamic_linker='Win32 ld.exe'
  *,cl*)
    # Native MSVC
    libname_spec='$name'
    library_names_spec='${libname}.dll.lib'
    case $build_os in
    mingw*)
      lt_save_ifs=$IFS
      IFS=';'
      for lt_path in $LIB
      do
        IFS=$lt_save_ifs
        # Let DOS variable expansion print the short 8.3 style file name.
        lt_path=`cd "$lt_path" 2>/dev/null && cmd //C "for %i in (".") do @echo %~si"`
        sys_lib_search_path_spec="$sys_lib_search_path_spec $lt_path"
      IFS=$lt_save_ifs
      # Convert to MSYS style.
      sys_lib_search_path_spec=`$ECHO "$sys_lib_search_path_spec" | sed -e 's|\\\\|/|g' -e 's| \\([a-zA-Z]\\):| /\\1|g' -e 's|^ ||'`
    cygwin*)
      # Convert to unix form, then to dos form, then back to unix form
      # but this time dos style (no spaces!) so that the unix form looks
      # like /cygdrive/c/PROGRA~1:/cygdr...
      sys_lib_search_path_spec=`cygpath --path --unix "$LIB"`
      sys_lib_search_path_spec=`cygpath --path --dos "$sys_lib_search_path_spec" 2>/dev/null`
      sys_lib_search_path_spec=`cygpath --path --unix "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
      sys_lib_search_path_spec="$LIB"
      if $ECHO "$sys_lib_search_path_spec" | $GREP ';[c-zC-Z]:/' >/dev/null; then
        # It is most probably a Windows format PATH.
        sys_lib_search_path_spec=`$ECHO "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
        sys_lib_search_path_spec=`$ECHO "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
      # FIXME: find the short name or the path components, as spaces are
      # common. (e.g. "Program Files" -> "PROGRA~1")
      $install_prog $dir/$dlname \$dldir/$dlname'
       $RM \$dlpath'
    dynamic_linker='Win32 link.exe'
    library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
  # FIXME: first we should search . and the directory the executable is in
  shlibpath_var=PATH
  dynamic_linker="$host_os dyld"
  version_type=darwin
  need_lib_prefix=no
  need_version=no
  library_names_spec='${libname}${release}${major}$shared_ext ${libname}$shared_ext'
  soname_spec='${libname}${release}${major}$shared_ext'
  shlibpath_var=DYLD_LIBRARY_PATH
  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
  sys_lib_search_path_spec="$sys_lib_search_path_spec /usr/local/lib"
  sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
dgux*)
  need_lib_prefix=no
  need_version=no
  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
  # DragonFly does not have aout.  When/if they implement a new
  # versioning mechanism, adjust this.
  if test -x /usr/bin/objformat; then
    objformat=`/usr/bin/objformat`
    case $host_os in
    freebsd[23].*) objformat=aout ;;
    *) objformat=elf ;;
  version_type=freebsd-$objformat
  case $version_type in
    freebsd-elf*)
      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
      need_version=no
      need_lib_prefix=no
    freebsd-*)
      library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
      need_version=yes
  case $host_os in
  freebsd2.*)
  freebsd3.[01]* | freebsdelf3.[01]*)
  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
    shlibpath_overrides_runpath=no
  *) # from 4.6 on, and DragonFly
haiku*)
  need_lib_prefix=no
  need_version=no
  dynamic_linker="$host_os runtime_loader"
  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
  sys_lib_dlsearch_path_spec='/boot/home/config/lib /boot/common/lib /boot/system/lib'
  # Give a soname corresponding to the major version so that dld.sl refuses to
  # link against other versions.
  version_type=sunos
  need_lib_prefix=no
  need_version=no
  case $host_cpu in
  ia64*)
    shrext_cmds='.so'
    dynamic_linker="$host_os dld.so"
    shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
    if test "X$HPUX_IA64_MODE" = X32; then
      sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
      sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
    sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
  hppa*64*)
    shrext_cmds='.sl'
    dynamic_linker="$host_os dld.sl"
    shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
    sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
    shrext_cmds='.sl'
    shlibpath_var=SHLIB_PATH
    shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
  # HP-UX runs *really* slowly unless shared libraries are mode 555, ...
  postinstall_cmds='chmod 555 $lib'
  # or fails outright, so override atomically:
  install_override_mode=555
interix[3-9]*)
  need_lib_prefix=no
  need_version=no
  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
  case $host_os in
    nonstopux*) version_type=nonstopux ;;
	if test "$lt_cv_prog_gnu_ld" = yes; then
		version_type=irix
	fi ;;
  need_lib_prefix=no
  need_version=no
  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
  case $host_os in
  irix5* | nonstopux*)
    libsuff= shlibsuff=
    case $LD in # libtool.m4 will add one of these switches to LD
    *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
      libsuff= shlibsuff= libmagic=32-bit;;
    *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
      libsuff=32 shlibsuff=N32 libmagic=N32;;
    *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
      libsuff=64 shlibsuff=64 libmagic=64-bit;;
    *) libsuff= shlibsuff= libmagic=never-match;;
  shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
  sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
  sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
# No shared lib support for Linux oldld, aout, or coff.
linux*oldld* | linux*aout* | linux*coff*)
  dynamic_linker=no
# This must be glibc/ELF.
linux* | k*bsd*-gnu | kopensolaris*-gnu | gnu*)
  need_lib_prefix=no
  need_version=no
  finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
  # Some binutils ld are patched to set DT_RUNPATH
  if ${lt_cv_shlibpath_overrides_runpath+:} false; then :
  $as_echo_n "(cached) " >&6
  lt_cv_shlibpath_overrides_runpath=no
    save_LDFLAGS=$LDFLAGS
    save_libdir=$libdir
    eval "libdir=/foo; wl=\"$lt_prog_compiler_wl\"; \
	 LDFLAGS=\"\$LDFLAGS $hardcode_libdir_flag_spec\""
int
main ()
_ACEOF
  if  ($OBJDUMP -p conftest$ac_exeext) 2>/dev/null | grep "RUNPATH.*$libdir" >/dev/null; then :
  lt_cv_shlibpath_overrides_runpath=yes
    LDFLAGS=$save_LDFLAGS
    libdir=$save_libdir
  shlibpath_overrides_runpath=$lt_cv_shlibpath_overrides_runpath
  # This implies no fast_install, which is unacceptable.
  # Some rework will be needed to allow for fast_install
  # before this can be enabled.
  # Append ld.so.conf contents to the search path
  if test -f /etc/ld.so.conf; then
    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s 2>/dev/null", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;/^[	 ]*hwcap[	 ]/d;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;s/"//g;/^$/d' | tr '\n' ' '`
    sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
  # We used to test for /lib/ld.so.1 and disable shared libraries on
  # powerpc, because MkLinux only supported shared libraries with the
  # GNU dynamic linker.  Since this was broken with cross compilers,
  # most powerpc-linux boxes support dynamic linking these days and
  # people can always --disable-shared, the test was removed, and we
  # assume the GNU/Linux dynamic linker is in use.
  dynamic_linker='GNU/Linux ld.so'
netbsdelf*-gnu)
  version_type=linux
  need_lib_prefix=no
  need_version=no
  dynamic_linker='NetBSD ld.elf_so'
netbsd*)
  version_type=sunos
  need_lib_prefix=no
  need_version=no
    library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
    finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
    dynamic_linker='NetBSD (a.out) ld.so'
newsos6)
*nto* | *qnx*)
  version_type=qnx
  need_lib_prefix=no
  need_version=no
  dynamic_linker='ldqnx.so'
openbsd*)
  version_type=sunos
  sys_lib_dlsearch_path_spec="/usr/lib"
  need_lib_prefix=no
  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
  case $host_os in
    openbsd3.3 | openbsd3.3.*)	need_version=yes ;;
    *)				need_version=no  ;;
    case $host_os in
      openbsd2.[89] | openbsd2.[89].*)
os2*)
  shrext_cmds=".dll"
  need_lib_prefix=no
  library_names_spec='$libname${shared_ext} $libname.a'
  dynamic_linker='OS/2 ld.exe'
  version_type=osf
  need_lib_prefix=no
  need_version=no
  sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
  sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
rdos*)
  dynamic_linker=no
solaris*)
  need_lib_prefix=no
  need_version=no
  # ldd complains unless libraries are executable
  postinstall_cmds='chmod +x $lib'
sunos4*)
  version_type=sunos
  finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
    need_lib_prefix=no
  need_version=yes
sysv4 | sysv4.3*)
    sni)
      need_lib_prefix=no
    siemens)
      need_lib_prefix=no
    motorola)
      need_lib_prefix=no
      need_version=no
      sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
sysv4*MP*)
    library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
    soname_spec='$libname${shared_ext}.$major'
sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
  version_type=freebsd-elf
  need_lib_prefix=no
  need_version=no
    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
    case $host_os in
      sco3.2v5*)
        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
  sys_lib_dlsearch_path_spec='/usr/lib'
tpf*)
  # TPF is a cross-target only.  Preferred cross-host = GNU/Linux.
  need_lib_prefix=no
  need_version=no
uts4*)
  dynamic_linker=no
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $dynamic_linker" >&5
$as_echo "$dynamic_linker" >&6; }
test "$dynamic_linker" = no && can_build_shared=no
variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
if test "$GCC" = yes; then
  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
if test "${lt_cv_sys_lib_search_path_spec+set}" = set; then
  sys_lib_search_path_spec="$lt_cv_sys_lib_search_path_spec"
if test "${lt_cv_sys_lib_dlsearch_path_spec+set}" = set; then
  sys_lib_dlsearch_path_spec="$lt_cv_sys_lib_dlsearch_path_spec"
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking how to hardcode library paths into programs" >&5
$as_echo_n "checking how to hardcode library paths into programs... " >&6; }
hardcode_action=
if test -n "$hardcode_libdir_flag_spec" ||
   test -n "$runpath_var" ||
   test "X$hardcode_automatic" = "Xyes" ; then
  # We can hardcode non-existent directories.
  if test "$hardcode_direct" != no &&
     # If the only mechanism to avoid hardcoding is shlibpath_var, we
     # have to relink, otherwise we might link with an installed library
     # when we should be linking with a yet-to-be-installed one
     ## test "$_LT_TAGVAR(hardcode_shlibpath_var, )" != no &&
     test "$hardcode_minus_L" != no; then
    # Linking always hardcodes the temporary library directory.
    hardcode_action=relink
    # We can link without hardcoding, and we can hardcode nonexisting dirs.
    hardcode_action=immediate
  # We cannot hardcode anything, or else we can only hardcode existing
  # directories.
  hardcode_action=unsupported
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $hardcode_action" >&5
$as_echo "$hardcode_action" >&6; }
if test "$hardcode_action" = relink ||
   test "$inherit_rpath" = yes; then
  # Fast installation is not supported
  enable_fast_install=no
elif test "$shlibpath_overrides_runpath" = yes ||
     test "$enable_shared" = no; then
  # Fast installation is not necessary
  enable_fast_install=needless
  if test "x$enable_dlopen" != xyes; then
  enable_dlopen=unknown
  enable_dlopen_self=unknown
  enable_dlopen_self_static=unknown
  lt_cv_dlopen=no
  lt_cv_dlopen_libs=
  case $host_os in
  beos*)
    lt_cv_dlopen="load_add_on"
    lt_cv_dlopen_libs=
    lt_cv_dlopen_self=yes
    lt_cv_dlopen="LoadLibrary"
    lt_cv_dlopen_libs=
  cygwin*)
    lt_cv_dlopen="dlopen"
    lt_cv_dlopen_libs=
  darwin*)
  # if libdl is installed we need to link against it
    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for dlopen in -ldl" >&5
$as_echo_n "checking for dlopen in -ldl... " >&6; }
if ${ac_cv_lib_dl_dlopen+:} false; then :
  ac_check_lib_save_LIBS=$LIBS
LIBS="-ldl  $LIBS"
/* Override any GCC internal prototype to avoid an error.
   Use char because int might match the return type of a GCC
   builtin and then its argument prototype would still apply.  */
extern "C"
char dlopen ();
int
main ()
return dlopen ();
_ACEOF
  ac_cv_lib_dl_dlopen=yes
  ac_cv_lib_dl_dlopen=no
LIBS=$ac_check_lib_save_LIBS
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_dl_dlopen" >&5
$as_echo "$ac_cv_lib_dl_dlopen" >&6; }
if test "x$ac_cv_lib_dl_dlopen" = xyes; then :
  lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
    lt_cv_dlopen="dyld"
    lt_cv_dlopen_libs=
    ac_fn_c_check_func "$LINENO" "shl_load" "ac_cv_func_shl_load"
if test "x$ac_cv_func_shl_load" = xyes; then :
  lt_cv_dlopen="shl_load"
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for shl_load in -ldld" >&5
$as_echo_n "checking for shl_load in -ldld... " >&6; }
if ${ac_cv_lib_dld_shl_load+:} false; then :
LIBS="-ldld  $LIBS"
extern "C"
char shl_load ();
int
main ()
return shl_load ();
_ACEOF
  ac_cv_lib_dld_shl_load=yes
  ac_cv_lib_dld_shl_load=no
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_dld_shl_load" >&5
$as_echo "$ac_cv_lib_dld_shl_load" >&6; }
if test "x$ac_cv_lib_dld_shl_load" = xyes; then :
  lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-ldld"
  ac_fn_c_check_func "$LINENO" "dlopen" "ac_cv_func_dlopen"
if test "x$ac_cv_func_dlopen" = xyes; then :
LIBS="-ldl  $LIBS"
extern "C"
char dlopen ();
int
main ()
return dlopen ();
_ACEOF
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for dlopen in -lsvld" >&5
$as_echo_n "checking for dlopen in -lsvld... " >&6; }
if ${ac_cv_lib_svld_dlopen+:} false; then :
LIBS="-lsvld  $LIBS"
extern "C"
char dlopen ();
int
main ()
return dlopen ();
_ACEOF
  ac_cv_lib_svld_dlopen=yes
  ac_cv_lib_svld_dlopen=no
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_svld_dlopen" >&5
$as_echo "$ac_cv_lib_svld_dlopen" >&6; }
if test "x$ac_cv_lib_svld_dlopen" = xyes; then :
  lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for dld_link in -ldld" >&5
$as_echo_n "checking for dld_link in -ldld... " >&6; }
if ${ac_cv_lib_dld_dld_link+:} false; then :
LIBS="-ldld  $LIBS"
extern "C"
char dld_link ();
int
main ()
return dld_link ();
_ACEOF
  ac_cv_lib_dld_dld_link=yes
  ac_cv_lib_dld_dld_link=no
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_dld_dld_link" >&5
$as_echo "$ac_cv_lib_dld_dld_link" >&6; }
if test "x$ac_cv_lib_dld_dld_link" = xyes; then :
  lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-ldld"
  if test "x$lt_cv_dlopen" != xno; then
    enable_dlopen=yes
    enable_dlopen=no
  case $lt_cv_dlopen in
  dlopen)
    save_CPPFLAGS="$CPPFLAGS"
    test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
    wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
    save_LIBS="$LIBS"
    LIBS="$lt_cv_dlopen_libs $LIBS"
    { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether a program can dlopen itself" >&5
$as_echo_n "checking whether a program can dlopen itself... " >&6; }
if ${lt_cv_dlopen_self+:} false; then :
  	  if test "$cross_compiling" = yes; then :
  lt_cv_dlopen_self=cross
  lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
  lt_status=$lt_dlunknown
  cat > conftest.$ac_ext <<_LT_EOF
#line $LINENO "configure"
#include "confdefs.h"
#if HAVE_DLFCN_H
#include <dlfcn.h>
#ifdef RTLD_GLOBAL
#  define LT_DLGLOBAL		RTLD_GLOBAL
#  ifdef DL_GLOBAL
#    define LT_DLGLOBAL		DL_GLOBAL
#  else
#    define LT_DLGLOBAL		0
#  endif
/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
   find out it does not work in some platform. */
#ifndef LT_DLLAZY_OR_NOW
#  ifdef RTLD_LAZY
#    define LT_DLLAZY_OR_NOW		RTLD_LAZY
#  else
#    ifdef DL_LAZY
#      define LT_DLLAZY_OR_NOW		DL_LAZY
#    else
#      ifdef RTLD_NOW
#        define LT_DLLAZY_OR_NOW	RTLD_NOW
#      else
#        ifdef DL_NOW
#          define LT_DLLAZY_OR_NOW	DL_NOW
#        else
#          define LT_DLLAZY_OR_NOW	0
#        endif
#      endif
#    endif
#  endif
/* When -fvisbility=hidden is used, assume the code has been annotated
   correspondingly for the symbols needed.  */
#if defined(__GNUC__) && (((__GNUC__ == 3) && (__GNUC_MINOR__ >= 3)) || (__GNUC__ > 3))
int fnord () __attribute__((visibility("default")));
int fnord () { return 42; }
int main ()
  void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
  int status = $lt_dlunknown;
  if (self)
      if (dlsym (self,"fnord"))       status = $lt_dlno_uscore;
	  if (dlsym( self,"_fnord"))  status = $lt_dlneed_uscore;
          else puts (dlerror ());
      /* dlclose (self); */
    puts (dlerror ());
  return status;
_LT_EOF
  if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_link\""; } >&5
  (eval $ac_link) 2>&5
  ac_status=$?
  test $ac_status = 0; } && test -s conftest${ac_exeext} 2>/dev/null; then
    (./conftest; exit; ) >&5 2>/dev/null
    lt_status=$?
    case x$lt_status in
      x$lt_dlno_uscore) lt_cv_dlopen_self=yes ;;
      x$lt_dlneed_uscore) lt_cv_dlopen_self=yes ;;
      x$lt_dlunknown|x*) lt_cv_dlopen_self=no ;;
  else :
    # compilation failed
rm -fr conftest*
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_dlopen_self" >&5
$as_echo "$lt_cv_dlopen_self" >&6; }
    if test "x$lt_cv_dlopen_self" = xyes; then
      wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $lt_prog_compiler_static\"
      { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether a statically linked program can dlopen itself" >&5
$as_echo_n "checking whether a statically linked program can dlopen itself... " >&6; }
if ${lt_cv_dlopen_self_static+:} false; then :
  lt_cv_dlopen_self_static=cross
#if HAVE_DLFCN_H
#include <dlfcn.h>
#ifdef RTLD_GLOBAL
#  ifdef DL_GLOBAL
#  else
#  endif
#  ifdef RTLD_LAZY
#  else
#    ifdef DL_LAZY
#    else
#      ifdef RTLD_NOW
#      else
#        ifdef DL_NOW
#        else
#        endif
#      endif
#    endif
#  endif
int main ()
  if (self)
    puts (dlerror ());
  return status;
_LT_EOF
  ac_status=$?
    lt_status=$?
    case x$lt_status in
      x$lt_dlno_uscore) lt_cv_dlopen_self_static=yes ;;
      x$lt_dlneed_uscore) lt_cv_dlopen_self_static=yes ;;
      x$lt_dlunknown|x*) lt_cv_dlopen_self_static=no ;;
  else :
rm -fr conftest*
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_dlopen_self_static" >&5
$as_echo "$lt_cv_dlopen_self_static" >&6; }
    CPPFLAGS="$save_CPPFLAGS"
    LDFLAGS="$save_LDFLAGS"
    LIBS="$save_LIBS"
  case $lt_cv_dlopen_self in
  yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
  *) enable_dlopen_self=unknown ;;
  case $lt_cv_dlopen_self_static in
  yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
  *) enable_dlopen_self_static=unknown ;;
striplib=
old_striplib=
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether stripping libraries is possible" >&5
$as_echo_n "checking whether stripping libraries is possible... " >&6; }
if test -n "$STRIP" && $STRIP -V 2>&1 | $GREP "GNU strip" >/dev/null; then
  test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
  test -z "$striplib" && striplib="$STRIP --strip-unneeded"
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
$as_echo "yes" >&6; }
# FIXME - insert some real tests, host_os isn't really good enough
  case $host_os in
  darwin*)
    if test -n "$STRIP" ; then
      striplib="$STRIP -x"
      old_striplib="$STRIP -S"
      { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
$as_echo "no" >&6; }
  # Report which library types will actually be built
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking if libtool supports shared libraries" >&5
$as_echo_n "checking if libtool supports shared libraries... " >&6; }
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $can_build_shared" >&5
$as_echo "$can_build_shared" >&6; }
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether to build shared libraries" >&5
$as_echo_n "checking whether to build shared libraries... " >&6; }
  test "$can_build_shared" = "no" && enable_shared=no
  # On AIX, shared libraries and static libraries use the same namespace, and
  # are all built from PIC.
  case $host_os in
  aix3*)
    test "$enable_shared" = yes && enable_static=no
    if test -n "$RANLIB"; then
      archive_cmds="$archive_cmds~\$RANLIB \$lib"
      postinstall_cmds='$RANLIB $lib'
  aix[4-9]*)
    if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $enable_shared" >&5
$as_echo "$enable_shared" >&6; }
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether to build static libraries" >&5
$as_echo_n "checking whether to build static libraries... " >&6; }
  # Make sure either enable_shared or enable_static is yes.
  test "$enable_shared" = yes || enable_static=yes
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $enable_static" >&5
$as_echo "$enable_static" >&6; }
ac_ext=c
ac_cpp='$CPP $CPPFLAGS'
ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
ac_compiler_gnu=$ac_cv_c_compiler_gnu
CC="$lt_save_CC"
      if test -n "$CXX" && ( test "X$CXX" != "Xno" &&
    ( (test "X$CXX" = "Xg++" && `g++ -v >/dev/null 2>&1` ) ||
    (test "X$CXX" != "Xg++"))) ; then
  ac_ext=cpp
ac_cpp='$CXXCPP $CPPFLAGS'
ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to run the C++ preprocessor" >&5
$as_echo_n "checking how to run the C++ preprocessor... " >&6; }
if test -z "$CXXCPP"; then
  if ${ac_cv_prog_CXXCPP+:} false; then :
      # Double quotes because CXXCPP needs to be expanded
    for CXXCPP in "$CXX -E" "/lib/cpp"
    do
      ac_preproc_ok=false
for ac_cxx_preproc_warn_flag in '' yes
do
  # Use a header file that comes with gcc, so configuring glibc
  # with a fresh cross-compiler works.
  # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
  # <limits.h> exists even on freestanding compilers.
  # On the NeXT, cc -E runs the code through the compiler's parser,
  # not just through cpp. "Syntax error" is here to catch this case.
#ifdef __STDC__
# include <limits.h>
# include <assert.h>
		     Syntax error
_ACEOF
if ac_fn_cxx_try_cpp "$LINENO"; then :
