#include "tuya_svc_netmgr.h"
#if defined(ENABLE_WIFI_SERVICE) && (ENABLE_WIFI_SERVICE == 1)
#include "tuya_iot_wifi_api.h"
#if defined(ENABLE_WIRED) && (ENABLE_WIRED == 1)
#include "tuya_iot_base_api.h"
#include "tuya_iot_com_api.h"
#include "tuya_ws_db.h"
#include "base_event.h"
#include "mf_test.h"
#include "mqc_app.h"
#if defined(ENABLE_LWIP) && (ENABLE_LWIP == 1)
#include "lwip_init.h"
#include "tkl_uart.h"
#include "tal_uart.h"
#include "dp_process.h"
#include "app_key.h"
#include "app_led.h"
#define PID         "3q2yklgx4sogrzsq"
#define UUID        "uuid8c979a2cea91955c"
#define AUTHKEY     "8TxpnLMkuovxRtlh5TfICLipjzZKnc07"
#define USER_SW_VER "1.0.0"
#define KEY_PIN 2
#define LED_PIN 3
extern void tuya_ble_enable_debug(bool enable);
STATIC THREAD_HANDLE ty_app_thread = NULL;
STATIC OPERATE_RET __soc_dev_rev_upgrade_info_cb(IN CONST FW_UG_S *fw)
    TAL_PR_DEBUG("SOC Rev Upgrade Info");
    TAL_PR_DEBUG("fw->tp:%d", fw->tp);
    TAL_PR_DEBUG("fw->fw_url:%s", fw->fw_url);
    TAL_PR_DEBUG("fw->fw_hmac:%s", fw->fw_hmac);
    TAL_PR_DEBUG("fw->sw_ver:%s", fw->sw_ver);
    TAL_PR_DEBUG("fw->file_size:%u", fw->file_size);
STATIC VOID_T __soc_dev_status_changed_cb(IN CONST GW_STATUS_E status)
    TAL_PR_DEBUG("SOC TUYA-Cloud Status:%d", status);
STATIC VOID_T __soc_dev_dp_query_cb(IN CONST TY_DP_QUERY_S *dp_qry)
    UINT32_T index = 0;
    TAL_PR_DEBUG("SOC Rev DP Query Cmd");
    if (dp_qry->cid != NULL) {
        TAL_PR_ERR("soc not have cid.%s", dp_qry->cid);
    if (dp_qry->cnt == 0) {
        TAL_PR_DEBUG("soc rev all dp query");
        respone_device_all_status();
        TAL_PR_DEBUG("soc rev dp query cnt:%d", dp_qry->cnt);
        for (index = 0; index < dp_qry->cnt; index++) {
            TAL_PR_DEBUG("rev dp query:%d", dp_qry->dpid[index]);
STATIC VOID_T __soc_dev_obj_dp_cmd_cb(IN CONST TY_RECV_OBJ_DP_S *dp)
    TAL_PR_DEBUG("SOC Rev DP Obj Cmd t1:%d t2:%d CNT:%u", dp->cmd_tp, dp->dtt_tp, dp->dps_cnt);
    dp_obj_process(dp->dps, dp->dps_cnt);
STATIC VOID_T __soc_dev_raw_dp_cmd_cb(IN CONST TY_RECV_RAW_DP_S *dp)
    TAL_PR_DEBUG("SOC Rev DP Raw Cmd t1:%d t2:%d dpid:%d len:%u", dp->cmd_tp, dp->dtt_tp, dp->dpid, dp->len);
    dp_raw_process(dp->dpid, dp->data, dp->len);
STATIC VOID_T __soc_dev_reset_inform_cb(GW_RESET_TYPE_E type)
    TAL_PR_DEBUG("reset type %d", type);
STATIC OPERATE_RET __soc_dev_net_status_cb(VOID *data)
    STATIC BOOL_T s_syn_all_status = FALSE;
    TAL_PR_DEBUG("network status changed!");
    if (tuya_svc_netmgr_linkage_is_up(LINKAGE_TYPE_DEFAULT)) {
        TAL_PR_DEBUG("linkage status changed, current status is up");
        if (get_mqc_conn_stat()) {
            TAL_PR_DEBUG("mqtt is connected!");
            if (FALSE == s_syn_all_status) {
                upload_device_all_status();
                s_syn_all_status = TRUE;
        TAL_PR_DEBUG("linkage status changed, current status is down");
VOID mf_uart_init_callback(UINT_T baud, UINT_T bufsz)
    TAL_UART_CFG_T cfg;
    memset(&cfg, 0, sizeof(TAL_UART_CFG_T));
    cfg.base_cfg.baudrate = baud;
    cfg.base_cfg.databits = TUYA_UART_DATA_LEN_8BIT;
    cfg.base_cfg.parity = TUYA_UART_PARITY_TYPE_NONE;
    cfg.base_cfg.stopbits = TUYA_UART_STOP_LEN_1BIT;
    cfg.rx_buffer_size = bufsz;
    tal_uart_init(TUYA_UART_NUM_0, &cfg);
VOID mf_uart_free_callback(VOID)
VOID mf_uart_send_callback(IN BYTE_T *data, IN CONST UINT_T len)
    tal_uart_write(TUYA_UART_NUM_0, data, len);
UINT_T mf_uart_recv_callback(OUT BYTE_T *buf, IN CONST UINT_T len)
    return tal_uart_read(TUYA_UART_NUM_0, buf, len);