  # Broken: fails on valid input.
continue
rm -f conftest.err conftest.i conftest.$ac_ext
  # OK, works on sane cases.  Now check whether nonexistent headers
  # can be detected and how.
#include <ac_nonexistent.h>
_ACEOF
  # Broken: success on invalid input.
continue
  # Passes both tests.
ac_preproc_ok=:
break
# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
rm -f conftest.i conftest.err conftest.$ac_ext
if $ac_preproc_ok; then :
  break
    ac_cv_prog_CXXCPP=$CXXCPP
  CXXCPP=$ac_cv_prog_CXXCPP
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $CXXCPP" >&5
$as_echo "$CXXCPP" >&6; }
ac_preproc_ok=false
do
#ifdef __STDC__
		     Syntax error
_ACEOF
continue
_ACEOF
continue
ac_preproc_ok=:
break
  { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
as_fn_error $? "C++ preprocessor \"$CXXCPP\" fails sanity check
See \`config.log' for more details" "$LINENO" 5; }
ac_ext=c
  _lt_caught_CXX_error=yes
ac_ext=cpp
archive_cmds_need_lc_CXX=no
allow_undefined_flag_CXX=
always_export_symbols_CXX=no
archive_expsym_cmds_CXX=
compiler_needs_object_CXX=no
export_dynamic_flag_spec_CXX=
hardcode_direct_CXX=no
hardcode_direct_absolute_CXX=no
hardcode_libdir_flag_spec_CXX=
hardcode_libdir_separator_CXX=
hardcode_minus_L_CXX=no
hardcode_shlibpath_var_CXX=unsupported
hardcode_automatic_CXX=no
inherit_rpath_CXX=no
module_cmds_CXX=
module_expsym_cmds_CXX=
link_all_deplibs_CXX=unknown
old_archive_cmds_CXX=$old_archive_cmds
reload_flag_CXX=$reload_flag
reload_cmds_CXX=$reload_cmds
no_undefined_flag_CXX=
whole_archive_flag_spec_CXX=
enable_shared_with_static_runtimes_CXX=no
# Source file extension for C++ test sources.
ac_ext=cpp
# Object file extension for compiled C++ test sources.
objext=o
objext_CXX=$objext
# No sense in running all these tests if we already determined that
# the CXX compiler isn't working.  Some variables (like enable_shared)
# are currently assumed to apply to all compilers on this platform,
# and will be corrupted by setting them based on a non-working compiler.
if test "$_lt_caught_CXX_error" != yes; then
  # Code to be used in simple compile tests
  lt_simple_compile_test_code="int some_variable = 0;"
  # Code to be used in simple link tests
  lt_simple_link_test_code='int main(int, char *[]) { return(0); }'
  # ltmain only uses $CC for tagged configurations so make sure $CC is set.
# If no C compiler was specified, use CC.
LTCC=${LTCC-"$CC"}
# If no C compiler flags were specified, use CFLAGS.
LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
# Allow CC to be a program name with arguments.
compiler=$CC
  # save warnings/boilerplate of simple test code
  ac_outfile=conftest.$ac_objext
echo "$lt_simple_compile_test_code" >conftest.$ac_ext
eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
_lt_compiler_boilerplate=`cat conftest.err`
$RM conftest*
echo "$lt_simple_link_test_code" >conftest.$ac_ext
eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
_lt_linker_boilerplate=`cat conftest.err`
$RM -r conftest*
  lt_save_CC=$CC
  lt_save_CFLAGS=$CFLAGS
  lt_save_LD=$LD
  lt_save_GCC=$GCC
  GCC=$GXX
  lt_save_with_gnu_ld=$with_gnu_ld
  lt_save_path_LD=$lt_cv_path_LD
  if test -n "${lt_cv_prog_gnu_ldcxx+set}"; then
    lt_cv_prog_gnu_ld=$lt_cv_prog_gnu_ldcxx
    $as_unset lt_cv_prog_gnu_ld
  if test -n "${lt_cv_path_LDCXX+set}"; then
    lt_cv_path_LD=$lt_cv_path_LDCXX
    $as_unset lt_cv_path_LD
  test -z "${LDCXX+set}" || LD=$LDCXX
  CC=${CXX-"c++"}
  CFLAGS=$CXXFLAGS
  compiler=$CC
  compiler_CXX=$CC
  for cc_temp in $compiler""; do
  case $cc_temp in
    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
    *) break;;
cc_basename=`$ECHO "$cc_temp" | $SED "s%.*/%%; s%^$host_alias-%%"`
  if test -n "$compiler"; then
    # We don't want -fno-exception when compiling C++ code, so set the
    # no_builtin_flag separately
    if test "$GXX" = yes; then
      lt_prog_compiler_no_builtin_flag_CXX=' -fno-builtin'
      # Set up default GNU C++ configuration
# Check whether --with-gnu-ld was given.
if test "${with_gnu_ld+set}" = set; then :
  withval=$with_gnu_ld; test "$withval" = no || with_gnu_ld=yes
  with_gnu_ld=no
ac_prog=ld
  # Check if gcc -print-prog-name=ld gives a path.
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for ld used by $CC" >&5
$as_echo_n "checking for ld used by $CC... " >&6; }
  case $host in
  *-*-mingw*)
    # gcc leaves a trailing carriage return which upsets mingw
    ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
    ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
  case $ac_prog in
    # Accept absolute paths.
      re_direlt='/[^/][^/]*/\.\./'
      # Canonicalize the pathname of ld
      ac_prog=`$ECHO "$ac_prog"| $SED 's%\\\\%/%g'`
      while $ECHO "$ac_prog" | $GREP "$re_direlt" > /dev/null 2>&1; do
	ac_prog=`$ECHO $ac_prog| $SED "s%$re_direlt%/%"`
      test -z "$LD" && LD="$ac_prog"
    # If it fails, then pretend we aren't using GCC.
    ac_prog=ld
    # If it is relative, then search for the first ld in PATH.
    with_gnu_ld=unknown
elif test "$with_gnu_ld" = yes; then
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for GNU ld" >&5
$as_echo_n "checking for GNU ld... " >&6; }
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking for non-GNU ld" >&5
$as_echo_n "checking for non-GNU ld... " >&6; }
if ${lt_cv_path_LD+:} false; then :
  if test -z "$LD"; then
  lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
  for ac_dir in $PATH; do
    IFS="$lt_save_ifs"
    test -z "$ac_dir" && ac_dir=.
    if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
      lt_cv_path_LD="$ac_dir/$ac_prog"
      # Check to see if the program is GNU ld.  I'd rather use --version,
      # but apparently some variants of GNU ld only accept -v.
      # Break only if it was the GNU/non-GNU ld that we prefer.
      case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
      *GNU* | *'with BFD'*)
	test "$with_gnu_ld" != no && break
	test "$with_gnu_ld" != yes && break
  IFS="$lt_save_ifs"
  lt_cv_path_LD="$LD" # Let the user override the test with a path.
LD="$lt_cv_path_LD"
if test -n "$LD"; then
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $LD" >&5
$as_echo "$LD" >&6; }
test -z "$LD" && as_fn_error $? "no acceptable ld found in \$PATH" "$LINENO" 5
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if the linker ($LD) is GNU ld" >&5
$as_echo_n "checking if the linker ($LD) is GNU ld... " >&6; }
if ${lt_cv_prog_gnu_ld+:} false; then :
  # I'd rather use --version here, but apparently some GNU lds only accept -v.
case `$LD -v 2>&1 </dev/null` in
  lt_cv_prog_gnu_ld=yes
  lt_cv_prog_gnu_ld=no
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_gnu_ld" >&5
$as_echo "$lt_cv_prog_gnu_ld" >&6; }
with_gnu_ld=$lt_cv_prog_gnu_ld
      # Check if GNU C++ uses GNU ld as the underlying linker, since the
      # archiving commands below assume that GNU ld is being used.
        archive_cmds_CXX='$CC $pic_flag -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
        archive_expsym_cmds_CXX='$CC $pic_flag -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
        hardcode_libdir_flag_spec_CXX='${wl}-rpath ${wl}$libdir'
        export_dynamic_flag_spec_CXX='${wl}--export-dynamic'
        # If archive_cmds runs LD, not CC, wlarc should be empty
        # XXX I think wlarc can be eliminated in ltcf-cxx, but I need to
        #     investigate it a little bit more. (MM)
        wlarc='${wl}'
        # ancient GNU ld didn't support --whole-archive et. al.
        if eval "`$CC -print-prog-name=ld` --help 2>&1" |
	  $GREP 'no-whole-archive' > /dev/null; then
          whole_archive_flag_spec_CXX="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
        with_gnu_ld=no
        wlarc=
        # A generic and very simple default shared library creation
        # command for GNU C++ for the case where it uses the native
        # linker, instead of GNU ld.  If possible, this setting should
        # overridden to take advantage of the native linker features on
        # the platform it is being used on.
        archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
      # Commands to make compiler produce verbose output that lists
      # what "hidden" libraries, object files and flags are used when
      # linking a shared library.
      output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | $GREP -v "^Configured with:" | $GREP "\-L"'
      GXX=no
      with_gnu_ld=no
      wlarc=
    # PORTME: fill in a description of your system's C++ link characteristics
    { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the $compiler linker ($LD) supports shared libraries" >&5
$as_echo_n "checking whether the $compiler linker ($LD) supports shared libraries... " >&6; }
    ld_shlibs_CXX=yes
    case $host_os in
      aix3*)
        # FIXME: insert proper C++ library support
        ld_shlibs_CXX=no
      aix[4-9]*)
          # On IA64, the linker does run time linking by default, so we don't
          # have to do anything special.
          aix_use_runtimelinking=no
          exp_sym_flag='-Bexport'
          no_entry_flag=""
	      case $ld_flag in
	      *-brtl*)
	        break
        archive_cmds_CXX=''
        hardcode_direct_CXX=yes
        hardcode_direct_absolute_CXX=yes
        hardcode_libdir_separator_CXX=':'
        link_all_deplibs_CXX=yes
        file_list_spec_CXX='${wl}-f,'
	  then
	    hardcode_direct_CXX=unsupported
	    hardcode_minus_L_CXX=yes
	    hardcode_libdir_flag_spec_CXX='-L$libdir'
          # not using gcc
	  shared_flag='-G'
        export_dynamic_flag_spec_CXX='${wl}-bexpall'
	# export.
        always_export_symbols_CXX=yes
          allow_undefined_flag_CXX='-berok'
          # Determine the default libpath from the value encoded in an empty
          # executable.
  if ${lt_cv_aix_libpath__CXX+:} false; then :
int
main ()
_ACEOF
if ac_fn_cxx_try_link "$LINENO"; then :
	  /^0/ {
	      p
  lt_cv_aix_libpath__CXX=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e "$lt_aix_libpath_sed"`
  if test -z "$lt_cv_aix_libpath__CXX"; then
    lt_cv_aix_libpath__CXX=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e "$lt_aix_libpath_sed"`
    lt_cv_aix_libpath__CXX="/usr/lib:/lib"
  aix_libpath=$lt_cv_aix_libpath__CXX
          hardcode_libdir_flag_spec_CXX='${wl}-blibpath:$libdir:'"$aix_libpath"
          archive_expsym_cmds_CXX='$CC -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then func_echo_all "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
	    hardcode_libdir_flag_spec_CXX='${wl}-R $libdir:/usr/lib:/lib'
	    allow_undefined_flag_CXX="-z nodefs"
	    archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
	    # empty executable.
int
main ()
_ACEOF
	  /^0/ {
	      p
	    no_undefined_flag_CXX=' ${wl}-bernotok'
	    allow_undefined_flag_CXX=' ${wl}-berok'
	      whole_archive_flag_spec_CXX='${wl}--whole-archive$convenience ${wl}--no-whole-archive'
	      whole_archive_flag_spec_CXX='$convenience'
	    archive_cmds_need_lc_CXX=yes
	    # libraries.
	    archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
      beos*)
	if $LD --help 2>&1 | $GREP ': supported targets:.* elf' > /dev/null; then
	  allow_undefined_flag_CXX=unsupported
	  # Joseph Beckenbach <jrb3@best.com> says some releases of gcc
	  # support --undefined.  This deserves some investigation.  FIXME
	  archive_cmds_CXX='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
	  ld_shlibs_CXX=no
      chorus*)
        case $cc_basename in
	  ld_shlibs_CXX=no
      cygwin* | mingw* | pw32* | cegcc*)
	case $GXX,$cc_basename in
	,cl* | no,cl*)
	  # Native MSVC
	  hardcode_libdir_flag_spec_CXX=' '
	  file_list_spec_CXX='@'
	  libext=lib
	  shrext_cmds=".dll"
	  archive_cmds_CXX='$CC -o $output_objdir/$soname $libobjs $compiler_flags $deplibs -Wl,-dll~linknames='
	  archive_expsym_cmds_CXX='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
	      $SED -n -e 's/\\\\\\\(.*\\\\\\\)/-link\\\ -EXPORT:\\\\\\\1/' -e '1\\\!p' < $export_symbols > $output_objdir/$soname.exp;
	      $SED -e 's/\\\\\\\(.*\\\\\\\)/-link\\\ -EXPORT:\\\\\\\1/' < $export_symbols > $output_objdir/$soname.exp;
	    fi~
	    linknames='
	  # _LT_TAGVAR(old_archive_from_new_cmds, CXX)='true'
	  enable_shared_with_static_runtimes_CXX=yes
	  # Don't use ranlib
	  old_postinstall_cmds_CXX='chmod 644 $oldlib'
	  postlink_cmds_CXX='lt_outputfile="@OUTPUT@"~
	      *.exe|*.EXE) ;;
	    esac~
	    func_to_tool_file "$lt_outputfile"~
	    fi'
	  # g++
	  # _LT_TAGVAR(hardcode_libdir_flag_spec, CXX) is actually meaningless,
	  # as there is no search path for DLLs.
	  export_dynamic_flag_spec_CXX='${wl}--export-all-symbols'
	  if $LD --help 2>&1 | $GREP 'auto-import' > /dev/null; then
	    archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
	    # If the export-symbols file already is a .def file (1st line
	    # is EXPORTS), use it as is; otherwise, prepend...
	      cp $export_symbols $output_objdir/$soname.def;
	      echo EXPORTS > $output_objdir/$soname.def;
	      cat $export_symbols >> $output_objdir/$soname.def;
	    fi~
	    $CC -shared -nostdlib $output_objdir/$soname.def $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
	    ld_shlibs_CXX=no
  hardcode_automatic_CXX=yes
    whole_archive_flag_spec_CXX='`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience ${wl}-force_load,$conv\"; done; func_echo_all \"$new_convenience\"`'
    whole_archive_flag_spec_CXX=''
  allow_undefined_flag_CXX="$_lt_dar_allow_undefined"
    archive_cmds_CXX="\$CC -dynamiclib \$allow_undefined_flag -o \$lib \$libobjs \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring $_lt_dar_single_mod${_lt_dsymutil}"
    module_cmds_CXX="\$CC \$allow_undefined_flag -o \$lib -bundle \$libobjs \$deplibs \$compiler_flags${_lt_dsymutil}"
    archive_expsym_cmds_CXX="sed 's,^,_,' < \$export_symbols > \$output_objdir/\${libname}-symbols.expsym~\$CC -dynamiclib \$allow_undefined_flag -o \$lib \$libobjs \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring ${_lt_dar_single_mod}${_lt_dar_export_syms}${_lt_dsymutil}"
    module_expsym_cmds_CXX="sed -e 's,^,_,' < \$export_symbols > \$output_objdir/\${libname}-symbols.expsym~\$CC \$allow_undefined_flag -o \$lib -bundle \$libobjs \$deplibs \$compiler_flags${_lt_dar_export_syms}${_lt_dsymutil}"
       if test "$lt_cv_apple_cc_single_mod" != "yes"; then
      archive_cmds_CXX="\$CC -r -keep_private_externs -nostdlib -o \${lib}-master.o \$libobjs~\$CC -dynamiclib \$allow_undefined_flag -o \$lib \${lib}-master.o \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring${_lt_dsymutil}"
      archive_expsym_cmds_CXX="sed 's,^,_,' < \$export_symbols > \$output_objdir/\${libname}-symbols.expsym~\$CC -r -keep_private_externs -nostdlib -o \${lib}-master.o \$libobjs~\$CC -dynamiclib \$allow_undefined_flag -o \$lib \${lib}-master.o \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring${_lt_dar_export_syms}${_lt_dsymutil}"
  ld_shlibs_CXX=no
      dgux*)
          ec++*)
	    ld_shlibs_CXX=no
          ghcx*)
	    # Green Hills C++ Compiler
	    ld_shlibs_CXX=no
	    ld_shlibs_CXX=no
      freebsd2.*)
        # C++ shared libraries reported to be fairly broken before
	# switch to ELF
        ld_shlibs_CXX=no
      freebsd-elf*)
        # FreeBSD 3 and later use GNU C++ and GNU ld with standard ELF
        # conventions
        ld_shlibs_CXX=yes
      haiku*)
        archive_cmds_CXX='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
      hpux9*)
        hardcode_libdir_flag_spec_CXX='${wl}+b ${wl}$libdir'
        hardcode_libdir_separator_CXX=:
        export_dynamic_flag_spec_CXX='${wl}-E'
        hardcode_minus_L_CXX=yes # Not in the search PATH,
				             # location of the library.
          CC*)
            ld_shlibs_CXX=no
          aCC*)
            archive_cmds_CXX='$RM $output_objdir/$soname~$CC -b ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
            # There doesn't appear to be a way to prevent this compiler from
            # explicitly linking system object files so we need to strip them
            # from the output so that they don't get included in the library
            # dependencies.
            output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | $EGREP "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; func_echo_all "$list"'
              archive_cmds_CXX='$RM $output_objdir/$soname~$CC -shared -nostdlib $pic_flag ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
              ld_shlibs_CXX=no
      hpux10*|hpux11*)
        if test $with_gnu_ld = no; then
          case $host_cpu in
            hppa*64*|ia64*)
        case $host_cpu in
          hppa*64*|ia64*)
            hardcode_shlibpath_var_CXX=no
          CC*)
	    ld_shlibs_CXX=no
          aCC*)
	    case $host_cpu in
	      hppa*64*)
	        archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
	      ia64*)
	        archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
	        archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
	    # dependencies.
	    output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | $GREP "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; func_echo_all "$list"'
	        case $host_cpu in
	          hppa*64*)
	            archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
	          ia64*)
	            archive_cmds_CXX='$CC -shared -nostdlib $pic_flag ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
	            archive_cmds_CXX='$CC -shared -nostdlib $pic_flag ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
	      ld_shlibs_CXX=no
      interix[3-9]*)
	hardcode_libdir_flag_spec_CXX='${wl}-rpath,$libdir'
	# Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
	# Instead, shared libraries are loaded at an image base (0x10000000 by
	# default) and relocated if they conflict, which is a slow very memory
	# consuming and fragmenting process.  To avoid this, we pick a random,
	# 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
	# time.  Moving up from 0x10000000 also allows more sbrk(2) space.
	archive_cmds_CXX='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
	archive_expsym_cmds_CXX='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
      irix5* | irix6*)
          CC*)
	    # SGI C++
	    archive_cmds_CXX='$CC -shared -all -multigot $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
	    # Archives containing C++ object files must be created using
	    # "CC -ar", where "CC" is the IRIX C++ compiler.  This is
	    # necessary to make sure instantiated templates are included
	    # in the archive.
	    old_archive_cmds_CXX='$CC -ar -WR,-u -o $oldlib $oldobjs'
	      if test "$with_gnu_ld" = no; then
	        archive_cmds_CXX='$CC -shared $pic_flag -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
	        archive_cmds_CXX='$CC -shared $pic_flag -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` -o $lib'
        inherit_rpath_CXX=yes
          KCC*)
	    # Kuck and Associates, Inc. (KAI) C++ Compiler
	    # KCC will only create a shared library if the output file
	    # ends with ".so" (or ".sl" for HP-UX), so rename the library
	    # to its proper name (with version) after linking.
	    archive_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib; mv \$templib $lib'
	    archive_expsym_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib ${wl}-retain-symbols-file,$export_symbols; mv \$templib $lib'
	    # dependencies.
	    output_verbose_link_cmd='templist=`$CC $CFLAGS -v conftest.$objext -o libconftest$shared_ext 2>&1 | $GREP "ld"`; rm -f libconftest$shared_ext; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; func_echo_all "$list"'
	    # "CC -Bstatic", where "CC" is the KAI C++ compiler.
	    old_archive_cmds_CXX='$CC -Bstatic -o $oldlib $oldobjs'
	  icpc* | ecpc* )
	    # Intel C++
	    with_gnu_ld=yes
	    # version 8.0 and above of icpc choke on multiply defined symbols
	    # if we add $predep_objects and $postdep_objects, however 7.1 and
	    # earlier do not add the objects themselves.
	      *"Version 7."*)
	        archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
		archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
	      *)  # Version 8.0 or newer
	        tmp_idyn=
	        case $host_cpu in
		  ia64*) tmp_idyn=' -i_dynamic';;
	        archive_cmds_CXX='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
		archive_expsym_cmds_CXX='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
          pgCC* | pgcpp*)
            # Portland Group C++ compiler
	    case `$CC -V` in
	    *pgCC\ [1-5].* | *pgcpp\ [1-5].*)
	      prelink_cmds_CXX='tpldir=Template.dir~
		rm -rf $tpldir~
		$CC --prelink_objects --instantiation_dir $tpldir $objs $libobjs $compile_deplibs~
		compile_command="$compile_command `find $tpldir -name \*.o | sort | $NL2SP`"'
	      old_archive_cmds_CXX='tpldir=Template.dir~
		rm -rf $tpldir~
		$CC --prelink_objects --instantiation_dir $tpldir $oldobjs$old_deplibs~
		$AR $AR_FLAGS $oldlib$oldobjs$old_deplibs `find $tpldir -name \*.o | sort | $NL2SP`~
		$RANLIB $oldlib'
		rm -rf $tpldir~
		$CC --prelink_objects --instantiation_dir $tpldir $predep_objects $libobjs $deplibs $convenience $postdep_objects~
		$CC -shared $pic_flag $predep_objects $libobjs $deplibs `find $tpldir -name \*.o | sort | $NL2SP` $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname -o $lib'
	      archive_expsym_cmds_CXX='tpldir=Template.dir~
		rm -rf $tpldir~
		$CC -shared $pic_flag $predep_objects $libobjs $deplibs `find $tpldir -name \*.o | sort | $NL2SP` $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname ${wl}-retain-symbols-file ${wl}$export_symbols -o $lib'
	    *) # Version 6 and above use weak symbols
	      archive_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname -o $lib'
	      archive_expsym_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname ${wl}-retain-symbols-file ${wl}$export_symbols -o $lib'
	    hardcode_libdir_flag_spec_CXX='${wl}--rpath ${wl}$libdir'
	    whole_archive_flag_spec_CXX='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; func_echo_all \"$new_convenience\"` ${wl}--no-whole-archive'
	  cxx*)
	    # Compaq C++
	    archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname  -o $lib ${wl}-retain-symbols-file $wl$export_symbols'
	    runpath_var=LD_RUN_PATH
	    hardcode_libdir_flag_spec_CXX='-rpath $libdir'
	    # dependencies.
	    output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | $GREP "ld"`; templist=`func_echo_all "$templist" | $SED "s/\(^.*ld.*\)\( .*ld .*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; func_echo_all "X$list" | $Xsed'
	  xl* | mpixl* | bgxl*)
	    # IBM XL 8.0 on PPC, with GNU ld
	    archive_cmds_CXX='$CC -qmkshrobj $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
	    if test "x$supports_anon_versioning" = xyes; then
	      archive_expsym_cmds_CXX='echo "{ global:" > $output_objdir/$libname.ver~
		cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
		echo "local: *; };" >> $output_objdir/$libname.ver~
		$CC -qmkshrobj $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
	    case `$CC -V 2>&1 | sed 5q` in
	    *Sun\ C*)
	      # Sun C++ 5.9
	      no_undefined_flag_CXX=' -zdefs'
	      archive_cmds_CXX='$CC -G${allow_undefined_flag} -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
	      archive_expsym_cmds_CXX='$CC -G${allow_undefined_flag} -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-retain-symbols-file ${wl}$export_symbols'
	      hardcode_libdir_flag_spec_CXX='-R$libdir'
	      whole_archive_flag_spec_CXX='${wl}--whole-archive`new_convenience=; for conv in $convenience\"\"; do test -z \"$conv\" || new_convenience=\"$new_convenience,$conv\"; done; func_echo_all \"$new_convenience\"` ${wl}--no-whole-archive'
	      compiler_needs_object_CXX=yes
	      # Not sure whether something based on
	      # $CC $CFLAGS -v conftest.$objext -o libconftest$shared_ext 2>&1
	      # would be better.
	      output_verbose_link_cmd='func_echo_all'
	      # "CC -xar", where "CC" is the Sun C++ compiler.  This is
	      # in the archive.
	      old_archive_cmds_CXX='$CC -xar -o $oldlib $oldobjs'
      lynxos*)
	ld_shlibs_CXX=no
      m88k*)
        ld_shlibs_CXX=no
      mvs*)
          cxx*)
	    ld_shlibs_CXX=no
	    ld_shlibs_CXX=no
      netbsd*)
        if echo __ELF__ | $CC -E - | $GREP __ELF__ >/dev/null; then
	  archive_cmds_CXX='$LD -Bshareable  -o $lib $predep_objects $libobjs $deplibs $postdep_objects $linker_flags'
	  wlarc=
	# Workaround some broken pre-1.5 toolchains
	output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | $GREP conftest.$objext | $SED -e "s:-lgcc -lc -lgcc::"'
      *nto* | *qnx*)
        ld_shlibs_CXX=yes
      openbsd2*)
        # C++ shared libraries are fairly broken
	ld_shlibs_CXX=no
      openbsd*)
	if test -f /usr/libexec/ld.so; then
	  archive_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
	  if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
	    archive_expsym_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-retain-symbols-file,$export_symbols -o $lib'
	  output_verbose_link_cmd=func_echo_all
	  ld_shlibs_CXX=no
      osf3* | osf4* | osf5*)
          KCC*)
	    archive_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo "$lib" | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib; mv \$templib $lib'
	    # the KAI C++ compiler.
	    case $host in
	      osf3*) old_archive_cmds_CXX='$CC -Bstatic -o $oldlib $oldobjs' ;;
	      *) old_archive_cmds_CXX='$CC -o $oldlib $oldobjs' ;;
          RCC*)
	    # Rational C++ 2.4.1
	    ld_shlibs_CXX=no
          cxx*)
	    case $host in
	      osf3*)
	        allow_undefined_flag_CXX=' ${wl}-expect_unresolved ${wl}\*'
	        archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $soname `test -n "$verstring" && func_echo_all "${wl}-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
	        allow_undefined_flag_CXX=' -expect_unresolved \*'
	        archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
	        archive_expsym_cmds_CXX='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done~
	          echo "-hidden">> $lib.exp~
	          $CC -shared$allow_undefined_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname ${wl}-input ${wl}$lib.exp  `test -n "$verstring" && $ECHO "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib~
	          $RM $lib.exp'
	    # dependencies.
	    output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | $GREP "ld" | $GREP -v "ld:"`; templist=`func_echo_all "$templist" | $SED "s/\(^.*ld.*\)\( .*ld.*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; func_echo_all "$list"'
	    if test "$GXX" = yes && test "$with_gnu_ld" = no; then
	      case $host in
	        osf3*)
	          archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
	          archive_cmds_CXX='$CC -shared $pic_flag -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
	      ld_shlibs_CXX=no
      psos*)
        ld_shlibs_CXX=no
      sunos4*)
          CC*)
	    # Sun C++ 4.x
	    ld_shlibs_CXX=no
          lcc*)
	    # Lucid
	    ld_shlibs_CXX=no
	    ld_shlibs_CXX=no
      solaris*)
          CC* | sunCC*)
	    # Sun C++ 4.2, 5.x and Centerline C++
	    archive_expsym_cmds_CXX='echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~echo "local: *; };" >> $lib.exp~
	      $CC -G${allow_undefined_flag} ${wl}-M ${wl}$lib.exp -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$RM $lib.exp'
	    case $host_os in
	      solaris2.[0-5] | solaris2.[0-5].*) ;;
		# The compiler driver will combine and reorder linker options,
		# but understands `-z linker_flag'.
	        # Supported since Solaris 2.6 (maybe 2.5.1?)
		whole_archive_flag_spec_CXX='-z allextract$convenience -z defaultextract'
	    # in the archive.
          gcx*)
	    archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
	    # The C++ compiler must be used to create the archive.
	    old_archive_cmds_CXX='$CC $LDFLAGS -archive -o $oldlib $oldobjs'
	    # GNU C++ compiler with Solaris linker
	      no_undefined_flag_CXX=' ${wl}-z ${wl}defs'
	      if $CC --version | $GREP -v '^2\.7' > /dev/null; then
	        archive_cmds_CXX='$CC -shared $pic_flag -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
		  $CC -shared $pic_flag -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$RM $lib.exp'
	        # g++ 2.7 appears to require `-G' NOT `-shared' on this
	        # platform.
	        archive_cmds_CXX='$CC -G -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
		  $CC -G -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$RM $lib.exp'
	        output_verbose_link_cmd='$CC -G $CFLAGS -v conftest.$objext 2>&1 | $GREP -v "^Configured with:" | $GREP "\-L"'
	      hardcode_libdir_flag_spec_CXX='${wl}-R $wl$libdir'
	      case $host_os in
		  whole_archive_flag_spec_CXX='${wl}-z ${wl}allextract$convenience ${wl}-z ${wl}defaultextract'
    sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7* | sco3.2v5.0.[024]*)
      no_undefined_flag_CXX='${wl}-z,text'
      runpath_var='LD_RUN_PATH'
        CC*)
	  archive_cmds_CXX='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
	  archive_expsym_cmds_CXX='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
	  archive_cmds_CXX='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
	  archive_expsym_cmds_CXX='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
      sysv5* | sco3.2v5* | sco5v6*)
	# Note: We can NOT use -z defs as we might desire, because we do not
	# link with -lc, and that would cause any symbols used from libc to
	# always be unresolved, which means just about no library would
	# ever link correctly.  If we're not using GNU ld we use -z text
	# though, which does catch some bad symbols but isn't as heavy-handed
	# as -z defs.
	allow_undefined_flag_CXX='${wl}-z,nodefs'
	hardcode_libdir_flag_spec_CXX='${wl}-R,$libdir'
	export_dynamic_flag_spec_CXX='${wl}-Bexport'
          CC*)
	    old_archive_cmds_CXX='$CC -Tprelink_objects $oldobjs~
	      '"$old_archive_cmds_CXX"
	    reload_cmds_CXX='$CC -Tprelink_objects $reload_objs~
	      '"$reload_cmds_CXX"
      tandem*)
          NCC*)
	    # NonStop-UX NCC 3.20
	    ld_shlibs_CXX=no
	    ld_shlibs_CXX=no
      vxworks*)
        ld_shlibs_CXX=no
        ld_shlibs_CXX=no
    { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ld_shlibs_CXX" >&5
$as_echo "$ld_shlibs_CXX" >&6; }
    test "$ld_shlibs_CXX" = no && can_build_shared=no
    GCC_CXX="$GXX"
    LD_CXX="$LD"
    ## CAVEAT EMPTOR:
    ## There is no encapsulation within the following macros, do not change
    ## the running order or otherwise move them around unless you know exactly
    ## what you are doing...
    # Dependencies to place before and after the object being linked:
predep_objects_CXX=
postdep_objects_CXX=
predeps_CXX=
postdeps_CXX=
compiler_lib_search_path_CXX=
class Foo
public:
  Foo (void) { a = 0; }
private:
  int a;
_LT_EOF
_lt_libdeps_save_CFLAGS=$CFLAGS
case "$CC $CFLAGS " in #(
*\ -flto*\ *) CFLAGS="$CFLAGS -fno-lto" ;;
*\ -fwhopr*\ *) CFLAGS="$CFLAGS -fno-whopr" ;;
*\ -fuse-linker-plugin*\ *) CFLAGS="$CFLAGS -fno-use-linker-plugin" ;;
if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_compile\""; } >&5
  (eval $ac_compile) 2>&5
  ac_status=$?
  $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
  test $ac_status = 0; }; then
  # Parse the compiler output and extract the necessary
  # objects, libraries and library flags.
  # Sentinel used to keep track of whether or not we are before
  # the conftest object file.
  pre_test_object_deps_done=no
  for p in `eval "$output_verbose_link_cmd"`; do
    case ${prev}${p} in
    -L* | -R* | -l*)
       # Some compilers place space between "-{L,R}" and the path.
       # Remove the space.
       if test $p = "-L" ||
          test $p = "-R"; then
	 prev=$p
	 continue
       # Expand the sysroot to ease extracting the directories later.
       if test -z "$prev"; then
         case $p in
         -L*) func_stripname_cnf '-L' '' "$p"; prev=-L; p=$func_stripname_result ;;
         -R*) func_stripname_cnf '-R' '' "$p"; prev=-R; p=$func_stripname_result ;;
         -l*) func_stripname_cnf '-l' '' "$p"; prev=-l; p=$func_stripname_result ;;
       case $p in
       =*) func_stripname_cnf '=' '' "$p"; p=$lt_sysroot$func_stripname_result ;;
       if test "$pre_test_object_deps_done" = no; then
	 case ${prev} in
	 -L | -R)
	   # Internal compiler library paths should come after those
	   # provided the user.  The postdeps already come after the
	   # user supplied libs so there is no need to process them.
	   if test -z "$compiler_lib_search_path_CXX"; then
	     compiler_lib_search_path_CXX="${prev}${p}"
	     compiler_lib_search_path_CXX="${compiler_lib_search_path_CXX} ${prev}${p}"
	 # The "-l" case would never come before the object being
	 # linked, so don't bother handling this case.
	 if test -z "$postdeps_CXX"; then
	   postdeps_CXX="${prev}${p}"
	   postdeps_CXX="${postdeps_CXX} ${prev}${p}"
       prev=
    *.lto.$objext) ;; # Ignore GCC LTO objects
    *.$objext)
       # This assumes that the test object file only shows up
       # once in the compiler output.
       if test "$p" = "conftest.$objext"; then
	 pre_test_object_deps_done=yes
	 continue
	 if test -z "$predep_objects_CXX"; then
	   predep_objects_CXX="$p"
	   predep_objects_CXX="$predep_objects_CXX $p"
	 if test -z "$postdep_objects_CXX"; then
	   postdep_objects_CXX="$p"
	   postdep_objects_CXX="$postdep_objects_CXX $p"
    *) ;; # Ignore the rest.
  # Clean up.
  rm -f a.out a.exe
  echo "libtool.m4: error: problem compiling CXX test program"
$RM -f confest.$objext
CFLAGS=$_lt_libdeps_save_CFLAGS
# PORTME: override above test on systems where it is broken
case $host_os in
interix[3-9]*)
  # Interix 3.5 installs completely hosed .la files for C++, so rather than
  # hack all around it, let's just trust "g++" to DTRT.
  predep_objects_CXX=
  postdeps_CXX=
linux*)
  *Sun\ C*)
    # Sun C++ 5.9
    # The more standards-conforming stlport4 library is
    # incompatible with the Cstd library. Avoid specifying
    # it if it's in CXXFLAGS. Ignore libCrun as
    # -library=stlport4 depends on it.
    case " $CXX $CXXFLAGS " in
    *" -library=stlport4 "*)
      solaris_use_stlport4=yes
    if test "$solaris_use_stlport4" != yes; then
      postdeps_CXX='-library=Cstd -library=Crun'
solaris*)
  CC* | sunCC*)
    # Adding this requires a known-good setup of shared libraries for
    # Sun compiler versions before 5.6, else PIC objects from an old
    # archive will be linked into the output, leading to subtle bugs.
case " $postdeps_CXX " in
*" -lc "*) archive_cmds_need_lc_CXX=no ;;
 compiler_lib_search_dirs_CXX=
if test -n "${compiler_lib_search_path_CXX}"; then
 compiler_lib_search_dirs_CXX=`echo " ${compiler_lib_search_path_CXX}" | ${SED} -e 's! -L! !g' -e 's!^ !!'`
    lt_prog_compiler_wl_CXX=
lt_prog_compiler_pic_CXX=
lt_prog_compiler_static_CXX=
  # C++ specific cases for pic, static, wl, etc.
    lt_prog_compiler_wl_CXX='-Wl,'
    lt_prog_compiler_static_CXX='-static'
    case $host_os in
    aix*)
      # All AIX code is PIC.
      if test "$host_cpu" = ia64; then
	# AIX 5 now supports IA64 processor
	lt_prog_compiler_static_CXX='-Bstatic'
    amigaos*)
      case $host_cpu in
      powerpc)
            # see comment about AmigaOS4 .so support
            lt_prog_compiler_pic_CXX='-fPIC'
      m68k)
            # FIXME: we need at least 68020 code to build shared libraries, but
            # adding the `-m68020' flag to GCC prevents building anything better,
            # like `-m68040'.
            lt_prog_compiler_pic_CXX='-m68020 -resident32 -malways-restore-a4'
    beos* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
      # PIC is the default for these OSes.
    mingw* | cygwin* | os2* | pw32* | cegcc*)
      # This hack is so that the source file can tell whether it is being
      # built for inclusion in a dll (and should export symbols for example).
      # Although the cygwin gcc ignores -fPIC, still need this for old-style
      # (--disable-auto-import) libraries
      lt_prog_compiler_pic_CXX='-DDLL_EXPORT'
    darwin* | rhapsody*)
      # PIC is the default on this platform
      # Common symbols not allowed in MH_DYLIB files
      lt_prog_compiler_pic_CXX='-fno-common'
    *djgpp*)
      # DJGPP does not support shared libraries at all
    haiku*)
      # PIC is the default for Haiku.
      # The "-static" flag exists, but is broken.
    interix[3-9]*)
      # Interix 3.x gcc -fpic/-fPIC options generate broken code.
      # Instead, we relocate shared libraries at runtime.
    sysv4*MP*)
      if test -d /usr/nec; then
	lt_prog_compiler_pic_CXX=-Kconform_pic
    hpux*)
      # PIC is the default for 64-bit PA HP-UX, but not for 32-bit
      # PA HP-UX.  On IA64 HP-UX, PIC is the default but the pic flag
      # sets the default TLS model and affects inlining.
      case $host_cpu in
      hppa*64*)
    *qnx* | *nto*)
      # QNX uses GNU C++, but need to define -shared option too, otherwise
      # it will coredump.
      lt_prog_compiler_pic_CXX='-fPIC -shared'
    case $host_os in
      aix[4-9]*)
	  lt_prog_compiler_static_CXX='-bnso -bI:/lib/syscalls.exp'
      chorus*)
	cxch68*)
	  # _LT_TAGVAR(lt_prog_compiler_static, CXX)="--no_auto_instantiation -u __main -u __premain -u _abort -r $COOL_DIR/lib/libOrb.a $MVME_DIR/lib/CC/libC.a $MVME_DIR/lib/classix/libcx.s.a"
      dgux*)
	  ec++*)
	    lt_prog_compiler_pic_CXX='-KPIC'
	  ghcx*)
	    lt_prog_compiler_pic_CXX='-pic'
      freebsd* | dragonfly*)
	# FreeBSD uses GNU C++
      hpux9* | hpux10* | hpux11*)
	  CC*)
	    lt_prog_compiler_static_CXX='${wl}-a ${wl}archive'
	    if test "$host_cpu" != ia64; then
	      lt_prog_compiler_pic_CXX='+Z'
	  aCC*)
	    case $host_cpu in
	    hppa*64*|ia64*)
	      # +Z the default
      interix*)
	# This is c89, which is MS Visual C++ (no shared libs)
	# Anyone wants to do a port?
      irix5* | irix6* | nonstopux*)
	  CC*)
	    lt_prog_compiler_static_CXX='-non_shared'
	    # CC pic flag -KPIC is the default.
	  KCC*)
	    # KAI C++ Compiler
	    lt_prog_compiler_wl_CXX='--backend -Wl,'
	  ecpc* )
	    # old Intel C++ for x86_64 which still supported -KPIC.
	  icpc* )
	    # Intel C++, used to be incompatible with GCC.
	    # ICC 10 doesn't accept -KPIC any more.
	  pgCC* | pgcpp*)
	    lt_prog_compiler_pic_CXX='-fpic'
	  cxx*)
	    # Compaq C++
	    # Make sure the PIC flag is empty.  It appears that all Alpha
	    # Linux and Compaq Tru64 Unix objects are PIC.
	  xlc* | xlC* | bgxl[cC]* | mpixl[cC]*)
	    # IBM XL 8.0, 9.0 on PPC and BlueGene
	    lt_prog_compiler_pic_CXX='-qpic'
	    lt_prog_compiler_static_CXX='-qstaticlink'
	    *Sun\ C*)
	      # Sun C++ 5.9
	      lt_prog_compiler_wl_CXX='-Qoption ld '
      lynxos*)
      m88k*)
      mvs*)
	  cxx*)
	    lt_prog_compiler_pic_CXX='-W c,exportall'
      netbsd* | netbsdelf*-gnu)
      *qnx* | *nto*)
        # it will coredump.
	  KCC*)
	  RCC*)
	  cxx*)
	    # Digital/Compaq C++
      psos*)
      solaris*)
	  CC* | sunCC*)
	  gcx*)
	    lt_prog_compiler_pic_CXX='-PIC'
      sunos4*)
	  CC*)
	    # Sun C++ 4.x
	  lcc*)
	    # Lucid
      sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
	  CC*)
      tandem*)
	  NCC*)
      vxworks*)
	lt_prog_compiler_can_build_shared_CXX=no
case $host_os in
  # For platforms which do not support PIC, -DPIC is meaningless:
  *djgpp*)
    lt_prog_compiler_pic_CXX="$lt_prog_compiler_pic_CXX -DPIC"
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $compiler option to produce PIC" >&5
$as_echo_n "checking for $compiler option to produce PIC... " >&6; }
if ${lt_cv_prog_compiler_pic_CXX+:} false; then :
  lt_cv_prog_compiler_pic_CXX=$lt_prog_compiler_pic_CXX
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_pic_CXX" >&5
$as_echo "$lt_cv_prog_compiler_pic_CXX" >&6; }
lt_prog_compiler_pic_CXX=$lt_cv_prog_compiler_pic_CXX
# Check to make sure the PIC flag actually works.
if test -n "$lt_prog_compiler_pic_CXX"; then
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works" >&5
$as_echo_n "checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works... " >&6; }
if ${lt_cv_prog_compiler_pic_works_CXX+:} false; then :
  lt_cv_prog_compiler_pic_works_CXX=no
   echo "$lt_simple_compile_test_code" > conftest.$ac_ext
   lt_compiler_flag="$lt_prog_compiler_pic_CXX -DPIC"
   # Insert the option either (1) after the last *FLAGS variable, or
   # (2) before a word containing "conftest.", or (3) at the end.
   # Note that $ac_compile itself does not contain backslashes and begins
   # with a dollar sign (not a hyphen), so the echo should work correctly.
   # The option is referenced via a variable to avoid confusing sed.
   lt_compile=`echo "$ac_compile" | $SED \
   -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
   -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
   -e 's:$: $lt_compiler_flag:'`
   (eval echo "\"\$as_me:$LINENO: $lt_compile\"" >&5)
   (eval "$lt_compile" 2>conftest.err)
   ac_status=$?
   cat conftest.err >&5
   echo "$as_me:$LINENO: \$? = $ac_status" >&5
   if (exit $ac_status) && test -s "$ac_outfile"; then
     # The compiler can only warn and ignore the option if not recognized
     # So say no if there are warnings other than the usual output.
     $ECHO "$_lt_compiler_boilerplate" | $SED '/^$/d' >conftest.exp
     $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
     if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
       lt_cv_prog_compiler_pic_works_CXX=yes
   $RM conftest*
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_pic_works_CXX" >&5
$as_echo "$lt_cv_prog_compiler_pic_works_CXX" >&6; }
if test x"$lt_cv_prog_compiler_pic_works_CXX" = xyes; then
    case $lt_prog_compiler_pic_CXX in
     *) lt_prog_compiler_pic_CXX=" $lt_prog_compiler_pic_CXX" ;;
# Check to make sure the static flag actually works.
wl=$lt_prog_compiler_wl_CXX eval lt_tmp_static_flag=\"$lt_prog_compiler_static_CXX\"
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler static flag $lt_tmp_static_flag works" >&5
$as_echo_n "checking if $compiler static flag $lt_tmp_static_flag works... " >&6; }
if ${lt_cv_prog_compiler_static_works_CXX+:} false; then :
  $as_echo_n "(cached) " >&6
  lt_cv_prog_compiler_static_works_CXX=no
   save_LDFLAGS="$LDFLAGS"
   LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
   echo "$lt_simple_link_test_code" > conftest.$ac_ext
   if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
     # The linker can only warn and ignore the option if not recognized
     if test -s conftest.err; then
       # Append any errors to the config.log.
       cat conftest.err 1>&5
       $ECHO "$_lt_linker_boilerplate" | $SED '/^$/d' > conftest.exp
       if diff conftest.exp conftest.er2 >/dev/null; then
         lt_cv_prog_compiler_static_works_CXX=yes
   $RM -r conftest*
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_static_works_CXX" >&5
$as_echo "$lt_cv_prog_compiler_static_works_CXX" >&6; }
if test x"$lt_cv_prog_compiler_static_works_CXX" = xyes; then
    { $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler supports -c -o file.$ac_objext" >&5
$as_echo_n "checking if $compiler supports -c -o file.$ac_objext... " >&6; }
if ${lt_cv_prog_compiler_c_o_CXX+:} false; then :
  lt_cv_prog_compiler_c_o_CXX=no
   $RM -r conftest 2>/dev/null
   mkdir conftest
   cd conftest
   mkdir out
   lt_compiler_flag="-o out/conftest2.$ac_objext"
   (eval "$lt_compile" 2>out/conftest.err)
   ac_status=$?
   cat out/conftest.err >&5
   if (exit $ac_status) && test -s out/conftest2.$ac_objext
   then
     $ECHO "$_lt_compiler_boilerplate" | $SED '/^$/d' > out/conftest.exp
     $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
     if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
       lt_cv_prog_compiler_c_o_CXX=yes
   chmod u+w . 2>&5
   $RM conftest*
   # SGI C++ compiler will create directory out/ii_files/ for
   # template instantiation
   test -d out/ii_files && $RM out/ii_files/* && rmdir out/ii_files
   $RM out/* && rmdir out
   cd ..
   $RM -r conftest
   $RM conftest*
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_c_o_CXX" >&5
$as_echo "$lt_cv_prog_compiler_c_o_CXX" >&6; }
   mkdir conftest
   cd conftest
   mkdir out
   ac_status=$?
   then
   chmod u+w . 2>&5
   $RM conftest*
   cd ..