OPERATE_RET mf_user_product_test_callback(USHORT_T cmd, UCHAR_T *data, UINT_T len, OUT UCHAR_T **ret_data, OUT USHORT_T *ret_len)
VOID mf_user_callback(VOID)
    return ;
VOID mf_user_enter_mf_callback(VOID)
    return ;
STATIC VOID_T uart_thread(VOID_T *arg)
    unsigned char tx[8];
    for (int i = 0; i < 8; i++) {
        tx[i] = 'A' + i;
    UINT_T len = 512;
    BYTE_T buf[len];
    OPERATE_RET ret = -1;
    unsigned char rx_char = 0;
    while(1){
        ret = tal_uart_read(TUYA_UART_NUM_1, &buf, sizeof(buf));
        if(ret>0) {
            //tal_uart_write(TUYA_UART_NUM_1, buf, sizeof(buf));
            tal_uart_write(TUYA_UART_NUM_1, tx, sizeof(tx));
            tal_system_sleep(1000);
OPERATE_RET __soc_device_init(VOID_T)
    ty_subscribe_event(EVENT_LINK_UP, "radar", __soc_dev_net_status_cb, SUBSCRIBE_TYPE_NORMAL);
    ty_subscribe_event(EVENT_LINK_DOWN, "radar", __soc_dev_net_status_cb, SUBSCRIBE_TYPE_NORMAL);
    ty_subscribe_event(EVENT_MQTT_CONNECTED, "radar", __soc_dev_net_status_cb, SUBSCRIBE_TYPE_NORMAL);
#if (defined(UUID) && defined(AUTHKEY))
#ifndef ENABLE_KV_FILE
    ws_db_init_mf();
#ifdef ENABLE_WIFI_SERVICE
    TUYA_CALL_ERR_RETURN(tuya_iot_set_wf_gw_prod_info(&prod_info));
    TUYA_CALL_ERR_RETURN(tuya_iot_set_gw_prod_info(&prod_info));
    MF_IMPORT_INTF_S intf = {0};
    intf.uart_init = mf_uart_init_callback;
    intf.uart_free = mf_uart_free_callback;
    intf.uart_send = mf_uart_send_callback;
    intf.uart_recv = mf_uart_recv_callback;
    intf.mf_user_product_test = mf_user_product_test_callback;
    intf.user_callback = mf_user_callback;
    intf.user_enter_mf_callback = mf_user_enter_mf_callback;
    TUYA_CALL_ERR_RETURN(mf_init(&intf, APP_BIN_NAME, USER_SW_VER, TRUE));
    TAL_PR_NOTICE("mf_init successfully");
    TY_IOT_CBS_S iot_cbs = {0};
    iot_cbs.gw_status_cb    = __soc_dev_status_changed_cb;
    iot_cbs.gw_ug_cb        = __soc_dev_rev_upgrade_info_cb;
    iot_cbs.gw_reset_cb     = __soc_dev_reset_inform_cb;
    iot_cbs.dev_obj_dp_cb   = __soc_dev_obj_dp_cmd_cb;
    iot_cbs.dev_raw_dp_cb   = __soc_dev_raw_dp_cmd_cb;
    iot_cbs.dev_dp_query_cb = __soc_dev_dp_query_cb;
    TUYA_CALL_ERR_RETURN(tuya_iot_wf_soc_dev_init(GWCM_OLD, WF_START_AP_FIRST, &iot_cbs, PID, USER_SW_VER));
#ifdef ENABLE_WIRED
    TUYA_CALL_ERR_RETURN(tuya_svc_wired_init());
    TUYA_CALL_ERR_RETURN(tuya_iot_soc_init(&iot_cbs, PID, USER_SW_VER));
#ifdef ENABLE_BT_SERVICE
    tuya_ble_enable_debug(false);
    app_led_init(LED_PIN);
    app_key_init(KEY_PIN);
    TAL_UART_CFG_T cfg;
    cfg.base_cfg.baudrate = 115200;
    cfg.rx_buffer_size = 256;
    // cfg.open_mode=O_BLOCK;
    // tal_uart_deinit(TUYA_UART_NUM_1);
    tal_uart_init(TUYA_UART_NUM_1, &cfg);
    THREAD_CFG_T thread_cfg = {
        .thrdname = "radar_uart",
        .stackDepth = 4096,
        .priority = THREAD_PRIO_3,//优先级
    tal_thread_create_and_start(&ty_app_thread, NULL, NULL, uart_thread, NULL, &thread_cfg);
STATIC VOID_T user_main(VOID_T)
    TY_INIT_PARAMS_S init_param = {0};
    init_param.init_db = TRUE;
    strcpy(init_param.sys_env, TARGET_PLATFORM);
    TUYA_CALL_ERR_LOG(tuya_iot_init_params(NULL, &init_param));
    tal_log_set_manage_attr(TAL_LOG_LEVEL_DEBUG);
    TAL_PR_DEBUG("device_init in");
    TUYA_CALL_ERR_LOG(__soc_device_init());
STATIC VOID_T tuya_app_thread(VOID_T *arg)
    user_main();
    tal_thread_delete(ty_app_thread);
VOID_T tuya_app_main(VOID)
    THREAD_CFG_T thrd_param = {4096, 4, "tuya_app_main"};
    tal_thread_create_and_start(&ty_app_thread, NULL, NULL, tuya_app_thread, NULL, &thrd_param);