   $RM -r conftest
   $RM conftest*
hard_links="nottested"
if test "$lt_cv_prog_compiler_c_o_CXX" = no && test "$need_locks" != no; then
  # do not overwrite the value of need_locks provided by the user
  { $as_echo "$as_me:${as_lineno-$LINENO}: checking if we can lock with hard links" >&5
$as_echo_n "checking if we can lock with hard links... " >&6; }
  hard_links=yes
  $RM conftest*
  ln conftest.a conftest.b 2>/dev/null && hard_links=no
  touch conftest.a
  ln conftest.a conftest.b 2>&5 || hard_links=no
  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $hard_links" >&5
$as_echo "$hard_links" >&6; }
  if test "$hard_links" = no; then
    { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
$as_echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
    need_locks=warn
  need_locks=no
  export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
  exclude_expsyms_CXX='_GLOBAL_OFFSET_TABLE_|_GLOBAL__F[ID]_.*'
  case $host_os in
  aix[4-9]*)
    # If we're using GNU nm, then we don't want the "-C" option.
    # -C means demangle to AIX nm, but means don't demangle with GNU nm
    # Also, AIX nm treats weak defined symbols like other global defined
    # symbols, whereas GNU nm marks them as "W".
    if $NM -V 2>&1 | $GREP 'GNU' > /dev/null; then
      export_symbols_cmds_CXX='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$ 2 == "T") || (\$ 2 == "D") || (\$ 2 == "B") || (\$ 2 == "W")) && (substr(\$ 3,1,1) != ".")) { print \$ 3 } }'\'' | sort -u > $export_symbols'
      export_symbols_cmds_CXX='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$ 2 == "T") || (\$ 2 == "D") || (\$ 2 == "B")) && (substr(\$ 3,1,1) != ".")) { print \$ 3 } }'\'' | sort -u > $export_symbols'
  pw32*)
    export_symbols_cmds_CXX="$ltdll_cmds"
  cygwin* | mingw* | cegcc*)
    cl*)
      exclude_expsyms_CXX='_NULL_IMPORT_DESCRIPTOR|_IMPORT_DESCRIPTOR_.*'
      export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS][ ]/s/.*[ ]\([^ ]*\)/\1 DATA/;s/^.*[ ]__nm__\([^ ]*\)[ ][^ ]*/\1 DATA/;/^I[ ]/d;/^[AITW][ ]/s/.* //'\'' | sort | uniq > $export_symbols'
      exclude_expsyms_CXX='[_]+GLOBAL_OFFSET_TABLE_|[_]+GLOBAL__[FID]_.*|[_]+head_[A-Za-z0-9_]+_dll|[A-Za-z0-9_]+_dll_iname'
  linux* | k*bsd*-gnu | gnu*)
    link_all_deplibs_CXX=no
with_gnu_ld_CXX=$with_gnu_ld
# Do we need to explicitly link libc?
case "x$archive_cmds_need_lc_CXX" in
x|xyes)
  # Assume -lc should be added
  if test "$enable_shared" = yes && test "$GCC" = yes; then
    case $archive_cmds_CXX in
      # FIXME: we may have to deal with multi-command sequences.
    '$CC '*)
      # Test whether the compiler implicitly links with -lc since on some
      # systems, -lgcc has to come before -lc. If gcc already passes -lc
      # to ld, don't add -lc before -lgcc.
      { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether -lc should be explicitly linked in" >&5
$as_echo_n "checking whether -lc should be explicitly linked in... " >&6; }
if ${lt_cv_archive_cmds_need_lc_CXX+:} false; then :
  $RM conftest*
  ac_status=$?
  test $ac_status = 0; } 2>conftest.err; then
	  soname=conftest
	  lib=conftest
	  libobjs=conftest.$ac_objext
	  deplibs=
	  pic_flag=$lt_prog_compiler_pic_CXX
	  compiler_flags=-v
	  linker_flags=-v
	  verstring=
	  output_objdir=.
	  libname=conftest
	  lt_save_allow_undefined_flag=$allow_undefined_flag_CXX
	  if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$archive_cmds_CXX 2\>\&1 \| $GREP \" -lc \" \>/dev/null 2\>\&1\""; } >&5
  (eval $archive_cmds_CXX 2\>\&1 \| $GREP \" -lc \" \>/dev/null 2\>\&1) 2>&5
  ac_status=$?
	  then
	    lt_cv_archive_cmds_need_lc_CXX=no
	    lt_cv_archive_cmds_need_lc_CXX=yes
	  allow_undefined_flag_CXX=$lt_save_allow_undefined_flag
	$RM conftest*
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_archive_cmds_need_lc_CXX" >&5
$as_echo "$lt_cv_archive_cmds_need_lc_CXX" >&6; }
      archive_cmds_need_lc_CXX=$lt_cv_archive_cmds_need_lc_CXX
    { $as_echo "$as_me:${as_lineno-$LINENO}: checking dynamic linker characteristics" >&5
$as_echo_n "checking dynamic linker characteristics... " >&6; }
library_names_spec=
libname_spec='lib$name'
soname_spec=
shrext_cmds=".so"
postinstall_cmds=
postuninstall_cmds=
finish_cmds=
finish_eval=
shlibpath_var=
shlibpath_overrides_runpath=unknown
version_type=none
dynamic_linker="$host_os ld.so"
sys_lib_dlsearch_path_spec="/lib /usr/lib"
need_lib_prefix=unknown
hardcode_into_libs=no
# when you set need_version to no, make sure it does not cause -set_version
# flags to be left without arguments
need_version=unknown
case $host_os in
aix3*)
  version_type=linux # correct to gnu/linux during the next big refactor
  library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
  shlibpath_var=LIBPATH
  # AIX 3 has no versioning support, so we append a major version to the name.
  soname_spec='${libname}${release}${shared_ext}$major'
aix[4-9]*)
  need_lib_prefix=no
  need_version=no
  hardcode_into_libs=yes
    # AIX 5 supports IA64
    library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
    shlibpath_var=LD_LIBRARY_PATH
    # With GCC up to 2.95.x, collect2 would create an import file
    # for dependence libraries.  The import file would start with
    # the line `#! .'.  This would cause the generated library to
    # depend on `.', always an invalid library.  This was fixed in
    # development snapshots of GCC prior to 3.0.
    case $host_os in
      aix4 | aix4.[01] | aix4.[01].*)
      if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
	   echo ' yes '
	   echo '#endif'; } | ${CC} -E - | $GREP yes > /dev/null; then
	can_build_shared=no
    # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
    # soname into executable. Probably we can add versioning support to
    # collect2, so additional links can be useful in future.
    if test "$aix_use_runtimelinking" = yes; then
      # If using run time linking (on AIX 4.2 or later) use lib<name>.so
      # instead of lib<name>.a to let people know that these are not
      # typical AIX shared libraries.
      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
      # We preserve .a as extension for shared libraries through AIX4.2
      # and later when we are not doing run time linking.
      library_names_spec='${libname}${release}.a $libname.a'
amigaos*)
  case $host_cpu in
  powerpc)
    # Since July 2007 AmigaOS4 officially supports .so libraries.
    # When compiling the executable, add -use-dynld -Lsobjs: to the compileline.
  m68k)
    library_names_spec='$libname.ixlibrary $libname.a'
    # Create ${libname}_ixlibrary.a entries in /sys/libs.
    finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`func_echo_all "$lib" | $SED '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $RM /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
beos*)
  library_names_spec='${libname}${shared_ext}'
  shlibpath_var=LIBRARY_PATH
bsdi[45]*)
  need_version=no
  finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
  sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
  sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
  # the default ld.so.conf also contains /usr/contrib/lib and
  # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
  # libtool to hard-code these into programs
  version_type=windows
  shrext_cmds=".dll"
  need_version=no
  need_lib_prefix=no
  case $GCC,$cc_basename in
  yes,*)
    # gcc
    library_names_spec='$libname.dll.a'
    # DLL is installed to $(libdir)/../bin by postinstall_cmds
    postinstall_cmds='base_file=`basename \${file}`~
      dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i; echo \$dlname'\''`~
      dldir=$destdir/`dirname \$dlpath`~
      test -d \$dldir || mkdir -p \$dldir~
      $install_prog $dir/$dlname \$dldir/$dlname~
      chmod a+x \$dldir/$dlname~
      if test -n '\''$stripme'\'' && test -n '\''$striplib'\''; then
        eval '\''$striplib \$dldir/$dlname'\'' || exit \$?;
      fi'
    postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
      dlpath=$dir/\$dldll~
       $RM \$dlpath'
    shlibpath_overrides_runpath=yes
    case $host_os in
    cygwin*)
      # Cygwin DLLs use 'cyg' prefix rather than 'lib'
      soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
    mingw* | cegcc*)
      # MinGW DLLs use traditional 'lib' prefix
      soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
    pw32*)
      # pw32 DLLs use 'pw' prefix rather than 'lib'
      library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
    dynamic_linker='Win32 ld.exe'
  *,cl*)
    # Native MSVC
    libname_spec='$name'
    library_names_spec='${libname}.dll.lib'
    case $build_os in
    mingw*)
      lt_save_ifs=$IFS
      IFS=';'
      for lt_path in $LIB
      do
        IFS=$lt_save_ifs
        # Let DOS variable expansion print the short 8.3 style file name.
        lt_path=`cd "$lt_path" 2>/dev/null && cmd //C "for %i in (".") do @echo %~si"`
        sys_lib_search_path_spec="$sys_lib_search_path_spec $lt_path"
      IFS=$lt_save_ifs
      # Convert to MSYS style.
      sys_lib_search_path_spec=`$ECHO "$sys_lib_search_path_spec" | sed -e 's|\\\\|/|g' -e 's| \\([a-zA-Z]\\):| /\\1|g' -e 's|^ ||'`
    cygwin*)
      # Convert to unix form, then to dos form, then back to unix form
      # but this time dos style (no spaces!) so that the unix form looks
      # like /cygdrive/c/PROGRA~1:/cygdr...
      sys_lib_search_path_spec=`cygpath --path --unix "$LIB"`
      sys_lib_search_path_spec=`cygpath --path --dos "$sys_lib_search_path_spec" 2>/dev/null`
      sys_lib_search_path_spec=`cygpath --path --unix "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
      sys_lib_search_path_spec="$LIB"
      if $ECHO "$sys_lib_search_path_spec" | $GREP ';[c-zC-Z]:/' >/dev/null; then
        # It is most probably a Windows format PATH.
        sys_lib_search_path_spec=`$ECHO "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
        sys_lib_search_path_spec=`$ECHO "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
      # FIXME: find the short name or the path components, as spaces are
      # common. (e.g. "Program Files" -> "PROGRA~1")
      $install_prog $dir/$dlname \$dldir/$dlname'
       $RM \$dlpath'
    dynamic_linker='Win32 link.exe'
    # Assume MSVC wrapper
    library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
  # FIXME: first we should search . and the directory the executable is in
  shlibpath_var=PATH
  dynamic_linker="$host_os dyld"
  version_type=darwin
  need_lib_prefix=no
  need_version=no
  library_names_spec='${libname}${release}${major}$shared_ext ${libname}$shared_ext'
  soname_spec='${libname}${release}${major}$shared_ext'
  shlibpath_var=DYLD_LIBRARY_PATH
  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
  sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
dgux*)
  need_lib_prefix=no
  need_version=no
  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
  # DragonFly does not have aout.  When/if they implement a new
  # versioning mechanism, adjust this.
  if test -x /usr/bin/objformat; then
    objformat=`/usr/bin/objformat`
    case $host_os in
    freebsd[23].*) objformat=aout ;;
    *) objformat=elf ;;
  version_type=freebsd-$objformat
  case $version_type in
    freebsd-elf*)
      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
      need_version=no
      need_lib_prefix=no
    freebsd-*)
      library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
      need_version=yes
  case $host_os in
  freebsd2.*)
  freebsd3.[01]* | freebsdelf3.[01]*)
  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
    shlibpath_overrides_runpath=no
  *) # from 4.6 on, and DragonFly
haiku*)
  need_lib_prefix=no
  need_version=no
  dynamic_linker="$host_os runtime_loader"
  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
  sys_lib_dlsearch_path_spec='/boot/home/config/lib /boot/common/lib /boot/system/lib'
  # Give a soname corresponding to the major version so that dld.sl refuses to
  # link against other versions.
  version_type=sunos
  need_lib_prefix=no
  need_version=no
  case $host_cpu in
  ia64*)
    shrext_cmds='.so'
    dynamic_linker="$host_os dld.so"
    shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
    if test "X$HPUX_IA64_MODE" = X32; then
      sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
      sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
    sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
  hppa*64*)
    shrext_cmds='.sl'
    dynamic_linker="$host_os dld.sl"
    shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
    sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
    shrext_cmds='.sl'
    shlibpath_var=SHLIB_PATH
    shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
  # HP-UX runs *really* slowly unless shared libraries are mode 555, ...
  postinstall_cmds='chmod 555 $lib'
  # or fails outright, so override atomically:
  install_override_mode=555
interix[3-9]*)
  need_lib_prefix=no
  need_version=no
  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
  case $host_os in
    nonstopux*) version_type=nonstopux ;;
	if test "$lt_cv_prog_gnu_ld" = yes; then
		version_type=irix
	fi ;;
  need_lib_prefix=no
  need_version=no
  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
  case $host_os in
  irix5* | nonstopux*)
    libsuff= shlibsuff=
    case $LD in # libtool.m4 will add one of these switches to LD
    *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
      libsuff= shlibsuff= libmagic=32-bit;;
    *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
      libsuff=32 shlibsuff=N32 libmagic=N32;;
    *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
      libsuff=64 shlibsuff=64 libmagic=64-bit;;
    *) libsuff= shlibsuff= libmagic=never-match;;
  shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
  sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
  sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
# No shared lib support for Linux oldld, aout, or coff.
linux*oldld* | linux*aout* | linux*coff*)
  dynamic_linker=no
# This must be glibc/ELF.
linux* | k*bsd*-gnu | kopensolaris*-gnu | gnu*)
  need_lib_prefix=no
  need_version=no
  finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
  # Some binutils ld are patched to set DT_RUNPATH
  if ${lt_cv_shlibpath_overrides_runpath+:} false; then :
  lt_cv_shlibpath_overrides_runpath=no
    save_LDFLAGS=$LDFLAGS
    save_libdir=$libdir
    eval "libdir=/foo; wl=\"$lt_prog_compiler_wl_CXX\"; \
	 LDFLAGS=\"\$LDFLAGS $hardcode_libdir_flag_spec_CXX\""
    cat confdefs.h - <<_ACEOF >conftest.$ac_ext
/* end confdefs.h.  */
int
main ()
_ACEOF
  if  ($OBJDUMP -p conftest$ac_exeext) 2>/dev/null | grep "RUNPATH.*$libdir" >/dev/null; then :
  lt_cv_shlibpath_overrides_runpath=yes
rm -f core conftest.err conftest.$ac_objext \
    conftest$ac_exeext conftest.$ac_ext
    LDFLAGS=$save_LDFLAGS
    libdir=$save_libdir
  shlibpath_overrides_runpath=$lt_cv_shlibpath_overrides_runpath
  # This implies no fast_install, which is unacceptable.
  # Some rework will be needed to allow for fast_install
  # before this can be enabled.
  # Append ld.so.conf contents to the search path
  if test -f /etc/ld.so.conf; then
    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s 2>/dev/null", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;/^[	 ]*hwcap[	 ]/d;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;s/"//g;/^$/d' | tr '\n' ' '`
    sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
  # We used to test for /lib/ld.so.1 and disable shared libraries on
  # powerpc, because MkLinux only supported shared libraries with the
  # GNU dynamic linker.  Since this was broken with cross compilers,
  # most powerpc-linux boxes support dynamic linking these days and
  # people can always --disable-shared, the test was removed, and we
  # assume the GNU/Linux dynamic linker is in use.
  dynamic_linker='GNU/Linux ld.so'
netbsdelf*-gnu)
  version_type=linux
  need_lib_prefix=no
  need_version=no
  dynamic_linker='NetBSD ld.elf_so'
netbsd*)
  version_type=sunos
  need_lib_prefix=no
  need_version=no
    library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
    finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
    dynamic_linker='NetBSD (a.out) ld.so'
newsos6)
*nto* | *qnx*)
  version_type=qnx
  need_lib_prefix=no
  need_version=no
  dynamic_linker='ldqnx.so'
openbsd*)
  version_type=sunos
  sys_lib_dlsearch_path_spec="/usr/lib"
  need_lib_prefix=no
  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
  case $host_os in
    openbsd3.3 | openbsd3.3.*)	need_version=yes ;;
    *)				need_version=no  ;;
  if test -z "`echo __ELF__ | $CC -E - | $GREP __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
    case $host_os in
      openbsd2.[89] | openbsd2.[89].*)
os2*)
  shrext_cmds=".dll"
  need_lib_prefix=no
  library_names_spec='$libname${shared_ext} $libname.a'
  dynamic_linker='OS/2 ld.exe'
  version_type=osf
  need_lib_prefix=no
  need_version=no
  sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
  sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
rdos*)
  dynamic_linker=no
solaris*)
  need_lib_prefix=no
  need_version=no
  # ldd complains unless libraries are executable
  postinstall_cmds='chmod +x $lib'
sunos4*)
  version_type=sunos
  finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
    need_lib_prefix=no
  need_version=yes
sysv4 | sysv4.3*)
  case $host_vendor in
    sni)
      need_lib_prefix=no
    siemens)
      need_lib_prefix=no
    motorola)
      need_lib_prefix=no
      need_version=no
      sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
sysv4*MP*)
  if test -d /usr/nec ;then
    library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
    soname_spec='$libname${shared_ext}.$major'
sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
  version_type=freebsd-elf
  need_lib_prefix=no
  need_version=no
  if test "$with_gnu_ld" = yes; then
    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
    case $host_os in
      sco3.2v5*)
        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
  sys_lib_dlsearch_path_spec='/usr/lib'
tpf*)
  # TPF is a cross-target only.  Preferred cross-host = GNU/Linux.
  need_lib_prefix=no
  need_version=no
uts4*)
  dynamic_linker=no
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $dynamic_linker" >&5
$as_echo "$dynamic_linker" >&6; }
test "$dynamic_linker" = no && can_build_shared=no
variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
if test "$GCC" = yes; then
  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
if test "${lt_cv_sys_lib_search_path_spec+set}" = set; then
  sys_lib_search_path_spec="$lt_cv_sys_lib_search_path_spec"
if test "${lt_cv_sys_lib_dlsearch_path_spec+set}" = set; then
  sys_lib_dlsearch_path_spec="$lt_cv_sys_lib_dlsearch_path_spec"
    { $as_echo "$as_me:${as_lineno-$LINENO}: checking how to hardcode library paths into programs" >&5
$as_echo_n "checking how to hardcode library paths into programs... " >&6; }
hardcode_action_CXX=
if test -n "$hardcode_libdir_flag_spec_CXX" ||
   test -n "$runpath_var_CXX" ||
   test "X$hardcode_automatic_CXX" = "Xyes" ; then
  # We can hardcode non-existent directories.
  if test "$hardcode_direct_CXX" != no &&
     # If the only mechanism to avoid hardcoding is shlibpath_var, we
     # have to relink, otherwise we might link with an installed library
     # when we should be linking with a yet-to-be-installed one
     ## test "$_LT_TAGVAR(hardcode_shlibpath_var, CXX)" != no &&
     test "$hardcode_minus_L_CXX" != no; then
    # Linking always hardcodes the temporary library directory.
    hardcode_action_CXX=relink
    # We can link without hardcoding, and we can hardcode nonexisting dirs.
    hardcode_action_CXX=immediate
  # We cannot hardcode anything, or else we can only hardcode existing
  # directories.
  hardcode_action_CXX=unsupported
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $hardcode_action_CXX" >&5
$as_echo "$hardcode_action_CXX" >&6; }
if test "$hardcode_action_CXX" = relink ||
   test "$inherit_rpath_CXX" = yes; then
  # Fast installation is not supported
  enable_fast_install=no
elif test "$shlibpath_overrides_runpath" = yes ||
     test "$enable_shared" = no; then
  # Fast installation is not necessary
  enable_fast_install=needless
  fi # test -n "$compiler"
  CC=$lt_save_CC
  CFLAGS=$lt_save_CFLAGS
  LDCXX=$LD
  LD=$lt_save_LD
  GCC=$lt_save_GCC
  with_gnu_ld=$lt_save_with_gnu_ld
  lt_cv_path_LDCXX=$lt_cv_path_LD
  lt_cv_path_LD=$lt_save_path_LD
  lt_cv_prog_gnu_ldcxx=$lt_cv_prog_gnu_ld
  lt_cv_prog_gnu_ld=$lt_save_with_gnu_ld
fi # test "$_lt_caught_CXX_error" != yes
ac_ext=c
ac_cpp='$CPP $CPPFLAGS'
ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
ac_compiler_gnu=$ac_cv_c_compiler_gnu
        ac_config_commands="$ac_config_commands libtool"
# Only expand once:
# Checks for libraries.
# Checks for header files.
# Checks for typedefs, structures, and compiler characteristics.
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for stdbool.h that conforms to C99" >&5
$as_echo_n "checking for stdbool.h that conforms to C99... " >&6; }
if ${ac_cv_header_stdbool_h+:} false; then :
             #include <stdbool.h>
             #ifndef bool
              "error: bool is not defined"
             #ifndef false
              "error: false is not defined"
             #if false
              "error: false is not 0"
             #ifndef true
              "error: true is not defined"
             #if true != 1
              "error: true is not 1"
             #ifndef __bool_true_false_are_defined
              "error: __bool_true_false_are_defined is not defined"
             struct s { _Bool s: 1; _Bool t; } s;
             char a[true == 1 ? 1 : -1];
             char b[false == 0 ? 1 : -1];
             char c[__bool_true_false_are_defined == 1 ? 1 : -1];
             char d[(bool) 0.5 == true ? 1 : -1];
             /* See body of main program for 'e'.  */
             char f[(_Bool) 0.0 == false ? 1 : -1];
             char g[true];
             char h[sizeof (_Bool)];
             char i[sizeof s.t];
             enum { j = false, k = true, l = false * true, m = true * 256 };
             /* The following fails for
                HP aC++/ANSI C B3910B A.05.55 [Dec 04 2003]. */
             _Bool n[m];
             char o[sizeof n == m * sizeof n[0] ? 1 : -1];
             char p[-1 - (_Bool) 0 < 0 && -1 - (bool) 0 < 0 ? 1 : -1];
             /* Catch a bug in an HP-UX C compiler.  See
                http://gcc.gnu.org/ml/gcc-patches/2003-12/msg02303.html
                http://lists.gnu.org/archive/html/bug-coreutils/2005-11/msg00161.html
             _Bool q = true;
             _Bool *pq = &q;
int
main ()
             bool e = &s;
             *pq |= q;
             *pq |= ! q;
             /* Refer to every declared value, to avoid compiler optimizations.  */
             return (!a + !b + !c + !d + !e + !f + !g + !h + !i + !!j + !k + !!l
                     + !m + !n + !o + !p + !q + !pq);
_ACEOF
if ac_fn_c_try_compile "$LINENO"; then :
  ac_cv_header_stdbool_h=yes
  ac_cv_header_stdbool_h=no
rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_header_stdbool_h" >&5
$as_echo "$ac_cv_header_stdbool_h" >&6; }
   ac_fn_c_check_type "$LINENO" "_Bool" "ac_cv_type__Bool" "$ac_includes_default"
if test "x$ac_cv_type__Bool" = xyes; then :
cat >>confdefs.h <<_ACEOF
#define HAVE__BOOL 1
_ACEOF
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for C/C++ restrict keyword" >&5
$as_echo_n "checking for C/C++ restrict keyword... " >&6; }
if ${ac_cv_c_restrict+:} false; then :
  ac_cv_c_restrict=no
   # The order here caters to the fact that C++ does not require restrict.
   for ac_kw in __restrict __restrict__ _Restrict restrict; do
typedef int * int_ptr;
	int foo (int_ptr $ac_kw ip) {
	return ip[0];
int
main ()
int s[1];
	int * $ac_kw t = s;
	t[0] = 0;
	return foo(t)
_ACEOF
  ac_cv_c_restrict=$ac_kw
     test "$ac_cv_c_restrict" != no && break
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_restrict" >&5
$as_echo "$ac_cv_c_restrict" >&6; }
 case $ac_cv_c_restrict in
   restrict) ;;
   no) $as_echo "#define restrict /**/" >>confdefs.h
   *)  cat >>confdefs.h <<_ACEOF
#define restrict $ac_cv_c_restrict
_ACEOF
ac_fn_c_check_type "$LINENO" "size_t" "ac_cv_type_size_t" "$ac_includes_default"
if test "x$ac_cv_type_size_t" = xyes; then :
#define size_t unsigned int
_ACEOF
# Checks for library functions.
build_platform="AK3761D"
# Check whether --with-platform was given.
if test "${with_platform+set}" = set; then :
  withval=$with_platform;
# Check whether --enable-platform was given.
if test "${enable_platform+set}" = set; then :
  enableval=$enable_platform; build_platform=$enableval
case "$with_platform" in
            "3520DV300")
                LIB_DIR="hisiv400"
            "x86")
                LIB_DIR="x86"
            "AK3761D")
            LIB_DIR="ak3761d"
            "AK3780C")
            "N32926")
                LIB_DIR="n32926"
                LIB_DIR="hisiv400"
ac_config_files="$ac_config_files libqvcloud.pc Makefile lib/Makefile src/Makefile"
cat >confcache <<\_ACEOF
# This file is a shell script that caches the results of configure
# tests run on this system so they can be shared between configure
# scripts and configure runs, see configure's option --config-cache.
# It is not useful on other systems.  If it contains results you don't
# want to keep, you may remove or edit it.
# config.status only pays attention to the cache file if you give it
# the --recheck option to rerun configure.
# `ac_cv_env_foo' variables (set or unset) will be overridden when
# loading this file, other *unset* `ac_cv_foo' will be assigned the
# following values.
_ACEOF
# The following way of writing the cache mishandles newlines in values,
# but we know of no workaround that is simple, portable, and efficient.
# So, we kill variables containing newlines.
# Ultrix sh set writes to stderr and can't be redirected directly,
# and sets the high bit in the cache file unless we assign to the vars.
  for ac_var in `(set) 2>&1 | sed -n 's/^\([a-zA-Z_][a-zA-Z0-9_]*\)=.*/\1/p'`; do
    eval ac_val=\$$ac_var
    case $ac_val in #(
    *${as_nl}*)
      case $ac_var in #(
      *_cv_*) { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: cache variable $ac_var contains a newline" >&5
$as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
      case $ac_var in #(
      _ | IFS | as_nl) ;; #(
      BASH_ARGV | BASH_SOURCE) eval $ac_var= ;; #(
      *) { eval $ac_var=; unset $ac_var;} ;;
      esac ;;
  (set) 2>&1 |
    case $as_nl`(ac_space=' '; set) 2>&1` in #(
    *${as_nl}ac_space=\ *)
      # `set' does not quote correctly, so add quotes: double-quote
      # substitution turns \\\\ into \\, and sed turns \\ into \.
      sed -n \
	"s/'/'\\\\''/g;
	  s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p"
      # `set' quotes correctly as required by POSIX, so do not add quotes.
      sed -n "/^[_$as_cr_alnum]*_cv_[_$as_cr_alnum]*=/p"
    esac |
    sort
  sed '
     /^ac_cv_env_/b end
     t clear
     :clear
     s/^\([^=]*\)=\(.*[{}].*\)$/test "${\1+set}" = set || &/
     t end
     s/^\([^=]*\)=\(.*\)$/\1=${\1=\2}/
     :end' >>confcache
if diff "$cache_file" confcache >/dev/null 2>&1; then :; else
  if test -w "$cache_file"; then
    if test "x$cache_file" != "x/dev/null"; then
      { $as_echo "$as_me:${as_lineno-$LINENO}: updating cache $cache_file" >&5
$as_echo "$as_me: updating cache $cache_file" >&6;}
      if test ! -f "$cache_file" || test -h "$cache_file"; then
	cat confcache >"$cache_file"
        case $cache_file in #(
	  mv -f confcache "$cache_file"$$ &&
	  mv -f "$cache_file"$$ "$cache_file" ;; #(
	  mv -f confcache "$cache_file" ;;
    { $as_echo "$as_me:${as_lineno-$LINENO}: not updating unwritable cache $cache_file" >&5
$as_echo "$as_me: not updating unwritable cache $cache_file" >&6;}
rm -f confcache
test "x$prefix" = xNONE && prefix=$ac_default_prefix
# Let make expand exec_prefix.
test "x$exec_prefix" = xNONE && exec_prefix='${prefix}'
DEFS=-DHAVE_CONFIG_H
ac_libobjs=
ac_ltlibobjs=
U=
for ac_i in : $LIBOBJS; do test "x$ac_i" = x: && continue
  # 1. Remove the extension, and $U if already installed.
  ac_script='s/\$U\././;s/\.o$//;s/\.obj$//'
  ac_i=`$as_echo "$ac_i" | sed "$ac_script"`
  # 2. Prepend LIBOBJDIR.  When used with automake>=1.10 LIBOBJDIR
  #    will be set to the directory where LIBOBJS objects are built.
  as_fn_append ac_libobjs " \${LIBOBJDIR}$ac_i\$U.$ac_objext"
  as_fn_append ac_ltlibobjs " \${LIBOBJDIR}$ac_i"'$U.lo'
LIBOBJS=$ac_libobjs
LTLIBOBJS=$ac_ltlibobjs
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking that generated files are newer than configure" >&5
$as_echo_n "checking that generated files are newer than configure... " >&6; }
   if test -n "$am_sleep_pid"; then
     # Hide warnings about reused PIDs.
     wait $am_sleep_pid 2>/dev/null
   { $as_echo "$as_me:${as_lineno-$LINENO}: result: done" >&5
$as_echo "done" >&6; }
 if test -n "$EXEEXT"; then
  am__EXEEXT_TRUE=
  am__EXEEXT_FALSE='#'
  am__EXEEXT_TRUE='#'
  am__EXEEXT_FALSE=
if test -z "${AMDEP_TRUE}" && test -z "${AMDEP_FALSE}"; then
  as_fn_error $? "conditional \"AMDEP\" was never defined.
Usually this means the macro was only invoked conditionally." "$LINENO" 5
if test -z "${am__fastdepCC_TRUE}" && test -z "${am__fastdepCC_FALSE}"; then
  as_fn_error $? "conditional \"am__fastdepCC\" was never defined.
if test -z "${am__fastdepCXX_TRUE}" && test -z "${am__fastdepCXX_FALSE}"; then
  as_fn_error $? "conditional \"am__fastdepCXX\" was never defined.
: "${CONFIG_STATUS=./config.status}"
ac_write_fail=0
ac_clean_files_save=$ac_clean_files
ac_clean_files="$ac_clean_files $CONFIG_STATUS"
{ $as_echo "$as_me:${as_lineno-$LINENO}: creating $CONFIG_STATUS" >&5
$as_echo "$as_me: creating $CONFIG_STATUS" >&6;}
as_write_fail=0
cat >$CONFIG_STATUS <<_ASEOF || as_write_fail=1
#! $SHELL
# Generated by $as_me.
# Run this file to recreate the current configuration.
# Compiler output produced by configure, useful for debugging
# configure, is in config.log if it exists.
debug=false
ac_cs_recheck=false
ac_cs_silent=false
SHELL=\${CONFIG_SHELL-$SHELL}
export SHELL
_ASEOF
cat >>$CONFIG_STATUS <<\_ASEOF || as_write_fail=1
## M4sh Initialization. ##
# Be more Bourne compatible
DUALCASE=1; export DUALCASE # for MKS sh
if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
  emulate sh
  NULLCMD=:
  # Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
  # is contrary to our usage.  Disable this feature.
  alias -g '${1+"$@"}'='"$@"'
  setopt NO_GLOB_SUBST
  case `(set -o) 2>/dev/null` in #(
  *posix*) :
    set -o posix ;; #(
as_nl='
export as_nl
# Printing a long string crashes Solaris 7 /usr/bin/printf.
as_echo='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo$as_echo
# Prefer a ksh shell builtin over an external printf program on Solaris,
# but without wasting forks for bash or zsh.
if test -z "$BASH_VERSION$ZSH_VERSION" \
    && (test "X`print -r -- $as_echo`" = "X$as_echo") 2>/dev/null; then
  as_echo='print -r --'
  as_echo_n='print -rn --'
elif (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
  as_echo='printf %s\n'
  as_echo_n='printf %s'
  if test "X`(/usr/ucb/echo -n -n $as_echo) 2>/dev/null`" = "X-n $as_echo"; then
    as_echo_body='eval /usr/ucb/echo -n "$1$as_nl"'
    as_echo_n='/usr/ucb/echo -n'
    as_echo_body='eval expr "X$1" : "X\\(.*\\)"'
    as_echo_n_body='eval
      arg=$1;
      case $arg in #(
      *"$as_nl"*)
	expr "X$arg" : "X\\(.*\\)$as_nl";
	arg=`expr "X$arg" : ".*$as_nl\\(.*\\)"`;;
      esac;
      expr "X$arg" : "X\\(.*\\)" | tr -d "$as_nl"
    export as_echo_n_body
    as_echo_n='sh -c $as_echo_n_body as_echo'
  export as_echo_body
  as_echo='sh -c $as_echo_body as_echo'
# The user is always right.
if test "${PATH_SEPARATOR+set}" != set; then
  PATH_SEPARATOR=:
  (PATH='/bin;/bin'; FPATH=$PATH; sh -c :) >/dev/null 2>&1 && {
    (PATH='/bin:/bin'; FPATH=$PATH; sh -c :) >/dev/null 2>&1 ||
      PATH_SEPARATOR=';'
# IFS
# We need space, tab and new line, in precisely that order.  Quoting is
# there to prevent editors from complaining about space-tab.
# (If _AS_PATH_WALK were called with IFS unset, it would disable word
# splitting by setting IFS to empty value.)
IFS=" ""	$as_nl"
# Find who we are.  Look in the path if we contain no directory separator.
as_myself=
case $0 in #((
  *[\\/]* ) as_myself=$0 ;;
  *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in $PATH
do
  IFS=$as_save_IFS
  test -z "$as_dir" && as_dir=.
    test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
IFS=$as_save_IFS
# We did not find ourselves, most probably we were run as `sh COMMAND'
# in which case we are not to be found in the path.
if test "x$as_myself" = x; then
  as_myself=$0
if test ! -f "$as_myself"; then
  $as_echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
  exit 1
# Unset variables that we do not need and which cause bugs (e.g. in
# pre-3.0 UWIN ksh).  But do not cause bugs in bash 2.01; the "|| exit 1"
# suppresses any "Segmentation fault" message there.  '((' could
# trigger a bug in pdksh 5.2.14.
for as_var in BASH_ENV ENV MAIL MAILPATH
do eval test x\${$as_var+set} = xset \
  && ( (unset $as_var) || exit 1) >/dev/null 2>&1 && unset $as_var || :
PS1='$ '
PS2='> '
PS4='+ '
# NLS nuisances.
LC_ALL=C
export LC_ALL
LANGUAGE=C
export LANGUAGE
# CDPATH.
(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
# as_fn_error STATUS ERROR [LINENO LOG_FD]
# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
# script with STATUS, using 1 if that was 0.
as_fn_error ()
  as_status=$1; test $as_status -eq 0 && as_status=1
  if test "$4"; then
    as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
    $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
  $as_echo "$as_me: error: $2" >&2
  as_fn_exit $as_status
} # as_fn_error
# as_fn_set_status STATUS
# Set $? to STATUS, without forking.
as_fn_set_status ()
  return $1
} # as_fn_set_status
# as_fn_exit STATUS
# Exit the shell with STATUS, even in a "trap 0" or "set -e" context.
as_fn_exit ()
  set +e
  as_fn_set_status $1
  exit $1
} # as_fn_exit
# as_fn_unset VAR
# Portably unset VAR.
as_fn_unset ()
  { eval $1=; unset $1;}
as_unset=as_fn_unset
# as_fn_append VAR VALUE
# Append the text in VALUE to the end of the definition contained in VAR. Take
# advantage of any shell optimizations that allow amortized linear growth over
# repeated appends, instead of the typical quadratic growth present in naive
# implementations.
if (eval "as_var=1; as_var+=2; test x\$as_var = x12") 2>/dev/null; then :
  eval 'as_fn_append ()
    eval $1+=\$2
  as_fn_append ()
    eval $1=\$$1\$2
fi # as_fn_append
# as_fn_arith ARG...
# Perform arithmetic evaluation on the ARGs, and store the result in the
# global $as_val. Take advantage of shells that can avoid forks. The arguments
# must be portable across $(()) and expr.
if (eval "test \$(( 1 + 1 )) = 2") 2>/dev/null; then :
  eval 'as_fn_arith ()
    as_val=$(( $* ))
  as_fn_arith ()
    as_val=`expr "$@" || test $? -eq 1`
fi # as_fn_arith
if expr a : '\(a\)' >/dev/null 2>&1 &&
   test "X`expr 00001 : '.*\(...\)'`" = X001; then
  as_expr=expr
  as_expr=false
if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
  as_basename=basename
  as_basename=false
if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
  as_dirname=dirname
  as_dirname=false
as_me=`$as_basename -- "$0" ||
$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
	 X"$0" : 'X\(//\)$' \| \
	 X"$0" : 'X\(/\)' \| . 2>/dev/null ||
$as_echo X/"$0" |
    sed '/^.*\/\([^/][^/]*\)\/*$/{
	    s//\1/
	    q
	  /^X\/\(\/\/\)$/{
	    s//\1/
	    q
	  /^X\/\(\/\).*/{
	    s//\1/
	    q
	  s/.*/./; q'`
# Avoid depending upon Character Ranges.
as_cr_letters='abcdefghijklmnopqrstuvwxyz'
as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
as_cr_Letters=$as_cr_letters$as_cr_LETTERS
as_cr_digits='0123456789'
as_cr_alnum=$as_cr_Letters$as_cr_digits
ECHO_C= ECHO_N= ECHO_T=
case `echo -n x` in #(((((
-n*)
  case `echo 'xy\c'` in
  *c*) ECHO_T='	';;	# ECHO_T is single tab character.
  xy)  ECHO_C='\c';;
  *)   echo `echo ksh88 bug on AIX 6.1` > /dev/null
       ECHO_T='	';;
  esac;;
  ECHO_N='-n';;
rm -f conf$$ conf$$.exe conf$$.file
if test -d conf$$.dir; then
  rm -f conf$$.dir/conf$$.file
  rm -f conf$$.dir
  mkdir conf$$.dir 2>/dev/null
if (echo >conf$$.file) 2>/dev/null; then
  if ln -s conf$$.file conf$$ 2>/dev/null; then
    as_ln_s='ln -s'
    # ... but there are two gotchas:
    # 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
    # 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
    # In both cases, we have to default to `cp -pR'.
    ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
      as_ln_s='cp -pR'
  elif ln conf$$.file conf$$ 2>/dev/null; then
    as_ln_s=ln
    as_ln_s='cp -pR'
  as_ln_s='cp -pR'
rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
rmdir conf$$.dir 2>/dev/null
# as_fn_mkdir_p
# Create "$as_dir" as a directory, including parents if necessary.
as_fn_mkdir_p ()
  case $as_dir in #(
  -*) as_dir=./$as_dir;;
  test -d "$as_dir" || eval $as_mkdir_p || {
    as_dirs=
    while :; do
      case $as_dir in #(
      *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
      *) as_qdir=$as_dir;;
      as_dirs="'$as_qdir' $as_dirs"
      as_dir=`$as_dirname -- "$as_dir" ||
$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
	 X"$as_dir" : 'X\(//\)[^/]' \| \
	 X"$as_dir" : 'X\(//\)$' \| \
	 X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
$as_echo X"$as_dir" |
    sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
	    s//\1/
	    q
	  /^X\(\/\/\)[^/].*/{
	    s//\1/
	    q
	  /^X\(\/\/\)$/{
	    s//\1/
	    q
	  /^X\(\/\).*/{
	    s//\1/
	    q
	  s/.*/./; q'`
      test -d "$as_dir" && break
    test -z "$as_dirs" || eval "mkdir $as_dirs"
  } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
} # as_fn_mkdir_p
if mkdir -p . 2>/dev/null; then
  as_mkdir_p='mkdir -p "$as_dir"'
  test -d ./-p && rmdir ./-p
  as_mkdir_p=false
# as_fn_executable_p FILE
# Test if FILE is an executable regular file.
as_fn_executable_p ()
  test -f "$1" && test -x "$1"
} # as_fn_executable_p
as_test_x='test -x'
as_executable_p=as_fn_executable_p
# Sed expression to map a string onto a valid CPP name.
as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
# Sed expression to map a string onto a valid variable name.
as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
exec 6>&1
## Main body of $CONFIG_STATUS script. ##
_ASEOF
test $as_write_fail = 0 && chmod +x $CONFIG_STATUS || ac_write_fail=1
cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
# Save the log message, to keep $0 and so on meaningful, and to
# report actual input values of CONFIG_FILES etc. instead of their
# values after options handling.
ac_log="
This file was extended by qvcloud $as_me 1.0, which was
generated by GNU Autoconf 2.69.  Invocation command line was
  CONFIG_FILES    = $CONFIG_FILES
  CONFIG_HEADERS  = $CONFIG_HEADERS
  CONFIG_LINKS    = $CONFIG_LINKS
  CONFIG_COMMANDS = $CONFIG_COMMANDS
  $ $0 $@
on `(hostname || uname -n) 2>/dev/null | sed 1q`
_ACEOF
case $ac_config_files in *"
"*) set x $ac_config_files; shift; ac_config_files=$*;;
case $ac_config_headers in *"
"*) set x $ac_config_headers; shift; ac_config_headers=$*;;
cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
# Files that config.status was made for.
config_files="$ac_config_files"
config_headers="$ac_config_headers"
config_commands="$ac_config_commands"
_ACEOF
ac_cs_usage="\
\`$as_me' instantiates files and other configuration actions
from templates according to the current configuration.  Unless the files
and actions are specified as TAGs, all are instantiated by default.
Usage: $0 [OPTION]... [TAG]...
  -h, --help       print this help, then exit
  -V, --version    print version number and configuration settings, then exit
      --config     print configuration, then exit
  -q, --quiet, --silent
                   do not print progress messages
  -d, --debug      don't remove temporary files
      --recheck    update $as_me by reconfiguring in the same conditions
      --file=FILE[:TEMPLATE]
                   instantiate the configuration file FILE
      --header=FILE[:TEMPLATE]
                   instantiate the configuration header FILE
Configuration files:
$config_files
Configuration headers:
$config_headers
Configuration commands:
$config_commands
Report bugs to the package provider."
_ACEOF
ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
ac_cs_version="\\
qvcloud config.status 1.0
configured by $0, generated by GNU Autoconf 2.69,
  with options \\"\$ac_cs_config\\"
Copyright (C) 2012 Free Software Foundation, Inc.
This config.status script is free software; the Free Software Foundation
gives unlimited permission to copy, distribute and modify it."
ac_pwd='$ac_pwd'
srcdir='$srcdir'
INSTALL='$INSTALL'
MKDIR_P='$MKDIR_P'
AWK='$AWK'
test -n "\$AWK" || AWK=awk
_ACEOF
# The default lists apply if the user does not specify any file.
ac_need_defaults=:
while test $# != 0
do
  case $1 in
    ac_option=`expr "X$1" : 'X\([^=]*\)='`
    ac_optarg=`expr "X$1" : 'X[^=]*=\(.*\)'`
    ac_shift=:
    ac_optarg=
    ac_shift=:
    ac_option=$1
    ac_optarg=$2
    ac_shift=shift
  case $ac_option in
  # Handling of the options.
  -recheck | --recheck | --rechec | --reche | --rech | --rec | --re | --r)
    ac_cs_recheck=: ;;
  --version | --versio | --versi | --vers | --ver | --ve | --v | -V )
    $as_echo "$ac_cs_version"; exit ;;
  --config | --confi | --conf | --con | --co | --c )
    $as_echo "$ac_cs_config"; exit ;;
  --debug | --debu | --deb | --de | --d | -d )
    debug=: ;;
  --file | --fil | --fi | --f )
    $ac_shift
    case $ac_optarg in
    *\'*) ac_optarg=`$as_echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"` ;;
    '') as_fn_error $? "missing file argument" ;;
    as_fn_append CONFIG_FILES " '$ac_optarg'"
    ac_need_defaults=false;;
  --header | --heade | --head | --hea )
    $ac_shift
    case $ac_optarg in
    as_fn_append CONFIG_HEADERS " '$ac_optarg'"
  --he | --h)
    # Conflict between --help and --header
    as_fn_error $? "ambiguous option: \`$1'
Try \`$0 --help' for more information.";;
  --help | --hel | -h )
    $as_echo "$ac_cs_usage"; exit ;;
  -q | -quiet | --quiet | --quie | --qui | --qu | --q \
  | -silent | --silent | --silen | --sile | --sil | --si | --s)
    ac_cs_silent=: ;;
  # This is an error.
  -*) as_fn_error $? "unrecognized option: \`$1'
Try \`$0 --help' for more information." ;;
  *) as_fn_append ac_config_targets " $1"
     ac_need_defaults=false ;;
  shift
ac_configure_extra_args=
if $ac_cs_silent; then
  exec 6>/dev/null
  ac_configure_extra_args="$ac_configure_extra_args --silent"
_ACEOF
if \$ac_cs_recheck; then
  set X $SHELL '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
  shift
  \$as_echo "running CONFIG_SHELL=$SHELL \$*" >&6
  CONFIG_SHELL='$SHELL'
  export CONFIG_SHELL
  exec "\$@"
_ACEOF
exec 5>>config.log
  echo
  sed 'h;s/./-/g;s/^.../## /;s/...$/ ##/;p;x;p;x' <<_ASBOX
## Running $as_me. ##
_ASBOX
  $as_echo "$ac_log"
} >&5
_ACEOF
# INIT-COMMANDS
AMDEP_TRUE="$AMDEP_TRUE" ac_aux_dir="$ac_aux_dir"
# The HP-UX ksh and POSIX shell print the target directory to stdout
# if CDPATH is set.
sed_quote_subst='$sed_quote_subst'
double_quote_subst='$double_quote_subst'
delay_variable_subst='$delay_variable_subst'
macro_version='`$ECHO "$macro_version" | $SED "$delay_single_quote_subst"`'
macro_revision='`$ECHO "$macro_revision" | $SED "$delay_single_quote_subst"`'
enable_shared='`$ECHO "$enable_shared" | $SED "$delay_single_quote_subst"`'
enable_static='`$ECHO "$enable_static" | $SED "$delay_single_quote_subst"`'
pic_mode='`$ECHO "$pic_mode" | $SED "$delay_single_quote_subst"`'
enable_fast_install='`$ECHO "$enable_fast_install" | $SED "$delay_single_quote_subst"`'
SHELL='`$ECHO "$SHELL" | $SED "$delay_single_quote_subst"`'
ECHO='`$ECHO "$ECHO" | $SED "$delay_single_quote_subst"`'
PATH_SEPARATOR='`$ECHO "$PATH_SEPARATOR" | $SED "$delay_single_quote_subst"`'
host_alias='`$ECHO "$host_alias" | $SED "$delay_single_quote_subst"`'
host='`$ECHO "$host" | $SED "$delay_single_quote_subst"`'
host_os='`$ECHO "$host_os" | $SED "$delay_single_quote_subst"`'
build_alias='`$ECHO "$build_alias" | $SED "$delay_single_quote_subst"`'
build='`$ECHO "$build" | $SED "$delay_single_quote_subst"`'
build_os='`$ECHO "$build_os" | $SED "$delay_single_quote_subst"`'
SED='`$ECHO "$SED" | $SED "$delay_single_quote_subst"`'
Xsed='`$ECHO "$Xsed" | $SED "$delay_single_quote_subst"`'
GREP='`$ECHO "$GREP" | $SED "$delay_single_quote_subst"`'
EGREP='`$ECHO "$EGREP" | $SED "$delay_single_quote_subst"`'
FGREP='`$ECHO "$FGREP" | $SED "$delay_single_quote_subst"`'
LD='`$ECHO "$LD" | $SED "$delay_single_quote_subst"`'
NM='`$ECHO "$NM" | $SED "$delay_single_quote_subst"`'
LN_S='`$ECHO "$LN_S" | $SED "$delay_single_quote_subst"`'
max_cmd_len='`$ECHO "$max_cmd_len" | $SED "$delay_single_quote_subst"`'
ac_objext='`$ECHO "$ac_objext" | $SED "$delay_single_quote_subst"`'
exeext='`$ECHO "$exeext" | $SED "$delay_single_quote_subst"`'
lt_unset='`$ECHO "$lt_unset" | $SED "$delay_single_quote_subst"`'
lt_SP2NL='`$ECHO "$lt_SP2NL" | $SED "$delay_single_quote_subst"`'
lt_NL2SP='`$ECHO "$lt_NL2SP" | $SED "$delay_single_quote_subst"`'
lt_cv_to_host_file_cmd='`$ECHO "$lt_cv_to_host_file_cmd" | $SED "$delay_single_quote_subst"`'
lt_cv_to_tool_file_cmd='`$ECHO "$lt_cv_to_tool_file_cmd" | $SED "$delay_single_quote_subst"`'
reload_flag='`$ECHO "$reload_flag" | $SED "$delay_single_quote_subst"`'
reload_cmds='`$ECHO "$reload_cmds" | $SED "$delay_single_quote_subst"`'
OBJDUMP='`$ECHO "$OBJDUMP" | $SED "$delay_single_quote_subst"`'
deplibs_check_method='`$ECHO "$deplibs_check_method" | $SED "$delay_single_quote_subst"`'
file_magic_cmd='`$ECHO "$file_magic_cmd" | $SED "$delay_single_quote_subst"`'
file_magic_glob='`$ECHO "$file_magic_glob" | $SED "$delay_single_quote_subst"`'
want_nocaseglob='`$ECHO "$want_nocaseglob" | $SED "$delay_single_quote_subst"`'
DLLTOOL='`$ECHO "$DLLTOOL" | $SED "$delay_single_quote_subst"`'
sharedlib_from_linklib_cmd='`$ECHO "$sharedlib_from_linklib_cmd" | $SED "$delay_single_quote_subst"`'
AR='`$ECHO "$AR" | $SED "$delay_single_quote_subst"`'
AR_FLAGS='`$ECHO "$AR_FLAGS" | $SED "$delay_single_quote_subst"`'
archiver_list_spec='`$ECHO "$archiver_list_spec" | $SED "$delay_single_quote_subst"`'
STRIP='`$ECHO "$STRIP" | $SED "$delay_single_quote_subst"`'
RANLIB='`$ECHO "$RANLIB" | $SED "$delay_single_quote_subst"`'
old_postinstall_cmds='`$ECHO "$old_postinstall_cmds" | $SED "$delay_single_quote_subst"`'
old_postuninstall_cmds='`$ECHO "$old_postuninstall_cmds" | $SED "$delay_single_quote_subst"`'
old_archive_cmds='`$ECHO "$old_archive_cmds" | $SED "$delay_single_quote_subst"`'
lock_old_archive_extraction='`$ECHO "$lock_old_archive_extraction" | $SED "$delay_single_quote_subst"`'
CC='`$ECHO "$CC" | $SED "$delay_single_quote_subst"`'
CFLAGS='`$ECHO "$CFLAGS" | $SED "$delay_single_quote_subst"`'
compiler='`$ECHO "$compiler" | $SED "$delay_single_quote_subst"`'
GCC='`$ECHO "$GCC" | $SED "$delay_single_quote_subst"`'
lt_cv_sys_global_symbol_pipe='`$ECHO "$lt_cv_sys_global_symbol_pipe" | $SED "$delay_single_quote_subst"`'
lt_cv_sys_global_symbol_to_cdecl='`$ECHO "$lt_cv_sys_global_symbol_to_cdecl" | $SED "$delay_single_quote_subst"`'
lt_cv_sys_global_symbol_to_c_name_address='`$ECHO "$lt_cv_sys_global_symbol_to_c_name_address" | $SED "$delay_single_quote_subst"`'
lt_cv_sys_global_symbol_to_c_name_address_lib_prefix='`$ECHO "$lt_cv_sys_global_symbol_to_c_name_address_lib_prefix" | $SED "$delay_single_quote_subst"`'
nm_file_list_spec='`$ECHO "$nm_file_list_spec" | $SED "$delay_single_quote_subst"`'
lt_sysroot='`$ECHO "$lt_sysroot" | $SED "$delay_single_quote_subst"`'
objdir='`$ECHO "$objdir" | $SED "$delay_single_quote_subst"`'
MAGIC_CMD='`$ECHO "$MAGIC_CMD" | $SED "$delay_single_quote_subst"`'
lt_prog_compiler_no_builtin_flag='`$ECHO "$lt_prog_compiler_no_builtin_flag" | $SED "$delay_single_quote_subst"`'
lt_prog_compiler_pic='`$ECHO "$lt_prog_compiler_pic" | $SED "$delay_single_quote_subst"`'
lt_prog_compiler_wl='`$ECHO "$lt_prog_compiler_wl" | $SED "$delay_single_quote_subst"`'
lt_prog_compiler_static='`$ECHO "$lt_prog_compiler_static" | $SED "$delay_single_quote_subst"`'
lt_cv_prog_compiler_c_o='`$ECHO "$lt_cv_prog_compiler_c_o" | $SED "$delay_single_quote_subst"`'
need_locks='`$ECHO "$need_locks" | $SED "$delay_single_quote_subst"`'
MANIFEST_TOOL='`$ECHO "$MANIFEST_TOOL" | $SED "$delay_single_quote_subst"`'
DSYMUTIL='`$ECHO "$DSYMUTIL" | $SED "$delay_single_quote_subst"`'
NMEDIT='`$ECHO "$NMEDIT" | $SED "$delay_single_quote_subst"`'
LIPO='`$ECHO "$LIPO" | $SED "$delay_single_quote_subst"`'
OTOOL='`$ECHO "$OTOOL" | $SED "$delay_single_quote_subst"`'
OTOOL64='`$ECHO "$OTOOL64" | $SED "$delay_single_quote_subst"`'
libext='`$ECHO "$libext" | $SED "$delay_single_quote_subst"`'
shrext_cmds='`$ECHO "$shrext_cmds" | $SED "$delay_single_quote_subst"`'
extract_expsyms_cmds='`$ECHO "$extract_expsyms_cmds" | $SED "$delay_single_quote_subst"`'
archive_cmds_need_lc='`$ECHO "$archive_cmds_need_lc" | $SED "$delay_single_quote_subst"`'
enable_shared_with_static_runtimes='`$ECHO "$enable_shared_with_static_runtimes" | $SED "$delay_single_quote_subst"`'
export_dynamic_flag_spec='`$ECHO "$export_dynamic_flag_spec" | $SED "$delay_single_quote_subst"`'
whole_archive_flag_spec='`$ECHO "$whole_archive_flag_spec" | $SED "$delay_single_quote_subst"`'
compiler_needs_object='`$ECHO "$compiler_needs_object" | $SED "$delay_single_quote_subst"`'
old_archive_from_new_cmds='`$ECHO "$old_archive_from_new_cmds" | $SED "$delay_single_quote_subst"`'
old_archive_from_expsyms_cmds='`$ECHO "$old_archive_from_expsyms_cmds" | $SED "$delay_single_quote_subst"`'
archive_cmds='`$ECHO "$archive_cmds" | $SED "$delay_single_quote_subst"`'
archive_expsym_cmds='`$ECHO "$archive_expsym_cmds" | $SED "$delay_single_quote_subst"`'
module_cmds='`$ECHO "$module_cmds" | $SED "$delay_single_quote_subst"`'
module_expsym_cmds='`$ECHO "$module_expsym_cmds" | $SED "$delay_single_quote_subst"`'
with_gnu_ld='`$ECHO "$with_gnu_ld" | $SED "$delay_single_quote_subst"`'
allow_undefined_flag='`$ECHO "$allow_undefined_flag" | $SED "$delay_single_quote_subst"`'
no_undefined_flag='`$ECHO "$no_undefined_flag" | $SED "$delay_single_quote_subst"`'
hardcode_libdir_flag_spec='`$ECHO "$hardcode_libdir_flag_spec" | $SED "$delay_single_quote_subst"`'
hardcode_libdir_separator='`$ECHO "$hardcode_libdir_separator" | $SED "$delay_single_quote_subst"`'
hardcode_direct='`$ECHO "$hardcode_direct" | $SED "$delay_single_quote_subst"`'
hardcode_direct_absolute='`$ECHO "$hardcode_direct_absolute" | $SED "$delay_single_quote_subst"`'
hardcode_minus_L='`$ECHO "$hardcode_minus_L" | $SED "$delay_single_quote_subst"`'
hardcode_shlibpath_var='`$ECHO "$hardcode_shlibpath_var" | $SED "$delay_single_quote_subst"`'
hardcode_automatic='`$ECHO "$hardcode_automatic" | $SED "$delay_single_quote_subst"`'
inherit_rpath='`$ECHO "$inherit_rpath" | $SED "$delay_single_quote_subst"`'
link_all_deplibs='`$ECHO "$link_all_deplibs" | $SED "$delay_single_quote_subst"`'
always_export_symbols='`$ECHO "$always_export_symbols" | $SED "$delay_single_quote_subst"`'
export_symbols_cmds='`$ECHO "$export_symbols_cmds" | $SED "$delay_single_quote_subst"`'
exclude_expsyms='`$ECHO "$exclude_expsyms" | $SED "$delay_single_quote_subst"`'
include_expsyms='`$ECHO "$include_expsyms" | $SED "$delay_single_quote_subst"`'
prelink_cmds='`$ECHO "$prelink_cmds" | $SED "$delay_single_quote_subst"`'
postlink_cmds='`$ECHO "$postlink_cmds" | $SED "$delay_single_quote_subst"`'
file_list_spec='`$ECHO "$file_list_spec" | $SED "$delay_single_quote_subst"`'
variables_saved_for_relink='`$ECHO "$variables_saved_for_relink" | $SED "$delay_single_quote_subst"`'
need_lib_prefix='`$ECHO "$need_lib_prefix" | $SED "$delay_single_quote_subst"`'
need_version='`$ECHO "$need_version" | $SED "$delay_single_quote_subst"`'
version_type='`$ECHO "$version_type" | $SED "$delay_single_quote_subst"`'
runpath_var='`$ECHO "$runpath_var" | $SED "$delay_single_quote_subst"`'
shlibpath_var='`$ECHO "$shlibpath_var" | $SED "$delay_single_quote_subst"`'
shlibpath_overrides_runpath='`$ECHO "$shlibpath_overrides_runpath" | $SED "$delay_single_quote_subst"`'
libname_spec='`$ECHO "$libname_spec" | $SED "$delay_single_quote_subst"`'
library_names_spec='`$ECHO "$library_names_spec" | $SED "$delay_single_quote_subst"`'
soname_spec='`$ECHO "$soname_spec" | $SED "$delay_single_quote_subst"`'
install_override_mode='`$ECHO "$install_override_mode" | $SED "$delay_single_quote_subst"`'
postinstall_cmds='`$ECHO "$postinstall_cmds" | $SED "$delay_single_quote_subst"`'
postuninstall_cmds='`$ECHO "$postuninstall_cmds" | $SED "$delay_single_quote_subst"`'
finish_cmds='`$ECHO "$finish_cmds" | $SED "$delay_single_quote_subst"`'
finish_eval='`$ECHO "$finish_eval" | $SED "$delay_single_quote_subst"`'
hardcode_into_libs='`$ECHO "$hardcode_into_libs" | $SED "$delay_single_quote_subst"`'
sys_lib_search_path_spec='`$ECHO "$sys_lib_search_path_spec" | $SED "$delay_single_quote_subst"`'
sys_lib_dlsearch_path_spec='`$ECHO "$sys_lib_dlsearch_path_spec" | $SED "$delay_single_quote_subst"`'
hardcode_action='`$ECHO "$hardcode_action" | $SED "$delay_single_quote_subst"`'
enable_dlopen='`$ECHO "$enable_dlopen" | $SED "$delay_single_quote_subst"`'
enable_dlopen_self='`$ECHO "$enable_dlopen_self" | $SED "$delay_single_quote_subst"`'
enable_dlopen_self_static='`$ECHO "$enable_dlopen_self_static" | $SED "$delay_single_quote_subst"`'
old_striplib='`$ECHO "$old_striplib" | $SED "$delay_single_quote_subst"`'
striplib='`$ECHO "$striplib" | $SED "$delay_single_quote_subst"`'
compiler_lib_search_dirs='`$ECHO "$compiler_lib_search_dirs" | $SED "$delay_single_quote_subst"`'
predep_objects='`$ECHO "$predep_objects" | $SED "$delay_single_quote_subst"`'
postdep_objects='`$ECHO "$postdep_objects" | $SED "$delay_single_quote_subst"`'
predeps='`$ECHO "$predeps" | $SED "$delay_single_quote_subst"`'
postdeps='`$ECHO "$postdeps" | $SED "$delay_single_quote_subst"`'
compiler_lib_search_path='`$ECHO "$compiler_lib_search_path" | $SED "$delay_single_quote_subst"`'
LD_CXX='`$ECHO "$LD_CXX" | $SED "$delay_single_quote_subst"`'
reload_flag_CXX='`$ECHO "$reload_flag_CXX" | $SED "$delay_single_quote_subst"`'
reload_cmds_CXX='`$ECHO "$reload_cmds_CXX" | $SED "$delay_single_quote_subst"`'
old_archive_cmds_CXX='`$ECHO "$old_archive_cmds_CXX" | $SED "$delay_single_quote_subst"`'
compiler_CXX='`$ECHO "$compiler_CXX" | $SED "$delay_single_quote_subst"`'
GCC_CXX='`$ECHO "$GCC_CXX" | $SED "$delay_single_quote_subst"`'
lt_prog_compiler_no_builtin_flag_CXX='`$ECHO "$lt_prog_compiler_no_builtin_flag_CXX" | $SED "$delay_single_quote_subst"`'
lt_prog_compiler_pic_CXX='`$ECHO "$lt_prog_compiler_pic_CXX" | $SED "$delay_single_quote_subst"`'
lt_prog_compiler_wl_CXX='`$ECHO "$lt_prog_compiler_wl_CXX" | $SED "$delay_single_quote_subst"`'
lt_prog_compiler_static_CXX='`$ECHO "$lt_prog_compiler_static_CXX" | $SED "$delay_single_quote_subst"`'
lt_cv_prog_compiler_c_o_CXX='`$ECHO "$lt_cv_prog_compiler_c_o_CXX" | $SED "$delay_single_quote_subst"`'
archive_cmds_need_lc_CXX='`$ECHO "$archive_cmds_need_lc_CXX" | $SED "$delay_single_quote_subst"`'
enable_shared_with_static_runtimes_CXX='`$ECHO "$enable_shared_with_static_runtimes_CXX" | $SED "$delay_single_quote_subst"`'
export_dynamic_flag_spec_CXX='`$ECHO "$export_dynamic_flag_spec_CXX" | $SED "$delay_single_quote_subst"`'
whole_archive_flag_spec_CXX='`$ECHO "$whole_archive_flag_spec_CXX" | $SED "$delay_single_quote_subst"`'
compiler_needs_object_CXX='`$ECHO "$compiler_needs_object_CXX" | $SED "$delay_single_quote_subst"`'
old_archive_from_new_cmds_CXX='`$ECHO "$old_archive_from_new_cmds_CXX" | $SED "$delay_single_quote_subst"`'
old_archive_from_expsyms_cmds_CXX='`$ECHO "$old_archive_from_expsyms_cmds_CXX" | $SED "$delay_single_quote_subst"`'
archive_cmds_CXX='`$ECHO "$archive_cmds_CXX" | $SED "$delay_single_quote_subst"`'
archive_expsym_cmds_CXX='`$ECHO "$archive_expsym_cmds_CXX" | $SED "$delay_single_quote_subst"`'
module_cmds_CXX='`$ECHO "$module_cmds_CXX" | $SED "$delay_single_quote_subst"`'
module_expsym_cmds_CXX='`$ECHO "$module_expsym_cmds_CXX" | $SED "$delay_single_quote_subst"`'
with_gnu_ld_CXX='`$ECHO "$with_gnu_ld_CXX" | $SED "$delay_single_quote_subst"`'
allow_undefined_flag_CXX='`$ECHO "$allow_undefined_flag_CXX" | $SED "$delay_single_quote_subst"`'
no_undefined_flag_CXX='`$ECHO "$no_undefined_flag_CXX" | $SED "$delay_single_quote_subst"`'
hardcode_libdir_flag_spec_CXX='`$ECHO "$hardcode_libdir_flag_spec_CXX" | $SED "$delay_single_quote_subst"`'
hardcode_libdir_separator_CXX='`$ECHO "$hardcode_libdir_separator_CXX" | $SED "$delay_single_quote_subst"`'
hardcode_direct_CXX='`$ECHO "$hardcode_direct_CXX" | $SED "$delay_single_quote_subst"`'
hardcode_direct_absolute_CXX='`$ECHO "$hardcode_direct_absolute_CXX" | $SED "$delay_single_quote_subst"`'
hardcode_minus_L_CXX='`$ECHO "$hardcode_minus_L_CXX" | $SED "$delay_single_quote_subst"`'
hardcode_shlibpath_var_CXX='`$ECHO "$hardcode_shlibpath_var_CXX" | $SED "$delay_single_quote_subst"`'
hardcode_automatic_CXX='`$ECHO "$hardcode_automatic_CXX" | $SED "$delay_single_quote_subst"`'
inherit_rpath_CXX='`$ECHO "$inherit_rpath_CXX" | $SED "$delay_single_quote_subst"`'
link_all_deplibs_CXX='`$ECHO "$link_all_deplibs_CXX" | $SED "$delay_single_quote_subst"`'
always_export_symbols_CXX='`$ECHO "$always_export_symbols_CXX" | $SED "$delay_single_quote_subst"`'
export_symbols_cmds_CXX='`$ECHO "$export_symbols_cmds_CXX" | $SED "$delay_single_quote_subst"`'
exclude_expsyms_CXX='`$ECHO "$exclude_expsyms_CXX" | $SED "$delay_single_quote_subst"`'
include_expsyms_CXX='`$ECHO "$include_expsyms_CXX" | $SED "$delay_single_quote_subst"`'
prelink_cmds_CXX='`$ECHO "$prelink_cmds_CXX" | $SED "$delay_single_quote_subst"`'
postlink_cmds_CXX='`$ECHO "$postlink_cmds_CXX" | $SED "$delay_single_quote_subst"`'
file_list_spec_CXX='`$ECHO "$file_list_spec_CXX" | $SED "$delay_single_quote_subst"`'
hardcode_action_CXX='`$ECHO "$hardcode_action_CXX" | $SED "$delay_single_quote_subst"`'
compiler_lib_search_dirs_CXX='`$ECHO "$compiler_lib_search_dirs_CXX" | $SED "$delay_single_quote_subst"`'
predep_objects_CXX='`$ECHO "$predep_objects_CXX" | $SED "$delay_single_quote_subst"`'
postdep_objects_CXX='`$ECHO "$postdep_objects_CXX" | $SED "$delay_single_quote_subst"`'
predeps_CXX='`$ECHO "$predeps_CXX" | $SED "$delay_single_quote_subst"`'
postdeps_CXX='`$ECHO "$postdeps_CXX" | $SED "$delay_single_quote_subst"`'
compiler_lib_search_path_CXX='`$ECHO "$compiler_lib_search_path_CXX" | $SED "$delay_single_quote_subst"`'
LTCC='$LTCC'
LTCFLAGS='$LTCFLAGS'
compiler='$compiler_DEFAULT'
# A function that is used when there is no print builtin or printf.
func_fallback_echo ()
  eval 'cat <<_LTECHO_EOF
\$1
_LTECHO_EOF'
# Quote evaled strings.
for var in SHELL \
ECHO \
PATH_SEPARATOR \
SED \
GREP \
EGREP \
FGREP \
LD \
NM \
LN_S \
lt_SP2NL \
lt_NL2SP \
reload_flag \
OBJDUMP \
deplibs_check_method \
file_magic_cmd \
file_magic_glob \
want_nocaseglob \
DLLTOOL \
sharedlib_from_linklib_cmd \
AR \
AR_FLAGS \
archiver_list_spec \
STRIP \
RANLIB \
CC \
CFLAGS \
compiler \
lt_cv_sys_global_symbol_pipe \
lt_cv_sys_global_symbol_to_cdecl \
lt_cv_sys_global_symbol_to_c_name_address \
lt_cv_sys_global_symbol_to_c_name_address_lib_prefix \
nm_file_list_spec \
lt_prog_compiler_no_builtin_flag \
lt_prog_compiler_pic \
lt_prog_compiler_wl \
lt_prog_compiler_static \
lt_cv_prog_compiler_c_o \
need_locks \
MANIFEST_TOOL \
DSYMUTIL \
NMEDIT \
LIPO \
OTOOL \
OTOOL64 \
shrext_cmds \
export_dynamic_flag_spec \
whole_archive_flag_spec \
compiler_needs_object \
with_gnu_ld \
allow_undefined_flag \
no_undefined_flag \
hardcode_libdir_flag_spec \
hardcode_libdir_separator \
exclude_expsyms \
include_expsyms \
file_list_spec \
variables_saved_for_relink \
libname_spec \
library_names_spec \
soname_spec \
install_override_mode \
finish_eval \
old_striplib \
striplib \
compiler_lib_search_dirs \
predep_objects \
postdep_objects \
predeps \
postdeps \
compiler_lib_search_path \
LD_CXX \
reload_flag_CXX \
compiler_CXX \
lt_prog_compiler_no_builtin_flag_CXX \
lt_prog_compiler_pic_CXX \
lt_prog_compiler_wl_CXX \
lt_prog_compiler_static_CXX \
lt_cv_prog_compiler_c_o_CXX \
export_dynamic_flag_spec_CXX \
whole_archive_flag_spec_CXX \
compiler_needs_object_CXX \
with_gnu_ld_CXX \
allow_undefined_flag_CXX \
no_undefined_flag_CXX \
hardcode_libdir_flag_spec_CXX \
hardcode_libdir_separator_CXX \
exclude_expsyms_CXX \
include_expsyms_CXX \
file_list_spec_CXX \
compiler_lib_search_dirs_CXX \
predep_objects_CXX \
postdep_objects_CXX \
predeps_CXX \
postdeps_CXX \
compiler_lib_search_path_CXX; do
    case \`eval \\\\\$ECHO \\\\""\\\\\$\$var"\\\\"\` in
      eval "lt_\$var=\\\\\\"\\\`\\\$ECHO \\"\\\$\$var\\" | \\\$SED \\"\\\$sed_quote_subst\\"\\\`\\\\\\""
      eval "lt_\$var=\\\\\\"\\\$\$var\\\\\\""
# Double-quote double-evaled strings.
for var in reload_cmds \
old_postinstall_cmds \
old_postuninstall_cmds \
old_archive_cmds \
extract_expsyms_cmds \
old_archive_from_new_cmds \
old_archive_from_expsyms_cmds \
archive_cmds \
archive_expsym_cmds \
module_cmds \
module_expsym_cmds \
export_symbols_cmds \
prelink_cmds \
postlink_cmds \
postinstall_cmds \
finish_cmds \
sys_lib_search_path_spec \
sys_lib_dlsearch_path_spec \
reload_cmds_CXX \
old_archive_cmds_CXX \
old_archive_from_new_cmds_CXX \
old_archive_from_expsyms_cmds_CXX \
archive_cmds_CXX \
archive_expsym_cmds_CXX \
module_cmds_CXX \
module_expsym_cmds_CXX \
export_symbols_cmds_CXX \
prelink_cmds_CXX \
postlink_cmds_CXX; do
      eval "lt_\$var=\\\\\\"\\\`\\\$ECHO \\"\\\$\$var\\" | \\\$SED -e \\"\\\$double_quote_subst\\" -e \\"\\\$sed_quote_subst\\" -e \\"\\\$delay_variable_subst\\"\\\`\\\\\\""
ac_aux_dir='$ac_aux_dir'
xsi_shell='$xsi_shell'
lt_shell_append='$lt_shell_append'
# See if we are running on zsh, and set the options which allow our
# commands through without removal of \ escapes INIT.
if test -n "\${ZSH_VERSION+set}" ; then
    PACKAGE='$PACKAGE'
    VERSION='$VERSION'
    TIMESTAMP='$TIMESTAMP'
    RM='$RM'
    ofile='$ofile'
_ACEOF
# Handling of arguments.
for ac_config_target in $ac_config_targets
do
  case $ac_config_target in
    "config.h") CONFIG_HEADERS="$CONFIG_HEADERS config.h" ;;
    "depfiles") CONFIG_COMMANDS="$CONFIG_COMMANDS depfiles" ;;
    "libtool") CONFIG_COMMANDS="$CONFIG_COMMANDS libtool" ;;
    "libqvcloud.pc") CONFIG_FILES="$CONFIG_FILES libqvcloud.pc" ;;
    "Makefile") CONFIG_FILES="$CONFIG_FILES Makefile" ;;
    "lib/Makefile") CONFIG_FILES="$CONFIG_FILES lib/Makefile" ;;
    "src/Makefile") CONFIG_FILES="$CONFIG_FILES src/Makefile" ;;
  *) as_fn_error $? "invalid argument: \`$ac_config_target'" "$LINENO" 5;;
# If the user did not use the arguments to specify the items to instantiate,
# then the envvar interface is used.  Set only those that are not.
# We use the long form for the default assignment because of an extremely
# bizarre bug on SunOS 4.1.3.
if $ac_need_defaults; then
  test "${CONFIG_FILES+set}" = set || CONFIG_FILES=$config_files
  test "${CONFIG_HEADERS+set}" = set || CONFIG_HEADERS=$config_headers
  test "${CONFIG_COMMANDS+set}" = set || CONFIG_COMMANDS=$config_commands
# Have a temporary directory for convenience.  Make it in the build tree
# simply because there is no reason against having it here, and in addition,
# creating and moving files from /tmp can sometimes cause problems.
# Hook for its removal unless debugging.
# Note that there is a small window in which the directory will not be cleaned:
# after its creation but before its name has been assigned to `$tmp'.
$debug ||
  tmp= ac_tmp=
  trap 'exit_status=$?
  : "${ac_tmp:=$tmp}"
  { test ! -d "$ac_tmp" || rm -fr "$ac_tmp"; } && exit $exit_status
' 0
  trap 'as_fn_exit 1' 1 2 13 15
# Create a (secure) tmp directory for tmp files.
  tmp=`(umask 077 && mktemp -d "./confXXXXXX") 2>/dev/null` &&
  test -d "$tmp"
  tmp=./conf$$-$RANDOM
  (umask 077 && mkdir "$tmp")
} || as_fn_error $? "cannot create a temporary directory in ." "$LINENO" 5
ac_tmp=$tmp
# Set up the scripts for CONFIG_FILES section.
# No need to generate them if there are no CONFIG_FILES.
# This happens for instance with `./config.status config.h'.
if test -n "$CONFIG_FILES"; then
ac_cr=`echo X | tr X '\015'`
# On cygwin, bash can eat \r inside `` if the user requested igncr.
# But we know of no other shell where ac_cr would be empty at this
# point, so we can use a bashism as a fallback.
if test "x$ac_cr" = x; then
  eval ac_cr=\$\'\\r\'
ac_cs_awk_cr=`$AWK 'BEGIN { print "a\rb" }' </dev/null 2>/dev/null`
if test "$ac_cs_awk_cr" = "a${ac_cr}b"; then
  ac_cs_awk_cr='\\r'
  ac_cs_awk_cr=$ac_cr
echo 'BEGIN {' >"$ac_tmp/subs1.awk" &&
_ACEOF
  echo "cat >conf$$subs.awk <<_ACEOF" &&
  echo "$ac_subst_vars" | sed 's/.*/&!$&$ac_delim/' &&
  echo "_ACEOF"
} >conf$$subs.sh ||
  as_fn_error $? "could not make $CONFIG_STATUS" "$LINENO" 5
ac_delim_num=`echo "$ac_subst_vars" | grep -c '^'`
ac_delim='%!_!# '
for ac_last_try in false false false false false :; do
  . ./conf$$subs.sh ||
  ac_delim_n=`sed -n "s/.*$ac_delim\$/X/p" conf$$subs.awk | grep -c X`
  if test $ac_delim_n = $ac_delim_num; then
    break
  elif $ac_last_try; then
    ac_delim="$ac_delim!$ac_delim _$ac_delim!! "
rm -f conf$$subs.sh
cat >>"\$ac_tmp/subs1.awk" <<\\_ACAWK &&
_ACEOF
sed -n '
h
s/^/S["/; s/!.*/"]=/
p
g
s/^[^!]*!//
:repl
t repl
s/'"$ac_delim"'$//
t delim
:nl
h
s/\(.\{148\}\)..*/\1/
t more1
s/["\\]/\\&/g; s/^/"/; s/$/\\n"\\/
p
n
b repl
:more1
s/["\\]/\\&/g; s/^/"/; s/$/"\\/
p
g
s/.\{148\}//
t nl
:delim
h
t more2
s/["\\]/\\&/g; s/^/"/; s/$/"/
p
b
:more2
p
g
s/.\{148\}//
t delim
' <conf$$subs.awk | sed '
  N
  s/\n//
' >>$CONFIG_STATUS || ac_write_fail=1
rm -f conf$$subs.awk
_ACAWK
cat >>"\$ac_tmp/subs1.awk" <<_ACAWK &&
  for (key in S) S_is_set[key] = 1
  FS = ""
  line = $ 0
  nfields = split(line, field, "@")
  substed = 0
  len = length(field[1])
  for (i = 2; i < nfields; i++) {
    key = field[i]
    keylen = length(key)
    if (S_is_set[key]) {
      value = S[key]
      line = substr(line, 1, len) "" value "" substr(line, len + keylen + 3)
      len += length(value) + length(field[++i])
      substed = 1
    } else
      len += 1 + keylen
  print line
_ACAWK
_ACEOF
if sed "s/$ac_cr//" < /dev/null > /dev/null 2>&1; then
  sed "s/$ac_cr\$//; s/$ac_cr/$ac_cs_awk_cr/g"
  cat
fi < "$ac_tmp/subs1.awk" > "$ac_tmp/subs.awk" \
  || as_fn_error $? "could not setup config files machinery" "$LINENO" 5
_ACEOF
# VPATH may cause trouble with some makes, so we remove sole $(srcdir),
# ${srcdir} and @srcdir@ entries from VPATH if srcdir is ".", strip leading and
# trailing colons and then remove the whole line if VPATH becomes empty
# (actually we leave an empty line to preserve line numbers).
if test "x$srcdir" = x.; then
  ac_vpsub='/^[	 ]*VPATH[	 ]*=[	 ]*/{
h
s///
s/^/:/
s/[	 ]*$/:/
s/:\$(srcdir):/:/g
s/:\${srcdir}:/:/g
s/:@srcdir@:/:/g
s/^:*//
s/:*$//
x
s/\(=[	 ]*\).*/\1/
G
s/\n//
s/^[^=]*=[	 ]*$//
fi # test -n "$CONFIG_FILES"
# Set up the scripts for CONFIG_HEADERS section.
# No need to generate them if there are no CONFIG_HEADERS.
# This happens for instance with `./config.status Makefile'.
if test -n "$CONFIG_HEADERS"; then
cat >"$ac_tmp/defines.awk" <<\_ACAWK ||
BEGIN {
_ACEOF
# Transform confdefs.h into an awk script `defines.awk', embedded as
# here-document in config.status, that substitutes the proper values into
# config.h.in to produce config.h.
# Create a delimiter string that does not exist in confdefs.h, to ease
# handling of long lines.
ac_delim='%!_!# '
for ac_last_try in false false :; do
  ac_tt=`sed -n "/$ac_delim/p" confdefs.h`
  if test -z "$ac_tt"; then
    break
    as_fn_error $? "could not make $CONFIG_HEADERS" "$LINENO" 5
# For the awk script, D is an array of macro values keyed by name,
# likewise P contains macro parameters if any.  Preserve backslash
# newline sequences.
ac_word_re=[_$as_cr_Letters][_$as_cr_alnum]*
sed -n '
s/.\{148\}/&'"$ac_delim"'/g
t rset
:rset
s/^[	 ]*#[	 ]*define[	 ][	 ]*/ /
t def
d
:def
s/\\$//
t bsnl
s/["\\]/\\&/g
s/^ \('"$ac_word_re"'\)\(([^()]*)\)[	 ]*\(.*\)/P["\1"]="\2"\
D["\1"]=" \3"/p
s/^ \('"$ac_word_re"'\)[	 ]*\(.*\)/D["\1"]=" \2"/p
d
:bsnl
s/["\\]/\\&/g
D["\1"]=" \3\\\\\\n"\\/p
t cont
s/^ \('"$ac_word_re"'\)[	 ]*\(.*\)/D["\1"]=" \2\\\\\\n"\\/p
t cont
d
:cont
n
t clear
:clear
s/\\$//
t bsnlc
s/["\\]/\\&/g; s/^/"/; s/$/"/p
d
:bsnlc
s/["\\]/\\&/g; s/^/"/; s/$/\\\\\\n"\\/p
b cont
' <confdefs.h | sed '
s/'"$ac_delim"'/"\\\
"/g' >>$CONFIG_STATUS || ac_write_fail=1
  for (key in D) D_is_set[key] = 1
  FS = ""
/^[\t ]*#[\t ]*(define|undef)[\t ]+$ac_word_re([\t (]|\$)/ {
  line = \$ 0
  split(line, arg, " ")
  if (arg[1] == "#") {
    defundef = arg[2]
    mac1 = arg[3]
    defundef = substr(arg[1], 2)
    mac1 = arg[2]
  split(mac1, mac2, "(") #)
  macro = mac2[1]
  prefix = substr(line, 1, index(line, defundef) - 1)
  if (D_is_set[macro]) {
    # Preserve the white space surrounding the "#".
    print prefix "define", macro P[macro] D[macro]
    next
    # Replace #undef with comments.  This is necessary, for example,
    # in the case of _POSIX_SOURCE, which is predefined and required
    # on some systems where configure will not decide to define it.
    if (defundef == "undef") {
      print "/*", prefix defundef, macro, "*/"
      next
{ print }
_ACAWK
_ACEOF
  as_fn_error $? "could not setup config headers machinery" "$LINENO" 5
fi # test -n "$CONFIG_HEADERS"
eval set X "  :F $CONFIG_FILES  :H $CONFIG_HEADERS    :C $CONFIG_COMMANDS"
shift
for ac_tag
do
  case $ac_tag in
  :[FHLC]) ac_mode=$ac_tag; continue;;
  case $ac_mode$ac_tag in
  :[FHL]*:*);;
  :L* | :C*:*) as_fn_error $? "invalid tag \`$ac_tag'" "$LINENO" 5;;
  :[FH]-) ac_tag=-:-;;
  :[FH]*) ac_tag=$ac_tag:$ac_tag.in;;
  ac_save_IFS=$IFS
  IFS=:
  set x $ac_tag
  IFS=$ac_save_IFS
  shift
  ac_file=$1
  shift
  case $ac_mode in
  :L) ac_source=$1;;
  :[FH])
    ac_file_inputs=
    for ac_f
    do
      case $ac_f in
      -) ac_f="$ac_tmp/stdin";;
      *) # Look for the file first in the build tree, then in the source tree
	 # (if the path is not absolute).  The absolute path cannot be DOS-style,
	 # because $ac_f cannot contain `:'.
	 test -f "$ac_f" ||
	   case $ac_f in
	   [\\/$]*) false;;
	   *) test -f "$srcdir/$ac_f" && ac_f="$srcdir/$ac_f";;
	   esac ||
	   as_fn_error 1 "cannot find input file: \`$ac_f'" "$LINENO" 5;;
      case $ac_f in *\'*) ac_f=`$as_echo "$ac_f" | sed "s/'/'\\\\\\\\''/g"`;; esac
      as_fn_append ac_file_inputs " '$ac_f'"
    # Let's still pretend it is `configure' which instantiates (i.e., don't
    # use $as_me), people would be surprised to read:
    #    /* config.h.  Generated by config.status.  */
    configure_input='Generated from '`
	  $as_echo "$*" | sed 's|^[^:]*/||;s|:[^:]*/|, |g'
	`' by configure.'
    if test x"$ac_file" != x-; then
      configure_input="$ac_file.  $configure_input"
      { $as_echo "$as_me:${as_lineno-$LINENO}: creating $ac_file" >&5
$as_echo "$as_me: creating $ac_file" >&6;}
    # Neutralize special characters interpreted by sed in replacement strings.
    case $configure_input in #(
       ac_sed_conf_input=`$as_echo "$configure_input" |
       sed 's/[\\\\&|]/\\\\&/g'`;; #(
    *) ac_sed_conf_input=$configure_input;;
    case $ac_tag in
    *:-:* | *:-) cat >"$ac_tmp/stdin" \
      || as_fn_error $? "could not create $ac_file" "$LINENO" 5 ;;
  ac_dir=`$as_dirname -- "$ac_file" ||
$as_expr X"$ac_file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
	 X"$ac_file" : 'X\(//\)[^/]' \| \
	 X"$ac_file" : 'X\(//\)$' \| \
	 X"$ac_file" : 'X\(/\)' \| . 2>/dev/null ||
$as_echo X"$ac_file" |
	    s//\1/
	    q
	  /^X\(\/\/\)[^/].*/{
	    s//\1/
	    q
	  /^X\(\/\/\)$/{
	    s//\1/
	    q
	  /^X\(\/\).*/{
	    s//\1/
	    q
	  s/.*/./; q'`
  as_dir="$ac_dir"; as_fn_mkdir_p
  ac_builddir=.
case "$ac_dir" in
.) ac_dir_suffix= ac_top_builddir_sub=. ac_top_build_prefix= ;;
  ac_dir_suffix=/`$as_echo "$ac_dir" | sed 's|^\.[\\/]||'`
  # A ".." for each directory in $ac_dir_suffix.
  ac_top_builddir_sub=`$as_echo "$ac_dir_suffix" | sed 's|/[^\\/]*|/..|g;s|/||'`
  case $ac_top_builddir_sub in
  "") ac_top_builddir_sub=. ac_top_build_prefix= ;;
  *)  ac_top_build_prefix=$ac_top_builddir_sub/ ;;
  esac ;;
ac_abs_top_builddir=$ac_pwd
ac_abs_builddir=$ac_pwd$ac_dir_suffix
# for backward compatibility:
ac_top_builddir=$ac_top_build_prefix
case $srcdir in
  .)  # We are building in place.
    ac_srcdir=.
    ac_top_srcdir=$ac_top_builddir_sub
    ac_abs_top_srcdir=$ac_pwd ;;
  [\\/]* | ?:[\\/]* )  # Absolute name.
    ac_srcdir=$srcdir$ac_dir_suffix;
    ac_top_srcdir=$srcdir
    ac_abs_top_srcdir=$srcdir ;;
  *) # Relative name.
    ac_srcdir=$ac_top_build_prefix$srcdir$ac_dir_suffix
    ac_top_srcdir=$ac_top_build_prefix$srcdir
    ac_abs_top_srcdir=$ac_pwd/$srcdir ;;
ac_abs_srcdir=$ac_abs_top_srcdir$ac_dir_suffix
  case $ac_mode in
  :F)
  # CONFIG_FILE
  case $INSTALL in
  [\\/$]* | ?:[\\/]* ) ac_INSTALL=$INSTALL ;;
  *) ac_INSTALL=$ac_top_build_prefix$INSTALL ;;
  ac_MKDIR_P=$MKDIR_P
  case $MKDIR_P in
  */*) ac_MKDIR_P=$ac_top_build_prefix$MKDIR_P ;;
_ACEOF
# If the template does not know about datarootdir, expand it.
# FIXME: This hack should be removed a few years after 2.60.
ac_datarootdir_hack=; ac_datarootdir_seen=
ac_sed_dataroot='
/datarootdir/ {
  p
  q
/@datadir@/p
/@docdir@/p
/@infodir@/p
/@localedir@/p
/@mandir@/p'
case `eval "sed -n \"\$ac_sed_dataroot\" $ac_file_inputs"` in
*datarootdir*) ac_datarootdir_seen=yes;;
*@datadir@*|*@docdir@*|*@infodir@*|*@localedir@*|*@mandir@*)
  { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5
$as_echo "$as_me: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&2;}
_ACEOF
  ac_datarootdir_hack='
  s&@datadir@&$datadir&g
  s&@docdir@&$docdir&g
  s&@infodir@&$infodir&g
  s&@localedir@&$localedir&g
  s&@mandir@&$mandir&g
  s&\\\${datarootdir}&$datarootdir&g' ;;
_ACEOF
# Neutralize VPATH when `$srcdir' = `.'.
# Shell code in configure.ac might set extrasub.
# FIXME: do we really want to maintain this feature?
ac_sed_extra="$ac_vpsub
$extrasub
_ACEOF
:t
/@[a-zA-Z_][a-zA-Z_0-9]*@/!b
s|@configure_input@|$ac_sed_conf_input|;t t
s&@top_builddir@&$ac_top_builddir_sub&;t t
s&@top_build_prefix@&$ac_top_build_prefix&;t t
s&@srcdir@&$ac_srcdir&;t t
s&@abs_srcdir@&$ac_abs_srcdir&;t t
s&@top_srcdir@&$ac_top_srcdir&;t t
s&@abs_top_srcdir@&$ac_abs_top_srcdir&;t t
s&@builddir@&$ac_builddir&;t t
s&@abs_builddir@&$ac_abs_builddir&;t t
s&@abs_top_builddir@&$ac_abs_top_builddir&;t t
s&@INSTALL@&$ac_INSTALL&;t t
s&@MKDIR_P@&$ac_MKDIR_P&;t t
$ac_datarootdir_hack
eval sed \"\$ac_sed_extra\" "$ac_file_inputs" | $AWK -f "$ac_tmp/subs.awk" \
  >$ac_tmp/out || as_fn_error $? "could not create $ac_file" "$LINENO" 5
test -z "$ac_datarootdir_hack$ac_datarootdir_seen" &&
  { ac_out=`sed -n '/\${datarootdir}/p' "$ac_tmp/out"`; test -n "$ac_out"; } &&
  { ac_out=`sed -n '/^[	 ]*datarootdir[	 ]*:*=/p' \
      "$ac_tmp/out"`; test -z "$ac_out"; } &&
  { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file contains a reference to the variable \`datarootdir'
which seems to be undefined.  Please make sure it is defined" >&5
$as_echo "$as_me: WARNING: $ac_file contains a reference to the variable \`datarootdir'
which seems to be undefined.  Please make sure it is defined" >&2;}
  rm -f "$ac_tmp/stdin"
  case $ac_file in
  -) cat "$ac_tmp/out" && rm -f "$ac_tmp/out";;
  *) rm -f "$ac_file" && mv "$ac_tmp/out" "$ac_file";;
  esac \
  :H)
  # CONFIG_HEADER
      $as_echo "/* $configure_input  */" \
      && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs"
    } >"$ac_tmp/config.h" \
    if diff "$ac_file" "$ac_tmp/config.h" >/dev/null 2>&1; then
      { $as_echo "$as_me:${as_lineno-$LINENO}: $ac_file is unchanged" >&5
$as_echo "$as_me: $ac_file is unchanged" >&6;}
      rm -f "$ac_file"
      mv "$ac_tmp/config.h" "$ac_file" \
      && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs" \
      || as_fn_error $? "could not create -" "$LINENO" 5
# Compute "$ac_file"'s index in $config_headers.
_am_arg="$ac_file"
_am_stamp_count=1
for _am_header in $config_headers :; do
  case $_am_header in
    $_am_arg | $_am_arg:* )
      break ;;
      _am_stamp_count=`expr $_am_stamp_count + 1` ;;
echo "timestamp for $_am_arg" >`$as_dirname -- "$_am_arg" ||
$as_expr X"$_am_arg" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
	 X"$_am_arg" : 'X\(//\)[^/]' \| \
	 X"$_am_arg" : 'X\(//\)$' \| \
	 X"$_am_arg" : 'X\(/\)' \| . 2>/dev/null ||
$as_echo X"$_am_arg" |
	    s//\1/
	    q
	  /^X\(\/\/\)[^/].*/{
	    s//\1/
	    q
	  /^X\(\/\/\)$/{
	    s//\1/
	    q
	  /^X\(\/\).*/{
	    s//\1/
	    q
	  s/.*/./; q'`/stamp-h$_am_stamp_count
  :C)  { $as_echo "$as_me:${as_lineno-$LINENO}: executing $ac_file commands" >&5
$as_echo "$as_me: executing $ac_file commands" >&6;}
  case $ac_file$ac_mode in
    "depfiles":C) test x"$AMDEP_TRUE" != x"" || {
  # Older Autoconf quotes --file arguments for eval, but not when files
  # are listed without --file.  Let's play safe and only enable the eval
  # if we detect the quoting.
  case $CONFIG_FILES in
  *\'*) eval set x "$CONFIG_FILES" ;;
  *)   set x $CONFIG_FILES ;;
  shift
  for mf
  do
    # Strip MF so we end up with the name of the file.
    mf=`echo "$mf" | sed -e 's/:.*$//'`
    # Check whether this is an Automake generated Makefile or not.
    # We used to match only the files named 'Makefile.in', but
    # some people rename them; so instead we look at the file content.
    # Grep'ing the first line is not enough: some people post-process
    # each Makefile.in and add a new line on top of each file to say so.
    # Grep'ing the whole file is not good either: AIX grep has a line
    # limit of 2048, but all sed's we know have understand at least 4000.
    if sed -n 's,^#.*generated by automake.*,X,p' "$mf" | grep X >/dev/null 2>&1; then
      dirpart=`$as_dirname -- "$mf" ||
$as_expr X"$mf" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
	 X"$mf" : 'X\(//\)[^/]' \| \
	 X"$mf" : 'X\(//\)$' \| \
	 X"$mf" : 'X\(/\)' \| . 2>/dev/null ||
$as_echo X"$mf" |
	    s//\1/
	    q
	  /^X\(\/\/\)[^/].*/{
	    s//\1/
	    q
	  /^X\(\/\/\)$/{
	    s//\1/
	    q
	  /^X\(\/\).*/{
	    s//\1/
	    q
	  s/.*/./; q'`
      continue
    # Extract the definition of DEPDIR, am__include, and am__quote
    # from the Makefile without running 'make'.
    DEPDIR=`sed -n 's/^DEPDIR = //p' < "$mf"`
    test -z "$DEPDIR" && continue
    am__include=`sed -n 's/^am__include = //p' < "$mf"`
    test -z "$am__include" && continue
    am__quote=`sed -n 's/^am__quote = //p' < "$mf"`
    # Find all dependency output files, they are included files with
    # $(DEPDIR) in their names.  We invoke sed twice because it is the
    # simplest approach to changing $(DEPDIR) to its actual value in the
    # expansion.
    for file in `sed -n "
      s/^$am__include $am__quote\(.*(DEPDIR).*\)$am__quote"'$/\1/p' <"$mf" | \
	 sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g'`; do
      # Make sure the directory exists.
      test -f "$dirpart/$file" && continue
      fdir=`$as_dirname -- "$file" ||
$as_expr X"$file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
	 X"$file" : 'X\(//\)[^/]' \| \
	 X"$file" : 'X\(//\)$' \| \
	 X"$file" : 'X\(/\)' \| . 2>/dev/null ||
$as_echo X"$file" |
	    s//\1/
	    q
	  /^X\(\/\/\)[^/].*/{
	    s//\1/
	    q
	  /^X\(\/\/\)$/{
	    s//\1/
	    q
	  /^X\(\/\).*/{
	    s//\1/
	    q
	  s/.*/./; q'`
      as_dir=$dirpart/$fdir; as_fn_mkdir_p
      # echo "creating $dirpart/$file"
      echo '# dummy' > "$dirpart/$file"
    "libtool":C)
    # commands through without removal of \ escapes.
    if test -n "${ZSH_VERSION+set}" ; then
    cfgfile="${ofile}T"
    trap "$RM \"$cfgfile\"; exit 1" 1 2 15
    $RM "$cfgfile"
    cat <<_LT_EOF >> "$cfgfile"
#! $SHELL
# `$ECHO "$ofile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
# Generated automatically by $as_me ($PACKAGE$TIMESTAMP) $VERSION
# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
# NOTE: Changes made to this file will be lost: look at ltmain.sh.
#   Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2003, 2004, 2005,
#                 2006, 2007, 2008, 2009, 2010, 2011 Free Software
#                 Foundation, Inc.
#   Written by Gordon Matzigkeit, 1996
#   This file is part of GNU Libtool.
# GNU Libtool is free software; you can redistribute it and/or
# modify it under the terms of the GNU General Public License as
# published by the Free Software Foundation; either version 2 of
# the License, or (at your option) any later version.
# As a special exception to the GNU General Public License,
# if you distribute this file as part of a program or library that
# is built using GNU Libtool, you may include this file under the
# same distribution terms that you use for the rest of that program.
# GNU Libtool is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with GNU Libtool; see the file COPYING.  If not, a copy
# can be downloaded from http://www.gnu.org/licenses/gpl.html, or
# obtained by writing to the Free Software Foundation, Inc.,
# 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
# The names of the tagged configurations supported by this script.
available_tags="CXX "
# ### BEGIN LIBTOOL CONFIG
# Which release of libtool.m4 was used?
macro_version=$macro_version
macro_revision=$macro_revision
# Whether or not to build shared libraries.
build_libtool_libs=$enable_shared
# Whether or not to build static libraries.
build_old_libs=$enable_static
# What type of objects to build.
pic_mode=$pic_mode
# Whether or not to optimize for fast installation.
fast_install=$enable_fast_install
# Shell to use when invoking shell scripts.
SHELL=$lt_SHELL
# An echo program that protects backslashes.
ECHO=$lt_ECHO
# The PATH separator for the build system.
PATH_SEPARATOR=$lt_PATH_SEPARATOR
# The host system.
host_alias=$host_alias
host=$host
host_os=$host_os
# The build system.
build_alias=$build_alias
build=$build
build_os=$build_os
# A sed program that does not truncate output.
SED=$lt_SED
# Sed that helps us avoid accidentally triggering echo(1) options like -n.
Xsed="\$SED -e 1s/^X//"
# A grep program that handles long lines.
GREP=$lt_GREP
# An ERE matcher.
EGREP=$lt_EGREP
# A literal string matcher.
FGREP=$lt_FGREP
# A BSD- or MS-compatible name lister.
NM=$lt_NM
# Whether we need soft or hard links.
LN_S=$lt_LN_S
# What is the maximum length of a command?
max_cmd_len=$max_cmd_len
# Object file suffix (normally "o").
objext=$ac_objext
# Executable file suffix (normally "").
exeext=$exeext
# whether the shell understands "unset".
lt_unset=$lt_unset
# turn spaces into newlines.
SP2NL=$lt_lt_SP2NL
# turn newlines into spaces.
NL2SP=$lt_lt_NL2SP
# convert \$build file names to \$host format.
to_host_file_cmd=$lt_cv_to_host_file_cmd
# convert \$build files to toolchain format.
to_tool_file_cmd=$lt_cv_to_tool_file_cmd
# An object symbol dumper.
OBJDUMP=$lt_OBJDUMP
# Method to check whether dependent libraries are shared objects.
deplibs_check_method=$lt_deplibs_check_method
# Command to use when deplibs_check_method = "file_magic".
file_magic_cmd=$lt_file_magic_cmd
# How to find potential files when deplibs_check_method = "file_magic".
file_magic_glob=$lt_file_magic_glob
# Find potential files using nocaseglob when deplibs_check_method = "file_magic".
want_nocaseglob=$lt_want_nocaseglob
# DLL creation program.
DLLTOOL=$lt_DLLTOOL
# Command to associate shared and link libraries.
sharedlib_from_linklib_cmd=$lt_sharedlib_from_linklib_cmd
# The archiver.
AR=$lt_AR
# Flags to create an archive.
AR_FLAGS=$lt_AR_FLAGS
# How to feed a file listing to the archiver.
archiver_list_spec=$lt_archiver_list_spec
# A symbol stripping program.
STRIP=$lt_STRIP
# Commands used to install an old-style archive.
RANLIB=$lt_RANLIB
old_postinstall_cmds=$lt_old_postinstall_cmds
old_postuninstall_cmds=$lt_old_postuninstall_cmds
# Whether to use a lock for old archive extraction.
lock_old_archive_extraction=$lock_old_archive_extraction
# A C compiler.
LTCC=$lt_CC
# LTCC compiler flags.
LTCFLAGS=$lt_CFLAGS
# Take the output of nm and produce a listing of raw symbols and C names.
global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
# Transform the output of nm in a proper C declaration.
global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
# Transform the output of nm in a C name address pair.
global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
# Transform the output of nm in a C name address pair when lib prefix is needed.
global_symbol_to_c_name_address_lib_prefix=$lt_lt_cv_sys_global_symbol_to_c_name_address_lib_prefix
# Specify filename containing input files for \$NM.
nm_file_list_spec=$lt_nm_file_list_spec
# The root where to search for dependent libraries,and in which our libraries should be installed.
lt_sysroot=$lt_sysroot
# The name of the directory that contains temporary libtool files.
objdir=$objdir
# Used to examine libraries when file_magic_cmd begins with "file".
MAGIC_CMD=$MAGIC_CMD
# Must we lock files when doing compilation?
need_locks=$lt_need_locks
# Manifest tool.
MANIFEST_TOOL=$lt_MANIFEST_TOOL
# Tool to manipulate archived DWARF debug symbol files on Mac OS X.
DSYMUTIL=$lt_DSYMUTIL
# Tool to change global to local symbols on Mac OS X.
NMEDIT=$lt_NMEDIT
# Tool to manipulate fat objects and archives on Mac OS X.
LIPO=$lt_LIPO
# ldd/readelf like tool for Mach-O binaries on Mac OS X.
OTOOL=$lt_OTOOL
# ldd/readelf like tool for 64 bit Mach-O binaries on Mac OS X 10.4.
OTOOL64=$lt_OTOOL64
# Old archive suffix (normally "a").
libext=$libext
# Shared library suffix (normally ".so").
shrext_cmds=$lt_shrext_cmds
# The commands to extract the exported symbol list from a shared archive.
extract_expsyms_cmds=$lt_extract_expsyms_cmds
# Variables whose values should be saved in libtool wrapper scripts and
# restored at link time.
variables_saved_for_relink=$lt_variables_saved_for_relink
# Do we need the "lib" prefix for modules?
need_lib_prefix=$need_lib_prefix
# Do we need a version for libraries?
need_version=$need_version
# Library versioning type.
version_type=$version_type
# Shared library runtime path variable.
runpath_var=$runpath_var
# Shared library path variable.
shlibpath_var=$shlibpath_var
# Is shlibpath searched before the hard-coded library search path?
shlibpath_overrides_runpath=$shlibpath_overrides_runpath
# Format of library name prefix.
libname_spec=$lt_libname_spec
# List of archive names.  First name is the real one, the rest are links.
# The last name is the one that the linker finds with -lNAME
library_names_spec=$lt_library_names_spec
# The coded name of the library, if different from the real name.
soname_spec=$lt_soname_spec
# Permission mode override for installation of shared libraries.
install_override_mode=$lt_install_override_mode
# Command to use after installation of a shared archive.
postinstall_cmds=$lt_postinstall_cmds
# Command to use after uninstallation of a shared archive.
postuninstall_cmds=$lt_postuninstall_cmds
# Commands used to finish a libtool library installation in a directory.
finish_cmds=$lt_finish_cmds
# As "finish_cmds", except a single script fragment to be evaled but
# not shown.
finish_eval=$lt_finish_eval
# Whether we should hardcode library paths into libraries.
hardcode_into_libs=$hardcode_into_libs
# Compile-time system search path for libraries.
sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
# Run-time system search path for libraries.
sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
# Whether dlopen is supported.
dlopen_support=$enable_dlopen
# Whether dlopen of programs is supported.
dlopen_self=$enable_dlopen_self
# Whether dlopen of statically linked programs is supported.
dlopen_self_static=$enable_dlopen_self_static
# Commands to strip libraries.
old_striplib=$lt_old_striplib
striplib=$lt_striplib
# The linker used to build libraries.
LD=$lt_LD
# How to create reloadable object files.
reload_flag=$lt_reload_flag
reload_cmds=$lt_reload_cmds
# Commands used to build an old-style archive.
old_archive_cmds=$lt_old_archive_cmds
# A language specific compiler.
CC=$lt_compiler
# Is the compiler the GNU compiler?
with_gcc=$GCC
# Compiler flag to turn off builtin functions.
no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag
# Additional compiler flags for building library objects.
pic_flag=$lt_lt_prog_compiler_pic
# How to pass a linker flag through the compiler.
wl=$lt_lt_prog_compiler_wl
# Compiler flag to prevent dynamic linking.
link_static_flag=$lt_lt_prog_compiler_static
# Does compiler simultaneously support -c and -o options?
compiler_c_o=$lt_lt_cv_prog_compiler_c_o
# Whether or not to add -lc for building shared libraries.
build_libtool_need_lc=$archive_cmds_need_lc
# Whether or not to disallow shared libs when runtime libs are static.
allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes
# Compiler flag to allow reflexive dlopens.
export_dynamic_flag_spec=$lt_export_dynamic_flag_spec
# Compiler flag to generate shared objects directly from archives.
whole_archive_flag_spec=$lt_whole_archive_flag_spec
# Whether the compiler copes with passing no objects directly.
compiler_needs_object=$lt_compiler_needs_object
# Create an old-style archive from a shared archive.
old_archive_from_new_cmds=$lt_old_archive_from_new_cmds
# Create a temporary old-style archive to link instead of a shared archive.
old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds
# Commands used to build a shared archive.
archive_cmds=$lt_archive_cmds
archive_expsym_cmds=$lt_archive_expsym_cmds
# Commands used to build a loadable module if different from building
# a shared archive.
module_cmds=$lt_module_cmds
module_expsym_cmds=$lt_module_expsym_cmds
# Whether we are building with GNU ld or not.
with_gnu_ld=$lt_with_gnu_ld
# Flag that allows shared libraries with undefined symbols to be built.
allow_undefined_flag=$lt_allow_undefined_flag
# Flag that enforces no undefined symbols.
no_undefined_flag=$lt_no_undefined_flag
# Flag to hardcode \$libdir into a binary during linking.
# This must work even if \$libdir does not exist
hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec
# Whether we need a single "-rpath" flag with a separated argument.
hardcode_libdir_separator=$lt_hardcode_libdir_separator
# Set to "yes" if using DIR/libNAME\${shared_ext} during linking hardcodes
# DIR into the resulting binary.
hardcode_direct=$hardcode_direct
# DIR into the resulting binary and the resulting library dependency is
# "absolute",i.e impossible to change by setting \${shlibpath_var} if the
# library is relocated.
hardcode_direct_absolute=$hardcode_direct_absolute
# Set to "yes" if using the -LDIR flag during linking hardcodes DIR
# into the resulting binary.
hardcode_minus_L=$hardcode_minus_L
# Set to "yes" if using SHLIBPATH_VAR=DIR during linking hardcodes DIR
hardcode_shlibpath_var=$hardcode_shlibpath_var
# Set to "yes" if building a shared library automatically hardcodes DIR
# into the library and all subsequent libraries and executables linked
# against it.
hardcode_automatic=$hardcode_automatic
# Set to yes if linker adds runtime paths of dependent libraries
# to runtime path list.
inherit_rpath=$inherit_rpath
# Whether libtool must link a program against all its dependency libraries.
link_all_deplibs=$link_all_deplibs
# Set to "yes" if exported symbols are required.
always_export_symbols=$always_export_symbols
# The commands to list exported symbols.
export_symbols_cmds=$lt_export_symbols_cmds
# Symbols that should not be listed in the preloaded symbols.
exclude_expsyms=$lt_exclude_expsyms
# Symbols that must always be exported.
include_expsyms=$lt_include_expsyms
# Commands necessary for linking programs (against libraries) with templates.
prelink_cmds=$lt_prelink_cmds
# Commands necessary for finishing linking programs.
postlink_cmds=$lt_postlink_cmds
# Specify filename containing input files.
file_list_spec=$lt_file_list_spec
# How to hardcode a shared library path into an executable.
hardcode_action=$hardcode_action
# The directories searched by this compiler when creating a shared library.
compiler_lib_search_dirs=$lt_compiler_lib_search_dirs
# Dependencies to place before and after the objects being linked to
# create a shared library.
predep_objects=$lt_predep_objects
postdep_objects=$lt_postdep_objects
predeps=$lt_predeps
postdeps=$lt_postdeps
# The library search path used internally by the compiler when linking
# a shared library.
compiler_lib_search_path=$lt_compiler_lib_search_path
# ### END LIBTOOL CONFIG
_LT_EOF
  case $host_os in
  aix3*)
    cat <<\_LT_EOF >> "$cfgfile"
# AIX sometimes has problems with the GCC collect2 program.  For some
# reason, if we set the COLLECT_NAMES environment variable, the problems
# vanish in a puff of smoke.
if test "X${COLLECT_NAMES+set}" != Xset; then
  COLLECT_NAMES=
  export COLLECT_NAMES
_LT_EOF
ltmain="$ac_aux_dir/ltmain.sh"
  # We use sed instead of cat because bash on DJGPP gets confused if
  # if finds mixed CR/LF and LF-only lines.  Since sed operates in
  # text mode, it properly converts lines to CR/LF.  This bash problem
  # is reportedly fixed, but why not run on old versions too?
  sed '$q' "$ltmain" >> "$cfgfile" \
     || (rm -f "$cfgfile"; exit 1)
  if test x"$xsi_shell" = xyes; then
  sed -e '/^func_dirname ()$/,/^} # func_dirname /c\
func_dirname ()\
\    case ${1} in\
\      */*) func_dirname_result="${1%/*}${2}" ;;\
\      *  ) func_dirname_result="${3}" ;;\
\    esac\
} # Extended-shell func_dirname implementation' "$cfgfile" > $cfgfile.tmp \
  && mv -f "$cfgfile.tmp" "$cfgfile" \
    || (rm -f "$cfgfile" && cp "$cfgfile.tmp" "$cfgfile" && rm -f "$cfgfile.tmp")
test 0 -eq $? || _lt_function_replace_fail=:
  sed -e '/^func_basename ()$/,/^} # func_basename /c\
func_basename ()\
\    func_basename_result="${1##*/}"\
} # Extended-shell func_basename implementation' "$cfgfile" > $cfgfile.tmp \
  sed -e '/^func_dirname_and_basename ()$/,/^} # func_dirname_and_basename /c\
func_dirname_and_basename ()\
\    case ${1} in\
\    esac\
} # Extended-shell func_dirname_and_basename implementation' "$cfgfile" > $cfgfile.tmp \
  sed -e '/^func_stripname ()$/,/^} # func_stripname /c\
func_stripname ()\
\    # pdksh 5.2.14 does not do ${X%$Y} correctly if both X and Y are\
\    # positional parameters, so assign one to ordinary parameter first.\
\    func_stripname_result=${3}\
\    func_stripname_result=${func_stripname_result#"${1}"}\
\    func_stripname_result=${func_stripname_result%"${2}"}\
} # Extended-shell func_stripname implementation' "$cfgfile" > $cfgfile.tmp \
  sed -e '/^func_split_long_opt ()$/,/^} # func_split_long_opt /c\
func_split_long_opt ()\
\    func_split_long_opt_name=${1%%=*}\
\    func_split_long_opt_arg=${1#*=}\
} # Extended-shell func_split_long_opt implementation' "$cfgfile" > $cfgfile.tmp \
  sed -e '/^func_split_short_opt ()$/,/^} # func_split_short_opt /c\
func_split_short_opt ()\
\    func_split_short_opt_arg=${1#??}\
\    func_split_short_opt_name=${1%"$func_split_short_opt_arg"}\
} # Extended-shell func_split_short_opt implementation' "$cfgfile" > $cfgfile.tmp \
  sed -e '/^func_lo2o ()$/,/^} # func_lo2o /c\
func_lo2o ()\
\    case ${1} in\
\      *.lo) func_lo2o_result=${1%.lo}.${objext} ;;\
\      *)    func_lo2o_result=${1} ;;\
\    esac\
} # Extended-shell func_lo2o implementation' "$cfgfile" > $cfgfile.tmp \
  sed -e '/^func_xform ()$/,/^} # func_xform /c\
func_xform ()\
    func_xform_result=${1%.*}.lo\
} # Extended-shell func_xform implementation' "$cfgfile" > $cfgfile.tmp \
  sed -e '/^func_arith ()$/,/^} # func_arith /c\
func_arith ()\
    func_arith_result=$(( $* ))\
} # Extended-shell func_arith implementation' "$cfgfile" > $cfgfile.tmp \
  sed -e '/^func_len ()$/,/^} # func_len /c\
func_len ()\
    func_len_result=${#1}\
} # Extended-shell func_len implementation' "$cfgfile" > $cfgfile.tmp \
if test x"$lt_shell_append" = xyes; then
  sed -e '/^func_append ()$/,/^} # func_append /c\
func_append ()\
    eval "${1}+=\\${2}"\
} # Extended-shell func_append implementation' "$cfgfile" > $cfgfile.tmp \
  sed -e '/^func_append_quoted ()$/,/^} # func_append_quoted /c\
func_append_quoted ()\
\    func_quote_for_eval "${2}"\
\    eval "${1}+=\\\\ \\$func_quote_for_eval_result"\
} # Extended-shell func_append_quoted implementation' "$cfgfile" > $cfgfile.tmp \
  # Save a `func_append' function call where possible by direct use of '+='
  sed -e 's%func_append \([a-zA-Z_]\{1,\}\) "%\1+="%g' $cfgfile > $cfgfile.tmp \
  # Save a `func_append' function call even when '+=' is not available
  sed -e 's%func_append \([a-zA-Z_]\{1,\}\) "%\1="$\1%g' $cfgfile > $cfgfile.tmp \
if test x"$_lt_function_replace_fail" = x":"; then
  { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Unable to substitute extended shell functions in $ofile" >&5
$as_echo "$as_me: WARNING: Unable to substitute extended shell functions in $ofile" >&2;}
   mv -f "$cfgfile" "$ofile" ||
    (rm -f "$ofile" && cp "$cfgfile" "$ofile" && rm -f "$cfgfile")
  chmod +x "$ofile"
    cat <<_LT_EOF >> "$ofile"
# ### BEGIN LIBTOOL TAG CONFIG: CXX
LD=$lt_LD_CXX
reload_flag=$lt_reload_flag_CXX
reload_cmds=$lt_reload_cmds_CXX
old_archive_cmds=$lt_old_archive_cmds_CXX
CC=$lt_compiler_CXX
with_gcc=$GCC_CXX
no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_CXX
pic_flag=$lt_lt_prog_compiler_pic_CXX
wl=$lt_lt_prog_compiler_wl_CXX
link_static_flag=$lt_lt_prog_compiler_static_CXX
compiler_c_o=$lt_lt_cv_prog_compiler_c_o_CXX
build_libtool_need_lc=$archive_cmds_need_lc_CXX
allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_CXX
export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_CXX
whole_archive_flag_spec=$lt_whole_archive_flag_spec_CXX
compiler_needs_object=$lt_compiler_needs_object_CXX
old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_CXX
old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_CXX
archive_cmds=$lt_archive_cmds_CXX
archive_expsym_cmds=$lt_archive_expsym_cmds_CXX
# a shared archive.
module_cmds=$lt_module_cmds_CXX
module_expsym_cmds=$lt_module_expsym_cmds_CXX
with_gnu_ld=$lt_with_gnu_ld_CXX
allow_undefined_flag=$lt_allow_undefined_flag_CXX
no_undefined_flag=$lt_no_undefined_flag_CXX
hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_CXX
hardcode_libdir_separator=$lt_hardcode_libdir_separator_CXX
hardcode_direct=$hardcode_direct_CXX
hardcode_direct_absolute=$hardcode_direct_absolute_CXX
hardcode_minus_L=$hardcode_minus_L_CXX
hardcode_shlibpath_var=$hardcode_shlibpath_var_CXX
# against it.
hardcode_automatic=$hardcode_automatic_CXX
inherit_rpath=$inherit_rpath_CXX
link_all_deplibs=$link_all_deplibs_CXX
always_export_symbols=$always_export_symbols_CXX
export_symbols_cmds=$lt_export_symbols_cmds_CXX
exclude_expsyms=$lt_exclude_expsyms_CXX
include_expsyms=$lt_include_expsyms_CXX
prelink_cmds=$lt_prelink_cmds_CXX
postlink_cmds=$lt_postlink_cmds_CXX
file_list_spec=$lt_file_list_spec_CXX
hardcode_action=$hardcode_action_CXX
compiler_lib_search_dirs=$lt_compiler_lib_search_dirs_CXX
predep_objects=$lt_predep_objects_CXX
postdep_objects=$lt_postdep_objects_CXX
predeps=$lt_predeps_CXX
postdeps=$lt_postdeps_CXX
# a shared library.
compiler_lib_search_path=$lt_compiler_lib_search_path_CXX
# ### END LIBTOOL TAG CONFIG: CXX
_LT_EOF
done # for ac_tag
as_fn_exit 0
_ACEOF
ac_clean_files=$ac_clean_files_save
test $ac_write_fail = 0 ||
  as_fn_error $? "write failure creating $CONFIG_STATUS" "$LINENO" 5
# configure is writing to config.log, and then calls config.status.
# config.status does its own redirection, appending to config.log.
# Unfortunately, on DOS this fails, as config.log is still kept open
# by configure, so config.status won't be able to write to it; its
# output is simply discarded.  So we exec the FD to /dev/null,
# effectively closing config.log, so it can be properly (re)opened and
# appended to by config.status.  When coming back to configure, we
# need to make the FD available again.
if test "$no_create" != yes; then
  ac_cs_success=:
  ac_config_status_args=
  test "$silent" = yes &&
    ac_config_status_args="$ac_config_status_args --quiet"
  exec 5>/dev/null
  $SHELL $CONFIG_STATUS $ac_config_status_args || ac_cs_success=false
  exec 5>>config.log
  # Use ||, not &&, to avoid exiting from the if with $? = 1, which
  # would make configure fail if this is the last instruction.
  $ac_cs_success || as_fn_exit 1
if test -n "$ac_unrecognized_opts" && test "$enable_option_checking" != no; then
  { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: unrecognized options: $ac_unrecognized_opts" >&5
$as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2;}
